ING B.V
Last activity: 28 Jun 2021 6:50 EDT
Unable to install Pega 8.6.0 PE
I am trying to install Pega 8.6.0 PE but getting "The Process Finished Unsuccessfully" message at the end.
Attached error screenshot and logs for reference.
Steps performed:
1.Tried installing multiple times
2. Added location in environmental variable path
3. Tried to delete Pega entries from regedit
Log:
Targets:Initialization,Database Server Installation,Data Load,Configuration,PRPC Launching
Buildfile: D:\116984_PE8.6.0\.\pegaGuiInstallerTemp\build.xml
Initialization:
[echo] Beginning installation of Pega Platform 8.6.0 Personal Edition -- this process should take about 5-10 minutes ...
[mkdir] Created dir: D:\Pega\PRPCPersonalEdition
[mkdir] Created dir: D:\Pega\PRPCPersonalEdition\temp
[unzip] Expanding: D:\116984_PE8.6.0\pegaGuiInstallerTemp\PersonalEdition.zip into D:\Pega\PRPCPersonalEdition
[echo] Configuring Tomcat (Setting Java Home and Catalina Home)...
[replace] Replaced 0 occurrences in 0 files.
[replace] Replaced 1 occurrences in 1 files.
[replace] Replaced 2 occurrences in 1 files.
Steps performed:
Log:
Initialization:
Database Server Installation:
[exec] The files belonging to this database system will be owned by user "rajesh.e".
[exec] This user must also own the server process.
[exec]
[exec] The database cluster will be initialized with locale "English_India.1252".
[exec] The default text search configuration will be set to "english".
[exec]
[exec] Data page checksums are disabled.
[exec]
[exec] creating directory D:/Pega/PRPCPersonalEdition/pgsql/data ... ok
[exec] creating subdirectories ... ok
[exec] selecting default max_connections ... 100
[exec] selecting default shared_buffers ... 128MB
[exec] selecting default timezone ... Asia/Calcutta
[exec] selecting dynamic shared memory implementation ... windows
[exec] creating configuration files ... ok
[exec] running bootstrap script ... ok
[exec] performing post-bootstrap initialization ... ok
[exec] syncing data to disk ... ok
[exec]
[exec] Success. You can now start the database server using:
[exec]
[exec] D:/Pega/PRPCPersonalEdition/pgsql/bin/pg_ctl -D ^"D^:^\Pega^\PRPCPersonalEdition^/pgsql^\data^" -l logfile start
[exec]
[exec]
[exec] WARNING: enabling "trust" authentication for local connections
[exec] You can change this by editing pg_hba.conf or using the option -A, or
[exec] --auth-local and --auth-host, the next time you run initdb.
[echo]
[echo] Waiting for Postgres to start...
[echo] Connected to Database.
[exec] ALTER ROLE
[exec] ALTER ROLE
[exec] CREATE SCHEMA
[exec] GRANT
[exec] psql:D:/Pega/PRPCPersonalEdition/scripts/installPLJava.sql:6: WARNING: Java virtual machine not yet loadedCREATE FUNCTION
[exec] CREATE LANGUAGE
[exec] DETAIL: The specified module could not be found.
[exec]
[exec] HINT: SET pljava.libjvm_location TO the correct path to the jvm library (libjvm.so or jvm.dll, etc.)
[exec]
[exec] CREATE FUNCTION
[exec] CREATE TABLE
[exec] GRANT
[exec] CREATE TABLE
[exec] GRANT
[exec] CREATE TABLE
[exec] GRANT
[exec] CREATE TABLE
[exec] GRANT
[exec] CREATE TABLE
[exec] GRANT
Data Load:
[echo]
[echo] Waiting for Postgres to restart...
[echo]
[echo] Loading database with Pega Platform...
[exec] pg_restore: connecting to database for restore
[exec] pg_restore: implied data-only restore
[exec] pg_restore: processing item 4602 ENCODING ENCODING
[exec] pg_restore: processing item 4603 STDSTRINGS STDSTRINGS
[exec] pg_restore: processing item 4604 SEARCHPATH SEARCHPATH
[exec] pg_restore: processing item 4605 DATABASE postgres
[exec] pg_restore: processing item 4607 DATABASE PROPERTIES postgres
[exec] pg_restore: entering main parallel loop
[exec] pg_restore: launching item 4467 TABLE DATA jar_repository
[exec] pg_restore: launching item 4470 TABLE DATA classpath_entry
[exec] pg_restore: launching item 4468 TABLE DATA jar_entry
[exec] pg_restore: launching item 4469 TABLE DATA jar_descriptor
[exec] pg_restore: disabling triggers for jar_descriptor
[exec] pg_restore: disabling triggers for jar_entry
[exec] pg_restore: disabling triggers for classpath_entry
[exec] pg_restore: disabling triggers for jar_repository
[exec] pg_restore: pg_restore: processing data for table "sqlj.jar_descriptor"
[exec] processing data for table "sqlj.classpath_entry"
[exec] pg_restore: enabling triggers for jar_descriptor
[exec] pg_restore: processing data for table "sqlj.jar_entry"
[exec] pg_restore: processing data for table "sqlj.jar_repository"
[exec] pg_restore: finished item 4469 TABLE DATA jar_descriptor
[exec] pg_restore: launching item 4471 TABLE DATA typemap_entry
[exec] pg_restore: disabling triggers for typemap_entry
[exec] pg_restore: enabling triggers for classpath_entry
[exec] pg_restore: processing data for table "sqlj.typemap_entry"
[exec] pg_restore: enabling triggers for jar_repository
[exec] pg_restore: finished item 4470 TABLE DATA classpath_entry
[exec] pg_restore: enabling triggers for typemap_entry
[exec] pg_restore: finished item 4467 TABLE DATA jar_repository
[exec] pg_restore: finished item 4471 TABLE DATA typemap_entry
[exec] pg_restore: enabling triggers for jar_entry
[exec] pg_restore: finished item 4468 TABLE DATA jar_entry
[exec] pg_restore: finished main parallel loop
[exec] pg_restore: processing item 6613 ENCODING ENCODING
[exec] pg_restore: processing item 6614 STDSTRINGS STDSTRINGS
[exec] pg_restore: processing item 6615 SEARCHPATH SEARCHPATH
[exec] pg_restore: processing item 6616 DATABASE postgres
[exec] pg_restore: processing item 6617 COMMENT DATABASE postgres
[exec] pg_restore: processing item 6618 DATABASE PROPERTIES postgres
[exec] pg_restore: processing item 12 SCHEMA data
[exec] pg_restore: creating SCHEMA "data"
[exec] pg_restore: processing item 13 SCHEMA rules
[exec] pg_restore: creating SCHEMA "rules"
[exec] pg_restore: processing item 742 FUNCTION pr_compare_value_lists(character varying, text, character varying, integer, integer)
[exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists(character varying, text, character varying, integer, integer)"
[exec] pg_restore: processing item 743 FUNCTION pr_compare_value_lists_allof(character varying, text)
[exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists_allof(character varying, text)"
[exec] pg_restore: processing item 744 FUNCTION pr_compare_value_lists_anyof(character varying, text)
[exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists_anyof(character varying, text)"
[exec] pg_restore: processing item 759 FUNCTION pr_read_decimal_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "data.pr_read_decimal_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 758 FUNCTION pr_read_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "data.pr_read_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 760 FUNCTION pr_read_int_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "data.pr_read_int_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 746 FUNCTION sppc_data_uniqueid_withouttran(character varying, character varying, character varying)
[exec] pg_restore: creating FUNCTION "data.sppc_data_uniqueid_withouttran(character varying, character varying, character varying)"
[exec] pg_restore: processing item 747 FUNCTION sppr_aggregate_usage()
[exec] pg_restore: creating FUNCTION "data.sppr_aggregate_usage()"
[exec] pg_restore: processing item 753 FUNCTION sppr_defragment_table(character varying, character varying)
[exec] pg_restore: creating FUNCTION "data.sppr_defragment_table(character varying, character varying)"
[exec] pg_restore: processing item 745 FUNCTION sppr_purge_table(character varying, character varying, integer)
[exec] pg_restore: creating FUNCTION "data.sppr_purge_table(character varying, character varying, integer)"
[exec] pg_restore: processing item 748 FUNCTION sppr_sys_getindextime(character varying)
[exec] pg_restore: creating FUNCTION "data.sppr_sys_getindextime(character varying)"
[exec] pg_restore: processing item 749 FUNCTION sppr_sys_reservequeueitem_b(character varying, character varying, character varying, character varying, character varying, character varying, timestamp without time zone, character varying, character varying)
[exec] pg_restore: creating FUNCTION "data.sppr_sys_reservequeueitem_b(character varying, character varying, character varying, character varying, character varying, character varying, timestamp without time zone, character varying, character varying)"
[exec] pg_restore: processing item 750 FUNCTION sppr_sys_statusnodes_set(character varying, character varying, character varying, character varying, character varying, character varying)
[exec] pg_restore: creating FUNCTION "data.sppr_sys_statusnodes_set(character varying, character varying, character varying, character varying, character varying, character varying)"
[exec] pg_restore: processing item 751 FUNCTION sppr_sys_updatescache_flush(integer)
[exec] pg_restore: creating FUNCTION "data.sppr_sys_updatescache_flush(integer)"
[exec] pg_restore: processing item 752 FUNCTION sppr_sys_updatescache_gettime(character varying)
[exec] pg_restore: creating FUNCTION "data.sppr_sys_updatescache_gettime(character varying)"
[exec] pg_restore: processing item 754 FUNCTION pr_compare_value_lists(character varying, text, character varying, integer, integer)
[exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists(character varying, text, character varying, integer, integer)"
[exec] pg_restore: processing item 755 FUNCTION pr_compare_value_lists_allof(character varying, text)
[exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists_allof(character varying, text)"
[exec] pg_restore: processing item 756 FUNCTION pr_compare_value_lists_anyof(character varying, text)
[exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists_anyof(character varying, text)"
[exec] pg_restore: processing item 762 FUNCTION pr_read_decimal_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "rules.pr_read_decimal_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 761 FUNCTION pr_read_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "rules.pr_read_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 763 FUNCTION pr_read_int_from_stream(character varying, character varying, bytea)
[exec] pg_restore: creating FUNCTION "rules.pr_read_int_from_stream(character varying, character varying, bytea)"
[exec] pg_restore: processing item 757 FUNCTION sppr_rebuild_indexes(character varying)
[exec] pg_restore: creating FUNCTION "rules.sppr_rebuild_indexes(character varying)"
[exec] pg_restore: processing item 433 TABLE p_address
[exec] pg_restore: creating TABLE "data.p_address"
[exec] pg_restore: processing item 434 TABLE p_contact
[exec] pg_restore: creating TABLE "data.p_contact"
[exec] pg_restore: processing item 429 TABLE p_contactcontactrel
[exec] pg_restore: creating TABLE "data.p_contactcontactrel"
[exec] pg_restore: processing item 430 TABLE p_contactorgrel
[exec] pg_restore: creating TABLE "data.p_contactorgrel"
[exec] pg_restore: processing item 435 TABLE p_organization
[exec] pg_restore: creating TABLE "data.p_organization"
[exec] pg_restore: processing item 431 TABLE p_orgorgrel
[exec] pg_restore: creating TABLE "data.p_orgorgrel"
[exec] pg_restore: processing item 432 TABLE p_role
[exec] pg_restore: creating TABLE "data.p_role"
[exec] pg_restore: processing item 362 TABLE pc_apn_token
[exec] pg_restore: creating TABLE "data.pc_apn_token"
[exec] pg_restore: processing item 256 TABLE pc_assign_workbasket
[exec] pg_restore: creating TABLE "data.pc_assign_workbasket"
[exec] pg_restore: processing item 257 TABLE pc_assign_worklist
[exec] pg_restore: creating TABLE "data.pc_assign_worklist"
[exec] pg_restore: processing item 319 TABLE pc_cep_actions_repository
[exec] pg_restore: creating TABLE "data.pc_cep_actions_repository"
[exec] pg_restore: processing item 320 TABLE pc_cep_events_repository
[exec] pg_restore: creating TABLE "data.pc_cep_events_repository"
[exec] pg_restore: processing item 467 TABLE pc_clientdata_restriction
[exec] pg_restore: creating TABLE "data.pc_clientdata_restriction"
[exec] pg_restore: processing item 233 TABLE pc_data_adm_seccorspol
[exec] pg_restore: creating TABLE "data.pc_data_adm_seccorspol"
[exec] pg_restore: processing item 234 TABLE pc_data_adm_seckeyid
[exec] pg_restore: creating TABLE "data.pc_data_adm_seckeyid"
[exec] pg_restore: processing item 492 TABLE pc_data_file_temp
[exec] pg_restore: creating TABLE "data.pc_data_file_temp"
[exec] pg_restore: processing item 237 TABLE pc_data_notiftn_param
[exec] pg_restore: creating TABLE "data.pc_data_notiftn_param"
[exec] pg_restore: processing item 258 TABLE pc_data_uniqueid
[exec] pg_restore: creating TABLE "data.pc_data_uniqueid"
[exec] pg_restore: processing item 259 TABLE pc_data_workattach
[exec] pg_restore: creating TABLE "data.pc_data_workattach"
[exec] pg_restore: processing item 266 TABLE pc_events
[exec] pg_restore: creating TABLE "data.pc_events"
[exec] pg_restore: processing item 483 TABLE pc_flaudit
[exec] pg_restore: creating TABLE "data.pc_flaudit"
[exec] pg_restore: processing item 363 TABLE pc_gcm_token
[exec] pg_restore: creating TABLE "data.pc_gcm_token"
[exec] pg_restore: processing item 380 TABLE pc_history_data_dms_work
[exec] pg_restore: creating TABLE "data.pc_history_data_dms_work"
[exec] pg_restore: processing item 478 TABLE pc_history_document
[exec] pg_restore: creating TABLE "data.pc_history_document"
[exec] pg_restore: processing item 450 TABLE pc_history_group
[exec] pg_restore: creating TABLE "data.pc_history_group"
[exec] pg_restore: processing item 260 TABLE pc_history_work
[exec] pg_restore: creating TABLE "data.pc_history_work"
[exec] pg_restore: processing item 470 TABLE pc_history_work_cover_task
[exec] pg_restore: creating TABLE "data.pc_history_work_cover_task"
[exec] pg_restore: processing item 254 TABLE pc_index_accel
[exec] pg_restore: creating TABLE "data.pc_index_accel"
[exec] pg_restore: processing item 386 TABLE pc_index_location
[exec] pg_restore: creating TABLE "data.pc_index_location"
[exec] pg_restore: processing item 261 TABLE pc_index_workparty
[exec] pg_restore: creating TABLE "data.pc_index_workparty"
[exec] pg_restore: processing item 407 TABLE pc_link_association
[exec] pg_restore: creating TABLE "data.pc_link_association"
[exec] pg_restore: processing item 485 TABLE pc_link_association_channel
[exec] pg_restore: creating TABLE "data.pc_link_association_channel"
[exec] pg_restore: processing item 423 TABLE pc_link_association_doc
[exec] pg_restore: creating TABLE "data.pc_link_association_doc"
[exec] pg_restore: processing item 451 TABLE pc_link_association_member
[exec] pg_restore: creating TABLE "data.pc_link_association_member"
[exec] pg_restore: processing item 464 TABLE pc_link_association_pin
[exec] pg_restore: creating TABLE "data.pc_link_association_pin"
[exec] pg_restore: processing item 481 TABLE pc_link_association_rrcategory
[exec] pg_restore: creating TABLE "data.pc_link_association_rrcategory"
[exec] pg_restore: processing item 468 TABLE pc_link_association_space
[exec] pg_restore: creating TABLE "data.pc_link_association_space"
[exec] pg_restore: processing item 262 TABLE pc_link_attachment
[exec] pg_restore: creating TABLE "data.pc_link_attachment"
[exec] pg_restore: processing item 448 TABLE pc_link_category
[exec] pg_restore: creating TABLE "data.pc_link_category"
[exec] pg_restore: processing item 263 TABLE pc_link_folder
[exec] pg_restore: creating TABLE "data.pc_link_folder"
[exec] pg_restore: processing item 289 TABLE pc_link_topcase
[exec] pg_restore: creating TABLE "data.pc_link_topcase"
[exec] pg_restore: processing item 357 TABLE pc_pegatask
[exec] pg_restore: creating TABLE "data.pc_pegatask"
[exec] pg_restore: processing item 265 TABLE pc_schedule_task
[exec] pg_restore: creating TABLE "data.pc_schedule_task"
[exec] pg_restore: processing item 267 TABLE pc_work
[exec] pg_restore: creating TABLE "data.pc_work"
[exec] pg_restore: processing item 264 TABLE pc_work_accel
[exec] pg_restore: creating TABLE "data.pc_work_accel"
[exec] pg_restore: processing item 406 TABLE pc_work_agile
[exec] pg_restore: creating TABLE "data.pc_work_agile"
[exec] pg_restore: processing item 454 TABLE pc_work_clientdata
[exec] pg_restore: creating TABLE "data.pc_work_clientdata"
[exec] pg_restore: processing item 469 TABLE pc_work_cover_task
[exec] pg_restore: creating TABLE "data.pc_work_cover_task"
[exec] pg_restore: processing item 379 TABLE pc_work_dms
[exec] pg_restore: creating TABLE "data.pc_work_dms"
[exec] pg_restore: processing item 422 TABLE pc_work_document
[exec] pg_restore: creating TABLE "data.pc_work_document"
[exec] pg_restore: processing item 269 TABLE pc_work_dsm_batch
[exec] pg_restore: creating TABLE "data.pc_work_dsm_batch"
[exec] pg_restore: processing item 500 TABLE pc_work_dsm_simulation
[exec] pg_restore: creating TABLE "data.pc_work_dsm_simulation"
[exec] pg_restore: processing item 449 TABLE pc_work_group
[exec] pg_restore: creating TABLE "data.pc_work_group"
[exec] pg_restore: processing item 408 TABLE pc_work_guide
[exec] pg_restore: creating TABLE "data.pc_work_guide"
[exec] pg_restore: processing item 403 TABLE pc_work_notification
[exec] pg_restore: creating TABLE "data.pc_work_notification"
[exec] pg_restore: processing item 496 TABLE pc_work_prediction
[exec] pg_restore: creating TABLE "data.pc_work_prediction"
[exec] pg_restore: processing item 268 TABLE pc_work_processemail
[exec] pg_restore: creating TABLE "data.pc_work_processemail"
[exec] pg_restore: processing item 339 TABLE pc_work_social
[exec] pg_restore: creating TABLE "data.pc_work_social"
[exec] pg_restore: processing item 494 TABLE pc_work_triage
[exec] pg_restore: creating TABLE "data.pc_work_triage"
[exec] pg_restore: processing item 274 TABLE pr_data_admin
[exec] pg_restore: creating TABLE "data.pr_data_admin"
[exec] pg_restore: processing item 509 VIEW pcv4_assignment_summary
[exec] pg_restore: creating VIEW "data.pcv4_assignment_summary"
[exec] pg_restore: processing item 510 VIEW pcv4_assignmentwb_summary
[exec] pg_restore: creating VIEW "data.pcv4_assignmentwb_summary"
[exec] pg_restore: processing item 511 VIEW pcv4_work_history
[exec] pg_restore: creating VIEW "data.pcv4_work_history"
[exec] pg_restore: processing item 270 TABLE pi_data_connect
[exec] pg_restore: creating TABLE "data.pi_data_connect"
[exec] pg_restore: processing item 285 TABLE pr4_history_rule
[exec] pg_restore: creating TABLE "data.pr4_history_rule"
[exec] pg_restore: processing item 322 TABLE pr4_log_rule_usage
[exec] pg_restore: creating TABLE "data.pr4_log_rule_usage"
[exec] pg_restore: processing item 323 TABLE pr4_log_rule_usage_details
[exec] pg_restore: creating TABLE "data.pr4_log_rule_usage_details"
[exec] pg_restore: processing item 508 TABLE pr_archival_class_dependency
[exec] pg_restore: creating TABLE "data.pr_archival_class_dependency"
[exec] pg_restore: processing item 271 TABLE pr_assign
[exec] pg_restore: creating TABLE "data.pr_assign"
[exec] pg_restore: processing item 316 TABLE pr_cep_events_queue
[exec] pg_restore: creating TABLE "data.pr_cep_events_queue"
[exec] pg_restore: processing item 317 TABLE pr_cep_eventslookup
[exec] pg_restore: creating TABLE "data.pr_cep_eventslookup"
[exec] pg_restore: processing item 318 TABLE pr_cep_user_subscriptions
[exec] pg_restore: creating TABLE "data.pr_cep_user_subscriptions"
[exec] pg_restore: processing item 329 TABLE pr_daily_usage
[exec] pg_restore: creating TABLE "data.pr_daily_usage"
[exec] pg_restore: processing item 273 TABLE pr_data
[exec] pg_restore: creating TABLE "data.pr_data"
[exec] pg_restore: processing item 399 TABLE pr_data_adm_configuration
[exec] pg_restore: creating TABLE "data.pr_data_adm_configuration"
[exec] pg_restore: processing item 400 TABLE pr_data_adm_factory
[exec] pg_restore: creating TABLE "data.pr_data_adm_factory"
[exec] pg_restore: processing item 452 TABLE pr_data_admin_auth_code
[exec] pg_restore: creating TABLE "data.pr_data_admin_auth_code"
[exec] pg_restore: processing item 499 TABLE pr_data_admin_dds_table
[exec] pg_restore: creating TABLE "data.pr_data_admin_dds_table"
[exec] pg_restore: processing item 472 TABLE pr_data_admin_sec_cert
[exec] pg_restore: creating TABLE "data.pr_data_admin_sec_cert"
[exec] pg_restore: processing item 409 TABLE pr_data_admin_sec_de_cdk
[exec] pg_restore: creating TABLE "data.pr_data_admin_sec_de_cdk"
[exec] pg_restore: processing item 410 TABLE pr_data_admin_sec_de_key
[exec] pg_restore: creating TABLE "data.pr_data_admin_sec_de_key"
[exec] pg_restore: processing item 442 TABLE pr_data_admin_sec_sde_cdk
[exec] pg_restore: creating TABLE "data.pr_data_admin_sec_sde_cdk"
[exec] pg_restore: processing item 275 TABLE pr_data_admin_tenant
[exec] pg_restore: creating TABLE "data.pr_data_admin_tenant"
[exec] pg_restore: processing item 251 TABLE pr_data_analysis_specification
[exec] pg_restore: creating TABLE "data.pr_data_analysis_specification"
[exec] pg_restore: processing item 491 TABLE pr_data_app_oauth2client
[exec] pg_restore: creating TABLE "data.pr_data_app_oauth2client"
[exec] pg_restore: processing item 498 TABLE pr_data_appalias_authservice
[exec] pg_restore: creating TABLE "data.pr_data_appalias_authservice"
[exec] pg_restore: processing item 463 TABLE pr_data_application_quality
[exec] pg_restore: creating TABLE "data.pr_data_application_quality"
[exec] pg_restore: processing item 420 TABLE pr_data_applicationpreference
[exec] pg_restore: creating TABLE "data.pr_data_applicationpreference"
[exec] pg_restore: processing item 255 TABLE pr_data_autotest
[exec] pg_restore: creating TABLE "data.pr_data_autotest"
[exec] pg_restore: processing item 447 TABLE pr_data_category
[exec] pg_restore: creating TABLE "data.pr_data_category"
[exec] pg_restore: processing item 482 TABLE pr_data_collaboration
[exec] pg_restore: creating TABLE "data.pr_data_collaboration"
[exec] pg_restore: processing item 507 TABLE pr_data_configuration_audit
[exec] pg_restore: creating TABLE "data.pr_data_configuration_audit"
[exec] pg_restore: processing item 502 TABLE pr_data_configuration_setting
[exec] pg_restore: creating TABLE "data.pr_data_configuration_setting"
[exec] pg_restore: processing item 236 TABLE pr_data_custm_date_fmt
[exec] pg_restore: creating TABLE "data.pr_data_custm_date_fmt"
[exec] pg_restore: processing item 484 TABLE pr_data_decision_biasresults
[exec] pg_restore: creating TABLE "data.pr_data_decision_biasresults"
[exec] pg_restore: processing item 382 TABLE pr_data_decision_ddf_error
[exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_error"
[exec] pg_restore: processing item 438 TABLE pr_data_decision_ddf_run_opts
[exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_run_opts"
[exec] pg_restore: processing item 241 TABLE pr_data_decision_ddf_runtime
[exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_runtime"
[exec] pg_restore: processing item 240 TABLE pr_data_decision_df_met
[exec] pg_restore: creating TABLE "data.pr_data_decision_df_met"
[exec] pg_restore: processing item 239 TABLE pr_data_decision_df_part
[exec] pg_restore: creating TABLE "data.pr_data_decision_df_part"
[exec] pg_restore: processing item 412 TABLE pr_data_distinctvalueindex
[exec] pg_restore: creating TABLE "data.pr_data_distinctvalueindex"
[exec] pg_restore: processing item 343 TABLE pr_data_dm_admmart_mdl_fact
[exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_mdl_fact"
[exec] pg_restore: processing item 342 TABLE pr_data_dm_admmart_model
[exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_model"
[exec] pg_restore: processing item 230 TABLE pr_data_dm_admmart_pred
[exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_pred"
[exec] pg_restore: processing item 457 TABLE pr_data_dm_binarydistribution
[exec] pg_restore: creating TABLE "data.pr_data_dm_binarydistribution"
[exec] pg_restore: processing item 460 TABLE pr_data_dm_contingencytable
[exec] pg_restore: creating TABLE "data.pr_data_dm_contingencytable"
[exec] pg_restore: processing item 458 TABLE pr_data_dm_histogram
[exec] pg_restore: creating TABLE "data.pr_data_dm_histogram"
[exec] pg_restore: processing item 475 TABLE pr_data_dm_notification
[exec] pg_restore: creating TABLE "data.pr_data_dm_notification"
[exec] pg_restore: processing item 459 TABLE pr_data_dm_snapshot
[exec] pg_restore: creating TABLE "data.pr_data_dm_snapshot"
[exec] pg_restore: processing item 455 TABLE pr_data_dmorg_dmsample_circle
[exec] pg_restore: creating TABLE "data.pr_data_dmorg_dmsample_circle"
[exec] pg_restore: processing item 371 TABLE pr_data_dms_customer_data
[exec] pg_restore: creating TABLE "data.pr_data_dms_customer_data"
[exec] pg_restore: processing item 372 TABLE pr_data_dms_device
[exec] pg_restore: creating TABLE "data.pr_data_dms_device"
[exec] pg_restore: processing item 375 TABLE pr_data_dms_droppedcallevents
[exec] pg_restore: creating TABLE "data.pr_data_dms_droppedcallevents"
[exec] pg_restore: processing item 376 TABLE pr_data_dms_global
[exec] pg_restore: creating TABLE "data.pr_data_dms_global"
[exec] pg_restore: processing item 373 TABLE pr_data_dms_purchase
[exec] pg_restore: creating TABLE "data.pr_data_dms_purchase"
[exec] pg_restore: processing item 374 TABLE pr_data_dms_subscription
[exec] pg_restore: creating TABLE "data.pr_data_dms_subscription"
[exec] pg_restore: processing item 398 TABLE pr_data_dms_survey_data
[exec] pg_restore: creating TABLE "data.pr_data_dms_survey_data"
[exec] pg_restore: processing item 471 TABLE pr_data_explain_simulation
[exec] pg_restore: creating TABLE "data.pr_data_explain_simulation"
[exec] pg_restore: processing item 401 TABLE pr_data_features
[exec] pg_restore: creating TABLE "data.pr_data_features"
[exec] pg_restore: processing item 249 TABLE pr_data_file
[exec] pg_restore: creating TABLE "data.pr_data_file"
[exec] pg_restore: processing item 473 TABLE pr_data_full_sync_stats
[exec] pg_restore: creating TABLE "data.pr_data_full_sync_stats"
[exec] pg_restore: processing item 250 TABLE pr_data_guardrails
[exec] pg_restore: creating TABLE "data.pr_data_guardrails"
[exec] pg_restore: processing item 486 TABLE pr_data_guardrails_evaluation
[exec] pg_restore: creating TABLE "data.pr_data_guardrails_evaluation"
[exec] pg_restore: processing item 487 TABLE pr_data_guardrails_runstatus
[exec] pg_restore: creating TABLE "data.pr_data_guardrails_runstatus"
[exec] pg_restore: processing item 461 TABLE pr_data_healthcheck
[exec] pg_restore: creating TABLE "data.pr_data_healthcheck"
[exec] pg_restore: processing item 356 TABLE pr_data_ih_association
[exec] pg_restore: creating TABLE "data.pr_data_ih_association"
[exec] pg_restore: processing item 347 TABLE pr_data_ih_dim_action
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_action"
[exec] pg_restore: processing item 352 TABLE pr_data_ih_dim_application
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_application"
[exec] pg_restore: processing item 353 TABLE pr_data_ih_dim_channel
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_channel"
[exec] pg_restore: processing item 351 TABLE pr_data_ih_dim_context
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_context"
[exec] pg_restore: processing item 348 TABLE pr_data_ih_dim_customer
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_customer"
[exec] pg_restore: processing item 411 TABLE pr_data_ih_dim_journey
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_journey"
[exec] pg_restore: processing item 349 TABLE pr_data_ih_dim_location
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_location"
[exec] pg_restore: processing item 350 TABLE pr_data_ih_dim_operator
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_operator"
[exec] pg_restore: processing item 354 TABLE pr_data_ih_dim_outcome
[exec] pg_restore: creating TABLE "data.pr_data_ih_dim_outcome"
[exec] pg_restore: processing item 355 TABLE pr_data_ih_fact
[exec] pg_restore: creating TABLE "data.pr_data_ih_fact"
[exec] pg_restore: processing item 462 TABLE pr_data_integrationsystem
[exec] pg_restore: creating TABLE "data.pr_data_integrationsystem"
[exec] pg_restore: processing item 238 TABLE pr_data_mobile_app_pf_asset
[exec] pg_restore: creating TABLE "data.pr_data_mobile_app_pf_asset"
[exec] pg_restore: processing item 361 TABLE pr_data_mobile_appinfo
[exec] pg_restore: creating TABLE "data.pr_data_mobile_appinfo"
[exec] pg_restore: processing item 359 TABLE pr_data_mobile_asset
[exec] pg_restore: creating TABLE "data.pr_data_mobile_asset"
[exec] pg_restore: processing item 358 TABLE pr_data_mobile_build
[exec] pg_restore: creating TABLE "data.pr_data_mobile_build"
[exec] pg_restore: processing item 360 TABLE pr_data_mobile_certificate
[exec] pg_restore: creating TABLE "data.pr_data_mobile_certificate"
[exec] pg_restore: processing item 391 TABLE pr_data_mobile_device
[exec] pg_restore: creating TABLE "data.pr_data_mobile_device"
[exec] pg_restore: processing item 425 TABLE pr_data_mobile_map_track
[exec] pg_restore: creating TABLE "data.pr_data_mobile_map_track"
[exec] pg_restore: processing item 426 TABLE pr_data_mobile_map_user
[exec] pg_restore: creating TABLE "data.pr_data_mobile_map_user"
[exec] pg_restore: processing item 384 TABLE pr_data_nlp_details
[exec] pg_restore: creating TABLE "data.pr_data_nlp_details"
[exec] pg_restore: processing item 413 TABLE pr_data_nlp_model_training
[exec] pg_restore: creating TABLE "data.pr_data_nlp_model_training"
[exec] pg_restore: processing item 504 TABLE pr_data_nlp_reporting
[exec] pg_restore: creating TABLE "data.pr_data_nlp_reporting"
[exec] pg_restore: processing item 503 TABLE pr_data_nlp_snapshot
[exec] pg_restore: creating TABLE "data.pr_data_nlp_snapshot"
[exec] pg_restore: processing item 497 TABLE pr_data_nlp_status
[exec] pg_restore: creating TABLE "data.pr_data_nlp_status"
[exec] pg_restore: processing item 383 TABLE pr_data_nlp_summary
[exec] pg_restore: creating TABLE "data.pr_data_nlp_summary"
[exec] pg_restore: processing item 404 TABLE pr_data_notification_recipient
[exec] pg_restore: creating TABLE "data.pr_data_notification_recipient"
[exec] pg_restore: processing item 421 TABLE pr_data_offline_sync
[exec] pg_restore: creating TABLE "data.pr_data_offline_sync"
[exec] pg_restore: processing item 489 TABLE pr_data_op_session
[exec] pg_restore: creating TABLE "data.pr_data_op_session"
[exec] pg_restore: processing item 385 TABLE pr_data_pegasample_product
[exec] pg_restore: creating TABLE "data.pr_data_pegasample_product"
[exec] pg_restore: processing item 336 TABLE pr_data_pmf_worklist
[exec] pg_restore: creating TABLE "data.pr_data_pmf_worklist"
[exec] pg_restore: processing item 474 TABLE pr_data_qp_run_partition
[exec] pg_restore: creating TABLE "data.pr_data_qp_run_partition"
[exec] pg_restore: processing item 346 TABLE pr_data_recents
[exec] pg_restore: creating TABLE "data.pr_data_recents"
[exec] pg_restore: processing item 276 TABLE pr_data_reportcategory
[exec] pg_restore: creating TABLE "data.pr_data_reportcategory"
[exec] pg_restore: processing item 277 TABLE pr_data_reportshortcut
[exec] pg_restore: creating TABLE "data.pr_data_reportshortcut"
[exec] pg_restore: processing item 441 TABLE pr_data_repositories
[exec] pg_restore: creating TABLE "data.pr_data_repositories"
[exec] pg_restore: processing item 443 TABLE pr_data_retention_policy
[exec] pg_restore: creating TABLE "data.pr_data_retention_policy"
[exec] pg_restore: processing item 479 TABLE pr_data_rrcategories
[exec] pg_restore: creating TABLE "data.pr_data_rrcategories"
[exec] pg_restore: processing item 419 TABLE pr_data_rulecoverage_results
[exec] pg_restore: creating TABLE "data.pr_data_rulecoverage_results"
[exec] pg_restore: processing item 394 TABLE pr_data_saml_authreqcontext
[exec] pg_restore: creating TABLE "data.pr_data_saml_authreqcontext"
[exec] pg_restore: processing item 393 TABLE pr_data_saml_logininfo
[exec] pg_restore: creating TABLE "data.pr_data_saml_logininfo"
[exec] pg_restore: processing item 396 TABLE pr_data_saml_logoutreqinfo
[exec] pg_restore: creating TABLE "data.pr_data_saml_logoutreqinfo"
[exec] pg_restore: processing item 392 TABLE pr_data_saml_replaycache
[exec] pg_restore: creating TABLE "data.pr_data_saml_replaycache"
[exec] pg_restore: processing item 397 TABLE pr_data_saml_requestorinfo
[exec] pg_restore: creating TABLE "data.pr_data_saml_requestorinfo"
[exec] pg_restore: processing item 395 TABLE pr_data_saml_sessioninfo
[exec] pg_restore: creating TABLE "data.pr_data_saml_sessioninfo"
[exec] pg_restore: processing item 345 TABLE pr_data_sample_shoppingcart
[exec] pg_restore: creating TABLE "data.pr_data_sample_shoppingcart"
[exec] pg_restore: processing item 278 TABLE pr_data_sample_uidetails
[exec] pg_restore: creating TABLE "data.pr_data_sample_uidetails"
[exec] pg_restore: processing item 279 TABLE pr_data_samplesrcustomer
[exec] pg_restore: creating TABLE "data.pr_data_samplesrcustomer"
[exec] pg_restore: processing item 280 TABLE pr_data_samplesrproduct
[exec] pg_restore: creating TABLE "data.pr_data_samplesrproduct"
[exec] pg_restore: processing item 281 TABLE pr_data_samplesrpurchase
[exec] pg_restore: creating TABLE "data.pr_data_samplesrpurchase"
[exec] pg_restore: processing item 495 TABLE pr_data_sizeestimator_config
[exec] pg_restore: creating TABLE "data.pr_data_sizeestimator_config"
[exec] pg_restore: processing item 436 TABLE pr_data_smsaccount
[exec] pg_restore: creating TABLE "data.pr_data_smsaccount"
[exec] pg_restore: processing item 341 TABLE pr_data_social_reference
[exec] pg_restore: creating TABLE "data.pr_data_social_reference"
[exec] pg_restore: processing item 417 TABLE pr_data_stream_node_updates
[exec] pg_restore: creating TABLE "data.pr_data_stream_node_updates"
[exec] pg_restore: processing item 416 TABLE pr_data_stream_nodes
[exec] pg_restore: creating TABLE "data.pr_data_stream_nodes"
[exec] pg_restore: processing item 415 TABLE pr_data_stream_sessions
[exec] pg_restore: creating TABLE "data.pr_data_stream_sessions"
[exec] pg_restore: processing item 231 TABLE pr_data_svcinvhist
[exec] pg_restore: creating TABLE "data.pr_data_svcinvhist"
[exec] pg_restore: processing item 331 TABLE pr_data_tag
[exec] pg_restore: creating TABLE "data.pr_data_tag"
[exec] pg_restore: processing item 388 TABLE pr_data_tag_oplink
[exec] pg_restore: creating TABLE "data.pr_data_tag_oplink"
[exec] pg_restore: processing item 389 TABLE pr_data_tag_relevantrecord
[exec] pg_restore: creating TABLE "data.pr_data_tag_relevantrecord"
[exec] pg_restore: processing item 282 TABLE pr_data_template_metadata
[exec] pg_restore: creating TABLE "data.pr_data_template_metadata"
[exec] pg_restore: processing item 367 TABLE pr_data_testcaseresults
[exec] pg_restore: creating TABLE "data.pr_data_testcaseresults"
[exec] pg_restore: processing item 405 TABLE pr_data_testsuiteresults
[exec] pg_restore: creating TABLE "data.pr_data_testsuiteresults"
[exec] pg_restore: processing item 402 TABLE pr_data_toggle
[exec] pg_restore: creating TABLE "data.pr_data_toggle"
