ING
Last activity: 16 Oct 2024 7:16 EDT
Visa certificate configuration on Pega Smart Dispute
I have a question regarding the Visa certificate configuration.
We received a .p7b file, generated a .pfx file, and then configured the VCRKeystore and VCRTruststore.
In the Authentication profile rule, what value should we enter under the host name? The OOTB configuration uses pkcs12; should we update this to Visa?
Additionally, do we need to add the SSL certificate to a keystore at the server level? Specifically, should we import the .p7b and .pfx files into a Java keystore and then install and import the SSL certificate into the Java keystore?
Is this additional step necessary for Visa integration or Pega configuration will suffice?
Ashwani
