Mastercard Inc
Last activity: 29 May 2018 5:45 EDT
Upgrade Estimator Tool stuck at 0%
I've installed the upgrade estimator tool on a PEGA 7.1.8 version to estimate the cost of upgrading .
I started the estimation process but it then stuck at 0%. Server restart didn't change anything. Found the below error in the logs.
Rule-Connect-SOAP.Data-PostUpgradeIssue-ServicesService-.TyGetDataForFilters Exception
com.pega.pegarules.pub.clipboard.InvalidParameterException: cannot be null/empty. page: DataPage. Details: Invalid value for aReference passed to com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.getString(String)
***Edited by Moderator Marissa to add SR Details***
Please find the attached sample logs of the Upgrade Estimator tool. You will see the following line in the logs which says estimator ran successfully.
The Upgrade Estimator Activity is completed for application : <Application Name>
In case execution is exited because of any specific Rule Type, please follow the below steps to exclude the Rule Types those are causing the issue.
We can ignore Obj-open-by-handle error, if the pzInsKey is null. UET will handle those errors. We can also ignore the SOAP connectors errors. Please let me know you need any other information.