[exec] pg_restore: processing item 368 TABLE pr_data_token
[exec] pg_restore: creating TABLE "data.pr_data_token"
[exec] pg_restore: processing item 490 TABLE pr_data_token_blacklisted_jti
[exec] pg_restore: creating TABLE "data.pr_data_token_blacklisted_jti"
[exec] pg_restore: processing item 506 TABLE pr_data_user_activity
[exec] pg_restore: creating TABLE "data.pr_data_user_activity"
[exec] pg_restore: processing item 390 TABLE pr_database_info_table
[exec] pg_restore: creating TABLE "data.pr_database_info_table"
[exec] pg_restore: processing item 272 TABLE pr_dm_proposition
[exec] pg_restore: creating TABLE "data.pr_dm_proposition"
[exec] pg_restore: processing item 232 TABLE pr_extract_time
[exec] pg_restore: creating TABLE "data.pr_extract_time"
[exec] pg_restore: processing item 324 TABLE pr_file_store
[exec] pg_restore: creating TABLE "data.pr_file_store"
[exec] pg_restore: processing item 325 TABLE pr_file_upload
[exec] pg_restore: creating TABLE "data.pr_file_upload"
[exec] pg_restore: processing item 326 TABLE pr_file_upload_fallback
[exec] pg_restore: creating TABLE "data.pr_file_upload_fallback"
[exec] pg_restore: processing item 283 TABLE pr_history
[exec] pg_restore: creating TABLE "data.pr_history"
[exec] pg_restore: processing item 284 TABLE pr_history_data
[exec] pg_restore: creating TABLE "data.pr_history_data"
[exec] pg_restore: processing item 377 TABLE pr_history_data_dms_customer
[exec] pg_restore: creating TABLE "data.pr_history_data_dms_customer"
[exec] pg_restore: processing item 378 TABLE pr_history_data_dms_glbl
[exec] pg_restore: creating TABLE "data.pr_history_data_dms_glbl"
[exec] pg_restore: processing item 328 TABLE pr_hourly_usage
[exec] pg_restore: creating TABLE "data.pr_hourly_usage"
[exec] pg_restore: processing item 286 TABLE pr_index
[exec] pg_restore: creating TABLE "data.pr_index"
[exec] pg_restore: processing item 245 TABLE pr_index_accessgrouproles
[exec] pg_restore: creating TABLE "data.pr_index_accessgrouproles"
[exec] pg_restore: processing item 246 TABLE pr_index_accessgroupwkpools
[exec] pg_restore: creating TABLE "data.pr_index_accessgroupwkpools"
[exec] pg_restore: processing item 243 TABLE pr_index_appfeatures
[exec] pg_restore: creating TABLE "data.pr_index_appfeatures"
[exec] pg_restore: processing item 334 TABLE pr_index_assignmentdeps
[exec] pg_restore: creating TABLE "data.pr_index_assignmentdeps"
[exec] pg_restore: processing item 294 TABLE pr_index_assignmentskills
[exec] pg_restore: creating TABLE "data.pr_index_assignmentskills"
[exec] pg_restore: processing item 366 TABLE pr_index_data_agents
[exec] pg_restore: creating TABLE "data.pr_index_data_agents"
[exec] pg_restore: processing item 414 TABLE pr_index_distinctvalues
[exec] pg_restore: creating TABLE "data.pr_index_distinctvalues"
[exec] pg_restore: processing item 248 TABLE pr_index_email
[exec] pg_restore: creating TABLE "data.pr_index_email"
[exec] pg_restore: processing item 344 TABLE pr_index_operator_workgroups
[exec] pg_restore: creating TABLE "data.pr_index_operator_workgroups"
[exec] pg_restore: processing item 293 TABLE pr_index_operators
[exec] pg_restore: creating TABLE "data.pr_index_operators"
[exec] pg_restore: processing item 295 TABLE pr_index_operatorskills
[exec] pg_restore: creating TABLE "data.pr_index_operatorskills"
[exec] pg_restore: processing item 387 TABLE pr_index_pref_notify
[exec] pg_restore: creating TABLE "data.pr_index_pref_notify"
[exec] pg_restore: processing item 287 TABLE pr_index_scheduledtask
[exec] pg_restore: creating TABLE "data.pr_index_scheduledtask"
[exec] pg_restore: processing item 340 TABLE pr_index_trackstatus
[exec] pg_restore: creating TABLE "data.pr_index_trackstatus"
[exec] pg_restore: processing item 493 TABLE pr_index_tracktriageactions
[exec] pg_restore: creating TABLE "data.pr_index_tracktriageactions"
[exec] pg_restore: processing item 247 TABLE pr_index_workgroups
[exec] pg_restore: creating TABLE "data.pr_index_workgroups"
[exec] pg_restore: processing item 444 TABLE pr_indexmetadata
[exec] pg_restore: creating TABLE "data.pr_indexmetadata"
[exec] pg_restore: processing item 440 TABLE pr_jobscheduler_override
[exec] pg_restore: creating TABLE "data.pr_jobscheduler_override"
[exec] pg_restore: processing item 327 TABLE pr_license_parameters
[exec] pg_restore: creating TABLE "data.pr_license_parameters"
[exec] pg_restore: processing item 288 TABLE pr_link
[exec] pg_restore: creating TABLE "data.pr_link"
[exec] pg_restore: processing item 333 TABLE pr_link_dco_pmf
[exec] pg_restore: creating TABLE "data.pr_link_dco_pmf"
[exec] pg_restore: processing item 337 TABLE pr_link_pmf_rulechanges
[exec] pg_restore: creating TABLE "data.pr_link_pmf_rulechanges"
[exec] pg_restore: processing item 332 TABLE pr_link_work_tag
[exec] pg_restore: creating TABLE "data.pr_link_work_tag"
[exec] pg_restore: processing item 290 TABLE pr_log
[exec] pg_restore: creating TABLE "data.pr_log"
[exec] pg_restore: processing item 501 TABLE pr_log_archivalsummary
[exec] pg_restore: creating TABLE "data.pr_log_archivalsummary"
[exec] pg_restore: processing item 456 TABLE pr_log_archivepurgeresults
[exec] pg_restore: creating TABLE "data.pr_log_archivepurgeresults"
[exec] pg_restore: processing item 338 TABLE pr_log_batchstats
[exec] pg_restore: creating TABLE "data.pr_log_batchstats"
[exec] pg_restore: processing item 369 TABLE pr_log_cluster
[exec] pg_restore: creating TABLE "data.pr_log_cluster"
[exec] pg_restore: processing item 439 TABLE pr_log_collaboration
[exec] pg_restore: creating TABLE "data.pr_log_collaboration"
[exec] pg_restore: processing item 252 TABLE pr_log_dataaccessaudit
[exec] pg_restore: creating TABLE "data.pr_log_dataaccessaudit"
[exec] pg_restore: processing item 437 TABLE pr_log_dataflow_events
[exec] pg_restore: creating TABLE "data.pr_log_dataflow_events"
[exec] pg_restore: processing item 505 TABLE pr_log_expungedcases
[exec] pg_restore: creating TABLE "data.pr_log_expungedcases"
[exec] pg_restore: processing item 476 TABLE pr_log_indexing_progress
[exec] pg_restore: creating TABLE "data.pr_log_indexing_progress"
[exec] pg_restore: processing item 418 TABLE pr_log_jobs_scheduler
[exec] pg_restore: creating TABLE "data.pr_log_jobs_scheduler"
[exec] pg_restore: processing item 381 TABLE pr_log_progress
[exec] pg_restore: creating TABLE "data.pr_log_progress"
[exec] pg_restore: processing item 244 TABLE pr_log_reportstats
[exec] pg_restore: creating TABLE "data.pr_log_reportstats"
[exec] pg_restore: processing item 335 TABLE pr_log_securityaudit
[exec] pg_restore: creating TABLE "data.pr_log_securityaudit"
[exec] pg_restore: processing item 480 TABLE pr_log_service_email
[exec] pg_restore: creating TABLE "data.pr_log_service_email"
[exec] pg_restore: processing item 370 TABLE pr_log_systemstate
[exec] pg_restore: creating TABLE "data.pr_log_systemstate"
[exec] pg_restore: processing item 445 TABLE pr_metadata
[exec] pg_restore: creating TABLE "data.pr_metadata"
[exec] pg_restore: processing item 242 TABLE pr_notification_channels
[exec] pg_restore: creating TABLE "data.pr_notification_channels"
[exec] pg_restore: processing item 428 TABLE pr_offline_attachment_mapping
[exec] pg_restore: creating TABLE "data.pr_offline_attachment_mapping"
[exec] pg_restore: processing item 427 TABLE pr_offline_attachment_stub
[exec] pg_restore: creating TABLE "data.pr_offline_attachment_stub"
[exec] pg_restore: processing item 299 TABLE pr_offline_pack
[exec] pg_restore: creating TABLE "data.pr_offline_pack"
[exec] pg_restore: processing item 465 TABLE pr_offline_sync_requests
[exec] pg_restore: creating TABLE "data.pr_offline_sync_requests"
[exec] pg_restore: processing item 466 TABLE pr_offline_sync_requests_info
[exec] pg_restore: creating TABLE "data.pr_offline_sync_requests_info"
[exec] pg_restore: processing item 292 TABLE pr_operator_prefs
[exec] pg_restore: creating TABLE "data.pr_operator_prefs"
[exec] pg_restore: processing item 291 TABLE pr_operators
[exec] pg_restore: creating TABLE "data.pr_operators"
[exec] pg_restore: processing item 296 TABLE pr_other
[exec] pg_restore: creating TABLE "data.pr_other"
[exec] pg_restore: processing item 298 TABLE pr_page_store
[exec] pg_restore: creating TABLE "data.pr_page_store"
[exec] pg_restore: processing item 321 TABLE pr_perf_stats
[exec] pg_restore: creating TABLE "data.pr_perf_stats"
[exec] pg_restore: processing item 297 TABLE pr_portal_state
[exec] pg_restore: creating TABLE "data.pr_portal_state"
[exec] pg_restore: processing item 477 TABLE pr_sys_bi_publisheddatamodel
[exec] pg_restore: creating TABLE "data.pr_sys_bi_publisheddatamodel"
[exec] pg_restore: processing item 300 TABLE pr_sys_context
[exec] pg_restore: creating TABLE "data.pr_sys_context"
[exec] pg_restore: processing item 453 TABLE pr_sys_delayed_queue
[exec] pg_restore: creating TABLE "data.pr_sys_delayed_queue"
[exec] pg_restore: processing item 301 TABLE pr_sys_locks
[exec] pg_restore: creating TABLE "data.pr_sys_locks"
[exec] pg_restore: processing item 446 TABLE pr_sys_msg_qp_brokenitems
[exec] pg_restore: creating TABLE "data.pr_sys_msg_qp_brokenitems"
[exec] pg_restore: processing item 308 TABLE pr_sys_queue_autotest
[exec] pg_restore: creating TABLE "data.pr_sys_queue_autotest"
[exec] pg_restore: processing item 314 TABLE pr_sys_queue_col_pop
[exec] pg_restore: creating TABLE "data.pr_sys_queue_col_pop"
[exec] pg_restore: processing item 315 TABLE pr_sys_queue_count
[exec] pg_restore: creating TABLE "data.pr_sys_queue_count"
[exec] pg_restore: processing item 312 TABLE pr_sys_queue_execreq_conn
[exec] pg_restore: creating TABLE "data.pr_sys_queue_execreq_conn"
[exec] pg_restore: processing item 311 TABLE pr_sys_queue_execreq_svc
[exec] pg_restore: creating TABLE "data.pr_sys_queue_execreq_svc"
[exec] pg_restore: processing item 424 TABLE pr_sys_queue_ftsconflict
[exec] pg_restore: creating TABLE "data.pr_sys_queue_ftsconflict"
[exec] pg_restore: processing item 365 TABLE pr_sys_queue_ftsindexer
[exec] pg_restore: creating TABLE "data.pr_sys_queue_ftsindexer"
[exec] pg_restore: processing item 310 TABLE pr_sys_queue_sla
[exec] pg_restore: creating TABLE "data.pr_sys_queue_sla"
[exec] pg_restore: processing item 313 TABLE pr_sys_queue_startflows
[exec] pg_restore: creating TABLE "data.pr_sys_queue_startflows"
[exec] pg_restore: processing item 307 TABLE pr_sys_queues
[exec] pg_restore: creating TABLE "data.pr_sys_queues"
[exec] pg_restore: processing item 302 TABLE pr_sys_serviceregistry
[exec] pg_restore: creating TABLE "data.pr_sys_serviceregistry"
[exec] pg_restore: processing item 303 TABLE pr_sys_serviceregistry_kvs
[exec] pg_restore: creating TABLE "data.pr_sys_serviceregistry_kvs"
[exec] pg_restore: processing item 364 TABLE pr_sys_statusdetails
[exec] pg_restore: creating TABLE "data.pr_sys_statusdetails"
[exec] pg_restore: processing item 304 TABLE pr_sys_statusnodes
[exec] pg_restore: creating TABLE "data.pr_sys_statusnodes"
[exec] pg_restore: processing item 305 TABLE pr_sys_updatescache
[exec] pg_restore: creating TABLE "data.pr_sys_updatescache"
[exec] pg_restore: processing item 306 TABLE pr_sys_user
[exec] pg_restore: creating TABLE "data.pr_sys_user"
[exec] pg_restore: processing item 488 TABLE pr_sys_user_grid
[exec] pg_restore: creating TABLE "data.pr_sys_user_grid"
[exec] pg_restore: processing item 309 TABLE pr_sys_workindexer_queue
[exec] pg_restore: creating TABLE "data.pr_sys_workindexer_queue"
[exec] pg_restore: processing item 253 TABLE pr_sysjobs
[exec] pg_restore: creating TABLE "data.pr_sysjobs"
[exec] pg_restore: processing item 330 TABLE pr_usage_summary
[exec] pg_restore: creating TABLE "data.pr_usage_summary"
[exec] pg_restore: processing item 235 TABLE prpc_ignite_server_addr
[exec] pg_restore: creating TABLE "data.prpc_ignite_server_addr"
[exec] pg_restore: processing item 522 TABLE pc_index_flowref
[exec] pg_restore: creating TABLE "rules.pc_index_flowref"
[exec] pg_restore: processing item 525 TABLE pr4_base
[exec] pg_restore: creating TABLE "rules.pr4_base"
[exec] pg_restore: processing item 527 TABLE pr4_fieldvalue
[exec] pg_restore: creating TABLE "rules.pr4_fieldvalue"
[exec] pg_restore: processing item 532 TABLE pr4_rule
[exec] pg_restore: creating TABLE "rules.pr4_rule"
[exec] pg_restore: processing item 580 TABLE pr4_rule_appconfiguration
[exec] pg_restore: creating TABLE "rules.pr4_rule_appconfiguration"
[exec] pg_restore: processing item 515 TABLE pr4_rule_application
[exec] pg_restore: creating TABLE "rules.pr4_rule_application"
[exec] pg_restore: processing item 534 TABLE pr4_rule_autotest
[exec] pg_restore: creating TABLE "rules.pr4_rule_autotest"
[exec] pg_restore: processing item 591 TABLE pr4_rule_bi_dashboard
[exec] pg_restore: creating TABLE "rules.pr4_rule_bi_dashboard"
[exec] pg_restore: processing item 595 TABLE pr4_rule_bi_insight
[exec] pg_restore: creating TABLE "rules.pr4_rule_bi_insight"
[exec] pg_restore: processing item 590 TABLE pr4_rule_bi_queryphrase
[exec] pg_restore: creating TABLE "rules.pr4_rule_bi_queryphrase"
[exec] pg_restore: processing item 589 TABLE pr4_rule_bi_theme
[exec] pg_restore: creating TABLE "rules.pr4_rule_bi_theme"
[exec] pg_restore: processing item 584 TABLE pr4_rule_clientdata
[exec] pg_restore: creating TABLE "rules.pr4_rule_clientdata"
[exec] pg_restore: processing item 583 TABLE pr4_rule_connect
[exec] pg_restore: creating TABLE "rules.pr4_rule_connect"
[exec] pg_restore: processing item 586 TABLE pr4_rule_connect_robot
[exec] pg_restore: creating TABLE "rules.pr4_rule_connect_robot"
[exec] pg_restore: processing item 597 TABLE pr4_rule_dataobject
[exec] pg_restore: creating TABLE "rules.pr4_rule_dataobject"
[exec] pg_restore: processing item 593 TABLE pr4_rule_declare_expression
[exec] pg_restore: creating TABLE "rules.pr4_rule_declare_expression"
[exec] pg_restore: processing item 542 TABLE pr4_rule_declarepages
[exec] pg_restore: creating TABLE "rules.pr4_rule_declarepages"
[exec] pg_restore: processing item 571 TABLE pr4_rule_delegationconfig
[exec] pg_restore: creating TABLE "rules.pr4_rule_delegationconfig"
[exec] pg_restore: processing item 541 TABLE pr4_rule_file
[exec] pg_restore: creating TABLE "rules.pr4_rule_file"
[exec] pg_restore: processing item 543 TABLE pr4_rule_file_binary
[exec] pg_restore: creating TABLE "rules.pr4_rule_file_binary"
[exec] pg_restore: processing item 537 TABLE pr4_rule_flow
[exec] pg_restore: creating TABLE "rules.pr4_rule_flow"
[exec] pg_restore: processing item 513 TABLE pr4_rule_guide
[exec] pg_restore: creating TABLE "rules.pr4_rule_guide"
[exec] pg_restore: processing item 514 TABLE pr4_rule_html_property
[exec] pg_restore: creating TABLE "rules.pr4_rule_html_property"
[exec] pg_restore: processing item 570 TABLE pr4_rule_library
[exec] pg_restore: creating TABLE "rules.pr4_rule_library"
[exec] pg_restore: processing item 568 TABLE pr4_rule_message
[exec] pg_restore: creating TABLE "rules.pr4_rule_message"
[exec] pg_restore: processing item 596 TABLE pr4_rule_persona
[exec] pg_restore: creating TABLE "rules.pr4_rule_persona"
[exec] pg_restore: processing item 581 TABLE pr4_rule_presentation
[exec] pg_restore: creating TABLE "rules.pr4_rule_presentation"
[exec] pg_restore: processing item 538 TABLE pr4_rule_property
[exec] pg_restore: creating TABLE "rules.pr4_rule_property"
[exec] pg_restore: processing item 582 TABLE pr4_rule_reports
[exec] pg_restore: creating TABLE "rules.pr4_rule_reports"
[exec] pg_restore: processing item 551 TABLE pr4_rule_requirement
[exec] pg_restore: creating TABLE "rules.pr4_rule_requirement"
[exec] pg_restore: processing item 539 TABLE pr4_rule_ruleset
[exec] pg_restore: creating TABLE "rules.pr4_rule_ruleset"
[exec] pg_restore: processing item 533 TABLE pr4_rule_section
[exec] pg_restore: creating TABLE "rules.pr4_rule_section"
[exec] pg_restore: processing item 575 TABLE pr4_rule_securitypolicies
[exec] pg_restore: creating TABLE "rules.pr4_rule_securitypolicies"
[exec] pg_restore: processing item 512 TABLE pr4_rule_service_rest
[exec] pg_restore: creating TABLE "rules.pr4_rule_service_rest"
[exec] pg_restore: processing item 535 TABLE pr4_rule_shortcut
[exec] pg_restore: creating TABLE "rules.pr4_rule_shortcut"
[exec] pg_restore: processing item 540 TABLE pr4_rule_sysgen
[exec] pg_restore: creating TABLE "rules.pr4_rule_sysgen"
[exec] pg_restore: processing item 572 TABLE pr4_rule_testcase
[exec] pg_restore: creating TABLE "rules.pr4_rule_testcase"
[exec] pg_restore: processing item 578 TABLE pr4_rule_testsuite
[exec] pg_restore: creating TABLE "rules.pr4_rule_testsuite"
[exec] pg_restore: processing item 552 TABLE pr4_rule_usecase
[exec] pg_restore: creating TABLE "rules.pr4_rule_usecase"
[exec] pg_restore: processing item 594 TABLE pr4_rule_view
[exec] pg_restore: creating TABLE "rules.pr4_rule_view"
[exec] pg_restore: processing item 536 TABLE pr4_rule_vw
[exec] pg_restore: creating TABLE "rules.pr4_rule_vw"
[exec] pg_restore: processing item 549 TABLE pr_app_branch_idx
[exec] pg_restore: creating TABLE "rules.pr_app_branch_idx"
[exec] pg_restore: processing item 547 TABLE pr_assembledclasses
[exec] pg_restore: creating TABLE "rules.pr_assembledclasses"
[exec] pg_restore: processing item 520 TABLE pr_changelog
[exec] pg_restore: creating TABLE "rules.pr_changelog"
[exec] pg_restore: processing item 563 TABLE pr_data_admin_product
[exec] pg_restore: creating TABLE "rules.pr_data_admin_product"
[exec] pg_restore: processing item 526 TABLE pr_data_admin_restore
[exec] pg_restore: creating TABLE "rules.pr_data_admin_restore"
[exec] pg_restore: processing item 573 TABLE pr_data_customproperties
[exec] pg_restore: creating TABLE "rules.pr_data_customproperties"
[exec] pg_restore: processing item 559 TABLE pr_data_map_entries
[exec] pg_restore: creating TABLE "rules.pr_data_map_entries"
[exec] pg_restore: processing item 553 TABLE pr_data_products
[exec] pg_restore: creating TABLE "rules.pr_data_products"
[exec] pg_restore: processing item 554 TABLE pr_data_restore
[exec] pg_restore: creating TABLE "rules.pr_data_restore"
[exec] pg_restore: processing item 561 TABLE pr_data_rule_appmetadata
[exec] pg_restore: creating TABLE "rules.pr_data_rule_appmetadata"
[exec] pg_restore: processing item 566 TABLE pr_data_scanner
[exec] pg_restore: creating TABLE "rules.pr_data_scanner"
[exec] pg_restore: processing item 546 TABLE pr_engineclasses
[exec] pg_restore: creating TABLE "rules.pr_engineclasses"
[exec] pg_restore: processing item 574 TABLE pr_index_applicationbuilton
[exec] pg_restore: creating TABLE "rules.pr_index_applicationbuilton"
[exec] pg_restore: processing item 592 TABLE pr_index_bi_permission
[exec] pg_restore: creating TABLE "rules.pr_index_bi_permission"
[exec] pg_restore: processing item 524 TABLE pr_index_circumstance_def
[exec] pg_restore: creating TABLE "rules.pr_index_circumstance_def"
[exec] pg_restore: processing item 528 TABLE pr_index_css
[exec] pg_restore: creating TABLE "rules.pr_index_css"
[exec] pg_restore: processing item 529 TABLE pr_index_customfields
[exec] pg_restore: creating TABLE "rules.pr_index_customfields"
[exec] pg_restore: processing item 579 TABLE pr_index_datasaveoptions
[exec] pg_restore: creating TABLE "rules.pr_index_datasaveoptions"
[exec] pg_restore: processing item 550 TABLE pr_index_datasources
[exec] pg_restore: creating TABLE "rules.pr_index_datasources"
[exec] pg_restore: processing item 576 TABLE pr_index_policyconditions
[exec] pg_restore: creating TABLE "rules.pr_index_policyconditions"
[exec] pg_restore: processing item 565 TABLE pr_index_privilege
[exec] pg_restore: creating TABLE "rules.pr_index_privilege"
[exec] pg_restore: processing item 531 TABLE pr_index_reference
[exec] pg_restore: creating TABLE "rules.pr_index_reference"
[exec] pg_restore: processing item 567 TABLE pr_index_rule_agents
[exec] pg_restore: creating TABLE "rules.pr_index_rule_agents"
[exec] pg_restore: processing item 530 TABLE pr_index_warnings
[exec] pg_restore: creating TABLE "rules.pr_index_warnings"
[exec] pg_restore: processing item 577 TABLE pr_link_feature
[exec] pg_restore: creating TABLE "rules.pr_link_feature"
[exec] pg_restore: processing item 523 TABLE pr_link_usecase
[exec] pg_restore: creating TABLE "rules.pr_link_usecase"
[exec] pg_restore: processing item 587 TABLE pr_migration_point
[exec] pg_restore: creating TABLE "rules.pr_migration_point"
[exec] pg_restore: processing item 562 TABLE pr_reference_page
[exec] pg_restore: creating TABLE "rules.pr_reference_page"
[exec] pg_restore: processing item 521 TABLE pr_selectquerylog
[exec] pg_restore: creating TABLE "rules.pr_selectquerylog"
[exec] pg_restore: processing item 556 TABLE pr_sys_app_hierarchy_flat
[exec] pg_restore: creating TABLE "rules.pr_sys_app_hierarchy_flat"
[exec] pg_restore: processing item 548 TABLE pr_sys_app_ruleset_index
[exec] pg_restore: creating TABLE "rules.pr_sys_app_ruleset_index"
[exec] pg_restore: processing item 557 TABLE pr_sys_appcache_dep
[exec] pg_restore: creating TABLE "rules.pr_sys_appcache_dep"
[exec] pg_restore: processing item 555 TABLE pr_sys_appcache_entry
[exec] pg_restore: creating TABLE "rules.pr_sys_appcache_entry"
[exec] pg_restore: processing item 558 TABLE pr_sys_appcache_shortcut
[exec] pg_restore: creating TABLE "rules.pr_sys_appcache_shortcut"
[exec] pg_restore: processing item 517 TABLE pr_sys_cache_dep
[exec] pg_restore: creating TABLE "rules.pr_sys_cache_dep"
[exec] pg_restore: processing item 516 TABLE pr_sys_cache_entry
[exec] pg_restore: creating TABLE "rules.pr_sys_cache_entry"
[exec] pg_restore: processing item 518 TABLE pr_sys_cache_impl
[exec] pg_restore: creating TABLE "rules.pr_sys_cache_impl"
[exec] pg_restore: processing item 519 TABLE pr_sys_class_ancestors
[exec] pg_restore: creating TABLE "rules.pr_sys_class_ancestors"
[exec] pg_restore: processing item 545 TABLE pr_sys_decchg
[exec] pg_restore: creating TABLE "rules.pr_sys_decchg"
[exec] pg_restore: processing item 569 TABLE pr_sys_hotfix_events
[exec] pg_restore: creating TABLE "rules.pr_sys_hotfix_events"
[exec] pg_restore: processing item 585 TABLE pr_sys_import_queue
[exec] pg_restore: creating TABLE "rules.pr_sys_import_queue"
[exec] pg_restore: processing item 560 TABLE pr_sys_rule_impl
[exec] pg_restore: creating TABLE "rules.pr_sys_rule_impl"
[exec] pg_restore: processing item 544 TABLE pr_sys_ruleset_index
[exec] pg_restore: creating TABLE "rules.pr_sys_ruleset_index"
[exec] pg_restore: processing item 588 TABLE pr_sys_runtime_context
[exec] pg_restore: creating TABLE "rules.pr_sys_runtime_context"
[exec] pg_restore: processing item 564 TABLE pr_sysgen_static_content
[exec] pg_restore: creating TABLE "rules.pr_sysgen_static_content"
[exec] pg_restore: processing item 601 TABLE prpc_install_log
[exec] pg_restore: creating TABLE "rules.prpc_install_log"
[exec] pg_restore: processing item 598 VIEW pwbv4_circumstance_duplicates
[exec] pg_restore: creating VIEW "rules.pwbv4_circumstance_duplicates"
[exec] pg_restore: processing item 599 VIEW pwbv4_rule_locking
[exec] pg_restore: creating VIEW "rules.pwbv4_rule_locking"
[exec] pg_restore: processing item 600 VIEW pwbv4_rule_overrides
[exec] pg_restore: creating VIEW "rules.pwbv4_rule_overrides"
[exec] pg_restore: launching item 6448 TABLE DATA p_address
[exec] pg_restore: launching item 6449 TABLE DATA p_contact
[exec] pg_restore: launching item 6444 TABLE DATA p_contactcontactrel
[exec] pg_restore: launching item 6445 TABLE DATA p_contactorgrel
[exec] pg_restore: processing data for table "data.p_address"
[exec] pg_restore: processing data for table "data.p_contactcontactrel"
[exec] pg_restore: processing data for table "data.p_contact"
[exec] pg_restore: processing data for table "data.p_contactorgrel"
[exec] pg_restore: finished item 6448 TABLE DATA p_address
[exec] pg_restore: launching item 6450 TABLE DATA p_organization
[exec] pg_restore: processing data for table "data.p_organization"
[exec] pg_restore: finished item 6444 TABLE DATA p_contactcontactrel
[exec] pg_restore: launching item 6446 TABLE DATA p_orgorgrel
[exec] pg_restore: finished item 6449 TABLE DATA p_contact
[exec] pg_restore: launching item 6447 TABLE DATA p_role
[exec] pg_restore: processing data for table "data.p_orgorgrel"
[exec] pg_restore: processing data for table "data.p_role"
[exec] pg_restore: finished item 6450 TABLE DATA p_organization
[exec] pg_restore: launching item 6377 TABLE DATA pc_apn_token
[exec] pg_restore: processing data for table "data.pc_apn_token"
[exec] pg_restore: finished item 6447 TABLE DATA p_role
[exec] pg_restore: launching item 6271 TABLE DATA pc_assign_workbasket
[exec] pg_restore: processing data for table "data.pc_assign_workbasket"
[exec] pg_restore: finished item 6445 TABLE DATA p_contactorgrel
[exec] pg_restore: launching item 6272 TABLE DATA pc_assign_worklist
[exec] pg_restore: finished item 6446 TABLE DATA p_orgorgrel
[exec] pg_restore: launching item 6334 TABLE DATA pc_cep_actions_repository
[exec] pg_restore: processing data for table "data.pc_assign_worklist"
[exec] pg_restore: processing data for table "data.pc_cep_actions_repository"
[exec] pg_restore: finished item 6377 TABLE DATA pc_apn_token
[exec] pg_restore: launching item 6335 TABLE DATA pc_cep_events_repository
[exec] pg_restore: processing data for table "data.pc_cep_events_repository"
[exec] pg_restore: finished item 6334 TABLE DATA pc_cep_actions_repository
[exec] pg_restore: launching item 6482 TABLE DATA pc_clientdata_restriction
[exec] pg_restore: finished item 6271 TABLE DATA pc_assign_workbasket
[exec] pg_restore: launching item 6248 TABLE DATA pc_data_adm_seccorspol
[exec] pg_restore: processing data for table "data.pc_clientdata_restriction"
[exec] pg_restore: pg_restore: processing data for table "data.pc_data_adm_seccorspol"
[exec] finished item 6272 TABLE DATA pc_assign_worklist
[exec] pg_restore: launching item 6249 TABLE DATA pc_data_adm_seckeyid
[exec] pg_restore: processing data for table "data.pc_data_adm_seckeyid"
[exec] pg_restore: finished item 6335 TABLE DATA pc_cep_events_repository
[exec] pg_restore: launching item 6507 TABLE DATA pc_data_file_temp
[exec] pg_restore: processing data for table "data.pc_data_file_temp"
[exec] pg_restore: finished item 6248 TABLE DATA pc_data_adm_seccorspol
[exec] pg_restore: launching item 6252 TABLE DATA pc_data_notiftn_param
[exec] pg_restore: finished item 6249 TABLE DATA pc_data_adm_seckeyid
[exec] pg_restore: launching item 6273 TABLE DATA pc_data_uniqueid
[exec] pg_restore: processing data for table "data.pc_data_notiftn_param"
[exec] pg_restore: processing data for table "data.pc_data_uniqueid"
[exec] pg_restore: finished item 6482 TABLE DATA pc_clientdata_restriction
[exec] pg_restore: launching item 6274 TABLE DATA pc_data_workattach
[exec] pg_restore: processing data for table "data.pc_data_workattach"
[exec] pg_restore: finished item 6507 TABLE DATA pc_data_file_temp
[exec] pg_restore: launching item 6281 TABLE DATA pc_events
[exec] pg_restore: processing data for table "data.pc_events"
[exec] pg_restore: finished item 6252 TABLE DATA pc_data_notiftn_param
[exec] pg_restore: launching item 6498 TABLE DATA pc_flaudit
[exec] pg_restore: processing data for table "data.pc_flaudit"
[exec] pg_restore: finished item 6273 TABLE DATA pc_data_uniqueid
[exec] pg_restore: launching item 6378 TABLE DATA pc_gcm_token
[exec] pg_restore: processing data for table "data.pc_gcm_token"
[exec] pg_restore: finished item 6274 TABLE DATA pc_data_workattach
[exec] pg_restore: launching item 6395 TABLE DATA pc_history_data_dms_work
[exec] pg_restore: processing data for table "data.pc_history_data_dms_work"
[exec] pg_restore: finished item 6498 TABLE DATA pc_flaudit
[exec] pg_restore: launching item 6493 TABLE DATA pc_history_document
[exec] pg_restore: pg_restore: processing data for table "data.pc_history_document"
[exec] finished item 6281 TABLE DATA pc_events
[exec] pg_restore: launching item 6465 TABLE DATA pc_history_group
[exec] pg_restore: finished item 6378 TABLE DATA pc_gcm_token
[exec] pg_restore: launching item 6275 TABLE DATA pc_history_work
[exec] pg_restore: processing data for table "data.pc_history_group"
[exec] pg_restore: processing data for table "data.pc_history_work"
[exec] pg_restore: finished item 6395 TABLE DATA pc_history_data_dms_work
[exec] pg_restore: launching item 6485 TABLE DATA pc_history_work_cover_task
[exec] pg_restore: processing data for table "data.pc_history_work_cover_task"
[exec] pg_restore: finished item 6465 TABLE DATA pc_history_group
[exec] pg_restore: launching item 6269 TABLE DATA pc_index_accel
[exec] pg_restore: finished item 6493 TABLE DATA pc_history_document
[exec] pg_restore: launching item 6401 TABLE DATA pc_index_location
[exec] pg_restore: finished item 6275 TABLE DATA pc_history_work
[exec] pg_restore: launching item 6276 TABLE DATA pc_index_workparty
[exec] pg_restore: processing data for table "data.pc_index_accel"
[exec] pg_restore: pg_restore: processing data for table "data.pc_index_location"
[exec] processing data for table "data.pc_index_workparty"
[exec] pg_restore: finished item 6485 TABLE DATA pc_history_work_cover_task
[exec] pg_restore: launching item 6422 TABLE DATA pc_link_association
[exec] pg_restore: processing data for table "data.pc_link_association"
[exec] pg_restore: finished item 6269 TABLE DATA pc_index_accel
[exec] pg_restore: launching item 6500 TABLE DATA pc_link_association_channel
[exec] pg_restore: processing data for table "data.pc_link_association_channel"
[exec] pg_restore: finished item 6276 TABLE DATA pc_index_workparty
[exec] pg_restore: launching item 6438 TABLE DATA pc_link_association_doc
[exec] pg_restore: processing data for table "data.pc_link_association_doc"
[exec] pg_restore: finished item 6401 TABLE DATA pc_index_location
[exec] pg_restore: launching item 6466 TABLE DATA pc_link_association_member
[exec] pg_restore: processing data for table "data.pc_link_association_member"
[exec] pg_restore: finished item 6422 TABLE DATA pc_link_association
[exec] pg_restore: launching item 6479 TABLE DATA pc_link_association_pin
[exec] pg_restore: processing data for table "data.pc_link_association_pin"
[exec] pg_restore: finished item 6500 TABLE DATA pc_link_association_channel
[exec] pg_restore: launching item 6496 TABLE DATA pc_link_association_rrcategory
[exec] pg_restore: pg_restore: processing data for table "data.pc_link_association_rrcategory"
[exec] finished item 6438 TABLE DATA pc_link_association_doc
[exec] pg_restore: launching item 6483 TABLE DATA pc_link_association_space
[exec] pg_restore: processing data for table "data.pc_link_association_space"
[exec] pg_restore: finished item 6466 TABLE DATA pc_link_association_member
[exec] pg_restore: launching item 6277 TABLE DATA pc_link_attachment
[exec] pg_restore: processing data for table "data.pc_link_attachment"
[exec] pg_restore: finished item 6483 TABLE DATA pc_link_association_space
[exec] pg_restore: launching item 6463 TABLE DATA pc_link_category
[exec] pg_restore: pg_restore: processing data for table "data.pc_link_category"
[exec] finished item 6479 TABLE DATA pc_link_association_pin
[exec] pg_restore: launching item 6278 TABLE DATA pc_link_folder
[exec] pg_restore: processing data for table "data.pc_link_folder"
[exec] pg_restore: finished item 6496 TABLE DATA pc_link_association_rrcategory
[exec] pg_restore: launching item 6304 TABLE DATA pc_link_topcase
[exec] pg_restore: processing data for table "data.pc_link_topcase"
[exec] pg_restore: finished item 6277 TABLE DATA pc_link_attachment
[exec] pg_restore: launching item 6372 TABLE DATA pc_pegatask
[exec] pg_restore: processing data for table "data.pc_pegatask"
[exec] pg_restore: finished item 6463 TABLE DATA pc_link_category
[exec] pg_restore: launching item 6280 TABLE DATA pc_schedule_task
[exec] pg_restore: processing data for table "data.pc_schedule_task"
[exec] pg_restore: finished item 6278 TABLE DATA pc_link_folder
[exec] pg_restore: launching item 6282 TABLE DATA pc_work
[exec] pg_restore: processing data for table "data.pc_work"
[exec] pg_restore: finished item 6304 TABLE DATA pc_link_topcase
[exec] pg_restore: launching item 6279 TABLE DATA pc_work_accel
[exec] pg_restore: processing data for table "data.pc_work_accel"
[exec] pg_restore: finished item 6372 TABLE DATA pc_pegatask
[exec] pg_restore: launching item 6421 TABLE DATA pc_work_agile
[exec] pg_restore: processing data for table "data.pc_work_agile"
[exec] pg_restore: finished item 6280 TABLE DATA pc_schedule_task
[exec] pg_restore: launching item 6469 TABLE DATA pc_work_clientdata
[exec] pg_restore: pg_restore: finished item 6282 TABLE DATA pc_work
[exec] pg_restore: processing data for table "data.pc_work_clientdata"
[exec] launching item 6484 TABLE DATA pc_work_cover_task
[exec] pg_restore: processing data for table "data.pc_work_cover_task"
[exec] pg_restore: finished item 6279 TABLE DATA pc_work_accel
[exec] pg_restore: launching item 6394 TABLE DATA pc_work_dms
[exec] pg_restore: processing data for table "data.pc_work_dms"
[exec] pg_restore: finished item 6421 TABLE DATA pc_work_agile
[exec] pg_restore: launching item 6437 TABLE DATA pc_work_document
[exec] pg_restore: processing data for table "data.pc_work_document"
[exec] pg_restore: finished item 6469 TABLE DATA pc_work_clientdata
[exec] pg_restore: launching item 6284 TABLE DATA pc_work_dsm_batch
[exec] pg_restore: processing data for table "data.pc_work_dsm_batch"
[exec] pg_restore: finished item 6484 TABLE DATA pc_work_cover_task
[exec] pg_restore: launching item 6515 TABLE DATA pc_work_dsm_simulation
[exec] pg_restore: processing data for table "data.pc_work_dsm_simulation"
[exec] pg_restore: finished item 6394 TABLE DATA pc_work_dms
[exec] pg_restore: launching item 6464 TABLE DATA pc_work_group
[exec] pg_restore: processing data for table "data.pc_work_group"
[exec] pg_restore: finished item 6437 TABLE DATA pc_work_document
[exec] pg_restore: launching item 6423 TABLE DATA pc_work_guide
[exec] pg_restore: finished item 6515 TABLE DATA pc_work_dsm_simulation
[exec] pg_restore: launching item 6418 TABLE DATA pc_work_notification
[exec] pg_restore: processing data for table "data.pc_work_guide"
[exec] pg_restore: pg_restore: processing data for table "data.pc_work_notification"
[exec] finished item 6284 TABLE DATA pc_work_dsm_batch
[exec] pg_restore: launching item 6511 TABLE DATA pc_work_prediction
[exec] pg_restore: processing data for table "data.pc_work_prediction"
[exec] pg_restore: finished item 6464 TABLE DATA pc_work_group
[exec] pg_restore: launching item 6283 TABLE DATA pc_work_processemail
[exec] pg_restore: processing data for table "data.pc_work_processemail"
[exec] pg_restore: finished item 6418 TABLE DATA pc_work_notification
[exec] pg_restore: launching item 6354 TABLE DATA pc_work_social
[exec] pg_restore: pg_restore: finished item 6423 TABLE DATA pc_work_guide
[exec] pg_restore: processing data for table "data.pc_work_social"
[exec] launching item 6509 TABLE DATA pc_work_triage
[exec] pg_restore: processing data for table "data.pc_work_triage"
[exec] pg_restore: finished item 6511 TABLE DATA pc_work_prediction
[exec] pg_restore: launching item 6285 TABLE DATA pi_data_connect
[exec] pg_restore: processing data for table "data.pi_data_connect"
[exec] pg_restore: finished item 6283 TABLE DATA pc_work_processemail
[exec] pg_restore: launching item 6300 TABLE DATA pr4_history_rule
[exec] pg_restore: processing data for table "data.pr4_history_rule"
[exec] pg_restore: finished item 6354 TABLE DATA pc_work_social
[exec] pg_restore: launching item 6337 TABLE DATA pr4_log_rule_usage
[exec] pg_restore: pg_restore: finished item 6509 TABLE DATA pc_work_triage
[exec] pg_restore: processing data for table "data.pr4_log_rule_usage"
[exec] launching item 6338 TABLE DATA pr4_log_rule_usage_details
[exec] pg_restore: processing data for table "data.pr4_log_rule_usage_details"
[exec] pg_restore: finished item 6285 TABLE DATA pi_data_connect
[exec] pg_restore: launching item 6523 TABLE DATA pr_archival_class_dependency
[exec] pg_restore: processing data for table "data.pr_archival_class_dependency"
[exec] pg_restore: finished item 6300 TABLE DATA pr4_history_rule
[exec] pg_restore: launching item 6286 TABLE DATA pr_assign
[exec] pg_restore: processing data for table "data.pr_assign"
[exec] pg_restore: finished item 6338 TABLE DATA pr4_log_rule_usage_details
[exec] pg_restore: launching item 6331 TABLE DATA pr_cep_events_queue
[exec] pg_restore: finished item 6337 TABLE DATA pr4_log_rule_usage
[exec] pg_restore: launching item 6332 TABLE DATA pr_cep_eventslookup
[exec] pg_restore: processing data for table "data.pr_cep_events_queue"
[exec] pg_restore: processing data for table "data.pr_cep_eventslookup"
[exec] pg_restore: finished item 6523 TABLE DATA pr_archival_class_dependency
[exec] pg_restore: launching item 6333 TABLE DATA pr_cep_user_subscriptions
[exec] pg_restore: processing data for table "data.pr_cep_user_subscriptions"
[exec] pg_restore: finished item 6331 TABLE DATA pr_cep_events_queue
[exec] pg_restore: launching item 6344 TABLE DATA pr_daily_usage
[exec] pg_restore: finished item 6332 TABLE DATA pr_cep_eventslookup
[exec] pg_restore: launching item 6288 TABLE DATA pr_data
[exec] pg_restore: finished item 6286 TABLE DATA pr_assign
[exec] pg_restore: launching item 6414 TABLE DATA pr_data_adm_configuration
[exec] pg_restore: processing data for table "data.pr_daily_usage"
[exec] pg_restore: processing data for table "data.pr_data"
[exec] pg_restore: processing data for table "data.pr_data_adm_configuration"
[exec] pg_restore: finished item 6344 TABLE DATA pr_daily_usage
[exec] pg_restore: launching item 6415 TABLE DATA pr_data_adm_factory
[exec] pg_restore: processing data for table "data.pr_data_adm_factory"
[exec] pg_restore: finished item 6333 TABLE DATA pr_cep_user_subscriptions
[exec] pg_restore: launching item 6289 TABLE DATA pr_data_admin
[exec] pg_restore: processing data for table "data.pr_data_admin"
[exec] pg_restore: finished item 6414 TABLE DATA pr_data_adm_configuration
[exec] pg_restore: launching item 6467 TABLE DATA pr_data_admin_auth_code
[exec] pg_restore: processing data for table "data.pr_data_admin_auth_code"
[exec] pg_restore: finished item 6415 TABLE DATA pr_data_adm_factory
[exec] pg_restore: launching item 6514 TABLE DATA pr_data_admin_dds_table
[exec] pg_restore: processing data for table "data.pr_data_admin_dds_table"
[exec] pg_restore: finished item 6467 TABLE DATA pr_data_admin_auth_code
[exec] pg_restore: launching item 6487 TABLE DATA pr_data_admin_sec_cert
[exec] pg_restore: processing data for table "data.pr_data_admin_sec_cert"
[exec] pg_restore: finished item 6514 TABLE DATA pr_data_admin_dds_table
[exec] pg_restore: launching item 6424 TABLE DATA pr_data_admin_sec_de_cdk
[exec] pg_restore: processing data for table "data.pr_data_admin_sec_de_cdk"
[exec] pg_restore: finished item 6487 TABLE DATA pr_data_admin_sec_cert
[exec] pg_restore: launching item 6425 TABLE DATA pr_data_admin_sec_de_key
[exec] pg_restore: processing data for table "data.pr_data_admin_sec_de_key"
[exec] pg_restore: finished item 6424 TABLE DATA pr_data_admin_sec_de_cdk
[exec] pg_restore: launching item 6457 TABLE DATA pr_data_admin_sec_sde_cdk
[exec] pg_restore: processing data for table "data.pr_data_admin_sec_sde_cdk"
[exec] pg_restore: finished item 6425 TABLE DATA pr_data_admin_sec_de_key
[exec] pg_restore: launching item 6290 TABLE DATA pr_data_admin_tenant
[exec] pg_restore: processing data for table "data.pr_data_admin_tenant"
[exec] pg_restore: finished item 6288 TABLE DATA pr_data
[exec] pg_restore: launching item 6266 TABLE DATA pr_data_analysis_specification
[exec] pg_restore: pg_restore: finished item 6289 TABLE DATA pr_data_admin
[exec] processing data for table "data.pr_data_analysis_specification"
[exec] pg_restore: launching item 6506 TABLE DATA pr_data_app_oauth2client
[exec] pg_restore: processing data for table "data.pr_data_app_oauth2client"
[exec] pg_restore: finished item 6457 TABLE DATA pr_data_admin_sec_sde_cdk
[exec] pg_restore: launching item 6513 TABLE DATA pr_data_appalias_authservice
[exec] pg_restore: processing data for table "data.pr_data_appalias_authservice"
[exec] pg_restore: finished item 6290 TABLE DATA pr_data_admin_tenant
[exec] pg_restore: launching item 6478 TABLE DATA pr_data_application_quality
[exec] pg_restore: processing data for table "data.pr_data_application_quality"
[exec] pg_restore: finished item 6266 TABLE DATA pr_data_analysis_specification
[exec] pg_restore: launching item 6435 TABLE DATA pr_data_applicationpreference
[exec] pg_restore: processing data for table "data.pr_data_applicationpreference"
[exec] pg_restore: finished item 6506 TABLE DATA pr_data_app_oauth2client
[exec] pg_restore: launching item 6270 TABLE DATA pr_data_autotest
[exec] pg_restore: processing data for table "data.pr_data_autotest"
[exec] pg_restore: finished item 6513 TABLE DATA pr_data_appalias_authservice
[exec] pg_restore: launching item 6462 TABLE DATA pr_data_category
[exec] pg_restore: processing data for table "data.pr_data_category"
[exec] pg_restore: finished item 6478 TABLE DATA pr_data_application_quality
[exec] pg_restore: launching item 6497 TABLE DATA pr_data_collaboration
[exec] pg_restore: processing data for table "data.pr_data_collaboration"
[exec] pg_restore: finished item 6270 TABLE DATA pr_data_autotest
[exec] pg_restore: launching item 6522 TABLE DATA pr_data_configuration_audit
[exec] pg_restore: finished item 6462 TABLE DATA pr_data_category
[exec] pg_restore: launching item 6517 TABLE DATA pr_data_configuration_setting
[exec] pg_restore: processing data for table "data.pr_data_configuration_audit"
[exec] pg_restore: processing data for table "data.pr_data_configuration_setting"
[exec] pg_restore: finished item 6435 TABLE DATA pr_data_applicationpreference
[exec] pg_restore: launching item 6251 TABLE DATA pr_data_custm_date_fmt
[exec] pg_restore: processing data for table "data.pr_data_custm_date_fmt"
[exec] pg_restore: finished item 6497 TABLE DATA pr_data_collaboration
[exec] pg_restore: launching item 6499 TABLE DATA pr_data_decision_biasresults
[exec] pg_restore: processing data for table "data.pr_data_decision_biasresults"
[exec] pg_restore: finished item 6522 TABLE DATA pr_data_configuration_audit
[exec] pg_restore: launching item 6397 TABLE DATA pr_data_decision_ddf_error
[exec] pg_restore: pg_restore: finished item 6251 TABLE DATA pr_data_custm_date_fmt
[exec] pg_restore: processing data for table "data.pr_data_decision_ddf_error"
[exec] launching item 6453 TABLE DATA pr_data_decision_ddf_run_opts
[exec] pg_restore: processing data for table "data.pr_data_decision_ddf_run_opts"
[exec] pg_restore: finished item 6517 TABLE DATA pr_data_configuration_setting
[exec] pg_restore: launching item 6256 TABLE DATA pr_data_decision_ddf_runtime
[exec] pg_restore: processing data for table "data.pr_data_decision_ddf_runtime"
[exec] pg_restore: finished item 6499 TABLE DATA pr_data_decision_biasresults
[exec] pg_restore: launching item 6255 TABLE DATA pr_data_decision_df_met
[exec] pg_restore: processing data for table "data.pr_data_decision_df_met"
[exec] pg_restore: finished item 6397 TABLE DATA pr_data_decision_ddf_error
[exec] pg_restore: launching item 6254 TABLE DATA pr_data_decision_df_part
[exec] pg_restore: processing data for table "data.pr_data_decision_df_part"
[exec] pg_restore: finished item 6453 TABLE DATA pr_data_decision_ddf_run_opts
[exec] pg_restore: launching item 6427 TABLE DATA pr_data_distinctvalueindex
[exec] pg_restore: pg_restore: finished item 6255 TABLE DATA pr_data_decision_df_met
[exec] pg_restore: processing data for table "data.pr_data_distinctvalueindex"
[exec] launching item 6358 TABLE DATA pr_data_dm_admmart_mdl_fact
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_dm_admmart_mdl_fact"
[exec] finished item 6256 TABLE DATA pr_data_decision_ddf_runtime
[exec] pg_restore: launching item 6357 TABLE DATA pr_data_dm_admmart_model
[exec] pg_restore: processing data for table "data.pr_data_dm_admmart_model"
[exec] pg_restore: finished item 6254 TABLE DATA pr_data_decision_df_part
[exec] pg_restore: launching item 6245 TABLE DATA pr_data_dm_admmart_pred
[exec] pg_restore: processing data for table "data.pr_data_dm_admmart_pred"
[exec] pg_restore: finished item 6427 TABLE DATA pr_data_distinctvalueindex
[exec] pg_restore: launching item 6472 TABLE DATA pr_data_dm_binarydistribution
[exec] pg_restore: processing data for table "data.pr_data_dm_binarydistribution"
[exec] pg_restore: finished item 6357 TABLE DATA pr_data_dm_admmart_model
[exec] pg_restore: launching item 6475 TABLE DATA pr_data_dm_contingencytable
[exec] pg_restore: finished item 6358 TABLE DATA pr_data_dm_admmart_mdl_fact
[exec] pg_restore: launching item 6473 TABLE DATA pr_data_dm_histogram
[exec] pg_restore: processing data for table "data.pr_data_dm_contingencytable"
[exec] pg_restore: processing data for table "data.pr_data_dm_histogram"
[exec] pg_restore: finished item 6245 TABLE DATA pr_data_dm_admmart_pred
[exec] pg_restore: launching item 6490 TABLE DATA pr_data_dm_notification
[exec] pg_restore: processing data for table "data.pr_data_dm_notification"
[exec] pg_restore: finished item 6475 TABLE DATA pr_data_dm_contingencytable
[exec] pg_restore: launching item 6474 TABLE DATA pr_data_dm_snapshot
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_dm_snapshot"
[exec] finished item 6472 TABLE DATA pr_data_dm_binarydistribution
[exec] pg_restore: launching item 6470 TABLE DATA pr_data_dmorg_dmsample_circle
[exec] pg_restore: processing data for table "data.pr_data_dmorg_dmsample_circle"
[exec] pg_restore: finished item 6473 TABLE DATA pr_data_dm_histogram
[exec] pg_restore: launching item 6386 TABLE DATA pr_data_dms_customer_data
[exec] pg_restore: processing data for table "data.pr_data_dms_customer_data"
[exec] pg_restore: finished item 6490 TABLE DATA pr_data_dm_notification
[exec] pg_restore: launching item 6387 TABLE DATA pr_data_dms_device
[exec] pg_restore: processing data for table "data.pr_data_dms_device"
[exec] pg_restore: finished item 6474 TABLE DATA pr_data_dm_snapshot
[exec] pg_restore: launching item 6390 TABLE DATA pr_data_dms_droppedcallevents
[exec] pg_restore: processing data for table "data.pr_data_dms_droppedcallevents"
[exec] pg_restore: finished item 6386 TABLE DATA pr_data_dms_customer_data
[exec] pg_restore: launching item 6391 TABLE DATA pr_data_dms_global
[exec] pg_restore: finished item 6470 TABLE DATA pr_data_dmorg_dmsample_circle
[exec] pg_restore: launching item 6388 TABLE DATA pr_data_dms_purchase
[exec] pg_restore: processing data for table "data.pr_data_dms_global"
[exec] pg_restore: processing data for table "data.pr_data_dms_purchase"
[exec] pg_restore: finished item 6390 TABLE DATA pr_data_dms_droppedcallevents
[exec] pg_restore: launching item 6389 TABLE DATA pr_data_dms_subscription
[exec] pg_restore: processing data for table "data.pr_data_dms_subscription"
[exec] pg_restore: finished item 6387 TABLE DATA pr_data_dms_device
[exec] pg_restore: launching item 6413 TABLE DATA pr_data_dms_survey_data
[exec] pg_restore: processing data for table "data.pr_data_dms_survey_data"
[exec] pg_restore: finished item 6413 TABLE DATA pr_data_dms_survey_data
[exec] pg_restore: launching item 6486 TABLE DATA pr_data_explain_simulation
[exec] pg_restore: pg_restore: finished item 6388 TABLE DATA pr_data_dms_purchase
[exec] pg_restore: processing data for table "data.pr_data_explain_simulation"
[exec] launching item 6416 TABLE DATA pr_data_features
[exec] pg_restore: processing data for table "data.pr_data_features"
[exec] pg_restore: finished item 6391 TABLE DATA pr_data_dms_global
[exec] pg_restore: launching item 6264 TABLE DATA pr_data_file
[exec] pg_restore: processing data for table "data.pr_data_file"
[exec] pg_restore: finished item 6389 TABLE DATA pr_data_dms_subscription
[exec] pg_restore: launching item 6488 TABLE DATA pr_data_full_sync_stats
[exec] pg_restore: processing data for table "data.pr_data_full_sync_stats"
[exec] pg_restore: finished item 6486 TABLE DATA pr_data_explain_simulation
[exec] pg_restore: launching item 6265 TABLE DATA pr_data_guardrails
[exec] pg_restore: processing data for table "data.pr_data_guardrails"
[exec] pg_restore: finished item 6488 TABLE DATA pr_data_full_sync_stats
[exec] pg_restore: launching item 6501 TABLE DATA pr_data_guardrails_evaluation
[exec] pg_restore: processing data for table "data.pr_data_guardrails_evaluation"
[exec] pg_restore: finished item 6264 TABLE DATA pr_data_file
[exec] pg_restore: launching item 6502 TABLE DATA pr_data_guardrails_runstatus
[exec] pg_restore: processing data for table "data.pr_data_guardrails_runstatus"
[exec] pg_restore: finished item 6265 TABLE DATA pr_data_guardrails
[exec] pg_restore: launching item 6476 TABLE DATA pr_data_healthcheck
[exec] pg_restore: processing data for table "data.pr_data_healthcheck"
[exec] pg_restore: finished item 6416 TABLE DATA pr_data_features
[exec] pg_restore: launching item 6371 TABLE DATA pr_data_ih_association
[exec] pg_restore: processing data for table "data.pr_data_ih_association"
[exec] pg_restore: finished item 6501 TABLE DATA pr_data_guardrails_evaluation
[exec] pg_restore: launching item 6362 TABLE DATA pr_data_ih_dim_action
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_action"
[exec] pg_restore: finished item 6502 TABLE DATA pr_data_guardrails_runstatus
[exec] pg_restore: launching item 6367 TABLE DATA pr_data_ih_dim_application
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_application"
[exec] pg_restore: finished item 6476 TABLE DATA pr_data_healthcheck
[exec] pg_restore: launching item 6368 TABLE DATA pr_data_ih_dim_channel
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_ih_dim_channel"
[exec] finished item 6371 TABLE DATA pr_data_ih_association
[exec] pg_restore: launching item 6366 TABLE DATA pr_data_ih_dim_context
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_context"
[exec] pg_restore: finished item 6366 TABLE DATA pr_data_ih_dim_context
[exec] pg_restore: launching item 6363 TABLE DATA pr_data_ih_dim_customer
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_customer"
[exec] pg_restore: finished item 6362 TABLE DATA pr_data_ih_dim_action
[exec] pg_restore: launching item 6426 TABLE DATA pr_data_ih_dim_journey
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_journey"
[exec] pg_restore: finished item 6367 TABLE DATA pr_data_ih_dim_application
[exec] pg_restore: launching item 6364 TABLE DATA pr_data_ih_dim_location
[exec] pg_restore: pg_restore: finished item 6368 TABLE DATA pr_data_ih_dim_channel
[exec] processing data for table "data.pr_data_ih_dim_location"
[exec] pg_restore: launching item 6365 TABLE DATA pr_data_ih_dim_operator
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_operator"
[exec] pg_restore: finished item 6364 TABLE DATA pr_data_ih_dim_location
[exec] pg_restore: launching item 6369 TABLE DATA pr_data_ih_dim_outcome
[exec] pg_restore: processing data for table "data.pr_data_ih_dim_outcome"
[exec] pg_restore: finished item 6369 TABLE DATA pr_data_ih_dim_outcome
[exec] pg_restore: launching item 6370 TABLE DATA pr_data_ih_fact
[exec] pg_restore: processing data for table "data.pr_data_ih_fact"
[exec] pg_restore: finished item 6363 TABLE DATA pr_data_ih_dim_customer
[exec] pg_restore: launching item 6477 TABLE DATA pr_data_integrationsystem
[exec] pg_restore: processing data for table "data.pr_data_integrationsystem"
[exec] pg_restore: finished item 6426 TABLE DATA pr_data_ih_dim_journey
[exec] pg_restore: launching item 6253 TABLE DATA pr_data_mobile_app_pf_asset
[exec] pg_restore: processing data for table "data.pr_data_mobile_app_pf_asset"
[exec] pg_restore: finished item 6365 TABLE DATA pr_data_ih_dim_operator
[exec] pg_restore: launching item 6376 TABLE DATA pr_data_mobile_appinfo
[exec] pg_restore: processing data for table "data.pr_data_mobile_appinfo"
[exec] pg_restore: finished item 6370 TABLE DATA pr_data_ih_fact
[exec] pg_restore: launching item 6374 TABLE DATA pr_data_mobile_asset
[exec] pg_restore: processing data for table "data.pr_data_mobile_asset"
[exec] pg_restore: finished item 6477 TABLE DATA pr_data_integrationsystem
[exec] pg_restore: launching item 6373 TABLE DATA pr_data_mobile_build
[exec] pg_restore: processing data for table "data.pr_data_mobile_build"
[exec] pg_restore: finished item 6253 TABLE DATA pr_data_mobile_app_pf_asset
[exec] pg_restore: launching item 6375 TABLE DATA pr_data_mobile_certificate
[exec] pg_restore: processing data for table "data.pr_data_mobile_certificate"
[exec] pg_restore: finished item 6376 TABLE DATA pr_data_mobile_appinfo
[exec] pg_restore: launching item 6406 TABLE DATA pr_data_mobile_device
[exec] pg_restore: processing data for table "data.pr_data_mobile_device"
[exec] pg_restore: finished item 6374 TABLE DATA pr_data_mobile_asset
[exec] pg_restore: launching item 6440 TABLE DATA pr_data_mobile_map_track
[exec] pg_restore: processing data for table "data.pr_data_mobile_map_track"
[exec] pg_restore: finished item 6373 TABLE DATA pr_data_mobile_build
[exec] pg_restore: launching item 6441 TABLE DATA pr_data_mobile_map_user
[exec] pg_restore: processing data for table "data.pr_data_mobile_map_user"
[exec] pg_restore: finished item 6375 TABLE DATA pr_data_mobile_certificate
[exec] pg_restore: launching item 6399 TABLE DATA pr_data_nlp_details
[exec] pg_restore: processing data for table "data.pr_data_nlp_details"
[exec] pg_restore: finished item 6440 TABLE DATA pr_data_mobile_map_track
[exec] pg_restore: launching item 6428 TABLE DATA pr_data_nlp_model_training
[exec] pg_restore: processing data for table "data.pr_data_nlp_model_training"
[exec] pg_restore: finished item 6406 TABLE DATA pr_data_mobile_device
[exec] pg_restore: launching item 6519 TABLE DATA pr_data_nlp_reporting
[exec] pg_restore: processing data for table "data.pr_data_nlp_reporting"
[exec] pg_restore: finished item 6441 TABLE DATA pr_data_mobile_map_user
[exec] pg_restore: launching item 6518 TABLE DATA pr_data_nlp_snapshot
[exec] pg_restore: processing data for table "data.pr_data_nlp_snapshot"
[exec] pg_restore: finished item 6399 TABLE DATA pr_data_nlp_details
[exec] pg_restore: launching item 6512 TABLE DATA pr_data_nlp_status
[exec] pg_restore: processing data for table "data.pr_data_nlp_status"
[exec] pg_restore: finished item 6428 TABLE DATA pr_data_nlp_model_training
[exec] pg_restore: launching item 6398 TABLE DATA pr_data_nlp_summary
[exec] pg_restore: processing data for table "data.pr_data_nlp_summary"
[exec] pg_restore: finished item 6519 TABLE DATA pr_data_nlp_reporting
[exec] pg_restore: launching item 6419 TABLE DATA pr_data_notification_recipient
[exec] pg_restore: processing data for table "data.pr_data_notification_recipient"
[exec] pg_restore: finished item 6518 TABLE DATA pr_data_nlp_snapshot
[exec] pg_restore: launching item 6436 TABLE DATA pr_data_offline_sync
[exec] pg_restore: processing data for table "data.pr_data_offline_sync"
[exec] pg_restore: finished item 6512 TABLE DATA pr_data_nlp_status
[exec] pg_restore: launching item 6504 TABLE DATA pr_data_op_session
[exec] pg_restore: processing data for table "data.pr_data_op_session"
[exec] pg_restore: finished item 6436 TABLE DATA pr_data_offline_sync
[exec] pg_restore: launching item 6400 TABLE DATA pr_data_pegasample_product
[exec] pg_restore: processing data for table "data.pr_data_pegasample_product"
[exec] pg_restore: finished item 6398 TABLE DATA pr_data_nlp_summary
[exec] pg_restore: launching item 6351 TABLE DATA pr_data_pmf_worklist
[exec] pg_restore: processing data for table "data.pr_data_pmf_worklist"
[exec] pg_restore: finished item 6419 TABLE DATA pr_data_notification_recipient
[exec] pg_restore: launching item 6489 TABLE DATA pr_data_qp_run_partition
[exec] pg_restore: processing data for table "data.pr_data_qp_run_partition"
[exec] pg_restore: finished item 6400 TABLE DATA pr_data_pegasample_product
[exec] pg_restore: launching item 6361 TABLE DATA pr_data_recents
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_recents"
[exec] finished item 6504 TABLE DATA pr_data_op_session
[exec] pg_restore: launching item 6291 TABLE DATA pr_data_reportcategory
[exec] pg_restore: processing data for table "data.pr_data_reportcategory"
[exec] pg_restore: finished item 6351 TABLE DATA pr_data_pmf_worklist
[exec] pg_restore: launching item 6292 TABLE DATA pr_data_reportshortcut
[exec] pg_restore: processing data for table "data.pr_data_reportshortcut"
[exec] pg_restore: finished item 6489 TABLE DATA pr_data_qp_run_partition
[exec] pg_restore: launching item 6456 TABLE DATA pr_data_repositories
[exec] pg_restore: processing data for table "data.pr_data_repositories"
[exec] pg_restore: finished item 6361 TABLE DATA pr_data_recents
[exec] pg_restore: launching item 6458 TABLE DATA pr_data_retention_policy
[exec] pg_restore: processing data for table "data.pr_data_retention_policy"
[exec] pg_restore: finished item 6291 TABLE DATA pr_data_reportcategory
[exec] pg_restore: launching item 6494 TABLE DATA pr_data_rrcategories
[exec] pg_restore: processing data for table "data.pr_data_rrcategories"
[exec] pg_restore: finished item 6292 TABLE DATA pr_data_reportshortcut
[exec] pg_restore: launching item 6434 TABLE DATA pr_data_rulecoverage_results
[exec] pg_restore: processing data for table "data.pr_data_rulecoverage_results"
[exec] pg_restore: finished item 6456 TABLE DATA pr_data_repositories
[exec] pg_restore: launching item 6409 TABLE DATA pr_data_saml_authreqcontext
[exec] pg_restore: finished item 6458 TABLE DATA pr_data_retention_policy
[exec] pg_restore: launching item 6408 TABLE DATA pr_data_saml_logininfo
[exec] pg_restore: processing data for table "data.pr_data_saml_authreqcontext"
[exec] pg_restore: processing data for table "data.pr_data_saml_logininfo"
[exec] pg_restore: finished item 6494 TABLE DATA pr_data_rrcategories
[exec] pg_restore: launching item 6411 TABLE DATA pr_data_saml_logoutreqinfo
[exec] pg_restore: pg_restore: finished item 6434 TABLE DATA pr_data_rulecoverage_results
[exec] pg_restore: processing data for table "data.pr_data_saml_logoutreqinfo"
[exec] launching item 6407 TABLE DATA pr_data_saml_replaycache
[exec] pg_restore: processing data for table "data.pr_data_saml_replaycache"
[exec] pg_restore: finished item 6409 TABLE DATA pr_data_saml_authreqcontext
[exec] pg_restore: launching item 6412 TABLE DATA pr_data_saml_requestorinfo
[exec] pg_restore: processing data for table "data.pr_data_saml_requestorinfo"
[exec] pg_restore: finished item 6408 TABLE DATA pr_data_saml_logininfo
[exec] pg_restore: launching item 6410 TABLE DATA pr_data_saml_sessioninfo
[exec] pg_restore: processing data for table "data.pr_data_saml_sessioninfo"
[exec] pg_restore: finished item 6407 TABLE DATA pr_data_saml_replaycache
[exec] pg_restore: launching item 6360 TABLE DATA pr_data_sample_shoppingcart
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_sample_shoppingcart"
[exec] finished item 6411 TABLE DATA pr_data_saml_logoutreqinfo
[exec] pg_restore: launching item 6293 TABLE DATA pr_data_sample_uidetails
[exec] pg_restore: processing data for table "data.pr_data_sample_uidetails"
[exec] pg_restore: finished item 6412 TABLE DATA pr_data_saml_requestorinfo
[exec] pg_restore: launching item 6294 TABLE DATA pr_data_samplesrcustomer
[exec] pg_restore: processing data for table "data.pr_data_samplesrcustomer"
[exec] pg_restore: finished item 6360 TABLE DATA pr_data_sample_shoppingcart
[exec] pg_restore: launching item 6295 TABLE DATA pr_data_samplesrproduct
[exec] pg_restore: finished item 6410 TABLE DATA pr_data_saml_sessioninfo
[exec] pg_restore: pg_restore: launching item 6296 TABLE DATA pr_data_samplesrpurchase
[exec] processing data for table "data.pr_data_samplesrproduct"
[exec] pg_restore: finished item 6293 TABLE DATA pr_data_sample_uidetails
[exec] pg_restore: launching item 6510 TABLE DATA pr_data_sizeestimator_config
[exec] pg_restore: processing data for table "data.pr_data_samplesrpurchase"
[exec] pg_restore: processing data for table "data.pr_data_sizeestimator_config"
[exec] pg_restore: finished item 6294 TABLE DATA pr_data_samplesrcustomer
[exec] pg_restore: launching item 6451 TABLE DATA pr_data_smsaccount
[exec] pg_restore: processing data for table "data.pr_data_smsaccount"
[exec] pg_restore: finished item 6295 TABLE DATA pr_data_samplesrproduct
[exec] pg_restore: launching item 6356 TABLE DATA pr_data_social_reference
[exec] pg_restore: processing data for table "data.pr_data_social_reference"
[exec] pg_restore: finished item 6510 TABLE DATA pr_data_sizeestimator_config
[exec] pg_restore: launching item 6432 TABLE DATA pr_data_stream_node_updates
[exec] pg_restore: processing data for table "data.pr_data_stream_node_updates"
[exec] pg_restore: finished item 6432 TABLE DATA pr_data_stream_node_updates
[exec] pg_restore: launching item 6431 TABLE DATA pr_data_stream_nodes
[exec] pg_restore: processing data for table "data.pr_data_stream_nodes"
[exec] pg_restore: finished item 6356 TABLE DATA pr_data_social_reference
[exec] pg_restore: launching item 6430 TABLE DATA pr_data_stream_sessions
[exec] pg_restore: processing data for table "data.pr_data_stream_sessions"
[exec] pg_restore: finished item 6296 TABLE DATA pr_data_samplesrpurchase
[exec] pg_restore: launching item 6246 TABLE DATA pr_data_svcinvhist
[exec] pg_restore: processing data for table "data.pr_data_svcinvhist"
[exec] pg_restore: finished item 6451 TABLE DATA pr_data_smsaccount
[exec] pg_restore: launching item 6346 TABLE DATA pr_data_tag
[exec] pg_restore: processing data for table "data.pr_data_tag"
[exec] pg_restore: finished item 6430 TABLE DATA pr_data_stream_sessions
[exec] pg_restore: launching item 6403 TABLE DATA pr_data_tag_oplink
[exec] pg_restore: processing data for table "data.pr_data_tag_oplink"
[exec] pg_restore: finished item 6431 TABLE DATA pr_data_stream_nodes
[exec] pg_restore: launching item 6404 TABLE DATA pr_data_tag_relevantrecord
[exec] pg_restore: processing data for table "data.pr_data_tag_relevantrecord"
[exec] pg_restore: finished item 6246 TABLE DATA pr_data_svcinvhist
[exec] pg_restore: launching item 6297 TABLE DATA pr_data_template_metadata
[exec] pg_restore: processing data for table "data.pr_data_template_metadata"
[exec] pg_restore: finished item 6403 TABLE DATA pr_data_tag_oplink
[exec] pg_restore: launching item 6382 TABLE DATA pr_data_testcaseresults
[exec] pg_restore: processing data for table "data.pr_data_testcaseresults"
[exec] pg_restore: finished item 6346 TABLE DATA pr_data_tag
[exec] pg_restore: launching item 6420 TABLE DATA pr_data_testsuiteresults
[exec] pg_restore: processing data for table "data.pr_data_testsuiteresults"
[exec] pg_restore: finished item 6297 TABLE DATA pr_data_template_metadata
[exec] pg_restore: launching item 6417 TABLE DATA pr_data_toggle
[exec] pg_restore: processing data for table "data.pr_data_toggle"
[exec] pg_restore: finished item 6382 TABLE DATA pr_data_testcaseresults
[exec] pg_restore: launching item 6383 TABLE DATA pr_data_token
[exec] pg_restore: processing data for table "data.pr_data_token"
[exec] pg_restore: finished item 6404 TABLE DATA pr_data_tag_relevantrecord
[exec] pg_restore: launching item 6505 TABLE DATA pr_data_token_blacklisted_jti
[exec] pg_restore: pg_restore: processing data for table "data.pr_data_token_blacklisted_jti"
[exec] finished item 6420 TABLE DATA pr_data_testsuiteresults
[exec] pg_restore: launching item 6521 TABLE DATA pr_data_user_activity
[exec] pg_restore: processing data for table "data.pr_data_user_activity"
[exec] pg_restore: finished item 6383 TABLE DATA pr_data_token
[exec] pg_restore: launching item 6405 TABLE DATA pr_database_info_table
[exec] pg_restore: processing data for table "data.pr_database_info_table"
[exec] pg_restore: finished item 6417 TABLE DATA pr_data_toggle
[exec] pg_restore: launching item 6287 TABLE DATA pr_dm_proposition
[exec] pg_restore: processing data for table "data.pr_dm_proposition"
[exec] pg_restore: finished item 6521 TABLE DATA pr_data_user_activity
[exec] pg_restore: launching item 6247 TABLE DATA pr_extract_time
[exec] pg_restore: pg_restore: processing data for table "data.pr_extract_time"
[exec] finished item 6505 TABLE DATA pr_data_token_blacklisted_jti
[exec] pg_restore: launching item 6339 TABLE DATA pr_file_store
[exec] pg_restore: processing data for table "data.pr_file_store"
[exec] pg_restore: finished item 6247 TABLE DATA pr_extract_time
[exec] pg_restore: launching item 6340 TABLE DATA pr_file_upload
[exec] pg_restore: processing data for table "data.pr_file_upload"
[exec] pg_restore: finished item 6405 TABLE DATA pr_database_info_table
[exec] pg_restore: launching item 6341 TABLE DATA pr_file_upload_fallback
[exec] pg_restore: processing data for table "data.pr_file_upload_fallback"
[exec] pg_restore: finished item 6287 TABLE DATA pr_dm_proposition
[exec] pg_restore: launching item 6298 TABLE DATA pr_history
[exec] pg_restore: processing data for table "data.pr_history"
[exec] pg_restore: finished item 6339 TABLE DATA pr_file_store
[exec] pg_restore: launching item 6299 TABLE DATA pr_history_data
[exec] pg_restore: processing data for table "data.pr_history_data"
[exec] pg_restore: finished item 6340 TABLE DATA pr_file_upload
[exec] pg_restore: launching item 6392 TABLE DATA pr_history_data_dms_customer
[exec] pg_restore: processing data for table "data.pr_history_data_dms_customer"
[exec] pg_restore: finished item 6341 TABLE DATA pr_file_upload_fallback
[exec] pg_restore: launching item 6393 TABLE DATA pr_history_data_dms_glbl
[exec] pg_restore: processing data for table "data.pr_history_data_dms_glbl"
[exec] pg_restore: finished item 6392 TABLE DATA pr_history_data_dms_customer
[exec] pg_restore: launching item 6343 TABLE DATA pr_hourly_usage
[exec] pg_restore: pg_restore: finished item 6298 TABLE DATA pr_history
[exec] pg_restore: processing data for table "data.pr_hourly_usage"
[exec] launching item 6301 TABLE DATA pr_index
[exec] pg_restore: processing data for table "data.pr_index"
[exec] pg_restore: finished item 6299 TABLE DATA pr_history_data
[exec] pg_restore: launching item 6260 TABLE DATA pr_index_accessgrouproles
[exec] pg_restore: processing data for table "data.pr_index_accessgrouproles"
[exec] pg_restore: finished item 6393 TABLE DATA pr_history_data_dms_glbl
[exec] pg_restore: launching item 6261 TABLE DATA pr_index_accessgroupwkpools
[exec] pg_restore: processing data for table "data.pr_index_accessgroupwkpools"
[exec] pg_restore: finished item 6260 TABLE DATA pr_index_accessgrouproles
[exec] pg_restore: launching item 6258 TABLE DATA pr_index_appfeatures
[exec] pg_restore: processing data for table "data.pr_index_appfeatures"
[exec] pg_restore: finished item 6343 TABLE DATA pr_hourly_usage
[exec] pg_restore: launching item 6349 TABLE DATA pr_index_assignmentdeps
[exec] pg_restore: processing data for table "data.pr_index_assignmentdeps"
[exec] pg_restore: finished item 6301 TABLE DATA pr_index
[exec] pg_restore: launching item 6309 TABLE DATA pr_index_assignmentskills
[exec] pg_restore: processing data for table "data.pr_index_assignmentskills"
[exec] pg_restore: finished item 6261 TABLE DATA pr_index_accessgroupwkpools
[exec] pg_restore: launching item 6381 TABLE DATA pr_index_data_agents
[exec] pg_restore: processing data for table "data.pr_index_data_agents"
[exec] pg_restore: finished item 6349 TABLE DATA pr_index_assignmentdeps
[exec] pg_restore: launching item 6429 TABLE DATA pr_index_distinctvalues
[exec] pg_restore: pg_restore: processing data for table "data.pr_index_distinctvalues"
[exec] finished item 6258 TABLE DATA pr_index_appfeatures
[exec] pg_restore: launching item 6263 TABLE DATA pr_index_email
[exec] pg_restore: pg_restore: processing data for table "data.pr_index_email"
[exec] finished item 6309 TABLE DATA pr_index_assignmentskills
[exec] pg_restore: launching item 6359 TABLE DATA pr_index_operator_workgroups
[exec] pg_restore: processing data for table "data.pr_index_operator_workgroups"
[exec] pg_restore: finished item 6381 TABLE DATA pr_index_data_agents
[exec] pg_restore: launching item 6308 TABLE DATA pr_index_operators
[exec] pg_restore: processing data for table "data.pr_index_operators"
[exec] pg_restore: finished item 6263 TABLE DATA pr_index_email
[exec] pg_restore: launching item 6310 TABLE DATA pr_index_operatorskills
[exec] pg_restore: processing data for table "data.pr_index_operatorskills"
[exec] pg_restore: finished item 6429 TABLE DATA pr_index_distinctvalues
[exec] pg_restore: launching item 6402 TABLE DATA pr_index_pref_notify
[exec] pg_restore: processing data for table "data.pr_index_pref_notify"
[exec] pg_restore: finished item 6359 TABLE DATA pr_index_operator_workgroups
[exec] pg_restore: launching item 6302 TABLE DATA pr_index_scheduledtask
[exec] pg_restore: processing data for table "data.pr_index_scheduledtask"
[exec] pg_restore: finished item 6308 TABLE DATA pr_index_operators
[exec] pg_restore: launching item 6355 TABLE DATA pr_index_trackstatus
[exec] pg_restore: processing data for table "data.pr_index_trackstatus"
[exec] pg_restore: finished item 6402 TABLE DATA pr_index_pref_notify
[exec] pg_restore: launching item 6508 TABLE DATA pr_index_tracktriageactions
[exec] pg_restore: processing data for table "data.pr_index_tracktriageactions"
[exec] pg_restore: finished item 6310 TABLE DATA pr_index_operatorskills
[exec] pg_restore: launching item 6262 TABLE DATA pr_index_workgroups
[exec] pg_restore: processing data for table "data.pr_index_workgroups"
[exec] pg_restore: finished item 6302 TABLE DATA pr_index_scheduledtask
[exec] pg_restore: launching item 6459 TABLE DATA pr_indexmetadata
[exec] pg_restore: processing data for table "data.pr_indexmetadata"
[exec] pg_restore: finished item 6262 TABLE DATA pr_index_workgroups
[exec] pg_restore: launching item 6455 TABLE DATA pr_jobscheduler_override
[exec] pg_restore: finished item 6355 TABLE DATA pr_index_trackstatus
[exec] pg_restore: launching item 6342 TABLE DATA pr_license_parameters
[exec] pg_restore: pg_restore: finished item 6508 TABLE DATA pr_index_tracktriageactions
[exec] pg_restore: processing data for table "data.pr_jobscheduler_override"
[exec] launching item 6303 TABLE DATA pr_link
[exec] pg_restore: processing data for table "data.pr_license_parameters"
[exec] pg_restore: processing data for table "data.pr_link"
[exec] pg_restore: finished item 6342 TABLE DATA pr_license_parameters
[exec] pg_restore: launching item 6348 TABLE DATA pr_link_dco_pmf
[exec] pg_restore: processing data for table "data.pr_link_dco_pmf"
[exec] pg_restore: finished item 6459 TABLE DATA pr_indexmetadata
[exec] pg_restore: launching item 6352 TABLE DATA pr_link_pmf_rulechanges
[exec] pg_restore: processing data for table "data.pr_link_pmf_rulechanges"
[exec] pg_restore: finished item 6455 TABLE DATA pr_jobscheduler_override
[exec] pg_restore: launching item 6347 TABLE DATA pr_link_work_tag
[exec] pg_restore: processing data for table "data.pr_link_work_tag"
[exec] pg_restore: finished item 6303 TABLE DATA pr_link
[exec] pg_restore: launching item 6305 TABLE DATA pr_log
[exec] pg_restore: processing data for table "data.pr_log"
[exec] pg_restore: finished item 6348 TABLE DATA pr_link_dco_pmf
[exec] pg_restore: launching item 6516 TABLE DATA pr_log_archivalsummary
[exec] pg_restore: processing data for table "data.pr_log_archivalsummary"
[exec] pg_restore: finished item 6352 TABLE DATA pr_link_pmf_rulechanges
[exec] pg_restore: launching item 6471 TABLE DATA pr_log_archivepurgeresults
[exec] pg_restore: processing data for table "data.pr_log_archivepurgeresults"
[exec] pg_restore: finished item 6347 TABLE DATA pr_link_work_tag
[exec] pg_restore: launching item 6353 TABLE DATA pr_log_batchstats
[exec] pg_restore: processing data for table "data.pr_log_batchstats"
[exec] pg_restore: finished item 6516 TABLE DATA pr_log_archivalsummary
[exec] pg_restore: launching item 6384 TABLE DATA pr_log_cluster
[exec] pg_restore: finished item 6305 TABLE DATA pr_log
[exec] pg_restore: launching item 6454 TABLE DATA pr_log_collaboration
[exec] pg_restore: processing data for table "data.pr_log_cluster"
[exec] pg_restore: finished item 6471 TABLE DATA pr_log_archivepurgeresults
[exec] pg_restore: launching item 6267 TABLE DATA pr_log_dataaccessaudit
[exec] pg_restore: processing data for table "data.pr_log_collaboration"
[exec] pg_restore: processing data for table "data.pr_log_dataaccessaudit"
[exec] pg_restore: finished item 6353 TABLE DATA pr_log_batchstats
[exec] pg_restore: launching item 6452 TABLE DATA pr_log_dataflow_events
[exec] pg_restore: processing data for table "data.pr_log_dataflow_events"
[exec] pg_restore: finished item 6384 TABLE DATA pr_log_cluster
[exec] pg_restore: launching item 6520 TABLE DATA pr_log_expungedcases
[exec] pg_restore: finished item 6267 TABLE DATA pr_log_dataaccessaudit
[exec] pg_restore: launching item 6491 TABLE DATA pr_log_indexing_progress
[exec] pg_restore: processing data for table "data.pr_log_expungedcases"
[exec] pg_restore: finished item 6454 TABLE DATA pr_log_collaboration
[exec] pg_restore: launching item 6433 TABLE DATA pr_log_jobs_scheduler
[exec] pg_restore: processing data for table "data.pr_log_indexing_progress"
[exec] pg_restore: processing data for table "data.pr_log_jobs_scheduler"
[exec] pg_restore: finished item 6452 TABLE DATA pr_log_dataflow_events
[exec] pg_restore: launching item 6396 TABLE DATA pr_log_progress
[exec] pg_restore: finished item 6491 TABLE DATA pr_log_indexing_progress
[exec] pg_restore: launching item 6259 TABLE DATA pr_log_reportstats
[exec] pg_restore: finished item 6433 TABLE DATA pr_log_jobs_scheduler
[exec] pg_restore: launching item 6350 TABLE DATA pr_log_securityaudit
[exec] pg_restore: processing data for table "data.pr_log_progress"
[exec] pg_restore: processing data for table "data.pr_log_reportstats"
[exec] pg_restore: processing data for table "data.pr_log_securityaudit"
[exec] pg_restore: finished item 6520 TABLE DATA pr_log_expungedcases
[exec] pg_restore: launching item 6495 TABLE DATA pr_log_service_email
[exec] pg_restore: processing data for table "data.pr_log_service_email"
[exec] pg_restore: finished item 6396 TABLE DATA pr_log_progress
[exec] pg_restore: launching item 6385 TABLE DATA pr_log_systemstate
[exec] pg_restore: pg_restore: finished item 6259 TABLE DATA pr_log_reportstats
[exec] processing data for table "data.pr_log_systemstate"
[exec] pg_restore: launching item 6460 TABLE DATA pr_metadata
[exec] pg_restore: pg_restore: processing data for table "data.pr_metadata"
[exec] finished item 6350 TABLE DATA pr_log_securityaudit
[exec] pg_restore: launching item 6257 TABLE DATA pr_notification_channels
[exec] pg_restore: processing data for table "data.pr_notification_channels"
[exec] pg_restore: finished item 6495 TABLE DATA pr_log_service_email
[exec] pg_restore: launching item 6443 TABLE DATA pr_offline_attachment_mapping
[exec] pg_restore: processing data for table "data.pr_offline_attachment_mapping"
[exec] pg_restore: finished item 6385 TABLE DATA pr_log_systemstate
[exec] pg_restore: launching item 6442 TABLE DATA pr_offline_attachment_stub
[exec] pg_restore: finished item 6460 TABLE DATA pr_metadata
[exec] pg_restore: launching item 6314 TABLE DATA pr_offline_pack
[exec] pg_restore: processing data for table "data.pr_offline_attachment_stub"
[exec] pg_restore: processing data for table "data.pr_offline_pack"
[exec] pg_restore: finished item 6257 TABLE DATA pr_notification_channels
[exec] pg_restore: launching item 6480 TABLE DATA pr_offline_sync_requests
[exec] pg_restore: processing data for table "data.pr_offline_sync_requests"
[exec] pg_restore: finished item 6443 TABLE DATA pr_offline_attachment_mapping
[exec] pg_restore: launching item 6481 TABLE DATA pr_offline_sync_requests_info
[exec] pg_restore: processing data for table "data.pr_offline_sync_requests_info"
[exec] pg_restore: finished item 6442 TABLE DATA pr_offline_attachment_stub
[exec] pg_restore: launching item 6307 TABLE DATA pr_operator_prefs
[exec] pg_restore: processing data for table "data.pr_operator_prefs"
[exec] pg_restore: finished item 6314 TABLE DATA pr_offline_pack
[exec] pg_restore: launching item 6306 TABLE DATA pr_operators
[exec] pg_restore: processing data for table "data.pr_operators"
[exec] pg_restore: finished item 6481 TABLE DATA pr_offline_sync_requests_info
[exec] pg_restore: launching item 6311 TABLE DATA pr_other
[exec] pg_restore: processing data for table "data.pr_other"
[exec] pg_restore: finished item 6480 TABLE DATA pr_offline_sync_requests
[exec] pg_restore: launching item 6313 TABLE DATA pr_page_store
[exec] pg_restore: processing data for table "data.pr_page_store"
[exec] pg_restore: finished item 6307 TABLE DATA pr_operator_prefs
[exec] pg_restore: launching item 6336 TABLE DATA pr_perf_stats
[exec] pg_restore: processing data for table "data.pr_perf_stats"
[exec] pg_restore: finished item 6311 TABLE DATA pr_other
[exec] pg_restore: launching item 6312 TABLE DATA pr_portal_state
[exec] pg_restore: processing data for table "data.pr_portal_state"
[exec] pg_restore: finished item 6313 TABLE DATA pr_page_store
[exec] pg_restore: launching item 6492 TABLE DATA pr_sys_bi_publisheddatamodel
[exec] pg_restore: pg_restore: finished item 6306 TABLE DATA pr_operators
[exec] pg_restore: processing data for table "data.pr_sys_bi_publisheddatamodel"
[exec] launching item 6315 TABLE DATA pr_sys_context
[exec] pg_restore: processing data for table "data.pr_sys_context"
[exec] pg_restore: finished item 6336 TABLE DATA pr_perf_stats
[exec] pg_restore: launching item 6468 TABLE DATA pr_sys_delayed_queue
[exec] pg_restore: processing data for table "data.pr_sys_delayed_queue"
[exec] pg_restore: finished item 6312 TABLE DATA pr_portal_state
[exec] pg_restore: launching item 6316 TABLE DATA pr_sys_locks
[exec] pg_restore: processing data for table "data.pr_sys_locks"
[exec] pg_restore: finished item 6492 TABLE DATA pr_sys_bi_publisheddatamodel
[exec] pg_restore: launching item 6461 TABLE DATA pr_sys_msg_qp_brokenitems
[exec] pg_restore: processing data for table "data.pr_sys_msg_qp_brokenitems"
[exec] pg_restore: finished item 6315 TABLE DATA pr_sys_context
[exec] pg_restore: launching item 6323 TABLE DATA pr_sys_queue_autotest
[exec] pg_restore: processing data for table "data.pr_sys_queue_autotest"
[exec] pg_restore: finished item 6316 TABLE DATA pr_sys_locks
[exec] pg_restore: launching item 6329 TABLE DATA pr_sys_queue_col_pop
[exec] pg_restore: processing data for table "data.pr_sys_queue_col_pop"
[exec] pg_restore: finished item 6461 TABLE DATA pr_sys_msg_qp_brokenitems
[exec] pg_restore: launching item 6330 TABLE DATA pr_sys_queue_count
[exec] pg_restore: pg_restore: processing data for table "data.pr_sys_queue_count"
[exec] finished item 6323 TABLE DATA pr_sys_queue_autotest
[exec] pg_restore: launching item 6327 TABLE DATA pr_sys_queue_execreq_conn
[exec] pg_restore: processing data for table "data.pr_sys_queue_execreq_conn"
[exec] pg_restore: finished item 6329 TABLE DATA pr_sys_queue_col_pop
[exec] pg_restore: launching item 6326 TABLE DATA pr_sys_queue_execreq_svc
[exec] pg_restore: pg_restore: processing data for table "data.pr_sys_queue_execreq_svc"
[exec] finished item 6468 TABLE DATA pr_sys_delayed_queue
[exec] pg_restore: launching item 6439 TABLE DATA pr_sys_queue_ftsconflict
[exec] pg_restore: processing data for table "data.pr_sys_queue_ftsconflict"
[exec] pg_restore: finished item 6327 TABLE DATA pr_sys_queue_execreq_conn
[exec] pg_restore: launching item 6380 TABLE DATA pr_sys_queue_ftsindexer
[exec] pg_restore: pg_restore: processing data for table "data.pr_sys_queue_ftsindexer"
[exec] finished item 6330 TABLE DATA pr_sys_queue_count
[exec] pg_restore: launching item 6325 TABLE DATA pr_sys_queue_sla
[exec] pg_restore: processing data for table "data.pr_sys_queue_sla"
[exec] pg_restore: finished item 6326 TABLE DATA pr_sys_queue_execreq_svc
[exec] pg_restore: launching item 6328 TABLE DATA pr_sys_queue_startflows
[exec] pg_restore: processing data for table "data.pr_sys_queue_startflows"
[exec] pg_restore: finished item 6439 TABLE DATA pr_sys_queue_ftsconflict
[exec] pg_restore: launching item 6322 TABLE DATA pr_sys_queues
[exec] pg_restore: processing data for table "data.pr_sys_queues"
[exec] pg_restore: finished item 6325 TABLE DATA pr_sys_queue_sla
[exec] pg_restore: launching item 6317 TABLE DATA pr_sys_serviceregistry
[exec] pg_restore: processing data for table "data.pr_sys_serviceregistry"
[exec] pg_restore: finished item 6380 TABLE DATA pr_sys_queue_ftsindexer
[exec] pg_restore: launching item 6318 TABLE DATA pr_sys_serviceregistry_kvs
[exec] pg_restore: processing data for table "data.pr_sys_serviceregistry_kvs"
[exec] pg_restore: finished item 6328 TABLE DATA pr_sys_queue_startflows
[exec] pg_restore: launching item 6379 TABLE DATA pr_sys_statusdetails
[exec] pg_restore: processing data for table "data.pr_sys_statusdetails"
[exec] pg_restore: finished item 6322 TABLE DATA pr_sys_queues
[exec] pg_restore: launching item 6319 TABLE DATA pr_sys_statusnodes
[exec] pg_restore: processing data for table "data.pr_sys_statusnodes"
[exec] pg_restore: finished item 6317 TABLE DATA pr_sys_serviceregistry
[exec] pg_restore: launching item 6320 TABLE DATA pr_sys_updatescache
[exec] pg_restore: processing data for table "data.pr_sys_updatescache"
[exec] pg_restore: finished item 6318 TABLE DATA pr_sys_serviceregistry_kvs
[exec] pg_restore: launching item 6321 TABLE DATA pr_sys_user
[exec] pg_restore: processing data for table "data.pr_sys_user"
[exec] pg_restore: finished item 6379 TABLE DATA pr_sys_statusdetails
[exec] pg_restore: launching item 6503 TABLE DATA pr_sys_user_grid
[exec] pg_restore: pg_restore: finished item 6319 TABLE DATA pr_sys_statusnodes
[exec] pg_restore: processing data for table "data.pr_sys_user_grid"
[exec] launching item 6324 TABLE DATA pr_sys_workindexer_queue
[exec] pg_restore: processing data for table "data.pr_sys_workindexer_queue"
[exec] pg_restore: finished item 6321 TABLE DATA pr_sys_user
[exec] pg_restore: launching item 6268 TABLE DATA pr_sysjobs
[exec] pg_restore: finished item 6503 TABLE DATA pr_sys_user_grid
[exec] pg_restore: launching item 6345 TABLE DATA pr_usage_summary
[exec] pg_restore: processing data for table "data.pr_sysjobs"
[exec] pg_restore: processing data for table "data.pr_usage_summary"
[exec] pg_restore: finished item 6320 TABLE DATA pr_sys_updatescache
[exec] pg_restore: launching item 6250 TABLE DATA prpc_ignite_server_addr
[exec] pg_restore: processing data for table "data.prpc_ignite_server_addr"
[exec] pg_restore: finished item 6345 TABLE DATA pr_usage_summary
[exec] pg_restore: launching item 6534 TABLE DATA pc_index_flowref
[exec] pg_restore: processing data for table "rules.pc_index_flowref"
[exec] pg_restore: finished item 6250 TABLE DATA prpc_ignite_server_addr
[exec] pg_restore: launching item 6537 TABLE DATA pr4_base
[exec] pg_restore: processing data for table "rules.pr4_base"
[exec] pg_restore: finished item 6324 TABLE DATA pr_sys_workindexer_queue
[exec] pg_restore: launching item 6539 TABLE DATA pr4_fieldvalue
[exec] pg_restore: processing data for table "rules.pr4_fieldvalue"
[exec] pg_restore: finished item 6268 TABLE DATA pr_sysjobs
[exec] pg_restore: launching item 6544 TABLE DATA pr4_rule
[exec] pg_restore: processing data for table "rules.pr4_rule"
[exec] pg_restore: finished item 6534 TABLE DATA pc_index_flowref
[exec] pg_restore: launching item 6592 TABLE DATA pr4_rule_appconfiguration
[exec] pg_restore: processing data for table "rules.pr4_rule_appconfiguration"
[exec] pg_restore: finished item 6592 TABLE DATA pr4_rule_appconfiguration
[exec] pg_restore: launching item 6527 TABLE DATA pr4_rule_application
[exec] pg_restore: processing data for table "rules.pr4_rule_application"
[exec] pg_restore: finished item 6527 TABLE DATA pr4_rule_application
[exec] pg_restore: launching item 6546 TABLE DATA pr4_rule_autotest
[exec] pg_restore: processing data for table "rules.pr4_rule_autotest"
[exec] pg_restore: finished item 6546 TABLE DATA pr4_rule_autotest
[exec] pg_restore: launching item 6603 TABLE DATA pr4_rule_bi_dashboard
[exec] pg_restore: processing data for table "rules.pr4_rule_bi_dashboard"
[exec] pg_restore: finished item 6603 TABLE DATA pr4_rule_bi_dashboard
[exec] pg_restore: launching item 6607 TABLE DATA pr4_rule_bi_insight
[exec] pg_restore: processing data for table "rules.pr4_rule_bi_insight"
[exec] pg_restore: finished item 6607 TABLE DATA pr4_rule_bi_insight
[exec] pg_restore: launching item 6602 TABLE DATA pr4_rule_bi_queryphrase
[exec] pg_restore: processing data for table "rules.pr4_rule_bi_queryphrase"
[exec] pg_restore: finished item 6602 TABLE DATA pr4_rule_bi_queryphrase
[exec] pg_restore: launching item 6601 TABLE DATA pr4_rule_bi_theme
[exec] pg_restore: processing data for table "rules.pr4_rule_bi_theme"
[exec] pg_restore: finished item 6601 TABLE DATA pr4_rule_bi_theme
[exec] pg_restore: launching item 6596 TABLE DATA pr4_rule_clientdata
[exec] pg_restore: processing data for table "rules.pr4_rule_clientdata"
[exec] pg_restore: finished item 6596 TABLE DATA pr4_rule_clientdata
[exec] pg_restore: launching item 6595 TABLE DATA pr4_rule_connect
[exec] pg_restore: processing data for table "rules.pr4_rule_connect"
[exec] pg_restore: finished item 6595 TABLE DATA pr4_rule_connect
[exec] pg_restore: launching item 6598 TABLE DATA pr4_rule_connect_robot
[exec] pg_restore: processing data for table "rules.pr4_rule_connect_robot"
[exec] pg_restore: finished item 6598 TABLE DATA pr4_rule_connect_robot
[exec] pg_restore: launching item 6609 TABLE DATA pr4_rule_dataobject
[exec] pg_restore: processing data for table "rules.pr4_rule_dataobject"
[exec] pg_restore: finished item 6609 TABLE DATA pr4_rule_dataobject
[exec] pg_restore: launching item 6605 TABLE DATA pr4_rule_declare_expression
[exec] pg_restore: processing data for table "rules.pr4_rule_declare_expression"
[exec] pg_restore: finished item 6605 TABLE DATA pr4_rule_declare_expression
[exec] pg_restore: launching item 6554 TABLE DATA pr4_rule_declarepages
[exec] pg_restore: processing data for table "rules.pr4_rule_declarepages"
[exec] pg_restore: finished item 6554 TABLE DATA pr4_rule_declarepages
[exec] pg_restore: launching item 6583 TABLE DATA pr4_rule_delegationconfig
[exec] pg_restore: processing data for table "rules.pr4_rule_delegationconfig"
[exec] pg_restore: finished item 6583 TABLE DATA pr4_rule_delegationconfig
[exec] pg_restore: launching item 6553 TABLE DATA pr4_rule_file
[exec] pg_restore: processing data for table "rules.pr4_rule_file"
[exec] pg_restore: finished item 6537 TABLE DATA pr4_base
[exec] pg_restore: launching item 6555 TABLE DATA pr4_rule_file_binary
[exec] pg_restore: processing data for table "rules.pr4_rule_file_binary"
[exec] pg_restore: finished item 6539 TABLE DATA pr4_fieldvalue
[exec] pg_restore: launching item 6549 TABLE DATA pr4_rule_flow
[exec] pg_restore: processing data for table "rules.pr4_rule_flow"
[exec] pg_restore: finished item 6553 TABLE DATA pr4_rule_file
[exec] pg_restore: launching item 6525 TABLE DATA pr4_rule_guide
[exec] pg_restore: processing data for table "rules.pr4_rule_guide"
[exec] pg_restore: finished item 6525 TABLE DATA pr4_rule_guide
[exec] pg_restore: launching item 6526 TABLE DATA pr4_rule_html_property
[exec] pg_restore: processing data for table "rules.pr4_rule_html_property"
[exec] pg_restore: finished item 6549 TABLE DATA pr4_rule_flow
[exec] pg_restore: launching item 6582 TABLE DATA pr4_rule_library
[exec] pg_restore: processing data for table "rules.pr4_rule_library"
[exec] pg_restore: finished item 6526 TABLE DATA pr4_rule_html_property
[exec] pg_restore: launching item 6580 TABLE DATA pr4_rule_message
[exec] pg_restore: processing data for table "rules.pr4_rule_message"
[exec] pg_restore: finished item 6582 TABLE DATA pr4_rule_library
[exec] pg_restore: launching item 6608 TABLE DATA pr4_rule_persona
[exec] pg_restore: processing data for table "rules.pr4_rule_persona"
[exec] pg_restore: finished item 6608 TABLE DATA pr4_rule_persona
[exec] pg_restore: launching item 6593 TABLE DATA pr4_rule_presentation
[exec] pg_restore: processing data for table "rules.pr4_rule_presentation"
[exec] pg_restore: finished item 6593 TABLE DATA pr4_rule_presentation
[exec] pg_restore: launching item 6550 TABLE DATA pr4_rule_property
[exec] pg_restore: processing data for table "rules.pr4_rule_property"
[exec] pg_restore: finished item 6580 TABLE DATA pr4_rule_message
[exec] pg_restore: launching item 6594 TABLE DATA pr4_rule_reports
[exec] pg_restore: processing data for table "rules.pr4_rule_reports"
[exec] pg_restore: finished item 6594 TABLE DATA pr4_rule_reports
[exec] pg_restore: launching item 6563 TABLE DATA pr4_rule_requirement
[exec] pg_restore: processing data for table "rules.pr4_rule_requirement"
[exec] pg_restore: finished item 6563 TABLE DATA pr4_rule_requirement
[exec] pg_restore: launching item 6551 TABLE DATA pr4_rule_ruleset
[exec] pg_restore: processing data for table "rules.pr4_rule_ruleset"
[exec] pg_restore: finished item 6551 TABLE DATA pr4_rule_ruleset
[exec] pg_restore: launching item 6545 TABLE DATA pr4_rule_section
[exec] pg_restore: processing data for table "rules.pr4_rule_section"
[exec] pg_restore: finished item 6550 TABLE DATA pr4_rule_property
[exec] pg_restore: launching item 6587 TABLE DATA pr4_rule_securitypolicies
[exec] pg_restore: processing data for table "rules.pr4_rule_securitypolicies"
[exec] pg_restore: finished item 6587 TABLE DATA pr4_rule_securitypolicies
[exec] pg_restore: launching item 6524 TABLE DATA pr4_rule_service_rest
[exec] pg_restore: processing data for table "rules.pr4_rule_service_rest"
[exec] pg_restore: finished item 6524 TABLE DATA pr4_rule_service_rest
[exec] pg_restore: launching item 6547 TABLE DATA pr4_rule_shortcut
[exec] pg_restore: processing data for table "rules.pr4_rule_shortcut"
[exec] pg_restore: finished item 6547 TABLE DATA pr4_rule_shortcut
[exec] pg_restore: launching item 6552 TABLE DATA pr4_rule_sysgen
[exec] pg_restore: processing data for table "rules.pr4_rule_sysgen"
[exec] pg_restore: finished item 6552 TABLE DATA pr4_rule_sysgen
[exec] pg_restore: launching item 6584 TABLE DATA pr4_rule_testcase
[exec] pg_restore: processing data for table "rules.pr4_rule_testcase"
[exec] pg_restore: finished item 6584 TABLE DATA pr4_rule_testcase
[exec] pg_restore: launching item 6590 TABLE DATA pr4_rule_testsuite
[exec] pg_restore: processing data for table "rules.pr4_rule_testsuite"
[exec] pg_restore: finished item 6590 TABLE DATA pr4_rule_testsuite
[exec] pg_restore: launching item 6564 TABLE DATA pr4_rule_usecase
[exec] pg_restore: processing data for table "rules.pr4_rule_usecase"
[exec] pg_restore: finished item 6564 TABLE DATA pr4_rule_usecase
[exec] pg_restore: launching item 6606 TABLE DATA pr4_rule_view
[exec] pg_restore: processing data for table "rules.pr4_rule_view"
[exec] pg_restore: finished item 6606 TABLE DATA pr4_rule_view
[exec] pg_restore: launching item 6548 TABLE DATA pr4_rule_vw
[exec] pg_restore: processing data for table "rules.pr4_rule_vw"
[exec] pg_restore: finished item 6555 TABLE DATA pr4_rule_file_binary
[exec] pg_restore: launching item 6561 TABLE DATA pr_app_branch_idx
[exec] pg_restore: processing data for table "rules.pr_app_branch_idx"
[exec] pg_restore: finished item 6561 TABLE DATA pr_app_branch_idx
[exec] pg_restore: launching item 6559 TABLE DATA pr_assembledclasses
[exec] pg_restore: processing data for table "rules.pr_assembledclasses"
[exec] pg_restore: finished item 6548 TABLE DATA pr4_rule_vw
[exec] pg_restore: launching item 6532 TABLE DATA pr_changelog
[exec] pg_restore: processing data for table "rules.pr_changelog"
[exec] pg_restore: finished item 6532 TABLE DATA pr_changelog
[exec] pg_restore: launching item 6575 TABLE DATA pr_data_admin_product
[exec] pg_restore: processing data for table "rules.pr_data_admin_product"
[exec] pg_restore: finished item 6575 TABLE DATA pr_data_admin_product
[exec] pg_restore: launching item 6538 TABLE DATA pr_data_admin_restore
[exec] pg_restore: processing data for table "rules.pr_data_admin_restore"
[exec] pg_restore: finished item 6538 TABLE DATA pr_data_admin_restore
[exec] pg_restore: launching item 6585 TABLE DATA pr_data_customproperties
[exec] pg_restore: processing data for table "rules.pr_data_customproperties"
[exec] pg_restore: finished item 6585 TABLE DATA pr_data_customproperties
[exec] pg_restore: launching item 6571 TABLE DATA pr_data_map_entries
[exec] pg_restore: processing data for table "rules.pr_data_map_entries"
[exec] pg_restore: finished item 6571 TABLE DATA pr_data_map_entries
[exec] pg_restore: launching item 6565 TABLE DATA pr_data_products
[exec] pg_restore: processing data for table "rules.pr_data_products"
[exec] pg_restore: finished item 6565 TABLE DATA pr_data_products
[exec] pg_restore: launching item 6566 TABLE DATA pr_data_restore
[exec] pg_restore: processing data for table "rules.pr_data_restore"
[exec] pg_restore: finished item 6566 TABLE DATA pr_data_restore
[exec] pg_restore: launching item 6573 TABLE DATA pr_data_rule_appmetadata
[exec] pg_restore: processing data for table "rules.pr_data_rule_appmetadata"
[exec] pg_restore: finished item 6573 TABLE DATA pr_data_rule_appmetadata
[exec] pg_restore: launching item 6578 TABLE DATA pr_data_scanner
[exec] pg_restore: processing data for table "rules.pr_data_scanner"
[exec] pg_restore: finished item 6578 TABLE DATA pr_data_scanner
[exec] pg_restore: launching item 6558 TABLE DATA pr_engineclasses
[exec] pg_restore: processing data for table "rules.pr_engineclasses"
[exec] pg_restore: finished item 6545 TABLE DATA pr4_rule_section
[exec] pg_restore: launching item 6586 TABLE DATA pr_index_applicationbuilton
[exec] pg_restore: processing data for table "rules.pr_index_applicationbuilton"
[exec] pg_restore: finished item 6586 TABLE DATA pr_index_applicationbuilton
[exec] pg_restore: launching item 6604 TABLE DATA pr_index_bi_permission
[exec] pg_restore: processing data for table "rules.pr_index_bi_permission"
[exec] pg_restore: finished item 6604 TABLE DATA pr_index_bi_permission
[exec] pg_restore: launching item 6536 TABLE DATA pr_index_circumstance_def
[exec] pg_restore: processing data for table "rules.pr_index_circumstance_def"
[exec] pg_restore: finished item 6544 TABLE DATA pr4_rule
[exec] pg_restore: launching item 6540 TABLE DATA pr_index_css
[exec] pg_restore: processing data for table "rules.pr_index_css"
[exec] pg_restore: finished item 6536 TABLE DATA pr_index_circumstance_def
[exec] pg_restore: launching item 6541 TABLE DATA pr_index_customfields
[exec] pg_restore: processing data for table "rules.pr_index_customfields"
[exec] pg_restore: finished item 6541 TABLE DATA pr_index_customfields
[exec] pg_restore: launching item 6591 TABLE DATA pr_index_datasaveoptions
[exec] pg_restore: processing data for table "rules.pr_index_datasaveoptions"
[exec] pg_restore: finished item 6591 TABLE DATA pr_index_datasaveoptions
[exec] pg_restore: launching item 6562 TABLE DATA pr_index_datasources
[exec] pg_restore: processing data for table "rules.pr_index_datasources"
[exec] pg_restore: finished item 6562 TABLE DATA pr_index_datasources
[exec] pg_restore: launching item 6588 TABLE DATA pr_index_policyconditions
[exec] pg_restore: processing data for table "rules.pr_index_policyconditions"
[exec] pg_restore: finished item 6588 TABLE DATA pr_index_policyconditions
[exec] pg_restore: launching item 6577 TABLE DATA pr_index_privilege
[exec] pg_restore: processing data for table "rules.pr_index_privilege"
[exec] pg_restore: finished item 6577 TABLE DATA pr_index_privilege
[exec] pg_restore: launching item 6543 TABLE DATA pr_index_reference
[exec] pg_restore: processing data for table "rules.pr_index_reference"
[exec] pg_restore: finished item 6540 TABLE DATA pr_index_css
[exec] pg_restore: launching item 6579 TABLE DATA pr_index_rule_agents
[exec] pg_restore: processing data for table "rules.pr_index_rule_agents"
[exec] pg_restore: finished item 6579 TABLE DATA pr_index_rule_agents
[exec] pg_restore: launching item 6542 TABLE DATA pr_index_warnings
[exec] pg_restore: processing data for table "rules.pr_index_warnings"
[exec] pg_restore: finished item 6542 TABLE DATA pr_index_warnings
[exec] pg_restore: launching item 6589 TABLE DATA pr_link_feature
[exec] pg_restore: processing data for table "rules.pr_link_feature"
[exec] pg_restore: finished item 6589 TABLE DATA pr_link_feature
[exec] pg_restore: launching item 6535 TABLE DATA pr_link_usecase
[exec] pg_restore: processing data for table "rules.pr_link_usecase"
[exec] pg_restore: finished item 6535 TABLE DATA pr_link_usecase
[exec] pg_restore: launching item 6599 TABLE DATA pr_migration_point
[exec] pg_restore: processing data for table "rules.pr_migration_point"
[exec] pg_restore: finished item 6599 TABLE DATA pr_migration_point
[exec] pg_restore: launching item 6574 TABLE DATA pr_reference_page
[exec] pg_restore: processing data for table "rules.pr_reference_page"
[exec] pg_restore: finished item 6574 TABLE DATA pr_reference_page
[exec] pg_restore: launching item 6533 TABLE DATA pr_selectquerylog
[exec] pg_restore: processing data for table "rules.pr_selectquerylog"
[exec] pg_restore: finished item 6533 TABLE DATA pr_selectquerylog
[exec] pg_restore: launching item 6568 TABLE DATA pr_sys_app_hierarchy_flat
[exec] pg_restore: processing data for table "rules.pr_sys_app_hierarchy_flat"
[exec] pg_restore: finished item 6568 TABLE DATA pr_sys_app_hierarchy_flat
[exec] pg_restore: launching item 6560 TABLE DATA pr_sys_app_ruleset_index
[exec] pg_restore: processing data for table "rules.pr_sys_app_ruleset_index"
[exec] pg_restore: finished item 6560 TABLE DATA pr_sys_app_ruleset_index
[exec] pg_restore: launching item 6569 TABLE DATA pr_sys_appcache_dep
[exec] pg_restore: processing data for table "rules.pr_sys_appcache_dep"
[exec] pg_restore: finished item 6569 TABLE DATA pr_sys_appcache_dep
[exec] pg_restore: launching item 6567 TABLE DATA pr_sys_appcache_entry
[exec] pg_restore: processing data for table "rules.pr_sys_appcache_entry"
[exec] pg_restore: finished item 6567 TABLE DATA pr_sys_appcache_entry
[exec] pg_restore: launching item 6570 TABLE DATA pr_sys_appcache_shortcut
[exec] pg_restore: processing data for table "rules.pr_sys_appcache_shortcut"
[exec] pg_restore: finished item 6570 TABLE DATA pr_sys_appcache_shortcut
[exec] pg_restore: launching item 6529 TABLE DATA pr_sys_cache_dep
[exec] pg_restore: processing data for table "rules.pr_sys_cache_dep"
[exec] pg_restore: finished item 6529 TABLE DATA pr_sys_cache_dep
[exec] pg_restore: launching item 6528 TABLE DATA pr_sys_cache_entry
[exec] pg_restore: processing data for table "rules.pr_sys_cache_entry"
[exec] pg_restore: finished item 6528 TABLE DATA pr_sys_cache_entry
[exec] pg_restore: launching item 6530 TABLE DATA pr_sys_cache_impl
[exec] pg_restore: processing data for table "rules.pr_sys_cache_impl"
[exec] pg_restore: finished item 6530 TABLE DATA pr_sys_cache_impl
[exec] pg_restore: launching item 6531 TABLE DATA pr_sys_class_ancestors
[exec] pg_restore: processing data for table "rules.pr_sys_class_ancestors"
[exec] pg_restore: finished item 6531 TABLE DATA pr_sys_class_ancestors
[exec] pg_restore: launching item 6557 TABLE DATA pr_sys_decchg
[exec] pg_restore: processing data for table "rules.pr_sys_decchg"
[exec] pg_restore: finished item 6557 TABLE DATA pr_sys_decchg
[exec] pg_restore: launching item 6581 TABLE DATA pr_sys_hotfix_events
[exec] pg_restore: processing data for table "rules.pr_sys_hotfix_events"
[exec] pg_restore: finished item 6581 TABLE DATA pr_sys_hotfix_events
[exec] pg_restore: launching item 6597 TABLE DATA pr_sys_import_queue
[exec] pg_restore: processing data for table "rules.pr_sys_import_queue"
[exec] pg_restore: finished item 6597 TABLE DATA pr_sys_import_queue
[exec] pg_restore: launching item 6572 TABLE DATA pr_sys_rule_impl
[exec] pg_restore: processing data for table "rules.pr_sys_rule_impl"
[exec] pg_restore: finished item 6572 TABLE DATA pr_sys_rule_impl
[exec] pg_restore: launching item 6556 TABLE DATA pr_sys_ruleset_index
[exec] pg_restore: processing data for table "rules.pr_sys_ruleset_index"
[exec] pg_restore: finished item 6556 TABLE DATA pr_sys_ruleset_index
[exec] pg_restore: launching item 6600 TABLE DATA pr_sys_runtime_context
[exec] pg_restore: processing data for table "rules.pr_sys_runtime_context"
[exec] pg_restore: finished item 6600 TABLE DATA pr_sys_runtime_context
[exec] pg_restore: launching item 6576 TABLE DATA pr_sysgen_static_content
[exec] pg_restore: processing data for table "rules.pr_sysgen_static_content"
[exec] pg_restore: finished item 6576 TABLE DATA pr_sysgen_static_content
[exec] pg_restore: launching item 6610 TABLE DATA prpc_install_log
[exec] pg_restore: processing data for table "rules.prpc_install_log"
[exec] pg_restore: finished item 6559 TABLE DATA pr_assembledclasses
[exec] pg_restore: launching item 5464 CONSTRAINT p_address p_address_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_address p_address_v2_pk"
[exec] pg_restore: finished item 6610 TABLE DATA prpc_install_log
[exec] pg_restore: launching item 5446 CONSTRAINT p_contactcontactrel p_contactcontactrel_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_contactcontactrel p_contactcontactrel_v2_pk"
[exec] pg_restore: finished item 5446 CONSTRAINT p_contactcontactrel p_contactcontactrel_v2_pk
[exec] pg_restore: launching item 5472 CONSTRAINT p_contact p_contact_v2_pk
[exec] pg_restore: finished item 5464 CONSTRAINT p_address p_address_v2_pk
[exec] pg_restore: launching item 5453 INDEX idx_city_v2
[exec] pg_restore: pg_restore: creating INDEX "data.idx_city_v2"
[exec] creating CONSTRAINT "data.p_contact p_contact_v2_pk"
[exec] pg_restore: finished item 5453 INDEX idx_city_v2
[exec] pg_restore: launching item 5454 INDEX idx_postalcode_v2
[exec] pg_restore: creating INDEX "data.idx_postalcode_v2"
[exec] pg_restore: finished item 5472 CONSTRAINT p_contact p_contact_v2_pk
[exec] pg_restore: launching item 5455 INDEX idx_primaryaddress_v2
[exec] pg_restore: creating INDEX "data.idx_primaryaddress_v2"
[exec] pg_restore: finished item 5455 INDEX idx_primaryaddress_v2
[exec] pg_restore: launching item 5456 INDEX idx_province_v2
[exec] pg_restore: pg_restore: finished item 5454 INDEX idx_postalcode_v2
[exec] pg_restore: creating INDEX "data.idx_province_v2"
[exec] launching item 5457 INDEX idx_region_v2
[exec] pg_restore: creating INDEX "data.idx_region_v2"
[exec] pg_restore: finished item 5457 INDEX idx_region_v2
[exec] pg_restore: launching item 5458 INDEX idx_state_v2
[exec] pg_restore: pg_restore: finished item 5456 INDEX idx_province_v2
[exec] pg_restore: creating INDEX "data.idx_state_v2"
[exec] launching item 5459 INDEX idx_subregion_v2
[exec] pg_restore: creating INDEX "data.idx_subregion_v2"
[exec] pg_restore: finished item 5458 INDEX idx_state_v2
[exec] pg_restore: launching item 5460 INDEX p_address_v2_idx1
[exec] pg_restore: finished item 5459 INDEX idx_subregion_v2
[exec] pg_restore: launching item 5461 INDEX p_address_v2_idx2
[exec] pg_restore: creating INDEX "data.p_address_v2_idx1"
[exec] pg_restore: creating INDEX "data.p_address_v2_idx2"
[exec] pg_restore: finished item 5461 INDEX p_address_v2_idx2
[exec] pg_restore: launching item 5462 INDEX p_address_v2_idx3
[exec] pg_restore: creating INDEX "data.p_address_v2_idx3"
[exec] pg_restore: finished item 5462 INDEX p_address_v2_idx3
[exec] pg_restore: launching item 5465 INDEX idx_lastname_v2
[exec] pg_restore: pg_restore: finished item 5460 INDEX p_address_v2_idx1
[exec] pg_restore: launching item 5466 INDEX idx_primaryemail_v2
[exec] creating INDEX "data.idx_lastname_v2"
[exec] pg_restore: creating INDEX "data.idx_primaryemail_v2"
[exec] pg_restore: finished item 5465 INDEX idx_lastname_v2
[exec] pg_restore: launching item 5467 INDEX idx_primaryphone_v2
[exec] pg_restore: creating INDEX "data.idx_primaryphone_v2"
[exec] pg_restore: finished item 5466 INDEX idx_primaryemail_v2
[exec] pg_restore: launching item 5468 INDEX idx_secondaryemail_v2
[exec] pg_restore: creating INDEX "data.idx_secondaryemail_v2"
[exec] pg_restore: finished item 5467 INDEX idx_primaryphone_v2
[exec] pg_restore: launching item 5469 INDEX idx_secondaryphone_v2
[exec] pg_restore: creating INDEX "data.idx_secondaryphone_v2"
[exec] pg_restore: finished item 5468 INDEX idx_secondaryemail_v2
[exec] pg_restore: launching item 5470 INDEX idx_tertiaryphone_v2
[exec] pg_restore: creating INDEX "data.idx_tertiaryphone_v2"
[exec] pg_restore: finished item 5469 INDEX idx_secondaryphone_v2
[exec] pg_restore: launching item 5479 CONSTRAINT p_organization p_organization_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_organization p_organization_v2_pk"
[exec] pg_restore: finished item 5470 INDEX idx_tertiaryphone_v2
[exec] pg_restore: launching item 5452 CONSTRAINT p_role p_role_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_role p_role_v2_pk"
[exec] pg_restore: finished item 5479 CONSTRAINT p_organization p_organization_v2_pk
[exec] pg_restore: launching item 5473 INDEX idx_active_orgn_v2
[exec] pg_restore: creating INDEX "data.idx_active_orgn_v2"
[exec] pg_restore: finished item 5452 CONSTRAINT p_role p_role_v2_pk
[exec] pg_restore: launching item 5474 INDEX idx_industry_v2
[exec] pg_restore: creating INDEX "data.idx_industry_v2"
[exec] pg_restore: finished item 5473 INDEX idx_active_orgn_v2
[exec] pg_restore: launching item 5475 INDEX idx_organizationname_v2
[exec] pg_restore: pg_restore: creating INDEX "data.idx_organizationname_v2"
[exec] finished item 5474 INDEX idx_industry_v2
[exec] pg_restore: launching item 5476 INDEX idx_organizationtype_v2
[exec] pg_restore: creating INDEX "data.idx_organizationtype_v2"
[exec] pg_restore: finished item 5476 INDEX idx_organizationtype_v2
[exec] pg_restore: launching item 5477 INDEX idx_revenue_v2
[exec] pg_restore: creating INDEX "data.idx_revenue_v2"
[exec] pg_restore: finished item 5475 INDEX idx_organizationname_v2
[exec] pg_restore: launching item 5448 CONSTRAINT p_contactorgrel p_contactorgrel_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_contactorgrel p_contactorgrel_v2_pk"
[exec] pg_restore: finished item 5477 INDEX idx_revenue_v2
[exec] pg_restore: launching item 5450 CONSTRAINT p_orgorgrel p_orgorgrel_v2_pk
[exec] pg_restore: creating CONSTRAINT "data.p_orgorgrel p_orgorgrel_v2_pk"
[exec] pg_restore: finished item 5448 CONSTRAINT p_contactorgrel p_contactorgrel_v2_pk
[exec] pg_restore: launching item 5248 CONSTRAINT pc_apn_token pc_apn_token_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_apn_token pc_apn_token_pk"
[exec] pg_restore: finished item 5450 CONSTRAINT p_orgorgrel p_orgorgrel_v2_pk
[exec] pg_restore: launching item 5130 CONSTRAINT pc_cep_actions_repository pc_cep_actions_repository_pk
[exec] pg_restore: pg_restore: finished item 5248 CONSTRAINT pc_apn_token pc_apn_token_pk
[exec] pg_restore: launching item 4916 CONSTRAINT pc_assign_workbasket pc_assign_workbasket_pk
[exec] creating CONSTRAINT "data.pc_cep_actions_repository pc_cep_actions_repository_pk"
[exec] pg_restore: creating CONSTRAINT "data.pc_assign_workbasket pc_assign_workbasket_pk"
[exec] pg_restore: finished item 5130 CONSTRAINT pc_cep_actions_repository pc_cep_actions_repository_pk
[exec] pg_restore: launching item 4921 CONSTRAINT pc_assign_worklist pc_assign_worklist_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pc_assign_worklist pc_assign_worklist_pk"
[exec] finished item 4916 CONSTRAINT pc_assign_workbasket pc_assign_workbasket_pk
[exec] pg_restore: launching item 4913 INDEX bulkprocessfrombasket
[exec] pg_restore: creating INDEX "data.bulkprocessfrombasket"
[exec] pg_restore: finished item 4921 CONSTRAINT pc_assign_worklist pc_assign_worklist_pk
[exec] pg_restore: launching item 4914 INDEX pc_assign_workbasket_idx1
[exec] pg_restore: pg_restore: finished item 4913 INDEX bulkprocessfrombasket
[exec] pg_restore: creating INDEX "data.pc_assign_workbasket_idx1"
[exec] launching item 4917 INDEX refobjectworkbasket
[exec] pg_restore: creating INDEX "data.refobjectworkbasket"
[exec] pg_restore: finished item 4917 INDEX refobjectworkbasket
[exec] pg_restore: launching item 4918 INDEX bulkprocessfromlist
[exec] pg_restore: pg_restore: creating INDEX "data.bulkprocessfromlist"
[exec] finished item 4914 INDEX pc_assign_workbasket_idx1
[exec] pg_restore: launching item 4919 INDEX getnextworkfromlist
[exec] pg_restore: creating INDEX "data.getnextworkfromlist"
[exec] pg_restore: finished item 4919 INDEX getnextworkfromlist
[exec] pg_restore: launching item 4922 INDEX refobjectworklist
[exec] pg_restore: creating INDEX "data.refobjectworklist"
[exec] pg_restore: finished item 4918 INDEX bulkprocessfromlist
[exec] pg_restore: launching item 5132 CONSTRAINT pc_cep_events_repository pc_cep_events_repository_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_cep_events_repository pc_cep_events_repository_pk"
[exec] pg_restore: finished item 4922 INDEX refobjectworklist
[exec] pg_restore: launching item 4845 CONSTRAINT pc_data_adm_seccorspol pc_data_adm_seccorspol_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_data_adm_seccorspol pc_data_adm_seccorspol_pk"
[exec] pg_restore: finished item 5132 CONSTRAINT pc_cep_events_repository pc_cep_events_repository_pk
[exec] pg_restore: launching item 4848 CONSTRAINT pc_data_adm_seckeyid pc_data_adm_seckeyid_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_data_adm_seckeyid pc_data_adm_seckeyid_pk"
[exec] pg_restore: finished item 4848 CONSTRAINT pc_data_adm_seckeyid pc_data_adm_seckeyid_pk
[exec] pg_restore: launching item 4846 INDEX pc_data_adm_seckeyid_idx1
[exec] pg_restore: creating INDEX "data.pc_data_adm_seckeyid_idx1"
[exec] pg_restore: finished item 4845 CONSTRAINT pc_data_adm_seccorspol pc_data_adm_seccorspol_pk
[exec] pg_restore: launching item 4843 INDEX pc_data_adm_seccorspol_idx1
[exec] pg_restore: creating INDEX "data.pc_data_adm_seccorspol_idx1"
[exec] pg_restore: finished item 4843 INDEX pc_data_adm_seccorspol_idx1
[exec] pg_restore: launching item 5590 CONSTRAINT pc_clientdata_restriction pc_clientdata_restri_1208_pk
[exec] pg_restore: pg_restore: finished item 4846 INDEX pc_data_adm_seckeyid_idx1
[exec] pg_restore: creating CONSTRAINT "data.pc_clientdata_restriction pc_clientdata_restri_1208_pk"
[exec] launching item 5684 CONSTRAINT pc_data_file_temp pc_data_file_temp_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_data_file_temp pc_data_file_temp_pk"
[exec] pg_restore: finished item 5590 CONSTRAINT pc_clientdata_restriction pc_clientdata_restri_1208_pk
[exec] pg_restore: launching item 5588 INDEX pc_clientdata_restri_1208_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pc_clientdata_restri_1208_idx1"
[exec] finished item 5684 CONSTRAINT pc_data_file_temp pc_data_file_temp_pk
[exec] pg_restore: launching item 5680 INDEX pc_data_file_temp_idx1
[exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx1"
[exec] pg_restore: finished item 5680 INDEX pc_data_file_temp_idx1
[exec] pg_restore: launching item 5681 INDEX pc_data_file_temp_idx2
[exec] pg_restore: finished item 5588 INDEX pc_clientdata_restri_1208_idx1
[exec] pg_restore: launching item 5682 INDEX pc_data_file_temp_idx3
[exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx2"
[exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx3"
[exec] pg_restore: finished item 5682 INDEX pc_data_file_temp_idx3
[exec] pg_restore: launching item 4855 CONSTRAINT pc_data_notiftn_param pc_data_notiftn_param_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_data_notiftn_param pc_data_notiftn_param_pk"
[exec] pg_restore: finished item 5681 INDEX pc_data_file_temp_idx2
[exec] pg_restore: launching item 4924 CONSTRAINT pc_data_uniqueid pc_data_uniqueid_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_data_uniqueid pc_data_uniqueid_pk"
[exec] pg_restore: finished item 4924 CONSTRAINT pc_data_uniqueid pc_data_uniqueid_pk
[exec] pg_restore: launching item 4926 CONSTRAINT pc_data_workattach pc_data_workattach_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pc_data_workattach pc_data_workattach_pk"
[exec] finished item 4855 CONSTRAINT pc_data_notiftn_param pc_data_notiftn_param_pk
[exec] pg_restore: launching item 4853 INDEX pc_data_notiftn_param_idx1
[exec] pg_restore: creating INDEX "data.pc_data_notiftn_param_idx1"
[exec] pg_restore: finished item 4853 INDEX pc_data_notiftn_param_idx1
[exec] pg_restore: launching item 5648 CONSTRAINT pc_flaudit pc_flaudit_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_flaudit pc_flaudit_pk"
[exec] pg_restore: finished item 4926 CONSTRAINT pc_data_workattach pc_data_workattach_pk
[exec] pg_restore: launching item 4954 CONSTRAINT pc_events pc_events_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_events pc_events_pk"
[exec] pg_restore: finished item 5648 CONSTRAINT pc_flaudit pc_flaudit_pk
[exec] pg_restore: launching item 5645 INDEX pc_flaudit_idx1
[exec] pg_restore: creating INDEX "data.pc_flaudit_idx1"
[exec] pg_restore: finished item 4954 CONSTRAINT pc_events pc_events_pk
[exec] pg_restore: launching item 5646 INDEX pc_flaudit_idx2
[exec] pg_restore: creating INDEX "data.pc_flaudit_idx2"
[exec] pg_restore: finished item 5645 INDEX pc_flaudit_idx1
[exec] pg_restore: launching item 4948 INDEX idx_events_ruleupdate
[exec] pg_restore: creating INDEX "data.idx_events_ruleupdate"
[exec] pg_restore: finished item 5646 INDEX pc_flaudit_idx2
[exec] pg_restore: launching item 4949 INDEX pc_events_apprt
[exec] pg_restore: creating INDEX "data.pc_events_apprt"
[exec] pg_restore: finished item 4948 INDEX idx_events_ruleupdate
[exec] pg_restore: launching item 4950 INDEX pc_events_idx1
[exec] pg_restore: creating INDEX "data.pc_events_idx1"
[exec] pg_restore: finished item 4949 INDEX pc_events_apprt
[exec] pg_restore: launching item 4951 INDEX pc_events_idx2
[exec] pg_restore: creating INDEX "data.pc_events_idx2"
[exec] pg_restore: finished item 4951 INDEX pc_events_idx2
[exec] pg_restore: launching item 4952 INDEX pc_events_objclass
[exec] pg_restore: finished item 4950 INDEX pc_events_idx1
[exec] pg_restore: launching item 5250 CONSTRAINT pc_gcm_token pc_gcm_token_pk
[exec] pg_restore: creating INDEX "data.pc_events_objclass"
[exec] pg_restore: creating CONSTRAINT "data.pc_gcm_token pc_gcm_token_pk"
[exec] pg_restore: finished item 4952 INDEX pc_events_objclass
[exec] pg_restore: launching item 5298 CONSTRAINT pc_history_data_dms_work pc_his_data_dms_work_pk
[exec] pg_restore: pg_restore: finished item 5250 CONSTRAINT pc_gcm_token pc_gcm_token_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_history_data_dms_work pc_his_data_dms_work_pk"
[exec] launching item 5536 CONSTRAINT pc_history_group pc_history_group_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_history_group pc_history_group_pk"
[exec] pg_restore: finished item 5298 CONSTRAINT pc_history_data_dms_work pc_his_data_dms_work_pk
[exec] pg_restore: launching item 5632 CONSTRAINT pc_history_document pc_history_document_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_history_document pc_history_document_pk"
[exec] pg_restore: finished item 5536 CONSTRAINT pc_history_group pc_history_group_pk
[exec] pg_restore: launching item 5533 INDEX pc_history_group_idx1
[exec] pg_restore: creating INDEX "data.pc_history_group_idx1"
[exec] pg_restore: finished item 5632 CONSTRAINT pc_history_document pc_history_document_pk
[exec] pg_restore: launching item 5534 INDEX pc_history_group_idx2
[exec] pg_restore: creating INDEX "data.pc_history_group_idx2"
[exec] pg_restore: finished item 5533 INDEX pc_history_group_idx1
[exec] pg_restore: launching item 5630 INDEX pc_history_document_idx1
[exec] pg_restore: creating INDEX "data.pc_history_document_idx1"
[exec] pg_restore: finished item 5534 INDEX pc_history_group_idx2
[exec] pg_restore: launching item 4929 CONSTRAINT pc_history_work pc_history_work_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_history_work pc_history_work_pk"
[exec] pg_restore: finished item 5630 INDEX pc_history_document_idx1
[exec] pg_restore: launching item 5605 CONSTRAINT pc_history_work_cover_task pc_history_work_cove_2353_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_history_work_cover_task pc_history_work_cove_2353_pk"
[exec] pg_restore: finished item 4929 CONSTRAINT pc_history_work pc_history_work_pk
[exec] pg_restore: launching item 4927 INDEX hist_insname
[exec] pg_restore: creating INDEX "data.hist_insname"
[exec] pg_restore: finished item 5605 CONSTRAINT pc_history_work_cover_task pc_history_work_cove_2353_pk
[exec] pg_restore: launching item 4930 INDEX pxhistoryforre
[exec] pg_restore: creating INDEX "data.pxhistoryforre"
[exec] pg_restore: finished item 4927 INDEX hist_insname
[exec] pg_restore: launching item 5600 INDEX pc_history_work_cove_2353_idx1
[exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx1"
[exec] pg_restore: finished item 4930 INDEX pxhistoryforre
[exec] pg_restore: launching item 5601 INDEX pc_history_work_cove_2353_idx2
[exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx2"
[exec] pg_restore: finished item 5601 INDEX pc_history_work_cove_2353_idx2
[exec] pg_restore: launching item 5602 INDEX pc_history_work_cove_2353_idx3
[exec] pg_restore: pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx3"
[exec] finished item 5600 INDEX pc_history_work_cove_2353_idx1
[exec] pg_restore: launching item 5603 INDEX pc_history_work_cove_2353_idx4
[exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx4"
[exec] pg_restore: finished item 5603 INDEX pc_history_work_cove_2353_idx4
[exec] pg_restore: launching item 4907 CONSTRAINT pc_index_accel pc_index_accel_pk
[exec] pg_restore: pg_restore: finished item 5602 INDEX pc_history_work_cove_2353_idx3
[exec] pg_restore: launching item 4934 CONSTRAINT pc_index_workparty pc_index_workparty_pk
[exec] creating CONSTRAINT "data.pc_index_accel pc_index_accel_pk"
[exec] pg_restore: creating CONSTRAINT "data.pc_index_workparty pc_index_workparty_pk"
[exec] pg_restore: finished item 4907 CONSTRAINT pc_index_accel pc_index_accel_pk
[exec] pg_restore: launching item 5316 CONSTRAINT pc_index_location pc_index_location_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_index_location pc_index_location_pk"
[exec] pg_restore: finished item 4934 CONSTRAINT pc_index_workparty pc_index_workparty_pk
[exec] pg_restore: launching item 4931 INDEX index_key_purp
[exec] pg_restore: creating INDEX "data.index_key_purp"
[exec] pg_restore: finished item 5316 CONSTRAINT pc_index_location pc_index_location_pk
[exec] pg_restore: launching item 4932 INDEX pc_index_workparty_idx1
[exec] pg_restore: pg_restore: finished item 4931 INDEX index_key_purp
[exec] pg_restore: creating INDEX "data.pc_index_workparty_idx1"
[exec] launching item 5314 INDEX keypurpose_pc_idx_location
[exec] pg_restore: creating INDEX "data.keypurpose_pc_idx_location"
[exec] pg_restore: finished item 4932 INDEX pc_index_workparty_idx1
[exec] pg_restore: launching item 5378 CONSTRAINT pc_link_association pc_link_association_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association pc_link_association_pk"
[exec] pg_restore: finished item 5314 INDEX keypurpose_pc_idx_location
[exec] pg_restore: launching item 5655 CONSTRAINT pc_link_association_channel pc_link_asso_channel_1128_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association_channel pc_link_asso_channel_1128_pk"
[exec] pg_restore: finished item 5378 CONSTRAINT pc_link_association pc_link_association_pk
[exec] pg_restore: launching item 5375 INDEX pc_link_association_idx1
[exec] pg_restore: creating INDEX "data.pc_link_association_idx1"
[exec] pg_restore: finished item 5655 CONSTRAINT pc_link_association_channel pc_link_asso_channel_1128_pk
[exec] pg_restore: launching item 5376 INDEX pc_link_association_idx2
[exec] pg_restore: creating INDEX "data.pc_link_association_idx2"
[exec] pg_restore: finished item 5376 INDEX pc_link_association_idx2
[exec] pg_restore: launching item 5652 INDEX pc_link_asso_channel_1128_idx1
[exec] pg_restore: finished item 5375 INDEX pc_link_association_idx1
[exec] pg_restore: launching item 5653 INDEX pc_link_asso_channel_1128_idx2
[exec] pg_restore: creating INDEX "data.pc_link_asso_channel_1128_idx2"
[exec] pg_restore: creating INDEX "data.pc_link_asso_channel_1128_idx1"
[exec] pg_restore: finished item 5652 INDEX pc_link_asso_channel_1128_idx1
[exec] pg_restore: launching item 5428 CONSTRAINT pc_link_association_doc pc_link_association_doc_pk
[exec] pg_restore: pg_restore: finished item 5653 INDEX pc_link_asso_channel_1128_idx2
[exec] creating CONSTRAINT "data.pc_link_association_doc pc_link_association_doc_pk"
[exec] pg_restore: launching item 5540 CONSTRAINT pc_link_association_member pc_link_am_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association_member pc_link_am_pk"
[exec] pg_restore: finished item 5540 CONSTRAINT pc_link_association_member pc_link_am_pk
[exec] pg_restore: launching item 5537 INDEX pc_link_am_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pc_link_am_idx1"
[exec] finished item 5428 CONSTRAINT pc_link_association_doc pc_link_association_doc_pk
[exec] pg_restore: launching item 5425 INDEX pc_link_association_doc_idx1
[exec] pg_restore: creating INDEX "data.pc_link_association_doc_idx1"
[exec] pg_restore: finished item 5425 INDEX pc_link_association_doc_idx1
[exec] pg_restore: launching item 5426 INDEX pc_link_association_doc_idx2
[exec] pg_restore: creating INDEX "data.pc_link_association_doc_idx2"
[exec] pg_restore: finished item 5537 INDEX pc_link_am_idx1
[exec] pg_restore: launching item 5538 INDEX pc_link_am_idx2
[exec] pg_restore: creating INDEX "data.pc_link_am_idx2"
[exec] pg_restore: finished item 5426 INDEX pc_link_association_doc_idx2
[exec] pg_restore: launching item 5592 CONSTRAINT pc_link_association_space pc_link_association_space_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association_space pc_link_association_space_pk"
[exec] pg_restore: finished item 5538 INDEX pc_link_am_idx2
[exec] pg_restore: launching item 5583 CONSTRAINT pc_link_association_pin pc_link_association_pin_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association_pin pc_link_association_pin_pk"
[exec] pg_restore: finished item 5592 CONSTRAINT pc_link_association_space pc_link_association_space_pk
[exec] pg_restore: launching item 5593 INDEX pr_link_ass_space_idx1
[exec] pg_restore: creating INDEX "data.pr_link_ass_space_idx1"
[exec] pg_restore: finished item 5593 INDEX pr_link_ass_space_idx1
[exec] pg_restore: launching item 5594 INDEX pr_link_ass_space_idx2
[exec] pg_restore: pg_restore: finished item 5583 CONSTRAINT pc_link_association_pin pc_link_association_pin_pk
[exec] pg_restore: creating INDEX "data.pr_link_ass_space_idx2"
[exec] launching item 5580 INDEX pc_link_association_pin_idx1
[exec] pg_restore: creating INDEX "data.pc_link_association_pin_idx1"
[exec] pg_restore: finished item 5594 INDEX pr_link_ass_space_idx2
[exec] pg_restore: launching item 5581 INDEX pc_link_association_pin_idx2
[exec] pg_restore: creating INDEX "data.pc_link_association_pin_idx2"
[exec] pg_restore: finished item 5580 INDEX pc_link_association_pin_idx1
[exec] pg_restore: launching item 5641 CONSTRAINT pc_link_association_rrcategory pc_link_association_1128_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_association_rrcategory pc_link_association_1128_pk"
[exec] pg_restore: finished item 5581 INDEX pc_link_association_pin_idx2
[exec] pg_restore: launching item 4939 CONSTRAINT pc_link_attachment pc_link_attachment_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_attachment pc_link_attachment_pk"
[exec] pg_restore: finished item 5641 CONSTRAINT pc_link_association_rrcategory pc_link_association_1128_pk
[exec] pg_restore: launching item 5639 INDEX pc_link_asso_1128_idx1
[exec] pg_restore: creating INDEX "data.pc_link_asso_1128_idx1"
[exec] pg_restore: finished item 4939 CONSTRAINT pc_link_attachment pc_link_attachment_pk
[exec] pg_restore: launching item 4935 INDEX attach_ref_from
[exec] pg_restore: creating INDEX "data.attach_ref_from"
[exec] pg_restore: finished item 5639 INDEX pc_link_asso_1128_idx1
[exec] pg_restore: launching item 4936 INDEX link_insname
[exec] pg_restore: creating INDEX "data.link_insname"
[exec] pg_restore: finished item 4935 INDEX attach_ref_from
[exec] pg_restore: launching item 4937 INDEX pc_link_attachment_idx1
[exec] pg_restore: creating INDEX "data.pc_link_attachment_idx1"
[exec] pg_restore: finished item 4936 INDEX link_insname
[exec] pg_restore: launching item 5528 CONSTRAINT pc_link_category pc_link_category_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_category pc_link_category_pk"
[exec] pg_restore: finished item 4937 INDEX pc_link_attachment_idx1
[exec] pg_restore: launching item 4942 CONSTRAINT pc_link_folder pc_link_folder_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_folder pc_link_folder_pk"
[exec] pg_restore: finished item 5528 CONSTRAINT pc_link_category pc_link_category_pk
[exec] pg_restore: launching item 5525 INDEX pc_link_category_idx1
[exec] pg_restore: finished item 4942 CONSTRAINT pc_link_folder pc_link_folder_pk
[exec] pg_restore: launching item 5526 INDEX pc_link_category_idx2
[exec] pg_restore: creating INDEX "data.pc_link_category_idx1"
[exec] pg_restore: creating INDEX "data.pc_link_category_idx2"
[exec] pg_restore: finished item 5525 INDEX pc_link_category_idx1
[exec] pg_restore: launching item 4940 INDEX folder_insname
[exec] pg_restore: pg_restore: creating INDEX "data.folder_insname"
[exec] finished item 5526 INDEX pc_link_category_idx2
[exec] pg_restore: launching item 5027 CONSTRAINT pc_link_topcase pc_link_topcase_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_link_topcase pc_link_topcase_pk"
[exec] pg_restore: finished item 5027 CONSTRAINT pc_link_topcase pc_link_topcase_pk
[exec] pg_restore: launching item 5028 INDEX topcase_refto
[exec] pg_restore: finished item 4940 INDEX folder_insname
[exec] pg_restore: launching item 5238 CONSTRAINT pc_pegatask pc_pegatask_pk
[exec] pg_restore: creating INDEX "data.topcase_refto"
[exec] pg_restore: creating CONSTRAINT "data.pc_pegatask pc_pegatask_pk"
[exec] pg_restore: finished item 5028 INDEX topcase_refto
[exec] pg_restore: launching item 4947 CONSTRAINT pc_schedule_task pc_schedule_task_pk
[exec] pg_restore: finished item 5238 CONSTRAINT pc_pegatask pc_pegatask_pk
[exec] pg_restore: launching item 5236 INDEX pc_pegatask_idx1
[exec] pg_restore: creating CONSTRAINT "data.pc_schedule_task pc_schedule_task_pk"
[exec] pg_restore: creating INDEX "data.pc_pegatask_idx1"
[exec] pg_restore: finished item 4947 CONSTRAINT pc_schedule_task pc_schedule_task_pk
[exec] pg_restore: launching item 4945 INDEX pc_schedule_task_idx1
[exec] pg_restore: finished item 5236 INDEX pc_pegatask_idx1
[exec] pg_restore: launching item 4958 CONSTRAINT pc_work pc_work_pk
[exec] pg_restore: creating INDEX "data.pc_schedule_task_idx1"
[exec] pg_restore: creating CONSTRAINT "data.pc_work pc_work_pk"
[exec] pg_restore: finished item 4958 CONSTRAINT pc_work pc_work_pk
[exec] pg_restore: launching item 4955 INDEX pc_work_idx1
[exec] pg_restore: finished item 4945 INDEX pc_schedule_task_idx1
[exec] pg_restore: launching item 4956 INDEX pc_work_idx2
[exec] pg_restore: creating INDEX "data.pc_work_idx1"
[exec] pg_restore: creating INDEX "data.pc_work_idx2"
[exec] pg_restore: finished item 4955 INDEX pc_work_idx1
[exec] pg_restore: launching item 4944 CONSTRAINT pc_work_accel pc_work_accel_pk
[exec] pg_restore: finished item 4956 INDEX pc_work_idx2
[exec] pg_restore: launching item 5374 CONSTRAINT pc_work_agile pc_work_agile_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_accel pc_work_accel_pk"
[exec] pg_restore: creating CONSTRAINT "data.pc_work_agile pc_work_agile_pk"
[exec] pg_restore: finished item 4944 CONSTRAINT pc_work_accel pc_work_accel_pk
[exec] pg_restore: launching item 5550 CONSTRAINT pc_work_clientdata pc_work_clientdata_pk
[exec] pg_restore: finished item 5374 CONSTRAINT pc_work_agile pc_work_agile_pk
[exec] pg_restore: launching item 5372 INDEX pc_work_agile_idx1
[exec] pg_restore: creating CONSTRAINT "data.pc_work_clientdata pc_work_clientdata_pk"
[exec] pg_restore: creating INDEX "data.pc_work_agile_idx1"
[exec] pg_restore: finished item 5372 INDEX pc_work_agile_idx1
[exec] pg_restore: launching item 5599 CONSTRAINT pc_work_cover_task pc_work_cover_task_pk
[exec] pg_restore: finished item 5550 CONSTRAINT pc_work_clientdata pc_work_clientdata_pk
[exec] pg_restore: launching item 5548 INDEX pc_work_clientdata_idx1
[exec] pg_restore: creating CONSTRAINT "data.pc_work_cover_task pc_work_cover_task_pk"
[exec] pg_restore: creating INDEX "data.pc_work_clientdata_idx1"
[exec] pg_restore: finished item 5548 INDEX pc_work_clientdata_idx1
[exec] pg_restore: launching item 5296 CONSTRAINT pc_work_dms pc_work_dms_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_dms pc_work_dms_pk"
[exec] pg_restore: finished item 5599 CONSTRAINT pc_work_cover_task pc_work_cover_task_pk
[exec] pg_restore: launching item 5595 INDEX pc_work_cover_task_idx1
[exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx1"
[exec] pg_restore: finished item 5296 CONSTRAINT pc_work_dms pc_work_dms_pk
[exec] pg_restore: launching item 5596 INDEX pc_work_cover_task_idx2
[exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx2"
[exec] pg_restore: finished item 5595 INDEX pc_work_cover_task_idx1
[exec] pg_restore: launching item 5597 INDEX pc_work_cover_task_idx3
[exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx3"
[exec] pg_restore: finished item 5596 INDEX pc_work_cover_task_idx2
[exec] pg_restore: launching item 5424 CONSTRAINT pc_work_document pc_work_document_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_document pc_work_document_pk"
[exec] pg_restore: finished item 5597 INDEX pc_work_cover_task_idx3
[exec] pg_restore: launching item 5708 CONSTRAINT pc_work_dsm_simulation pc_work_dsm_simulation_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_dsm_simulation pc_work_dsm_simulation_pk"
[exec] pg_restore: finished item 5424 CONSTRAINT pc_work_document pc_work_document_pk
[exec] pg_restore: launching item 5421 INDEX pc_work_document_idx1
[exec] pg_restore: creating INDEX "data.pc_work_document_idx1"
[exec] pg_restore: finished item 5421 INDEX pc_work_document_idx1
[exec] pg_restore: launching item 5422 INDEX pc_work_document_idx2
[exec] pg_restore: creating INDEX "data.pc_work_document_idx2"
[exec] pg_restore: finished item 5708 CONSTRAINT pc_work_dsm_simulation pc_work_dsm_simulation_pk
[exec] pg_restore: launching item 5706 INDEX pc_work_dsm_simulation_idx1
[exec] pg_restore: creating INDEX "data.pc_work_dsm_simulation_idx1"
[exec] pg_restore: finished item 5422 INDEX pc_work_document_idx2
[exec] pg_restore: launching item 4965 CONSTRAINT pc_work_dsm_batch pc_work_dsm_batch_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_dsm_batch pc_work_dsm_batch_pk"
[exec] pg_restore: finished item 5706 INDEX pc_work_dsm_simulation_idx1
[exec] pg_restore: launching item 5532 CONSTRAINT pc_work_group pc_work_group_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_group pc_work_group_pk"
[exec] pg_restore: finished item 4965 CONSTRAINT pc_work_dsm_batch pc_work_dsm_batch_pk
[exec] pg_restore: launching item 4963 INDEX pc_work_dsm_batch_idx1
[exec] pg_restore: creating INDEX "data.pc_work_dsm_batch_idx1"
[exec] pg_restore: finished item 5532 CONSTRAINT pc_work_group pc_work_group_pk
[exec] pg_restore: launching item 4966 INDEX work_stratname
[exec] pg_restore: creating INDEX "data.work_stratname"
[exec] pg_restore: finished item 4963 INDEX pc_work_dsm_batch_idx1
[exec] pg_restore: launching item 5529 INDEX pc_work_group_idx1
[exec] pg_restore: creating INDEX "data.pc_work_group_idx1"
[exec] pg_restore: finished item 4966 INDEX work_stratname
[exec] pg_restore: launching item 5530 INDEX pc_work_group_idx2
[exec] pg_restore: creating INDEX "data.pc_work_group_idx2"
[exec] pg_restore: finished item 5529 INDEX pc_work_group_idx1
[exec] pg_restore: launching item 5364 CONSTRAINT pc_work_notification pc_work_notification_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_notification pc_work_notification_pk"
[exec] pg_restore: finished item 5530 INDEX pc_work_group_idx2
[exec] pg_restore: launching item 5381 CONSTRAINT pc_work_guide pc_work_guide_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_guide pc_work_guide_pk"
[exec] pg_restore: finished item 5381 CONSTRAINT pc_work_guide pc_work_guide_pk
[exec] pg_restore: launching item 5379 INDEX pc_work_guide_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pc_work_guide_idx1"
[exec] finished item 5364 CONSTRAINT pc_work_notification pc_work_notification_pk
[exec] pg_restore: launching item 5361 INDEX pc_work_notification_idx1
[exec] pg_restore: creating INDEX "data.pc_work_notification_idx1"
[exec] pg_restore: finished item 5379 INDEX pc_work_guide_idx1
[exec] pg_restore: launching item 5362 INDEX pc_work_notification_idx2
[exec] pg_restore: pg_restore: creating INDEX "data.pc_work_notification_idx2"
[exec] finished item 5361 INDEX pc_work_notification_idx1
[exec] pg_restore: launching item 5694 CONSTRAINT pc_work_prediction pc_work_prediction_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_prediction pc_work_prediction_pk"
[exec] pg_restore: finished item 5362 INDEX pc_work_notification_idx2
[exec] pg_restore: launching item 4960 CONSTRAINT pc_work_processemail pc_work_processemail_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_processemail pc_work_processemail_pk"
[exec] pg_restore: finished item 5694 CONSTRAINT pc_work_prediction pc_work_prediction_pk
[exec] pg_restore: launching item 5691 INDEX pc_work_prediction_idx1
[exec] pg_restore: creating INDEX "data.pc_work_prediction_idx1"
[exec] pg_restore: finished item 4960 CONSTRAINT pc_work_processemail pc_work_processemail_pk
[exec] pg_restore: launching item 5692 INDEX pc_work_prediction_idx2
[exec] pg_restore: pg_restore: creating INDEX "data.pc_work_prediction_idx2"
[exec] finished item 5691 INDEX pc_work_prediction_idx1
[exec] pg_restore: launching item 4961 INDEX processemail_assignmentcdt
[exec] pg_restore: creating INDEX "data.processemail_assignmentcdt"
[exec] pg_restore: finished item 4961 INDEX processemail_assignmentcdt
[exec] pg_restore: launching item 4962 INDEX processemail_itemid
[exec] pg_restore: finished item 5692 INDEX pc_work_prediction_idx2
[exec] pg_restore: launching item 5189 CONSTRAINT pc_work_social pc_work_social_pk
[exec] pg_restore: creating INDEX "data.processemail_itemid"
[exec] pg_restore: creating CONSTRAINT "data.pc_work_social pc_work_social_pk"
[exec] pg_restore: finished item 4962 INDEX processemail_itemid
[exec] pg_restore: launching item 5688 CONSTRAINT pc_work_triage pc_work_triage_pk
[exec] pg_restore: creating CONSTRAINT "data.pc_work_triage pc_work_triage_pk"
[exec] pg_restore: finished item 5189 CONSTRAINT pc_work_social pc_work_social_pk
[exec] pg_restore: launching item 5182 INDEX pc_work_social_idx4
[exec] pg_restore: creating INDEX "data.pc_work_social_idx4"
[exec] pg_restore: finished item 5688 CONSTRAINT pc_work_triage pc_work_triage_pk
[exec] pg_restore: launching item 5183 INDEX pc_work_social_idx_replyto
[exec] pg_restore: creating INDEX "data.pc_work_social_idx_replyto"
[exec] pg_restore: finished item 5182 INDEX pc_work_social_idx4
[exec] pg_restore: launching item 5184 INDEX pc_work_social_index1
[exec] pg_restore: creating INDEX "data.pc_work_social_index1"
[exec] pg_restore: finished item 5184 INDEX pc_work_social_index1
[exec] pg_restore: launching item 5185 INDEX pc_work_social_index2
[exec] pg_restore: pg_restore: creating INDEX "data.pc_work_social_index2"
[exec] finished item 5183 INDEX pc_work_social_idx_replyto
[exec] pg_restore: launching item 5186 INDEX pc_work_social_index3
[exec] pg_restore: creating INDEX "data.pc_work_social_index3"
[exec] pg_restore: finished item 5185 INDEX pc_work_social_index2
[exec] pg_restore: launching item 5187 INDEX pc_work_social_index4
[exec] pg_restore: creating INDEX "data.pc_work_social_index4"
[exec] pg_restore: finished item 5186 INDEX pc_work_social_index3
[exec] pg_restore: launching item 4970 CONSTRAINT pi_data_connect pi_data_connect_pk
[exec] pg_restore: creating CONSTRAINT "data.pi_data_connect pi_data_connect_pk"
[exec] pg_restore: finished item 5187 INDEX pc_work_social_index4
[exec] pg_restore: launching item 5012 CONSTRAINT pr4_history_rule pr4_history_rule_pk
[exec] pg_restore: creating CONSTRAINT "data.pr4_history_rule pr4_history_rule_pk"
[exec] pg_restore: finished item 5012 CONSTRAINT pr4_history_rule pr4_history_rule_pk
[exec] pg_restore: launching item 5013 INDEX rule_historyforre
[exec] pg_restore: finished item 4970 CONSTRAINT pi_data_connect pi_data_connect_pk
[exec] pg_restore: launching item 4967 INDEX connect_insname
[exec] pg_restore: creating INDEX "data.rule_historyforre"
[exec] pg_restore: creating INDEX "data.connect_insname"
[exec] pg_restore: finished item 4967 INDEX connect_insname
[exec] pg_restore: launching item 4968 INDEX connect_objclass
[exec] pg_restore: pg_restore: finished item 5013 INDEX rule_historyforre
[exec] creating INDEX "data.connect_objclass"
[exec] pg_restore: launching item 5014 INDEX rule_historytc
[exec] pg_restore: creating INDEX "data.rule_historytc"
[exec] pg_restore: finished item 4968 INDEX connect_objclass
[exec] pg_restore: launching item 5142 CONSTRAINT pr4_log_rule_usage_details pr4_log_rule_usage_details_pk
[exec] pg_restore: finished item 5014 INDEX rule_historytc
[exec] pg_restore: launching item 5138 CONSTRAINT pr4_log_rule_usage pr4_log_rule_usage_pk
[exec] pg_restore: creating CONSTRAINT "data.pr4_log_rule_usage_details pr4_log_rule_usage_details_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr4_log_rule_usage pr4_log_rule_usage_pk"
[exec] pg_restore: finished item 5142 CONSTRAINT pr4_log_rule_usage_details pr4_log_rule_usage_details_pk
[exec] pg_restore: launching item 5140 INDEX pr4_log_detail_idx1
[exec] pg_restore: creating INDEX "data.pr4_log_detail_idx1"
[exec] pg_restore: finished item 5138 CONSTRAINT pr4_log_rule_usage pr4_log_rule_usage_pk
[exec] pg_restore: launching item 5143 INDEX pr_log_detail_cacheusage
[exec] pg_restore: creating INDEX "data.pr_log_detail_cacheusage"
[exec] pg_restore: finished item 5143 INDEX pr_log_detail_cacheusage
[exec] pg_restore: launching item 5139 INDEX pr_log_rule_node
[exec] pg_restore: finished item 5140 INDEX pr4_log_detail_idx1
[exec] pg_restore: launching item 5732 CONSTRAINT pr_archival_class_dependency pr_archival_class_de_1812_pk
[exec] pg_restore: creating INDEX "data.pr_log_rule_node"
[exec] pg_restore: creating CONSTRAINT "data.pr_archival_class_dependency pr_archival_class_de_1812_pk"
[exec] pg_restore: finished item 5139 INDEX pr_log_rule_node
[exec] pg_restore: launching item 5121 CONSTRAINT pr_cep_events_queue pr_cep_events_queue_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_cep_events_queue pr_cep_events_queue_pk"
[exec] pg_restore: finished item 5732 CONSTRAINT pr_archival_class_dependency pr_archival_class_de_1812_pk
[exec] pg_restore: launching item 5730 INDEX pr_archival_class_de_1812_idx1
[exec] pg_restore: creating INDEX "data.pr_archival_class_de_1812_idx1"
[exec] pg_restore: finished item 5121 CONSTRAINT pr_cep_events_queue pr_cep_events_queue_pk
[exec] pg_restore: launching item 5122 INDEX pr_cep_queue_idx1
[exec] pg_restore: creating INDEX "data.pr_cep_queue_idx1"
[exec] pg_restore: finished item 5730 INDEX pr_archival_class_de_1812_idx1
[exec] pg_restore: launching item 5123 INDEX pr_cep_queue_idx2
[exec] pg_restore: creating INDEX "data.pr_cep_queue_idx2"
[exec] pg_restore: finished item 5122 INDEX pr_cep_queue_idx1
[exec] pg_restore: launching item 5125 CONSTRAINT pr_cep_eventslookup pr_cep_eventslookup_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_cep_eventslookup pr_cep_eventslookup_pk"
[exec] pg_restore: finished item 5123 INDEX pr_cep_queue_idx2
[exec] pg_restore: launching item 4974 CONSTRAINT pr_assign pr_assign_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_assign pr_assign_pk"
[exec] pg_restore: finished item 5125 CONSTRAINT pr_cep_eventslookup pr_cep_eventslookup_pk
[exec] pg_restore: launching item 5160 CONSTRAINT pr_daily_usage pr_daily_usage_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_daily_usage pr_daily_usage_pk"
[exec] pg_restore: finished item 4974 CONSTRAINT pr_assign pr_assign_pk
[exec] pg_restore: launching item 4971 INDEX bulkprocesscleanup
[exec] pg_restore: pg_restore: creating INDEX "data.bulkprocesscleanup"
[exec] finished item 5160 CONSTRAINT pr_daily_usage pr_daily_usage_pk
[exec] pg_restore: launching item 4972 INDEX bulkprocesscollate
[exec] pg_restore: creating INDEX "data.bulkprocesscollate"
[exec] pg_restore: finished item 4972 INDEX bulkprocesscollate
[exec] pg_restore: launching item 5127 CONSTRAINT pr_cep_user_subscriptions pr_cep_user_subscriptions_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_cep_user_subscriptions pr_cep_user_subscriptions_pk"
[exec] pg_restore: finished item 4971 INDEX bulkprocesscleanup
[exec] pg_restore: launching item 5353 CONSTRAINT pr_data_adm_configuration pr_data_adm_config_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_adm_configuration pr_data_adm_config_pk"
[exec] pg_restore: finished item 5127 CONSTRAINT pr_cep_user_subscriptions pr_cep_user_subscriptions_pk
[exec] pg_restore: launching item 5128 INDEX pr_cep_usersub_index
[exec] pg_restore: creating INDEX "data.pr_cep_usersub_index"
[exec] pg_restore: finished item 5128 INDEX pr_cep_usersub_index
[exec] pg_restore: launching item 5355 CONSTRAINT pr_data_adm_factory pr_data_adm_factory_pk
[exec] pg_restore: finished item 5353 CONSTRAINT pr_data_adm_configuration pr_data_adm_config_pk
[exec] pg_restore: launching item 5543 CONSTRAINT pr_data_admin_auth_code pr_data_admin_auth_code_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_adm_factory pr_data_adm_factory_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_auth_code pr_data_admin_auth_code_pk"
[exec] pg_restore: finished item 5355 CONSTRAINT pr_data_adm_factory pr_data_adm_factory_pk
[exec] pg_restore: launching item 5705 CONSTRAINT pr_data_admin_dds_table pr_data_admin_dds_table_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_dds_table pr_data_admin_dds_table_pk"
[exec] pg_restore: finished item 5543 CONSTRAINT pr_data_admin_auth_code pr_data_admin_auth_code_pk
[exec] pg_restore: launching item 5541 INDEX pr_data_admin_auth_code_idx1
[exec] pg_restore: creating INDEX "data.pr_data_admin_auth_code_idx1"
[exec] pg_restore: finished item 5541 INDEX pr_data_admin_auth_code_idx1
[exec] pg_restore: launching item 5610 CONSTRAINT pr_data_admin_sec_cert pr_data_admin_sec_cert_pk
[exec] pg_restore: finished item 5705 CONSTRAINT pr_data_admin_dds_table pr_data_admin_dds_table_pk
[exec] pg_restore: pg_restore: launching item 5703 INDEX pr_data_admin_dds_table_idx1
[exec] creating CONSTRAINT "data.pr_data_admin_sec_cert pr_data_admin_sec_cert_pk"
[exec] pg_restore: creating INDEX "data.pr_data_admin_dds_table_idx1"
[exec] pg_restore: finished item 5703 INDEX pr_data_admin_dds_table_idx1
[exec] pg_restore: launching item 5385 CONSTRAINT pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk
[exec] pg_restore: finished item 5610 CONSTRAINT pr_data_admin_sec_cert pr_data_admin_sec_cert_pk
[exec] pg_restore: launching item 5611 INDEX pr_data_admin_sec_idx1
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk"
[exec] pg_restore: creating INDEX "data.pr_data_admin_sec_idx1"
[exec] pg_restore: finished item 5611 INDEX pr_data_admin_sec_idx1
[exec] pg_restore: launching item 5387 CONSTRAINT pr_data_admin_sec_de_key pr_data_admin_sec_key_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_de_key pr_data_admin_sec_key_pk"
[exec] pg_restore: finished item 5385 CONSTRAINT pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk
[exec] pg_restore: launching item 5382 INDEX pr_ata_admin_sec_cdk_idx1
[exec] pg_restore: creating INDEX "data.pr_ata_admin_sec_cdk_idx1"
[exec] pg_restore: finished item 5382 INDEX pr_ata_admin_sec_cdk_idx1
[exec] pg_restore: launching item 5383 INDEX pr_ata_admin_sec_cdk_idx2
[exec] pg_restore: creating INDEX "data.pr_ata_admin_sec_cdk_idx2"
[exec] pg_restore: finished item 5383 INDEX pr_ata_admin_sec_cdk_idx2
[exec] pg_restore: launching item 4979 CONSTRAINT pr_data pr_data_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data pr_data_pk"
[exec] finished item 5387 CONSTRAINT pr_data_admin_sec_de_key pr_data_admin_sec_key_pk
[exec] pg_restore: launching item 4986 CONSTRAINT pr_data_admin pr_data_admin_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin pr_data_admin_pk"
[exec] pg_restore: finished item 4986 CONSTRAINT pr_data_admin pr_data_admin_pk
[exec] pg_restore: launching item 4980 INDEX cleardataadminstartflowsbywp
[exec] pg_restore: pg_restore: creating INDEX "data.cleardataadminstartflowsbywp"
[exec] finished item 4979 CONSTRAINT pr_data pr_data_pk
[exec] pg_restore: launching item 4977 INDEX assoc_data
[exec] pg_restore: creating INDEX "data.assoc_data"
[exec] pg_restore: finished item 4977 INDEX assoc_data
[exec] pg_restore: launching item 4981 INDEX cleardataadminstartflowsforag
[exec] pg_restore: creating INDEX "data.cleardataadminstartflowsforag"
[exec] pg_restore: finished item 4980 INDEX cleardataadminstartflowsbywp
[exec] pg_restore: launching item 4982 INDEX clearstartflowsbyapp
[exec] pg_restore: creating INDEX "data.clearstartflowsbyapp"
[exec] pg_restore: finished item 4982 INDEX clearstartflowsbyapp
[exec] pg_restore: launching item 4983 INDEX pr_data_admin_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_admin_idx1"
[exec] finished item 4981 INDEX cleardataadminstartflowsforag
[exec] pg_restore: launching item 4984 INDEX pr_data_admin_idx2
[exec] pg_restore: creating INDEX "data.pr_data_admin_idx2"
[exec] pg_restore: finished item 4983 INDEX pr_data_admin_idx1
[exec] pg_restore: launching item 5504 CONSTRAINT pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk"
[exec] pg_restore: finished item 4984 INDEX pr_data_admin_idx2
[exec] pg_restore: launching item 4988 CONSTRAINT pr_data_admin_tenant pr_data_admin_tenant_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_tenant pr_data_admin_tenant_pk"
[exec] pg_restore: finished item 5504 CONSTRAINT pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk
[exec] pg_restore: launching item 4900 CONSTRAINT pr_data_analysis_specification pr_data_analysis_spec_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_analysis_specification pr_data_analysis_spec_pk"
[exec] pg_restore: finished item 4988 CONSTRAINT pr_data_admin_tenant pr_data_admin_tenant_pk
[exec] pg_restore: launching item 5679 CONSTRAINT pr_data_app_oauth2client pr_data_app_oauth2client_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_app_oauth2client pr_data_app_oauth2client_pk"
[exec] pg_restore: finished item 4900 CONSTRAINT pr_data_analysis_specification pr_data_analysis_spec_pk
[exec] pg_restore: launching item 4901 INDEX pr_data_analysis_spec_product
[exec] pg_restore: creating INDEX "data.pr_data_analysis_spec_product"
[exec] pg_restore: finished item 5679 CONSTRAINT pr_data_app_oauth2client pr_data_app_oauth2client_pk
[exec] pg_restore: launching item 5677 INDEX pr_data_app_oauth2client_idx1
[exec] pg_restore: creating INDEX "data.pr_data_app_oauth2client_idx1"
[exec] pg_restore: finished item 4901 INDEX pr_data_analysis_spec_product
[exec] pg_restore: launching item 5702 CONSTRAINT pr_data_appalias_authservice pr_data_appalias_aut_1610_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_appalias_authservice pr_data_appalias_aut_1610_pk"
[exec] pg_restore: finished item 5677 INDEX pr_data_app_oauth2client_idx1
[exec] pg_restore: launching item 5579 CONSTRAINT pr_data_application_quality pr_data_application_5304_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_application_quality pr_data_application_5304_pk"
[exec] pg_restore: finished item 5702 CONSTRAINT pr_data_appalias_authservice pr_data_appalias_aut_1610_pk
[exec] pg_restore: launching item 5700 INDEX pr_data_appalias_aut_1610_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_appalias_aut_1610_idx1"
[exec] finished item 5579 CONSTRAINT pr_data_application_quality pr_data_application_5304_pk
[exec] pg_restore: launching item 5577 INDEX pr_data_application_5304_idx1
[exec] pg_restore: creating INDEX "data.pr_data_application_5304_idx1"
[exec] pg_restore: finished item 5577 INDEX pr_data_application_5304_idx1
[exec] pg_restore: launching item 4912 CONSTRAINT pr_data_autotest pr_data_autotest_pk
[exec] pg_restore: finished item 5700 INDEX pr_data_appalias_aut_1610_idx1
[exec] pg_restore: launching item 5524 CONSTRAINT pr_data_category pr_data_category_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_autotest pr_data_autotest_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_category pr_data_category_pk"
[exec] pg_restore: finished item 5524 CONSTRAINT pr_data_category pr_data_category_pk
[exec] pg_restore: launching item 5522 INDEX pr_data_category_idx1
[exec] pg_restore: pg_restore: finished item 4912 CONSTRAINT pr_data_autotest pr_data_autotest_pk
[exec] pg_restore: creating INDEX "data.pr_data_category_idx1"
[exec] launching item 4908 INDEX pr_data_at_exestat
[exec] pg_restore: creating INDEX "data.pr_data_at_exestat"
[exec] pg_restore: finished item 4908 INDEX pr_data_at_exestat
[exec] pg_restore: launching item 4909 INDEX pr_data_at_obj
[exec] pg_restore: creating INDEX "data.pr_data_at_obj"
[exec] pg_restore: finished item 5522 INDEX pr_data_category_idx1
[exec] pg_restore: launching item 4910 INDEX pr_data_at_reqop
[exec] pg_restore: creating INDEX "data.pr_data_at_reqop"
[exec] pg_restore: finished item 4910 INDEX pr_data_at_reqop
[exec] pg_restore: launching item 5417 CONSTRAINT pr_data_applicationpreference pr_data_apppref_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_applicationpreference pr_data_apppref_pk"
[exec] finished item 4909 INDEX pr_data_at_obj
[exec] pg_restore: launching item 5644 CONSTRAINT pr_data_collaboration pr_data_collaboration_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_collaboration pr_data_collaboration_pk"
[exec] pg_restore: finished item 5417 CONSTRAINT pr_data_applicationpreference pr_data_apppref_pk
[exec] pg_restore: launching item 5415 INDEX pr_data_apppref_idx1
[exec] pg_restore: creating INDEX "data.pr_data_apppref_idx1"
[exec] pg_restore: finished item 5644 CONSTRAINT pr_data_collaboration pr_data_collaboration_pk
[exec] pg_restore: launching item 5642 INDEX pr_data_collaboration_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_collaboration_idx1"
[exec] finished item 5415 INDEX pr_data_apppref_idx1
[exec] pg_restore: launching item 5729 CONSTRAINT pr_data_configuration_audit pr_data_config_audit_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_configuration_audit pr_data_config_audit_pk"
[exec] pg_restore: finished item 5729 CONSTRAINT pr_data_configuration_audit pr_data_config_audit_pk
[exec] pg_restore: launching item 5727 INDEX pr_data_config_audit_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_config_audit_idx1"
[exec] finished item 5642 INDEX pr_data_collaboration_idx1
[exec] pg_restore: launching item 4852 CONSTRAINT pr_data_custm_date_fmt pr_data_custm_date_fmt_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_custm_date_fmt pr_data_custm_date_fmt_pk"
[exec] pg_restore: finished item 4852 CONSTRAINT pr_data_custm_date_fmt pr_data_custm_date_fmt_pk
[exec] pg_restore: launching item 5713 CONSTRAINT pr_data_configuration_setting pr_data_configuratio_2969_pk
[exec] pg_restore: finished item 5727 INDEX pr_data_config_audit_idx1
[exec] pg_restore: launching item 5651 CONSTRAINT pr_data_decision_biasresults pr_data_decision_br_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_configuration_setting pr_data_configuratio_2969_pk"
[exec] creating CONSTRAINT "data.pr_data_decision_biasresults pr_data_decision_br_pk"
[exec] pg_restore: finished item 5713 CONSTRAINT pr_data_configuration_setting pr_data_configuratio_2969_pk
[exec] pg_restore: launching item 5711 INDEX pr_data_configuratio_2969_idx1
[exec] pg_restore: finished item 5651 CONSTRAINT pr_data_decision_biasresults pr_data_decision_br_pk
[exec] pg_restore: launching item 5649 INDEX pr_data_decision_br_idx1
[exec] pg_restore: creating INDEX "data.pr_data_configuratio_2969_idx1"
[exec] pg_restore: creating INDEX "data.pr_data_decision_br_idx1"
[exec] pg_restore: finished item 5649 INDEX pr_data_decision_br_idx1
[exec] pg_restore: launching item 5303 CONSTRAINT pr_data_decision_ddf_error pr_data_ddf_error_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_error pr_data_ddf_error_pk"
[exec] pg_restore: finished item 5711 INDEX pr_data_configuratio_2969_idx1
[exec] pg_restore: launching item 5493 CONSTRAINT pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk"
[exec] pg_restore: finished item 5303 CONSTRAINT pr_data_decision_ddf_error pr_data_ddf_error_pk
[exec] pg_restore: launching item 5301 INDEX pr_data_ddf_error_idx1
[exec] pg_restore: creating INDEX "data.pr_data_ddf_error_idx1"
[exec] pg_restore: finished item 5493 CONSTRAINT pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk
[exec] pg_restore: launching item 5487 INDEX pr_data_decision_ddf_opts_idx1
[exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx1"
[exec] pg_restore: finished item 5301 INDEX pr_data_ddf_error_idx1
[exec] pg_restore: launching item 5488 INDEX pr_data_decision_ddf_opts_idx2
[exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx2"
[exec] pg_restore: finished item 5487 INDEX pr_data_decision_ddf_opts_idx1
[exec] pg_restore: launching item 5489 INDEX pr_data_decision_ddf_opts_idx3
[exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx3"
[exec] pg_restore: finished item 5488 INDEX pr_data_decision_ddf_opts_idx2
[exec] pg_restore: launching item 5490 INDEX pr_data_decision_ddf_opts_idx4
[exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx4"
[exec] pg_restore: finished item 5489 INDEX pr_data_decision_ddf_opts_idx3
[exec] pg_restore: launching item 5491 INDEX pr_data_decision_ddf_opts_idx5
[exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx5"
[exec] pg_restore: finished item 5490 INDEX pr_data_decision_ddf_opts_idx4
[exec] pg_restore: launching item 4866 CONSTRAINT pr_data_decision_df_met pr_data_decision_df_met_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_df_met pr_data_decision_df_met_pk"
[exec] pg_restore: finished item 5491 INDEX pr_data_decision_ddf_opts_idx5
[exec] pg_restore: launching item 4870 CONSTRAINT pr_data_decision_ddf_runtime pr_data_decision_runtime_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_runtime pr_data_decision_runtime_pk"
[exec] pg_restore: finished item 4866 CONSTRAINT pr_data_decision_df_met pr_data_decision_df_met_pk
[exec] pg_restore: launching item 4863 INDEX pr_data_decision_df_met_idx1
[exec] pg_restore: creating INDEX "data.pr_data_decision_df_met_idx1"
[exec] pg_restore: finished item 4870 CONSTRAINT pr_data_decision_ddf_runtime pr_data_decision_runtime_pk
[exec] pg_restore: launching item 4864 INDEX pr_data_decision_df_met_idx2
[exec] pg_restore: creating INDEX "data.pr_data_decision_df_met_idx2"
[exec] pg_restore: finished item 4863 INDEX pr_data_decision_df_met_idx1
[exec] pg_restore: launching item 4867 INDEX pr_data_decision_runtime_idx1
[exec] pg_restore: creating INDEX "data.pr_data_decision_runtime_idx1"
[exec] pg_restore: finished item 4864 INDEX pr_data_decision_df_met_idx2
[exec] pg_restore: launching item 4868 INDEX pr_data_decision_runtime_idx2
[exec] pg_restore: creating INDEX "data.pr_data_decision_runtime_idx2"
[exec] pg_restore: finished item 4868 INDEX pr_data_decision_runtime_idx2
[exec] pg_restore: launching item 4862 CONSTRAINT pr_data_decision_df_part pr_data_decision_df_part_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_decision_df_part pr_data_decision_df_part_pk"
[exec] finished item 4867 INDEX pr_data_decision_runtime_idx1
[exec] pg_restore: launching item 5392 CONSTRAINT pr_data_distinctvalueindex pr_data_distinctvalue_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_distinctvalueindex pr_data_distinctvalue_pk"
[exec] pg_restore: finished item 4862 CONSTRAINT pr_data_decision_df_part pr_data_decision_df_part_pk
[exec] pg_restore: launching item 4858 INDEX pr_data_decision_df_part_idx1
[exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx1"
[exec] pg_restore: finished item 5392 CONSTRAINT pr_data_distinctvalueindex pr_data_distinctvalue_pk
[exec] pg_restore: launching item 4859 INDEX pr_data_decision_df_part_idx2
[exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx2"
[exec] pg_restore: finished item 4858 INDEX pr_data_decision_df_part_idx1
[exec] pg_restore: launching item 4860 INDEX pr_data_decision_df_part_idx3
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_decision_df_part_idx3"
[exec] finished item 4859 INDEX pr_data_decision_df_part_idx2
[exec] pg_restore: launching item 5390 INDEX pr_data_distinctvalue_oc
[exec] pg_restore: creating INDEX "data.pr_data_distinctvalue_oc"
[exec] pg_restore: finished item 5390 INDEX pr_data_distinctvalue_oc
[exec] pg_restore: launching item 5197 CONSTRAINT pr_data_dm_admmart_model pr_data_dm_admmart_model_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_model pr_data_dm_admmart_model_pk"
[exec] finished item 4860 INDEX pr_data_decision_df_part_idx3
[exec] pg_restore: launching item 5200 CONSTRAINT pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk"
[exec] pg_restore: finished item 5200 CONSTRAINT pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk
[exec] pg_restore: launching item 5198 INDEX admmart_model_fact_idx
[exec] pg_restore: pg_restore: finished item 5197 CONSTRAINT pr_data_dm_admmart_model pr_data_dm_admmart_model_pk
[exec] pg_restore: creating INDEX "data.admmart_model_fact_idx"
[exec] launching item 5195 INDEX admmart_model_idx
[exec] pg_restore: creating INDEX "data.admmart_model_idx"
[exec] pg_restore: finished item 5195 INDEX admmart_model_idx
[exec] pg_restore: launching item 4836 CONSTRAINT pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk"
[exec] pg_restore: finished item 5198 INDEX admmart_model_fact_idx
[exec] pg_restore: launching item 5567 CONSTRAINT pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk"
[exec] pg_restore: finished item 5567 CONSTRAINT pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk
[exec] pg_restore: launching item 5568 INDEX pr_data_dm_contingency_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_dm_contingency_idx1"
[exec] finished item 4836 CONSTRAINT pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk
[exec] pg_restore: launching item 4834 INDEX pr_data_dm_admmart_pred_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dm_admmart_pred_idx1"
[exec] pg_restore: finished item 5568 INDEX pr_data_dm_contingency_idx1
[exec] pg_restore: launching item 5558 CONSTRAINT pr_data_dm_binarydistribution pr_data_dm_binarydist_pk
[exec] pg_restore: finished item 4834 INDEX pr_data_dm_admmart_pred_idx1
[exec] pg_restore: launching item 5561 CONSTRAINT pr_data_dm_histogram pr_data_dm_histogram_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_binarydistribution pr_data_dm_binarydist_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_histogram pr_data_dm_histogram_pk"
[exec] pg_restore: finished item 5561 CONSTRAINT pr_data_dm_histogram pr_data_dm_histogram_pk
[exec] pg_restore: launching item 5559 INDEX pr_data_dm_histogram_idx1
[exec] pg_restore: finished item 5558 CONSTRAINT pr_data_dm_binarydistribution pr_data_dm_binarydist_pk
[exec] pg_restore: launching item 5555 INDEX pr_data_dm_binarydist_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dm_histogram_idx1"
[exec] pg_restore: creating INDEX "data.pr_data_dm_binarydist_idx1"
[exec] pg_restore: finished item 5555 INDEX pr_data_dm_binarydist_idx1
[exec] pg_restore: launching item 5556 INDEX pr_data_dm_binarydist_idx2
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_dm_binarydist_idx2"
[exec] finished item 5559 INDEX pr_data_dm_histogram_idx1
[exec] pg_restore: launching item 5623 CONSTRAINT pr_data_dm_notification pr_data_dm_ntfctn_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_notification pr_data_dm_ntfctn_pk"
[exec] pg_restore: finished item 5556 INDEX pr_data_dm_binarydist_idx2
[exec] pg_restore: launching item 5565 CONSTRAINT pr_data_dm_snapshot pr_data_dm_snapshot_pk
[exec] pg_restore: finished item 5623 CONSTRAINT pr_data_dm_notification pr_data_dm_ntfctn_pk
[exec] pg_restore: launching item 5619 INDEX pr_data_dm_ntfctn_idx1
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_dm_snapshot pr_data_dm_snapshot_pk"
[exec] creating INDEX "data.pr_data_dm_ntfctn_idx1"
[exec] pg_restore: finished item 5619 INDEX pr_data_dm_ntfctn_idx1
[exec] pg_restore: launching item 5620 INDEX pr_data_dm_ntfctn_idx2
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx2"
[exec] finished item 5565 CONSTRAINT pr_data_dm_snapshot pr_data_dm_snapshot_pk
[exec] pg_restore: launching item 5621 INDEX pr_data_dm_ntfctn_idx3
[exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx3"
[exec] pg_restore: finished item 5620 INDEX pr_data_dm_ntfctn_idx2
[exec] pg_restore: launching item 5562 INDEX pr_data_dm_snapshot_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dm_snapshot_idx1"
[exec] pg_restore: finished item 5621 INDEX pr_data_dm_ntfctn_idx3
[exec] pg_restore: launching item 5563 INDEX pr_data_dm_snapshot_idx2
[exec] pg_restore: creating INDEX "data.pr_data_dm_snapshot_idx2"
[exec] pg_restore: finished item 5562 INDEX pr_data_dm_snapshot_idx1
[exec] pg_restore: launching item 5276 CONSTRAINT pr_data_dms_customer_data pr_data_dms_customer_data_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_customer_data pr_data_dms_customer_data_pk"
[exec] pg_restore: finished item 5563 INDEX pr_data_dm_snapshot_idx2
[exec] pg_restore: launching item 5552 CONSTRAINT pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk"
[exec] pg_restore: finished item 5552 CONSTRAINT pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk
[exec] pg_restore: launching item 5287 CONSTRAINT pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk
[exec] pg_restore: pg_restore: finished item 5276 CONSTRAINT pr_data_dms_customer_data pr_data_dms_customer_data_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk"
[exec] launching item 5274 INDEX pr_data_dms_customer_data_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dms_customer_data_idx1"
[exec] pg_restore: finished item 5287 CONSTRAINT pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk
[exec] pg_restore: launching item 5279 CONSTRAINT pr_data_dms_device pr_data_dms_device_pk
[exec] pg_restore: pg_restore: finished item 5274 INDEX pr_data_dms_customer_data_idx1
[exec] creating CONSTRAINT "data.pr_data_dms_device pr_data_dms_device_pk"
[exec] pg_restore: launching item 5351 CONSTRAINT pr_data_dms_survey_data pr_data_dms_survey_data_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_survey_data pr_data_dms_survey_data_pk"
[exec] pg_restore: finished item 5351 CONSTRAINT pr_data_dms_survey_data pr_data_dms_survey_data_pk
[exec] pg_restore: launching item 5282 CONSTRAINT pr_data_dms_purchase pr_data_dms_purchase_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_purchase pr_data_dms_purchase_pk"
[exec] pg_restore: finished item 5282 CONSTRAINT pr_data_dms_purchase pr_data_dms_purchase_pk
[exec] pg_restore: launching item 5280 INDEX pr_data_dms_purchase_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dms_purchase_idx1"
[exec] pg_restore: finished item 5279 CONSTRAINT pr_data_dms_device pr_data_dms_device_pk
[exec] pg_restore: launching item 5277 INDEX pr_data_dms_device_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dms_device_idx1"
[exec] pg_restore: finished item 5277 INDEX pr_data_dms_device_idx1
[exec] pg_restore: launching item 5289 CONSTRAINT pr_data_dms_global pr_data_dms_global_pk
[exec] pg_restore: finished item 5280 INDEX pr_data_dms_purchase_idx1
[exec] pg_restore: launching item 5285 CONSTRAINT pr_data_dms_subscription pr_data_dms_subscription_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_global pr_data_dms_global_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_subscription pr_data_dms_subscription_pk"
[exec] pg_restore: finished item 5285 CONSTRAINT pr_data_dms_subscription pr_data_dms_subscription_pk
[exec] pg_restore: launching item 5283 INDEX pr_data_dms_subscription_idx1
[exec] pg_restore: creating INDEX "data.pr_data_dms_subscription_idx1"
[exec] pg_restore: finished item 5289 CONSTRAINT pr_data_dms_global pr_data_dms_global_pk
[exec] pg_restore: launching item 5608 CONSTRAINT pr_data_explain_simulation pr_data_explain_simu_1179_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_explain_simulation pr_data_explain_simu_1179_pk"
[exec] pg_restore: finished item 5283 INDEX pr_data_dms_subscription_idx1
[exec] pg_restore: launching item 5615 CONSTRAINT pr_data_full_sync_stats pr_offline_fullsync_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_full_sync_stats pr_offline_fullsync_pk"
[exec] pg_restore: finished item 5608 CONSTRAINT pr_data_explain_simulation pr_data_explain_simu_1179_pk
[exec] pg_restore: launching item 5606 INDEX pr_data_explain_simu_1179_idx1
[exec] pg_restore: creating INDEX "data.pr_data_explain_simu_1179_idx1"
[exec] pg_restore: finished item 5606 INDEX pr_data_explain_simu_1179_idx1
[exec] pg_restore: launching item 4895 CONSTRAINT pr_data_file pr_data_file_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_file pr_data_file_pk"
[exec] pg_restore: finished item 5615 CONSTRAINT pr_data_full_sync_stats pr_offline_fullsync_pk
[exec] pg_restore: launching item 5612 INDEX pr_offline_fullsync_idx1
[exec] pg_restore: creating INDEX "data.pr_offline_fullsync_idx1"
[exec] pg_restore: finished item 4895 CONSTRAINT pr_data_file pr_data_file_pk
[exec] pg_restore: launching item 5613 INDEX pr_offline_fullsync_idx2
[exec] pg_restore: finished item 5612 INDEX pr_offline_fullsync_idx1
[exec] pg_restore: launching item 4893 INDEX datafile_pd
[exec] pg_restore: creating INDEX "data.pr_offline_fullsync_idx2"
[exec] pg_restore: creating INDEX "data.datafile_pd"
[exec] pg_restore: finished item 5613 INDEX pr_offline_fullsync_idx2
[exec] pg_restore: launching item 4897 CONSTRAINT pr_data_guardrails pr_data_guardrails_pk
[exec] pg_restore: pg_restore: finished item 4893 INDEX datafile_pd
[exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails pr_data_guardrails_pk"
[exec] launching item 5358 CONSTRAINT pr_data_features pr_data_features_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_features pr_data_features_pk"
[exec] pg_restore: finished item 4897 CONSTRAINT pr_data_guardrails pr_data_guardrails_pk
[exec] pg_restore: launching item 4898 INDEX pr_data_guardrails_product
[exec] pg_restore: creating INDEX "data.pr_data_guardrails_product"
[exec] pg_restore: finished item 5358 CONSTRAINT pr_data_features pr_data_features_pk
[exec] pg_restore: launching item 5356 INDEX pr_data_features_idx1
[exec] pg_restore: creating INDEX "data.pr_data_features_idx1"
[exec] pg_restore: finished item 4898 INDEX pr_data_guardrails_product
[exec] pg_restore: launching item 5659 CONSTRAINT pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk"
[exec] pg_restore: finished item 5356 INDEX pr_data_features_idx1
[exec] pg_restore: launching item 5661 CONSTRAINT pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk"
[exec] pg_restore: finished item 5659 CONSTRAINT pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk
[exec] pg_restore: launching item 5656 INDEX pr_data_guardrails_e_8355_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_guardrails_e_8355_idx1"
[exec] finished item 5661 CONSTRAINT pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk
[exec] pg_restore: launching item 5657 INDEX pr_data_guardrails_e_8355_idx2
[exec] pg_restore: creating INDEX "data.pr_data_guardrails_e_8355_idx2"
[exec] pg_restore: finished item 5657 INDEX pr_data_guardrails_e_8355_idx2
[exec] pg_restore: launching item 5573 CONSTRAINT pr_data_healthcheck pr_data_healthcheck_pk
[exec] pg_restore: pg_restore: finished item 5656 INDEX pr_data_guardrails_e_8355_idx1
[exec] creating CONSTRAINT "data.pr_data_healthcheck pr_data_healthcheck_pk"
[exec] pg_restore: launching item 5235 CONSTRAINT pr_data_ih_association pr_data_ih_association_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_association pr_data_ih_association_pk"
[exec] pg_restore: finished item 5235 CONSTRAINT pr_data_ih_association pr_data_ih_association_pk
[exec] pg_restore: launching item 5233 INDEX pr_data_ih_association_idx1
[exec] pg_restore: creating INDEX "data.pr_data_ih_association_idx1"
[exec] pg_restore: finished item 5573 CONSTRAINT pr_data_healthcheck pr_data_healthcheck_pk
[exec] pg_restore: launching item 5569 INDEX pr_data_healthcheck_idx1
[exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx1"
[exec] pg_restore: finished item 5233 INDEX pr_data_ih_association_idx1
[exec] pg_restore: launching item 5570 INDEX pr_data_healthcheck_idx2
[exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx2"
[exec] pg_restore: finished item 5569 INDEX pr_data_healthcheck_idx1
[exec] pg_restore: launching item 5571 INDEX pr_data_healthcheck_idx3
[exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx3"
[exec] pg_restore: finished item 5570 INDEX pr_data_healthcheck_idx2
[exec] pg_restore: launching item 5220 CONSTRAINT pr_data_ih_dim_context pr_data_ih_dim_context_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_context pr_data_ih_dim_context_pk"
[exec] pg_restore: finished item 5571 INDEX pr_data_healthcheck_idx3
[exec] pg_restore: launching item 5212 CONSTRAINT pr_data_ih_dim_action pr_data_ih_dim_action_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_action pr_data_ih_dim_action_pk"
[exec] pg_restore: finished item 5220 CONSTRAINT pr_data_ih_dim_context pr_data_ih_dim_context_pk
[exec] pg_restore: launching item 5222 CONSTRAINT pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk"
[exec] pg_restore: finished item 5212 CONSTRAINT pr_data_ih_dim_action pr_data_ih_dim_action_pk
[exec] pg_restore: launching item 5224 CONSTRAINT pr_data_ih_dim_channel pr_data_ih_dim_channel_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_channel pr_data_ih_dim_channel_pk"
[exec] pg_restore: finished item 5224 CONSTRAINT pr_data_ih_dim_channel pr_data_ih_dim_channel_pk
[exec] pg_restore: launching item 5216 CONSTRAINT pr_data_ih_dim_location pr_data_ih_dim_location_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_location pr_data_ih_dim_location_pk"
[exec] finished item 5222 CONSTRAINT pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk
[exec] pg_restore: launching item 5226 CONSTRAINT pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk"
[exec] pg_restore: finished item 5216 CONSTRAINT pr_data_ih_dim_location pr_data_ih_dim_location_pk
[exec] pg_restore: launching item 5214 CONSTRAINT pr_data_ih_dim_customer pr_data_ih_dim_customer_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_customer pr_data_ih_dim_customer_pk"
[exec] pg_restore: finished item 5226 CONSTRAINT pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk
[exec] pg_restore: launching item 5389 CONSTRAINT pr_data_ih_dim_journey pr_data_ih_dim_journey_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_journey pr_data_ih_dim_journey_pk"
[exec] pg_restore: finished item 5389 CONSTRAINT pr_data_ih_dim_journey pr_data_ih_dim_journey_pk
[exec] pg_restore: launching item 5218 CONSTRAINT pr_data_ih_dim_operator pr_data_ih_dim_operator_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_operator pr_data_ih_dim_operator_pk"
[exec] pg_restore: finished item 5214 CONSTRAINT pr_data_ih_dim_customer pr_data_ih_dim_customer_pk
[exec] pg_restore: launching item 5232 CONSTRAINT pr_data_ih_fact pr_data_ih_fact_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_fact pr_data_ih_fact_pk"
[exec] pg_restore: finished item 5218 CONSTRAINT pr_data_ih_dim_operator pr_data_ih_dim_operator_pk
[exec] pg_restore: launching item 5576 CONSTRAINT pr_data_integrationsystem pr_data_integrationsystem_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_integrationsystem pr_data_integrationsystem_pk"
[exec] pg_restore: finished item 5232 CONSTRAINT pr_data_ih_fact pr_data_ih_fact_pk
[exec] pg_restore: launching item 5227 INDEX pr_data_ih_fact_idx1
[exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx1"
[exec] pg_restore: finished item 5227 INDEX pr_data_ih_fact_idx1
[exec] pg_restore: launching item 5228 INDEX pr_data_ih_fact_idx2
[exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx2"
[exec] pg_restore: finished item 5576 CONSTRAINT pr_data_integrationsystem pr_data_integrationsystem_pk
[exec] pg_restore: launching item 5229 INDEX pr_data_ih_fact_idx3
[exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx3"
[exec] pg_restore: finished item 5228 INDEX pr_data_ih_fact_idx2
[exec] pg_restore: launching item 5230 INDEX pr_data_ih_fact_idx4
[exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx4"
[exec] pg_restore: finished item 5229 INDEX pr_data_ih_fact_idx3
[exec] pg_restore: launching item 5574 INDEX pr_data_integrationsystem_idx1
[exec] pg_restore: creating INDEX "data.pr_data_integrationsystem_idx1"
[exec] pg_restore: finished item 5230 INDEX pr_data_ih_fact_idx4
[exec] pg_restore: launching item 4857 CONSTRAINT pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk"
[exec] pg_restore: finished item 5574 INDEX pr_data_integrationsystem_idx1
[exec] pg_restore: launching item 5246 CONSTRAINT pr_data_mobile_appinfo pr_data_mobile_appinfo_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_appinfo pr_data_mobile_appinfo_pk"
[exec] pg_restore: finished item 4857 CONSTRAINT pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk
[exec] pg_restore: launching item 5242 CONSTRAINT pr_data_mobile_asset pr_data_mobile_asset_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_mobile_asset pr_data_mobile_asset_pk"
[exec] finished item 5246 CONSTRAINT pr_data_mobile_appinfo pr_data_mobile_appinfo_pk
[exec] pg_restore: launching item 5240 CONSTRAINT pr_data_mobile_build pr_data_mobile_build_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_build pr_data_mobile_build_pk"
[exec] pg_restore: finished item 5240 CONSTRAINT pr_data_mobile_build pr_data_mobile_build_pk
[exec] pg_restore: launching item 5244 CONSTRAINT pr_data_mobile_certificate pr_data_mobile_certificate_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_mobile_certificate pr_data_mobile_certificate_pk"
[exec] finished item 5242 CONSTRAINT pr_data_mobile_asset pr_data_mobile_asset_pk
[exec] pg_restore: launching item 5435 CONSTRAINT pr_data_mobile_map_track pr_data_mobile_map_track_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_map_track pr_data_mobile_map_track_pk"
[exec] pg_restore: finished item 5244 CONSTRAINT pr_data_mobile_certificate pr_data_mobile_certificate_pk
[exec] pg_restore: launching item 5330 CONSTRAINT pr_data_mobile_device pr_data_mobile_device_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_device pr_data_mobile_device_pk"
[exec] pg_restore: finished item 5435 CONSTRAINT pr_data_mobile_map_track pr_data_mobile_map_track_pk
[exec] pg_restore: launching item 5433 INDEX pr_data_mobile_map_idx1
[exec] pg_restore: creating INDEX "data.pr_data_mobile_map_idx1"
[exec] pg_restore: finished item 5433 INDEX pr_data_mobile_map_idx1
[exec] pg_restore: launching item 5438 CONSTRAINT pr_data_mobile_map_user pr_data_mobile_map_user_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_mobile_map_user pr_data_mobile_map_user_pk"
[exec] finished item 5330 CONSTRAINT pr_data_mobile_device pr_data_mobile_device_pk
[exec] pg_restore: launching item 5311 CONSTRAINT pr_data_nlp_details pr_data_nlp_result_d_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_details pr_data_nlp_result_d_pk"
[exec] pg_restore: finished item 5438 CONSTRAINT pr_data_mobile_map_user pr_data_mobile_map_user_pk
[exec] pg_restore: launching item 5436 INDEX pr_data_mobile_map_user_idx1
[exec] pg_restore: creating INDEX "data.pr_data_mobile_map_user_idx1"
[exec] pg_restore: finished item 5311 CONSTRAINT pr_data_nlp_details pr_data_nlp_result_d_pk
[exec] pg_restore: launching item 5308 INDEX pr_data_nlp_d_pxdocid_idx
[exec] pg_restore: creating INDEX "data.pr_data_nlp_d_pxdocid_idx"
[exec] pg_restore: finished item 5436 INDEX pr_data_mobile_map_user_idx1
[exec] pg_restore: launching item 5309 INDEX pr_data_nlp_d_pytype_idx
[exec] pg_restore: pg_restore: finished item 5308 INDEX pr_data_nlp_d_pxdocid_idx
[exec] creating INDEX "data.pr_data_nlp_d_pytype_idx"
[exec] pg_restore: launching item 5396 CONSTRAINT pr_data_nlp_model_training pr_data_nlp_model_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_model_training pr_data_nlp_model_pk"
[exec] pg_restore: finished item 5396 CONSTRAINT pr_data_nlp_model_training pr_data_nlp_model_pk
[exec] pg_restore: launching item 5393 INDEX pr_data_nlp_model_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_nlp_model_idx1"
[exec] finished item 5309 INDEX pr_data_nlp_d_pytype_idx
[exec] pg_restore: launching item 5394 INDEX pr_data_nlp_model_idx2
[exec] pg_restore: creating INDEX "data.pr_data_nlp_model_idx2"
[exec] pg_restore: finished item 5394 INDEX pr_data_nlp_model_idx2
[exec] pg_restore: launching item 5721 CONSTRAINT pr_data_nlp_reporting pr_data_nlp_reporting_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_reporting pr_data_nlp_reporting_pk"
[exec] pg_restore: finished item 5393 INDEX pr_data_nlp_model_idx1
[exec] pg_restore: launching item 5717 CONSTRAINT pr_data_nlp_snapshot pr_data_nlp_snapshot_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_snapshot pr_data_nlp_snapshot_pk"
[exec] pg_restore: finished item 5717 CONSTRAINT pr_data_nlp_snapshot pr_data_nlp_snapshot_pk
[exec] pg_restore: launching item 5714 INDEX pr_data_nlp_snapshot_idx1
[exec] pg_restore: creating INDEX "data.pr_data_nlp_snapshot_idx1"
[exec] pg_restore: finished item 5721 CONSTRAINT pr_data_nlp_reporting pr_data_nlp_reporting_pk
[exec] pg_restore: launching item 5718 INDEX pr_data_nlp_reporting_idx1
[exec] pg_restore: creating INDEX "data.pr_data_nlp_reporting_idx1"
[exec] pg_restore: finished item 5714 INDEX pr_data_nlp_snapshot_idx1
[exec] pg_restore: launching item 5719 INDEX pr_data_nlp_reporting_idx2
[exec] pg_restore: creating INDEX "data.pr_data_nlp_reporting_idx2"
[exec] pg_restore: finished item 5718 INDEX pr_data_nlp_reporting_idx1
[exec] pg_restore: launching item 5715 INDEX pr_data_nlp_snapshot_idx2
[exec] pg_restore: creating INDEX "data.pr_data_nlp_snapshot_idx2"
[exec] pg_restore: finished item 5719 INDEX pr_data_nlp_reporting_idx2
[exec] pg_restore: launching item 5699 CONSTRAINT pr_data_nlp_status pr_data_nlp_status_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_status pr_data_nlp_status_pk"
[exec] pg_restore: finished item 5715 INDEX pr_data_nlp_snapshot_idx2
[exec] pg_restore: launching item 5420 CONSTRAINT pr_data_offline_sync pr_data_offline_sync_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_offline_sync pr_data_offline_sync_pk"
[exec] pg_restore: finished item 5420 CONSTRAINT pr_data_offline_sync pr_data_offline_sync_pk
[exec] pg_restore: launching item 5418 INDEX pr_data_offline_sync_idx1
[exec] pg_restore: creating INDEX "data.pr_data_offline_sync_idx1"
[exec] pg_restore: finished item 5699 CONSTRAINT pr_data_nlp_status pr_data_nlp_status_pk
[exec] pg_restore: launching item 5695 INDEX pr_data_nlp_status_idx1
[exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx1"
[exec] pg_restore: finished item 5418 INDEX pr_data_offline_sync_idx1
[exec] pg_restore: launching item 5696 INDEX pr_data_nlp_status_idx2
[exec] pg_restore: pg_restore: finished item 5695 INDEX pr_data_nlp_status_idx1
[exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx2"
[exec] launching item 5697 INDEX pr_data_nlp_status_idx3
[exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx3"
[exec] pg_restore: finished item 5697 INDEX pr_data_nlp_status_idx3
[exec] pg_restore: launching item 5305 CONSTRAINT pr_data_nlp_summary pr_data_nlp_result_pk
[exec] pg_restore: finished item 5696 INDEX pr_data_nlp_status_idx2
[exec] pg_restore: launching item 5367 CONSTRAINT pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_summary pr_data_nlp_result_pk"
[exec] pg_restore: finished item 5367 CONSTRAINT pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk
[exec] pg_restore: launching item 5365 INDEX pr_data_ntfctn_rcpnt_idx1
[exec] pg_restore: creating INDEX "data.pr_data_ntfctn_rcpnt_idx1"
[exec] pg_restore: finished item 5305 CONSTRAINT pr_data_nlp_summary pr_data_nlp_result_pk
[exec] pg_restore: launching item 5306 INDEX pr_data_nlp_s_pydatasetid_idx
[exec] pg_restore: creating INDEX "data.pr_data_nlp_s_pydatasetid_idx"
[exec] pg_restore: finished item 5306 INDEX pr_data_nlp_s_pydatasetid_idx
[exec] pg_restore: launching item 5307 INDEX pr_data_nlp_s_pysentiment_idx
[exec] pg_restore: pg_restore: finished item 5365 INDEX pr_data_ntfctn_rcpnt_idx1
[exec] pg_restore: creating INDEX "data.pr_data_nlp_s_pysentiment_idx"
[exec] launching item 5313 CONSTRAINT pr_data_pegasample_product pr_data_pegasample_product_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_pegasample_product pr_data_pegasample_product_pk"
[exec] pg_restore: finished item 5313 CONSTRAINT pr_data_pegasample_product pr_data_pegasample_product_pk
[exec] pg_restore: launching item 5670 CONSTRAINT pr_data_op_session pr_data_op_session_pk
[exec] pg_restore: pg_restore: finished item 5307 INDEX pr_data_nlp_s_pysentiment_idx
[exec] creating CONSTRAINT "data.pr_data_op_session pr_data_op_session_pk"
[exec] pg_restore: launching item 5177 CONSTRAINT pr_data_pmf_worklist pr_data_pmf_worklist_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_pmf_worklist pr_data_pmf_worklist_pk"
[exec] pg_restore: finished item 5670 CONSTRAINT pr_data_op_session pr_data_op_session_pk
[exec] pg_restore: launching item 5665 INDEX pr_data_op_session_idx1
[exec] pg_restore: finished item 5177 CONSTRAINT pr_data_pmf_worklist pr_data_pmf_worklist_pk
[exec] pg_restore: launching item 5666 INDEX pr_data_op_session_idx2
[exec] pg_restore: creating INDEX "data.pr_data_op_session_idx1"
[exec] pg_restore: creating INDEX "data.pr_data_op_session_idx2"
[exec] pg_restore: finished item 5666 INDEX pr_data_op_session_idx2
[exec] pg_restore: launching item 5667 INDEX pr_data_op_session_idx3
[exec] pg_restore: finished item 5665 INDEX pr_data_op_session_idx1
[exec] pg_restore: launching item 5668 INDEX pr_data_op_session_idx4
[exec] pg_restore: creating INDEX "data.pr_data_op_session_idx3"
[exec] pg_restore: creating INDEX "data.pr_data_op_session_idx4"
[exec] pg_restore: finished item 5667 INDEX pr_data_op_session_idx3
[exec] pg_restore: launching item 5175 INDEX pmf_dev_integration_idx
[exec] pg_restore: pg_restore: creating INDEX "data.pmf_dev_integration_idx"
[exec] finished item 5668 INDEX pr_data_op_session_idx4
[exec] pg_restore: launching item 5618 CONSTRAINT pr_data_qp_run_partition pr_data_qp_run_partition_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_qp_run_partition pr_data_qp_run_partition_pk"
[exec] pg_restore: finished item 5175 INDEX pmf_dev_integration_idx
[exec] pg_restore: launching item 5210 CONSTRAINT pr_data_recents pr_data_recents_pk
[exec] pg_restore: finished item 5618 CONSTRAINT pr_data_qp_run_partition pr_data_qp_run_partition_pk
[exec] pg_restore: launching item 5616 INDEX pr_data_qp_run_partition_idx1
[exec] pg_restore: creating INDEX "data.pr_data_qp_run_partition_idx1"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_recents pr_data_recents_pk"
[exec] pg_restore: finished item 5210 CONSTRAINT pr_data_recents pr_data_recents_pk
[exec] pg_restore: launching item 5208 INDEX pr_data_recents_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_recents_idx1"
[exec] finished item 5616 INDEX pr_data_qp_run_partition_idx1
[exec] pg_restore: launching item 4990 CONSTRAINT pr_data_reportcategory pr_data_reportcategory_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_reportcategory pr_data_reportcategory_pk"
[exec] pg_restore: finished item 4990 CONSTRAINT pr_data_reportcategory pr_data_reportcategory_pk
[exec] pg_restore: launching item 4992 CONSTRAINT pr_data_reportshortcut pr_data_reportshortcut_pk
[exec] pg_restore: pg_restore: finished item 5208 INDEX pr_data_recents_idx1
[exec] pg_restore: creating CONSTRAINT "data.pr_data_reportshortcut pr_data_reportshortcut_pk"
[exec] launching item 5502 CONSTRAINT pr_data_repositories pr_data_repositories_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_repositories pr_data_repositories_pk"
[exec] pg_restore: finished item 4992 CONSTRAINT pr_data_reportshortcut pr_data_reportshortcut_pk
[exec] pg_restore: launching item 5508 CONSTRAINT pr_data_retention_policy pr_data_retention_policy_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_retention_policy pr_data_retention_policy_pk"
[exec] pg_restore: finished item 5502 CONSTRAINT pr_data_repositories pr_data_repositories_pk
[exec] pg_restore: launching item 5500 INDEX data_repositoryname
[exec] pg_restore: creating INDEX "data.data_repositoryname"
[exec] pg_restore: finished item 5508 CONSTRAINT pr_data_retention_policy pr_data_retention_policy_pk
[exec] pg_restore: launching item 5505 INDEX pr_data_retention_policy_idx1
[exec] pg_restore: creating INDEX "data.pr_data_retention_policy_idx1"
[exec] pg_restore: finished item 5500 INDEX data_repositoryname
[exec] pg_restore: launching item 5506 INDEX pr_data_retention_policy_idx2
[exec] pg_restore: creating INDEX "data.pr_data_retention_policy_idx2"
[exec] pg_restore: finished item 5505 INDEX pr_data_retention_policy_idx1
[exec] pg_restore: launching item 5635 CONSTRAINT pr_data_rrcategories pr_data_rrcategories_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_rrcategories pr_data_rrcategories_pk"
[exec] pg_restore: finished item 5635 CONSTRAINT pr_data_rrcategories pr_data_rrcategories_pk
[exec] pg_restore: launching item 5633 INDEX pr_data_rrcategories_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_rrcategories_idx1"
[exec] finished item 5506 INDEX pr_data_retention_policy_idx2
[exec] pg_restore: launching item 5414 CONSTRAINT pr_data_rulecoverage_results pr_data_rcr_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_rulecoverage_results pr_data_rcr_pk"
[exec] pg_restore: finished item 5414 CONSTRAINT pr_data_rulecoverage_results pr_data_rcr_pk
[exec] pg_restore: launching item 5411 INDEX pr_data_rcr_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_rcr_idx1"
[exec] finished item 5633 INDEX pr_data_rrcategories_idx1
[exec] pg_restore: launching item 5412 INDEX pr_data_rcr_idx2
[exec] pg_restore: creating INDEX "data.pr_data_rcr_idx2"
[exec] pg_restore: finished item 5412 INDEX pr_data_rcr_idx2
[exec] pg_restore: launching item 5339 CONSTRAINT pr_data_saml_authreqcontext pr_data_saml_arc_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_authreqcontext pr_data_saml_arc_pk"
[exec] pg_restore: finished item 5411 INDEX pr_data_rcr_idx1
[exec] pg_restore: launching item 5336 CONSTRAINT pr_data_saml_logininfo pr_data_saml_logininfo_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_logininfo pr_data_saml_logininfo_pk"
[exec] pg_restore: finished item 5336 CONSTRAINT pr_data_saml_logininfo pr_data_saml_logininfo_pk
[exec] pg_restore: launching item 5334 INDEX pr_data_saml_logininfo_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_saml_logininfo_idx1"
[exec] finished item 5339 CONSTRAINT pr_data_saml_authreqcontext pr_data_saml_arc_pk
[exec] pg_restore: launching item 5337 INDEX pr_data_saml_arc_idx1
[exec] pg_restore: creating INDEX "data.pr_data_saml_arc_idx1"
[exec] pg_restore: finished item 5334 INDEX pr_data_saml_logininfo_idx1
[exec] pg_restore: launching item 5333 CONSTRAINT pr_data_saml_replaycache pr_data_saml_rc_pk
[exec] pg_restore: finished item 5337 INDEX pr_data_saml_arc_idx1
[exec] pg_restore: launching item 5345 CONSTRAINT pr_data_saml_logoutreqinfo pr_data_saml_logout_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_logoutreqinfo pr_data_saml_logout_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_replaycache pr_data_saml_rc_pk"
[exec] pg_restore: finished item 5345 CONSTRAINT pr_data_saml_logoutreqinfo pr_data_saml_logout_pk
[exec] pg_restore: launching item 5343 INDEX pr_data_saml_logout_idx1
[exec] pg_restore: creating INDEX "data.pr_data_saml_logout_idx1"
[exec] pg_restore: finished item 5333 CONSTRAINT pr_data_saml_replaycache pr_data_saml_rc_pk
[exec] pg_restore: launching item 5331 INDEX pr_data_saml_rc_idx1
[exec] pg_restore: creating INDEX "data.pr_data_saml_rc_idx1"
[exec] pg_restore: finished item 5343 INDEX pr_data_saml_logout_idx1
[exec] pg_restore: launching item 5349 CONSTRAINT pr_data_saml_requestorinfo pr_data_saml_requestor_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_requestorinfo pr_data_saml_requestor_pk"
[exec] pg_restore: finished item 5331 INDEX pr_data_saml_rc_idx1
[exec] pg_restore: launching item 5205 CONSTRAINT pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk"
[exec] pg_restore: finished item 5349 CONSTRAINT pr_data_saml_requestorinfo pr_data_saml_requestor_pk
[exec] pg_restore: launching item 5346 INDEX pr_data_saml_requestor_idx1
[exec] pg_restore: creating INDEX "data.pr_data_saml_requestor_idx1"
[exec] pg_restore: finished item 5205 CONSTRAINT pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk
[exec] pg_restore: launching item 5347 INDEX pr_data_saml_requestor_idx2
[exec] pg_restore: creating INDEX "data.pr_data_saml_requestor_idx2"
[exec] pg_restore: finished item 5346 INDEX pr_data_saml_requestor_idx1
[exec] pg_restore: launching item 5206 INDEX shoppingcartdispname
[exec] pg_restore: creating INDEX "data.shoppingcartdispname"
[exec] pg_restore: finished item 5347 INDEX pr_data_saml_requestor_idx2
[exec] pg_restore: launching item 5207 INDEX shoppingcartproductkey
[exec] pg_restore: creating INDEX "data.shoppingcartproductkey"
[exec] pg_restore: finished item 5206 INDEX shoppingcartdispname
[exec] pg_restore: launching item 5342 CONSTRAINT pr_data_saml_sessioninfo pr_data_saml_session_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_sessioninfo pr_data_saml_session_pk"
[exec] pg_restore: finished item 5207 INDEX shoppingcartproductkey
[exec] pg_restore: launching item 4994 CONSTRAINT pr_data_sample_uidetails pr_data_sample_uidetails_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_sample_uidetails pr_data_sample_uidetails_pk"
[exec] pg_restore: finished item 5342 CONSTRAINT pr_data_saml_sessioninfo pr_data_saml_session_pk
[exec] pg_restore: launching item 5340 INDEX pr_data_saml_session_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_data_saml_session_idx1"
[exec] finished item 4994 CONSTRAINT pr_data_sample_uidetails pr_data_sample_uidetails_pk
[exec] pg_restore: launching item 4996 CONSTRAINT pr_data_samplesrcustomer pr_data_samplesrcustomer_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrcustomer pr_data_samplesrcustomer_pk"
[exec] pg_restore: finished item 5340 INDEX pr_data_saml_session_idx1
[exec] pg_restore: launching item 4998 CONSTRAINT pr_data_samplesrproduct pr_data_samplesrproduct_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrproduct pr_data_samplesrproduct_pk"
[exec] pg_restore: finished item 4996 CONSTRAINT pr_data_samplesrcustomer pr_data_samplesrcustomer_pk
[exec] pg_restore: launching item 5690 CONSTRAINT pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk"
[exec] pg_restore: finished item 5690 CONSTRAINT pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk
[exec] pg_restore: launching item 5405 CONSTRAINT pr_data_stream_node_updates pr_data_strem_nodes_upd_pk
[exec] pg_restore: pg_restore: finished item 4998 CONSTRAINT pr_data_samplesrproduct pr_data_samplesrproduct_pk
[exec] creating CONSTRAINT "data.pr_data_stream_node_updates pr_data_strem_nodes_upd_pk"
[exec] pg_restore: launching item 5194 CONSTRAINT pr_data_social_reference pr_data_social_reference_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_social_reference pr_data_social_reference_pk"
[exec] pg_restore: finished item 5194 CONSTRAINT pr_data_social_reference pr_data_social_reference_pk
[exec] pg_restore: launching item 5192 INDEX pr_data_social_reference_idx1
[exec] pg_restore: finished item 5405 CONSTRAINT pr_data_stream_node_updates pr_data_strem_nodes_upd_pk
[exec] pg_restore: launching item 5000 CONSTRAINT pr_data_samplesrpurchase pr_data_samplesrpurchase_pk
[exec] pg_restore: creating INDEX "data.pr_data_social_reference_idx1"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrpurchase pr_data_samplesrpurchase_pk"
[exec] pg_restore: finished item 5192 INDEX pr_data_social_reference_idx1
[exec] pg_restore: launching item 5481 CONSTRAINT pr_data_smsaccount pr_data_smsaccount_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_smsaccount pr_data_smsaccount_pk"
[exec] pg_restore: finished item 5000 CONSTRAINT pr_data_samplesrpurchase pr_data_samplesrpurchase_pk
[exec] pg_restore: launching item 5401 CONSTRAINT pr_data_stream_sessions pr_data_stream_sessions_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_stream_sessions pr_data_stream_sessions_pk"
[exec] pg_restore: finished item 5481 CONSTRAINT pr_data_smsaccount pr_data_smsaccount_pk
[exec] pg_restore: launching item 5403 CONSTRAINT pr_data_stream_nodes pr_data_stream_nodes_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_stream_nodes pr_data_stream_nodes_pk"
[exec] pg_restore: finished item 5401 CONSTRAINT pr_data_stream_sessions pr_data_stream_sessions_pk
[exec] pg_restore: launching item 4840 CONSTRAINT pr_data_svcinvhist pr_data_svcinvhist_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_svcinvhist pr_data_svcinvhist_pk"
[exec] pg_restore: finished item 5403 CONSTRAINT pr_data_stream_nodes pr_data_stream_nodes_pk
[exec] pg_restore: launching item 5323 CONSTRAINT pr_data_tag_oplink pr_data_tag_oplink_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_tag_oplink pr_data_tag_oplink_pk"
[exec] pg_restore: finished item 4840 CONSTRAINT pr_data_svcinvhist pr_data_svcinvhist_pk
[exec] pg_restore: launching item 4837 INDEX pr_data_svcinvhist_idx1
[exec] pg_restore: creating INDEX "data.pr_data_svcinvhist_idx1"
[exec] pg_restore: finished item 4837 INDEX pr_data_svcinvhist_idx1
[exec] pg_restore: launching item 4838 INDEX pr_data_svcinvhist_idx2
[exec] pg_restore: creating INDEX "data.pr_data_svcinvhist_idx2"
[exec] pg_restore: finished item 5323 CONSTRAINT pr_data_tag_oplink pr_data_tag_oplink_pk
[exec] pg_restore: launching item 5321 INDEX pr_data_tag_oplink_ix1
[exec] pg_restore: creating INDEX "data.pr_data_tag_oplink_ix1"
[exec] pg_restore: finished item 5321 INDEX pr_data_tag_oplink_ix1
[exec] pg_restore: launching item 5164 CONSTRAINT pr_data_tag pr_data_tag_pk
[exec] pg_restore: finished item 4838 INDEX pr_data_svcinvhist_idx2
[exec] pg_restore: launching item 5002 CONSTRAINT pr_data_template_metadata pr_data_template_metadata_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_tag pr_data_tag_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_template_metadata pr_data_template_metadata_pk"
[exec] pg_restore: finished item 5002 CONSTRAINT pr_data_template_metadata pr_data_template_metadata_pk
[exec] pg_restore: launching item 5264 CONSTRAINT pr_data_testcaseresults pr_data_tcr_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_testcaseresults pr_data_tcr_pk"
[exec] pg_restore: finished item 5164 CONSTRAINT pr_data_tag pr_data_tag_pk
[exec] pg_restore: launching item 5325 CONSTRAINT pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk"
[exec] pg_restore: finished item 5264 CONSTRAINT pr_data_testcaseresults pr_data_tcr_pk
[exec] pg_restore: launching item 5261 INDEX pr_data_tcr_idx1
[exec] pg_restore: creating INDEX "data.pr_data_tcr_idx1"
[exec] pg_restore: finished item 5261 INDEX pr_data_tcr_idx1
[exec] pg_restore: launching item 5262 INDEX pr_data_tcr_idx2
[exec] pg_restore: finished item 5325 CONSTRAINT pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk
[exec] pg_restore: launching item 5326 INDEX pr_data_tag_rr_idx1
[exec] pg_restore: creating INDEX "data.pr_data_tag_rr_idx1"
[exec] pg_restore: creating INDEX "data.pr_data_tcr_idx2"
[exec] pg_restore: finished item 5262 INDEX pr_data_tcr_idx2
[exec] pg_restore: launching item 5371 CONSTRAINT pr_data_testsuiteresults pr_data_tsr_pk
[exec] pg_restore: finished item 5326 INDEX pr_data_tag_rr_idx1
[exec] pg_restore: launching item 5268 CONSTRAINT pr_data_token pr_data_token_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_token pr_data_token_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_data_testsuiteresults pr_data_tsr_pk"
[exec] pg_restore: finished item 5371 CONSTRAINT pr_data_testsuiteresults pr_data_tsr_pk
[exec] pg_restore: launching item 5368 INDEX pr_data_tsr_idx1
[exec] pg_restore: creating INDEX "data.pr_data_tsr_idx1"
[exec] pg_restore: finished item 5268 CONSTRAINT pr_data_token pr_data_token_pk
[exec] pg_restore: launching item 5369 INDEX pr_data_tsr_idx2
[exec] pg_restore: creating INDEX "data.pr_data_tsr_idx2"
[exec] pg_restore: finished item 5369 INDEX pr_data_tsr_idx2
[exec] pg_restore: launching item 5265 INDEX pr_data_token_idx1
[exec] pg_restore: creating INDEX "data.pr_data_token_idx1"
[exec] pg_restore: finished item 5368 INDEX pr_data_tsr_idx1
[exec] pg_restore: launching item 5266 INDEX pr_data_token_idx3
[exec] pg_restore: creating INDEX "data.pr_data_token_idx3"
[exec] pg_restore: finished item 5265 INDEX pr_data_token_idx1
[exec] pg_restore: launching item 5360 CONSTRAINT pr_data_toggle pr_data_toggle_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_toggle pr_data_toggle_pk"
[exec] pg_restore: finished item 5266 INDEX pr_data_token_idx3
[exec] pg_restore: launching item 5726 CONSTRAINT pr_data_user_activity pr_data_user_activity_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_data_user_activity pr_data_user_activity_pk"
[exec] pg_restore: finished item 5360 CONSTRAINT pr_data_toggle pr_data_toggle_pk
[exec] pg_restore: launching item 5676 CONSTRAINT pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk"
[exec] finished item 5726 CONSTRAINT pr_data_user_activity pr_data_user_activity_pk
[exec] pg_restore: launching item 5724 INDEX pr_data_user_activity_idx1
[exec] pg_restore: creating INDEX "data.pr_data_user_activity_idx1"
[exec] pg_restore: finished item 5724 INDEX pr_data_user_activity_idx1
[exec] pg_restore: launching item 4842 CONSTRAINT pr_extract_time pr_extract_time_pk
[exec] pg_restore: finished item 5676 CONSTRAINT pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk
[exec] pg_restore: launching item 5671 INDEX pr_data_token_blackl_1063_idx1
[exec] pg_restore: creating CONSTRAINT "data.pr_extract_time pr_extract_time_pk"
[exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx1"
[exec] pg_restore: finished item 4842 CONSTRAINT pr_extract_time pr_extract_time_pk
[exec] pg_restore: launching item 5672 INDEX pr_data_token_blackl_1063_idx2
[exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx2"
[exec] pg_restore: finished item 5671 INDEX pr_data_token_blackl_1063_idx1
[exec] pg_restore: launching item 5673 INDEX pr_data_token_blackl_1063_idx3
[exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx3"
[exec] pg_restore: finished item 5672 INDEX pr_data_token_blackl_1063_idx2
[exec] pg_restore: launching item 5674 INDEX pr_data_token_blackl_1063_idx4
[exec] pg_restore: pg_restore: finished item 5673 INDEX pr_data_token_blackl_1063_idx3
[exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx4"
[exec] launching item 5328 CONSTRAINT pr_database_info_table pr_database_info_table_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_database_info_table pr_database_info_table_pk"
[exec] pg_restore: finished item 5328 CONSTRAINT pr_database_info_table pr_database_info_table_pk
[exec] pg_restore: launching item 4976 CONSTRAINT pr_dm_proposition pr_dm_proposition_pk
[exec] pg_restore: finished item 5674 INDEX pr_data_token_blackl_1063_idx4
[exec] pg_restore: launching item 5146 CONSTRAINT pr_file_store pr_file_store_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_file_store pr_file_store_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_dm_proposition pr_dm_proposition_pk"
[exec] pg_restore: finished item 5146 CONSTRAINT pr_file_store pr_file_store_pk
[exec] pg_restore: launching item 5144 INDEX pathinfo_index
[exec] pg_restore: creating INDEX "data.pathinfo_index"
[exec] pg_restore: finished item 4976 CONSTRAINT pr_dm_proposition pr_dm_proposition_pk
[exec] pg_restore: launching item 5150 CONSTRAINT pr_file_upload pr_file_upload_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_file_upload pr_file_upload_pk"
[exec] pg_restore: finished item 5150 CONSTRAINT pr_file_upload pr_file_upload_pk
[exec] pg_restore: launching item 5147 INDEX pr_file_upload_abs
[exec] pg_restore: pg_restore: finished item 5144 INDEX pathinfo_index
[exec] pg_restore: creating INDEX "data.pr_file_upload_abs"
[exec] launching item 5148 INDEX pr_file_upload_path
[exec] pg_restore: creating INDEX "data.pr_file_upload_path"
[exec] pg_restore: finished item 5147 INDEX pr_file_upload_abs
[exec] pg_restore: launching item 5154 CONSTRAINT pr_file_upload_fallback pr_file_upl_fb_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_file_upload_fallback pr_file_upl_fb_pk"
[exec] pg_restore: finished item 5148 INDEX pr_file_upload_path
[exec] pg_restore: launching item 5291 CONSTRAINT pr_history_data_dms_customer pr_his_data_dms_customer_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_history_data_dms_customer pr_his_data_dms_customer_pk"
[exec] pg_restore: finished item 5154 CONSTRAINT pr_file_upload_fallback pr_file_upl_fb_pk
[exec] pg_restore: launching item 5151 INDEX pr_file_upl_fb_abs
[exec] pg_restore: creating INDEX "data.pr_file_upl_fb_abs"
[exec] pg_restore: finished item 5291 CONSTRAINT pr_history_data_dms_customer pr_his_data_dms_customer_pk
[exec] pg_restore: launching item 5152 INDEX pr_file_upl_fb_path
[exec] pg_restore: creating INDEX "data.pr_file_upl_fb_path"
[exec] pg_restore: finished item 5151 INDEX pr_file_upl_fb_abs
[exec] pg_restore: launching item 5005 CONSTRAINT pr_history pr_history_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_history pr_history_pk"
[exec] pg_restore: finished item 5152 INDEX pr_file_upl_fb_path
[exec] pg_restore: launching item 5010 CONSTRAINT pr_history_data pr_history_data_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_history_data pr_history_data_pk"
[exec] pg_restore: finished item 5005 CONSTRAINT pr_history pr_history_pk
[exec] pg_restore: launching item 5003 INDEX pr_history_idx2
[exec] pg_restore: finished item 5010 CONSTRAINT pr_history_data pr_history_data_pk
[exec] pg_restore: launching item 5006 INDEX workhistory_re
[exec] pg_restore: pg_restore: creating INDEX "data.pr_history_idx2"
[exec] creating INDEX "data.workhistory_re"
[exec] pg_restore: finished item 5003 INDEX pr_history_idx2
[exec] pg_restore: launching item 5007 INDEX pr_history_data_idx2
[exec] pg_restore: finished item 5006 INDEX workhistory_re
[exec] pg_restore: launching item 5008 INDEX pr_history_data_idx3
[exec] pg_restore: creating INDEX "data.pr_history_data_idx2"
[exec] pg_restore: creating INDEX "data.pr_history_data_idx3"
[exec] pg_restore: finished item 5008 INDEX pr_history_data_idx3
[exec] pg_restore: launching item 5294 CONSTRAINT pr_history_data_dms_glbl pr_his_data_dms_glbl_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_history_data_dms_glbl pr_his_data_dms_glbl_pk"
[exec] finished item 5007 INDEX pr_history_data_idx2
[exec] pg_restore: launching item 4883 CONSTRAINT pr_index_accessgrouproles pr_index_accessgrouproles_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_accessgrouproles pr_index_accessgrouproles_pk"
[exec] pg_restore: finished item 4883 CONSTRAINT pr_index_accessgrouproles pr_index_accessgrouproles_pk
[exec] pg_restore: launching item 4881 INDEX keypurposeidx_agrproles
[exec] pg_restore: finished item 5294 CONSTRAINT pr_history_data_dms_glbl pr_his_data_dms_glbl_pk
[exec] pg_restore: pg_restore: launching item 5292 INDEX pr_his_data_dms_glbl_idx1
[exec] creating INDEX "data.keypurposeidx_agrproles"
[exec] pg_restore: creating INDEX "data.pr_his_data_dms_glbl_idx1"
[exec] pg_restore: finished item 5292 INDEX pr_his_data_dms_glbl_idx1
[exec] pg_restore: launching item 5158 CONSTRAINT pr_hourly_usage pr_hourly_usage_pk
[exec] pg_restore: pg_restore: finished item 4881 INDEX keypurposeidx_agrproles
[exec] pg_restore: creating CONSTRAINT "data.pr_hourly_usage pr_hourly_usage_pk"
[exec] launching item 5018 CONSTRAINT pr_index pr_index_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index pr_index_pk"
[exec] pg_restore: finished item 5158 CONSTRAINT pr_hourly_usage pr_hourly_usage_pk
[exec] pg_restore: launching item 4886 CONSTRAINT pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk"
[exec] pg_restore: finished item 5018 CONSTRAINT pr_index pr_index_pk
[exec] pg_restore: launching item 5015 INDEX insindexedkey
[exec] pg_restore: creating INDEX "data.insindexedkey"
[exec] pg_restore: finished item 4886 CONSTRAINT pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk
[exec] pg_restore: launching item 5016 INDEX keypurposeidx
[exec] pg_restore: creating INDEX "data.keypurposeidx"
[exec] pg_restore: finished item 5015 INDEX insindexedkey
[exec] pg_restore: launching item 4884 INDEX keypurposeidx_agrpwrk
[exec] pg_restore: creating INDEX "data.keypurposeidx_agrpwrk"
[exec] pg_restore: finished item 5016 INDEX keypurposeidx
[exec] pg_restore: launching item 5171 CONSTRAINT pr_index_assignmentdeps pr_index_assignmentdeps_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_assignmentdeps pr_index_assignmentdeps_pk"
[exec] pg_restore: finished item 4884 INDEX keypurposeidx_agrpwrk
[exec] pg_restore: launching item 4877 CONSTRAINT pr_index_appfeatures pr_index_appfeatures_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_appfeatures pr_index_appfeatures_pk"
[exec] pg_restore: finished item 5171 CONSTRAINT pr_index_assignmentdeps pr_index_assignmentdeps_pk
[exec] pg_restore: launching item 5169 INDEX keypurposeidx_adeps
[exec] pg_restore: creating INDEX "data.keypurposeidx_adeps"
[exec] pg_restore: finished item 4877 CONSTRAINT pr_index_appfeatures pr_index_appfeatures_pk
[exec] pg_restore: launching item 5172 INDEX pri_assigndeps
[exec] pg_restore: creating INDEX "data.pri_assigndeps"
[exec] pg_restore: finished item 5169 INDEX keypurposeidx_adeps
[exec] pg_restore: launching item 4873 INDEX pr_index_appfeatures_idx1
[exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx1"
[exec] pg_restore: finished item 5172 INDEX pri_assigndeps
[exec] pg_restore: launching item 4874 INDEX pr_index_appfeatures_idx2
[exec] pg_restore: finished item 4873 INDEX pr_index_appfeatures_idx1
[exec] pg_restore: launching item 4875 INDEX pr_index_appfeatures_idx3
[exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx2"
[exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx3"
[exec] pg_restore: finished item 4875 INDEX pr_index_appfeatures_idx3
[exec] pg_restore: launching item 5049 CONSTRAINT pr_index_assignmentskills pr_index_assignmentskills_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_assignmentskills pr_index_assignmentskills_pk"
[exec] pg_restore: finished item 4874 INDEX pr_index_appfeatures_idx2
[exec] pg_restore: launching item 5260 CONSTRAINT pr_index_data_agents pr_index_data_agents_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_data_agents pr_index_data_agents_pk"
[exec] pg_restore: finished item 5049 CONSTRAINT pr_index_assignmentskills pr_index_assignmentskills_pk
[exec] pg_restore: launching item 5044 INDEX getnextwork2assignmentskills
[exec] pg_restore: creating INDEX "data.getnextwork2assignmentskills"
[exec] pg_restore: finished item 5260 CONSTRAINT pr_index_data_agents pr_index_data_agents_pk
[exec] pg_restore: launching item 5045 INDEX getnextworkassignmentskills
[exec] pg_restore: creating INDEX "data.getnextworkassignmentskills"
[exec] pg_restore: finished item 5044 INDEX getnextwork2assignmentskills
[exec] pg_restore: launching item 5046 INDEX keypurposeidx_askills
[exec] pg_restore: creating INDEX "data.keypurposeidx_askills"
[exec] pg_restore: finished item 5045 INDEX getnextworkassignmentskills
[exec] pg_restore: launching item 5047 INDEX pr_index_assignmentskills_idx1
[exec] pg_restore: creating INDEX "data.pr_index_assignmentskills_idx1"
[exec] pg_restore: finished item 5046 INDEX keypurposeidx_askills
[exec] pg_restore: launching item 5258 INDEX pr_index_data_agents_idx1
[exec] pg_restore: creating INDEX "data.pr_index_data_agents_idx1"
[exec] pg_restore: finished item 5258 INDEX pr_index_data_agents_idx1
[exec] pg_restore: launching item 4892 CONSTRAINT pr_index_email pr_index_email_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_email pr_index_email_pk"
[exec] pg_restore: finished item 5047 INDEX pr_index_assignmentskills_idx1
[exec] pg_restore: launching item 5399 CONSTRAINT pr_index_distinctvalues pr_index_distinctvalues_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_distinctvalues pr_index_distinctvalues_pk"
[exec] pg_restore: finished item 4892 CONSTRAINT pr_index_email pr_index_email_pk
[exec] pg_restore: launching item 4890 INDEX pr_index_email_keypurposeidx
[exec] pg_restore: creating INDEX "data.pr_index_email_keypurposeidx"
[exec] pg_restore: finished item 5399 CONSTRAINT pr_index_distinctvalues pr_index_distinctvalues_pk
[exec] pg_restore: launching item 5397 INDEX pr_index_distinctvalues_ins
[exec] pg_restore: creating INDEX "data.pr_index_distinctvalues_ins"
[exec] pg_restore: finished item 4890 INDEX pr_index_email_keypurposeidx
[exec] pg_restore: launching item 5203 CONSTRAINT pr_index_operator_workgroups pr_index_operator_wg_pk
[exec] pg_restore: pg_restore: finished item 5397 INDEX pr_index_distinctvalues_ins
[exec] pg_restore: creating CONSTRAINT "data.pr_index_operator_workgroups pr_index_operator_wg_pk"
[exec] launching item 5043 CONSTRAINT pr_index_operators pr_index_operators_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_operators pr_index_operators_pk"
[exec] pg_restore: finished item 5203 CONSTRAINT pr_index_operator_workgroups pr_index_operator_wg_pk
[exec] pg_restore: launching item 5201 INDEX pr_index_operator_wg_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_index_operator_wg_idx1"
[exec] finished item 5043 CONSTRAINT pr_index_operators pr_index_operators_pk
[exec] pg_restore: launching item 5041 INDEX keypurposeidx_oper
[exec] pg_restore: creating INDEX "data.keypurposeidx_oper"
[exec] pg_restore: finished item 5041 INDEX keypurposeidx_oper
[exec] pg_restore: launching item 5320 CONSTRAINT pr_index_pref_notify pr_index_pref_notify_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_index_pref_notify pr_index_pref_notify_pk"
[exec] finished item 5201 INDEX pr_index_operator_wg_idx1
[exec] pg_restore: launching item 5053 CONSTRAINT pr_index_operatorskills pr_index_operatorskills_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_operatorskills pr_index_operatorskills_pk"
[exec] pg_restore: finished item 5053 CONSTRAINT pr_index_operatorskills pr_index_operatorskills_pk
[exec] pg_restore: launching item 5050 INDEX keypurposeidx_oskills
[exec] pg_restore: creating INDEX "data.keypurposeidx_oskills"
[exec] pg_restore: finished item 5320 CONSTRAINT pr_index_pref_notify pr_index_pref_notify_pk
[exec] pg_restore: launching item 5317 INDEX pr_index_pref_notify_idx1
[exec] pg_restore: creating INDEX "data.pr_index_pref_notify_idx1"
[exec] pg_restore: finished item 5317 INDEX pr_index_pref_notify_idx1
[exec] pg_restore: launching item 5318 INDEX pr_index_pref_notify_idx2
[exec] pg_restore: finished item 5050 INDEX keypurposeidx_oskills
[exec] pg_restore: launching item 5051 INDEX pr_index_operatorskills_idx1
[exec] pg_restore: creating INDEX "data.pr_index_pref_notify_idx2"
[exec] pg_restore: creating INDEX "data.pr_index_operatorskills_idx1"
[exec] pg_restore: finished item 5318 INDEX pr_index_pref_notify_idx2
[exec] pg_restore: launching item 5022 CONSTRAINT pr_index_scheduledtask pr_index_scheduledtask_pk
[exec] pg_restore: finished item 5051 INDEX pr_index_operatorskills_idx1
[exec] pg_restore: launching item 4889 CONSTRAINT pr_index_workgroups pr_index_workgroups_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_scheduledtask pr_index_scheduledtask_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_index_workgroups pr_index_workgroups_pk"
[exec] pg_restore: finished item 5022 CONSTRAINT pr_index_scheduledtask pr_index_scheduledtask_pk
[exec] pg_restore: launching item 5019 INDEX insindexedschtaskkey
[exec] pg_restore: creating INDEX "data.insindexedschtaskkey"
[exec] pg_restore: finished item 4889 CONSTRAINT pr_index_workgroups pr_index_workgroups_pk
[exec] pg_restore: launching item 5020 INDEX keypurposeidx_schedtask
[exec] pg_restore: creating INDEX "data.keypurposeidx_schedtask"
[exec] pg_restore: finished item 5019 INDEX insindexedschtaskkey
[exec] pg_restore: launching item 4887 INDEX pr_index_workgroups_idx1
[exec] pg_restore: creating INDEX "data.pr_index_workgroups_idx1"
[exec] pg_restore: finished item 5020 INDEX keypurposeidx_schedtask
[exec] pg_restore: launching item 5191 CONSTRAINT pr_index_trackstatus pr_index_trackstatus_pk
[exec] pg_restore: finished item 4887 INDEX pr_index_workgroups_idx1
[exec] pg_restore: launching item 5686 CONSTRAINT pr_index_tracktriageactions pr_index_tracktriage_1119_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_index_trackstatus pr_index_trackstatus_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_index_tracktriageactions pr_index_tracktriage_1119_pk"
[exec] pg_restore: finished item 5191 CONSTRAINT pr_index_trackstatus pr_index_trackstatus_pk
[exec] pg_restore: launching item 5156 CONSTRAINT pr_license_parameters pr_lic_param_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_license_parameters pr_lic_param_pk"
[exec] pg_restore: finished item 5686 CONSTRAINT pr_index_tracktriageactions pr_index_tracktriage_1119_pk
[exec] pg_restore: launching item 5511 CONSTRAINT pr_indexmetadata pr_indexmetadata_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_indexmetadata pr_indexmetadata_pk"
[exec] pg_restore: finished item 5511 CONSTRAINT pr_indexmetadata pr_indexmetadata_pk
[exec] pg_restore: launching item 5509 INDEX pr_indexmetadata_idx1
[exec] pg_restore: creating INDEX "data.pr_indexmetadata_idx1"
[exec] pg_restore: finished item 5509 INDEX pr_indexmetadata_idx1
[exec] pg_restore: launching item 5499 CONSTRAINT pr_jobscheduler_override pr_jobscheduler_override_pk
[exec] pg_restore: pg_restore: finished item 5156 CONSTRAINT pr_license_parameters pr_lic_param_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_jobscheduler_override pr_jobscheduler_override_pk"
[exec] launching item 5024 CONSTRAINT pr_link pr_link_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_link pr_link_pk"
[exec] pg_restore: finished item 5024 CONSTRAINT pr_link pr_link_pk
[exec] pg_restore: launching item 5025 INDEX pr_link_ref_idx
[exec] pg_restore: finished item 5499 CONSTRAINT pr_jobscheduler_override pr_jobscheduler_override_pk
[exec] pg_restore: launching item 5497 INDEX pr_jobscheduler_override_idx1
[exec] pg_restore: creating INDEX "data.pr_link_ref_idx"
[exec] pg_restore: creating INDEX "data.pr_jobscheduler_override_idx1"
[exec] pg_restore: finished item 5025 INDEX pr_link_ref_idx
[exec] pg_restore: launching item 5168 CONSTRAINT pr_link_dco_pmf pr_link_dco_pmf_pk
[exec] pg_restore: finished item 5497 INDEX pr_jobscheduler_override_idx1
[exec] pg_restore: launching item 5179 CONSTRAINT pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_link_dco_pmf pr_link_dco_pmf_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk"
[exec] pg_restore: finished item 5168 CONSTRAINT pr_link_dco_pmf pr_link_dco_pmf_pk
[exec] pg_restore: launching item 5166 CONSTRAINT pr_link_work_tag pr_link_work_tag_pk
[exec] pg_restore: finished item 5179 CONSTRAINT pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_link_work_tag pr_link_work_tag_pk"
[exec] launching item 5710 CONSTRAINT pr_log_archivalsummary pr_log_archivalsummary_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_archivalsummary pr_log_archivalsummary_pk"
[exec] pg_restore: finished item 5710 CONSTRAINT pr_log_archivalsummary pr_log_archivalsummary_pk
[exec] pg_restore: launching item 5032 CONSTRAINT pr_log pr_log_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log pr_log_pk"
[exec] pg_restore: finished item 5166 CONSTRAINT pr_link_work_tag pr_link_work_tag_pk
[exec] pg_restore: launching item 5554 CONSTRAINT pr_log_archivepurgeresults pr_log_archivepurgeresults_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_archivepurgeresults pr_log_archivepurgeresults_pk"
[exec] pg_restore: finished item 5554 CONSTRAINT pr_log_archivepurgeresults pr_log_archivepurgeresults_pk
[exec] pg_restore: launching item 5181 CONSTRAINT pr_log_batchstats pr_log_batchstats_pk
[exec] pg_restore: finished item 5032 CONSTRAINT pr_log pr_log_pk
[exec] pg_restore: launching item 5029 INDEX pr_log_fn
[exec] pg_restore: pg_restore: creating INDEX "data.pr_log_fn"
[exec] creating CONSTRAINT "data.pr_log_batchstats pr_log_batchstats_pk"
[exec] pg_restore: finished item 5181 CONSTRAINT pr_log_batchstats pr_log_batchstats_pk
[exec] pg_restore: launching item 5030 INDEX pr_log_idx1
[exec] pg_restore: creating INDEX "data.pr_log_idx1"
[exec] pg_restore: finished item 5029 INDEX pr_log_fn
[exec] pg_restore: launching item 5270 CONSTRAINT pr_log_cluster pr_log_cluster_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_cluster pr_log_cluster_pk"
[exec] pg_restore: finished item 5030 INDEX pr_log_idx1
[exec] pg_restore: launching item 4903 CONSTRAINT pr_log_dataaccessaudit pr_log_dataaccessaudit_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_dataaccessaudit pr_log_dataaccessaudit_pk"
[exec] pg_restore: finished item 5270 CONSTRAINT pr_log_cluster pr_log_cluster_pk
[exec] pg_restore: launching item 5271 INDEX pr_log_custer_idx1
[exec] pg_restore: creating INDEX "data.pr_log_custer_idx1"
[exec] pg_restore: finished item 4903 CONSTRAINT pr_log_dataaccessaudit pr_log_dataaccessaudit_pk
[exec] pg_restore: launching item 5496 CONSTRAINT pr_log_collaboration pr_log_collaboration_pk
[exec] pg_restore: pg_restore: finished item 5271 INDEX pr_log_custer_idx1
[exec] pg_restore: launching item 5486 CONSTRAINT pr_log_dataflow_events pr_log_dataflow_events_pk
[exec] creating CONSTRAINT "data.pr_log_collaboration pr_log_collaboration_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_log_dataflow_events pr_log_dataflow_events_pk"
[exec] pg_restore: finished item 5496 CONSTRAINT pr_log_collaboration pr_log_collaboration_pk
[exec] pg_restore: launching item 5494 INDEX pr_log_collaboration_idx1
[exec] pg_restore: pg_restore: finished item 5486 CONSTRAINT pr_log_dataflow_events pr_log_dataflow_events_pk
[exec] pg_restore: launching item 5482 INDEX pr_log_dataflow_events_idx1
[exec] creating INDEX "data.pr_log_collaboration_idx1"
[exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx1"
[exec] pg_restore: finished item 5494 INDEX pr_log_collaboration_idx1
[exec] pg_restore: launching item 5483 INDEX pr_log_dataflow_events_idx2
[exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx2"
[exec] pg_restore: finished item 5482 INDEX pr_log_dataflow_events_idx1
[exec] pg_restore: launching item 5484 INDEX pr_log_dataflow_events_idx3
[exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx3"
[exec] pg_restore: finished item 5483 INDEX pr_log_dataflow_events_idx2
[exec] pg_restore: launching item 5626 CONSTRAINT pr_log_indexing_progress pr_log_indexing_progress_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_indexing_progress pr_log_indexing_progress_pk"
[exec] pg_restore: finished item 5484 INDEX pr_log_dataflow_events_idx3
[exec] pg_restore: launching item 5410 CONSTRAINT pr_log_jobs_scheduler pr_log_jobs_scheduler_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_jobs_scheduler pr_log_jobs_scheduler_pk"
[exec] pg_restore: finished item 5626 CONSTRAINT pr_log_indexing_progress pr_log_indexing_progress_pk
[exec] pg_restore: launching item 5624 INDEX pr_log_indexing_progress_idx1
[exec] pg_restore: creating INDEX "data.pr_log_indexing_progress_idx1"
[exec] pg_restore: finished item 5410 CONSTRAINT pr_log_jobs_scheduler pr_log_jobs_scheduler_pk
[exec] pg_restore: launching item 5406 INDEX pr_log_jobs_scheduler_idx1
[exec] pg_restore: creating INDEX "data.pr_log_jobs_scheduler_idx1"
[exec] pg_restore: finished item 5406 INDEX pr_log_jobs_scheduler_idx1
[exec] pg_restore: launching item 5407 INDEX pr_log_jobs_scheduler_idx2
[exec] pg_restore: finished item 5624 INDEX pr_log_indexing_progress_idx1
[exec] pg_restore: launching item 5408 INDEX pr_log_jobs_scheduler_idx3
[exec] pg_restore: pg_restore: creating INDEX "data.pr_log_jobs_scheduler_idx2"
[exec] creating INDEX "data.pr_log_jobs_scheduler_idx3"
[exec] pg_restore: finished item 5407 INDEX pr_log_jobs_scheduler_idx2
[exec] pg_restore: launching item 5723 CONSTRAINT pr_log_expungedcases pr_log_expungedcases_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_log_expungedcases pr_log_expungedcases_pk"
[exec] finished item 5408 INDEX pr_log_jobs_scheduler_idx3
[exec] pg_restore: launching item 5300 CONSTRAINT pr_log_progress pr_log_progress_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_progress pr_log_progress_pk"
[exec] pg_restore: finished item 5723 CONSTRAINT pr_log_expungedcases pr_log_expungedcases_pk
[exec] pg_restore: launching item 4880 CONSTRAINT pr_log_reportstats pr_log_reportstats_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_reportstats pr_log_reportstats_pk"
[exec] pg_restore: finished item 5300 CONSTRAINT pr_log_progress pr_log_progress_pk
[exec] pg_restore: launching item 5174 CONSTRAINT pr_log_securityaudit pr_log_securityaudit_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_securityaudit pr_log_securityaudit_pk"
[exec] pg_restore: finished item 5174 CONSTRAINT pr_log_securityaudit pr_log_securityaudit_pk
[exec] pg_restore: launching item 5638 CONSTRAINT pr_log_service_email pr_log_service_email_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_log_service_email pr_log_service_email_pk"
[exec] pg_restore: finished item 4880 CONSTRAINT pr_log_reportstats pr_log_reportstats_pk
[exec] pg_restore: launching item 4878 INDEX pr_log_reportstats_idx1
[exec] pg_restore: creating INDEX "data.pr_log_reportstats_idx1"
[exec] pg_restore: finished item 4878 INDEX pr_log_reportstats_idx1
[exec] pg_restore: launching item 5273 CONSTRAINT pr_log_systemstate pr_log_systemstate_pk
[exec] pg_restore: finished item 5638 CONSTRAINT pr_log_service_email pr_log_service_email_pk
[exec] pg_restore: launching item 5636 INDEX pr_log_service_email_idx1
[exec] pg_restore: creating INDEX "data.pr_log_service_email_idx1"
[exec] pg_restore: creating CONSTRAINT "data.pr_log_systemstate pr_log_systemstate_pk"
[exec] pg_restore: finished item 5636 INDEX pr_log_service_email_idx1
[exec] pg_restore: launching item 5517 CONSTRAINT pr_metadata pr_metadata_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_metadata pr_metadata_pk"
[exec] finished item 5273 CONSTRAINT pr_log_systemstate pr_log_systemstate_pk
[exec] pg_restore: launching item 4872 CONSTRAINT pr_notification_channels pr_notification_channels_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_notification_channels pr_notification_channels_pk"
[exec] pg_restore: finished item 5517 CONSTRAINT pr_metadata pr_metadata_pk
[exec] pg_restore: launching item 5512 INDEX pr_metadata_idx1
[exec] pg_restore: creating INDEX "data.pr_metadata_idx1"
[exec] pg_restore: finished item 4872 CONSTRAINT pr_notification_channels pr_notification_channels_pk
[exec] pg_restore: launching item 5513 INDEX pr_metadata_idx2
[exec] pg_restore: creating INDEX "data.pr_metadata_idx2"
[exec] pg_restore: finished item 5512 INDEX pr_metadata_idx1
[exec] pg_restore: launching item 5514 INDEX pr_metadata_idx3
[exec] pg_restore: finished item 5513 INDEX pr_metadata_idx2
[exec] pg_restore: launching item 5515 INDEX pr_metadata_idx4
[exec] pg_restore: creating INDEX "data.pr_metadata_idx3"
[exec] pg_restore: creating INDEX "data.pr_metadata_idx4"
[exec] pg_restore: finished item 5515 INDEX pr_metadata_idx4
[exec] pg_restore: launching item 5444 CONSTRAINT pr_offline_attachment_mapping pr_off_att_map_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_offline_attachment_mapping pr_off_att_map_pk"
[exec] finished item 5514 INDEX pr_metadata_idx3
[exec] pg_restore: launching item 5441 CONSTRAINT pr_offline_attachment_stub pr_off_att_stub_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_offline_attachment_stub pr_off_att_stub_pk"
[exec] pg_restore: finished item 5444 CONSTRAINT pr_offline_attachment_mapping pr_off_att_map_pk
[exec] pg_restore: launching item 5442 INDEX pr_off_att_map_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_off_att_map_idx1"
[exec] finished item 5441 CONSTRAINT pr_offline_attachment_stub pr_off_att_stub_pk
[exec] pg_restore: launching item 5439 INDEX pr_off_att_stub_idx1
[exec] pg_restore: creating INDEX "data.pr_off_att_stub_idx1"
[exec] pg_restore: finished item 5442 INDEX pr_off_att_map_idx1
[exec] pg_restore: launching item 5063 CONSTRAINT pr_offline_pack pr_offline_pack_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_offline_pack pr_offline_pack_pk"
[exec] pg_restore: finished item 5439 INDEX pr_off_att_stub_idx1
[exec] pg_restore: launching item 5587 CONSTRAINT pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk"
[exec] pg_restore: finished item 5587 CONSTRAINT pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk
[exec] pg_restore: launching item 5585 CONSTRAINT pr_offline_sync_requests pr_offline_sync_requests_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_offline_sync_requests pr_offline_sync_requests_pk"
[exec] pg_restore: finished item 5063 CONSTRAINT pr_offline_pack pr_offline_pack_pk
[exec] pg_restore: launching item 5039 CONSTRAINT pr_operator_prefs pr_operator_prefs_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_operator_prefs pr_operator_prefs_pk"
[exec] pg_restore: finished item 5585 CONSTRAINT pr_offline_sync_requests pr_offline_sync_requests_pk
[exec] pg_restore: launching item 5055 CONSTRAINT pr_other pr_other_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_other pr_other_pk"
[exec] pg_restore: finished item 5039 CONSTRAINT pr_operator_prefs pr_operator_prefs_pk
[exec] pg_restore: launching item 5040 INDEX prefs_uid
[exec] pg_restore: creating INDEX "data.prefs_uid"
[exec] pg_restore: finished item 5055 CONSTRAINT pr_other pr_other_pk
[exec] pg_restore: launching item 5059 CONSTRAINT pr_page_store pr_page_store_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_page_store pr_page_store_pk"
[exec] pg_restore: finished item 5040 INDEX prefs_uid
[exec] pg_restore: launching item 5037 CONSTRAINT pr_operators pr_operators_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_operators pr_operators_pk"
[exec] pg_restore: finished item 5059 CONSTRAINT pr_page_store pr_page_store_pk
[exec] pg_restore: launching item 5060 INDEX pr_pagestore_create
[exec] pg_restore: creating INDEX "data.pr_pagestore_create"
[exec] pg_restore: finished item 5060 INDEX pr_pagestore_create
[exec] pg_restore: launching item 5061 INDEX pr_pagestore_req
[exec] pg_restore: creating INDEX "data.pr_pagestore_req"
[exec] pg_restore: finished item 5037 CONSTRAINT pr_operators pr_operators_pk
[exec] pg_restore: launching item 5033 INDEX operators_oc_wg
[exec] pg_restore: creating INDEX "data.operators_oc_wg"
[exec] pg_restore: finished item 5061 INDEX pr_pagestore_req
[exec] pg_restore: launching item 5034 INDEX ops_extension
[exec] pg_restore: finished item 5033 INDEX operators_oc_wg
[exec] pg_restore: launching item 5035 INDEX pr_operators_idx1
[exec] pg_restore: creating INDEX "data.ops_extension"
[exec] pg_restore: creating INDEX "data.pr_operators_idx1"
[exec] pg_restore: finished item 5035 INDEX pr_operators_idx1
[exec] pg_restore: launching item 5136 CONSTRAINT pr_perf_stats pr_perf_stats_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_perf_stats pr_perf_stats_pk"
[exec] finished item 5034 INDEX ops_extension
[exec] pg_restore: launching item 5057 CONSTRAINT pr_portal_state pr_portal_state_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_portal_state pr_portal_state_pk"
[exec] pg_restore: finished item 5057 CONSTRAINT pr_portal_state pr_portal_state_pk
[exec] pg_restore: launching item 5629 CONSTRAINT pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk
[exec] pg_restore: finished item 5136 CONSTRAINT pr_perf_stats pr_perf_stats_pk
[exec] pg_restore: launching item 5133 INDEX pr_perf_snap
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk"
[exec] pg_restore: creating INDEX "data.pr_perf_snap"
[exec] pg_restore: finished item 5629 CONSTRAINT pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk
[exec] pg_restore: launching item 5134 INDEX pr_perf_snaptime
[exec] pg_restore: creating INDEX "data.pr_perf_snaptime"
[exec] pg_restore: finished item 5133 INDEX pr_perf_snap
[exec] pg_restore: launching item 5627 INDEX pr_sys_bi_publishedd_2895_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_bi_publishedd_2895_idx1"
[exec] pg_restore: finished item 5134 INDEX pr_perf_snaptime
[exec] pg_restore: launching item 5065 CONSTRAINT pr_sys_context pr_sys_context_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_context pr_sys_context_pk"
[exec] pg_restore: finished item 5065 CONSTRAINT pr_sys_context pr_sys_context_pk
[exec] pg_restore: launching item 5066 INDEX pr_syscontext_create
[exec] pg_restore: pg_restore: creating INDEX "data.pr_syscontext_create"
[exec] finished item 5627 INDEX pr_sys_bi_publishedd_2895_idx1
[exec] pg_restore: launching item 5067 INDEX pr_syscontext_req
[exec] pg_restore: creating INDEX "data.pr_syscontext_req"
[exec] pg_restore: finished item 5067 INDEX pr_syscontext_req
[exec] pg_restore: launching item 5069 CONSTRAINT pr_sys_locks pr_sys_locks_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_locks pr_sys_locks_pk"
[exec] pg_restore: finished item 5066 INDEX pr_syscontext_create
[exec] pg_restore: launching item 5521 CONSTRAINT pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk"
[exec] pg_restore: finished item 5069 CONSTRAINT pr_sys_locks pr_sys_locks_pk
[exec] pg_restore: launching item 5070 INDEX syslocks
[exec] pg_restore: creating INDEX "data.syslocks"
[exec] pg_restore: finished item 5521 CONSTRAINT pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk
[exec] pg_restore: launching item 5518 INDEX pr_sys_msg_qp_bi_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_msg_qp_bi_idx1"
[exec] pg_restore: finished item 5070 INDEX syslocks
[exec] pg_restore: launching item 5519 INDEX pr_sys_msg_qp_bi_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_msg_qp_bi_idx2"
[exec] pg_restore: finished item 5518 INDEX pr_sys_msg_qp_bi_idx1
[exec] pg_restore: launching item 5093 CONSTRAINT pr_sys_queue_autotest pr_sys_queue_autotest_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_autotest pr_sys_queue_autotest_pk"
[exec] pg_restore: finished item 5519 INDEX pr_sys_msg_qp_bi_idx2
[exec] pg_restore: launching item 5117 CONSTRAINT pr_sys_queue_col_pop pr_sys_queue_col_pop_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_col_pop pr_sys_queue_col_pop_pk"
[exec] pg_restore: finished item 5093 CONSTRAINT pr_sys_queue_autotest pr_sys_queue_autotest_pk
[exec] pg_restore: launching item 5090 INDEX pr_sys_queue_autotest1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_autotest1"
[exec] pg_restore: finished item 5090 INDEX pr_sys_queue_autotest1
[exec] pg_restore: launching item 5091 INDEX pr_sys_queue_autotest2
[exec] pg_restore: pg_restore: finished item 5117 CONSTRAINT pr_sys_queue_col_pop pr_sys_queue_col_pop_pk
[exec] pg_restore: creating INDEX "data.pr_sys_queue_autotest2"
[exec] launching item 5114 INDEX pr_sys_queue_col_pop_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_col_pop_idx1"
[exec] pg_restore: finished item 5091 INDEX pr_sys_queue_autotest2
[exec] pg_restore: launching item 5115 INDEX pr_sys_queue_col_pop_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_col_pop_idx2"
[exec] pg_restore: finished item 5114 INDEX pr_sys_queue_col_pop_idx1
[exec] pg_restore: launching item 5547 CONSTRAINT pr_sys_delayed_queue pr_sys_delayed_queue_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_delayed_queue pr_sys_delayed_queue_pk"
[exec] pg_restore: finished item 5115 INDEX pr_sys_queue_col_pop_idx2
[exec] pg_restore: launching item 5109 CONSTRAINT pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk"
[exec] pg_restore: finished item 5109 CONSTRAINT pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk
[exec] pg_restore: launching item 5106 INDEX pr_sys_queue_conn_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_conn_idx1"
[exec] pg_restore: finished item 5547 CONSTRAINT pr_sys_delayed_queue pr_sys_delayed_queue_pk
[exec] pg_restore: launching item 5544 INDEX pr_sys_delayed_queue_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_delayed_queue_idx1"
[exec] pg_restore: finished item 5106 INDEX pr_sys_queue_conn_idx1
[exec] pg_restore: launching item 5545 INDEX pr_sys_delayed_queue_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_delayed_queue_idx2"
[exec] pg_restore: finished item 5544 INDEX pr_sys_delayed_queue_idx1
[exec] pg_restore: launching item 5107 INDEX pr_sys_queue_conn_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_conn_idx2"
[exec] pg_restore: finished item 5545 INDEX pr_sys_delayed_queue_idx2
[exec] pg_restore: launching item 5119 CONSTRAINT pr_sys_queue_count pr_sys_queue_count_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_count pr_sys_queue_count_pk"
[exec] pg_restore: finished item 5107 INDEX pr_sys_queue_conn_idx2
[exec] pg_restore: launching item 5103 CONSTRAINT pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk"
[exec] pg_restore: finished item 5119 CONSTRAINT pr_sys_queue_count pr_sys_queue_count_pk
[exec] pg_restore: launching item 5432 CONSTRAINT pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk"
[exec] pg_restore: finished item 5432 CONSTRAINT pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk
[exec] pg_restore: launching item 5429 INDEX pr_sys_queue_ftsconflict_idx1
[exec] pg_restore: pg_restore: creating INDEX "data.pr_sys_queue_ftsconflict_idx1"
[exec] finished item 5103 CONSTRAINT pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk
[exec] pg_restore: launching item 5104 INDEX pr_sys_queue_svc_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_svc_idx1"
[exec] pg_restore: finished item 5104 INDEX pr_sys_queue_svc_idx1
[exec] pg_restore: launching item 5105 INDEX pr_sys_queue_svc_idx2
[exec] pg_restore: pg_restore: creating INDEX "data.pr_sys_queue_svc_idx2"
[exec] finished item 5429 INDEX pr_sys_queue_ftsconflict_idx1
[exec] pg_restore: launching item 5430 INDEX pr_sys_queue_ftsconflict_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsconflict_idx2"
[exec] pg_restore: finished item 5105 INDEX pr_sys_queue_svc_idx2
[exec] pg_restore: launching item 5101 CONSTRAINT pr_sys_queue_sla pr_sys_queue_sla_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_sys_queue_sla pr_sys_queue_sla_pk"
[exec] finished item 5430 INDEX pr_sys_queue_ftsconflict_idx2
[exec] pg_restore: launching item 5257 CONSTRAINT pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk"
[exec] pg_restore: finished item 5101 CONSTRAINT pr_sys_queue_sla pr_sys_queue_sla_pk
[exec] pg_restore: launching item 5098 INDEX pr_sys_queue_sla_index1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_sla_index1"
[exec] pg_restore: finished item 5257 CONSTRAINT pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk
[exec] pg_restore: launching item 5099 INDEX pr_sys_queue_sla_index2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_sla_index2"
[exec] pg_restore: finished item 5098 INDEX pr_sys_queue_sla_index1
[exec] pg_restore: launching item 5254 INDEX pr_sys_queue_ftsindexer_index1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsindexer_index1"
[exec] pg_restore: finished item 5099 INDEX pr_sys_queue_sla_index2
[exec] pg_restore: launching item 5255 INDEX pr_sys_queue_ftsindexer_index2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsindexer_index2"
[exec] pg_restore: finished item 5254 INDEX pr_sys_queue_ftsindexer_index1
[exec] pg_restore: launching item 5113 CONSTRAINT pr_sys_queue_startflows pr_sys_queue_startflows_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_startflows pr_sys_queue_startflows_pk"
[exec] pg_restore: finished item 5255 INDEX pr_sys_queue_ftsindexer_index2
[exec] pg_restore: launching item 5089 CONSTRAINT pr_sys_queues pr_sys_queues_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_queues pr_sys_queues_pk"
[exec] pg_restore: finished item 5113 CONSTRAINT pr_sys_queue_startflows pr_sys_queue_startflows_pk
[exec] pg_restore: launching item 5110 INDEX pr_sys_queue_startflows_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_queue_startflows_idx1"
[exec] pg_restore: finished item 5089 CONSTRAINT pr_sys_queues pr_sys_queues_pk
[exec] pg_restore: launching item 5111 INDEX pr_sys_queue_startflows_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_queue_startflows_idx2"
[exec] pg_restore: finished item 5111 INDEX pr_sys_queue_startflows_idx2
[exec] pg_restore: launching item 5086 INDEX pr_sys_queues_index1
[exec] pg_restore: finished item 5110 INDEX pr_sys_queue_startflows_idx1
[exec] pg_restore: launching item 5087 INDEX pr_sys_queues_index2
[exec] pg_restore: creating INDEX "data.pr_sys_queues_index1"
[exec] pg_restore: creating INDEX "data.pr_sys_queues_index2"
[exec] pg_restore: finished item 5086 INDEX pr_sys_queues_index1
[exec] pg_restore: launching item 5074 CONSTRAINT pr_sys_serviceregistry pr_sys_serviceregistry_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_serviceregistry pr_sys_serviceregistry_pk"
[exec] pg_restore: finished item 5087 INDEX pr_sys_queues_index2
[exec] pg_restore: launching item 5078 CONSTRAINT pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk"
[exec] pg_restore: finished item 5074 CONSTRAINT pr_sys_serviceregistry pr_sys_serviceregistry_pk
[exec] pg_restore: launching item 5071 INDEX pr_sys_serviceregistry_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_serviceregistry_idx1"
[exec] pg_restore: finished item 5078 CONSTRAINT pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk
[exec] pg_restore: launching item 5072 INDEX pr_sys_serviceregistry_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_serviceregistry_idx2"
[exec] pg_restore: finished item 5071 INDEX pr_sys_serviceregistry_idx1
[exec] pg_restore: launching item 5075 INDEX pr_sys_servicereg_kvs_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_servicereg_kvs_idx1"
[exec] pg_restore: finished item 5075 INDEX pr_sys_servicereg_kvs_idx1
[exec] pg_restore: launching item 5076 INDEX pr_sys_servicereg_kvs_idx2
[exec] pg_restore: finished item 5072 INDEX pr_sys_serviceregistry_idx2
[exec] pg_restore: launching item 5253 CONSTRAINT pr_sys_statusdetails pr_sys_statusdetails_pk
[exec] pg_restore: creating INDEX "data.pr_sys_servicereg_kvs_idx2"
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_statusdetails pr_sys_statusdetails_pk"
[exec] pg_restore: finished item 5076 INDEX pr_sys_servicereg_kvs_idx2
[exec] pg_restore: launching item 5080 CONSTRAINT pr_sys_statusnodes pr_sys_statusnodes_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_statusnodes pr_sys_statusnodes_pk"
[exec] pg_restore: finished item 5253 CONSTRAINT pr_sys_statusdetails pr_sys_statusdetails_pk
[exec] pg_restore: launching item 5251 INDEX pr_sys_statusdetails_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_statusdetails_idx1"
[exec] pg_restore: finished item 5080 CONSTRAINT pr_sys_statusnodes pr_sys_statusnodes_pk
[exec] pg_restore: launching item 5085 CONSTRAINT pr_sys_user pr_sys_user_pk
[exec] pg_restore: finished item 5251 INDEX pr_sys_statusdetails_idx1
[exec] pg_restore: pg_restore: launching item 5664 CONSTRAINT pr_sys_user_grid pr_sys_user_grid_pk
[exec] creating CONSTRAINT "data.pr_sys_user pr_sys_user_pk"
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_user_grid pr_sys_user_grid_pk"
[exec] pg_restore: finished item 5085 CONSTRAINT pr_sys_user pr_sys_user_pk
[exec] pg_restore: launching item 5082 INDEX pr_sys_user_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_user_idx1"
[exec] pg_restore: finished item 5664 CONSTRAINT pr_sys_user_grid pr_sys_user_grid_pk
[exec] pg_restore: launching item 5083 INDEX pr_sys_user_idx2
[exec] pg_restore: creating INDEX "data.pr_sys_user_idx2"
[exec] pg_restore: finished item 5082 INDEX pr_sys_user_idx1
[exec] pg_restore: launching item 5662 INDEX pr_sys_user_grid_idx1
[exec] pg_restore: creating INDEX "data.pr_sys_user_grid_idx1"
[exec] pg_restore: finished item 5083 INDEX pr_sys_user_idx2
[exec] pg_restore: launching item 5081 INDEX updatecachenode
[exec] pg_restore: creating INDEX "data.updatecachenode"
[exec] pg_restore: finished item 5662 INDEX pr_sys_user_grid_idx1
[exec] pg_restore: launching item 5162 CONSTRAINT pr_usage_summary pr_usage_sum_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_usage_summary pr_usage_sum_pk"
[exec] pg_restore: finished item 5081 INDEX updatecachenode
[exec] pg_restore: launching item 4850 CONSTRAINT prpc_ignite_server_addr prpc_ignite_server_addr_pk
[exec] pg_restore: creating CONSTRAINT "data.prpc_ignite_server_addr prpc_ignite_server_addr_pk"
[exec] pg_restore: finished item 4850 CONSTRAINT prpc_ignite_server_addr prpc_ignite_server_addr_pk
[exec] pg_restore: launching item 5097 CONSTRAINT pr_sys_workindexer_queue pr_sys_workindexer_queue_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sys_workindexer_queue pr_sys_workindexer_queue_pk"
[exec] pg_restore: finished item 5162 CONSTRAINT pr_usage_summary pr_usage_sum_pk
[exec] pg_restore: launching item 4905 CONSTRAINT pr_sysjobs pr_sysjobs_pk
[exec] pg_restore: creating CONSTRAINT "data.pr_sysjobs pr_sysjobs_pk"
[exec] pg_restore: finished item 4905 CONSTRAINT pr_sysjobs pr_sysjobs_pk
[exec] pg_restore: launching item 5773 CONSTRAINT pc_index_flowref pc_index_flowref_pk
[exec] pg_restore: creating CONSTRAINT "rules.pc_index_flowref pc_index_flowref_pk"
[exec] pg_restore: finished item 5097 CONSTRAINT pr_sys_workindexer_queue pr_sys_workindexer_queue_pk
[exec] pg_restore: launching item 5094 INDEX pr_sys_workindexer_index1
[exec] pg_restore: creating INDEX "data.pr_sys_workindexer_index1"
[exec] pg_restore: finished item 6543 TABLE DATA pr_index_reference
[exec] pg_restore: launching item 5095 INDEX pr_sys_workindexer_index2
[exec] pg_restore: creating INDEX "data.pr_sys_workindexer_index2"
[exec] pg_restore: finished item 5094 INDEX pr_sys_workindexer_index1
[exec] pg_restore: launching item 6057 CONSTRAINT pr4_rule_appconfiguration pr4_rule_appconfiguration_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "rules.pr4_rule_appconfiguration pr4_rule_appconfiguration_pk"
[exec] finished item 5773 CONSTRAINT pc_index_flowref pc_index_flowref_pk
[exec] pg_restore: launching item 5744 CONSTRAINT pr4_rule_application pr4_rule_application_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_application pr4_rule_application_pk"
[exec] pg_restore: finished item 5095 INDEX pr_sys_workindexer_index2
[exec] pg_restore: launching item 5837 CONSTRAINT pr4_rule_autotest pr4_rule_autotest_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_autotest pr4_rule_autotest_pk"
[exec] pg_restore: finished item 6057 CONSTRAINT pr4_rule_appconfiguration pr4_rule_appconfiguration_pk
[exec] pg_restore: launching item 6091 CONSTRAINT pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk
[exec] pg_restore: pg_restore: finished item 5744 CONSTRAINT pr4_rule_application pr4_rule_application_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk"
[exec] launching item 5741 INDEX pr4_rule_app_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_app_idx1"
[exec] pg_restore: finished item 5837 CONSTRAINT pr4_rule_autotest pr4_rule_autotest_pk
[exec] pg_restore: launching item 5742 INDEX pr4_rule_app_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_app_idx2"
[exec] pg_restore: finished item 5741 INDEX pr4_rule_app_idx1
[exec] pg_restore: launching item 5835 INDEX autotstres_1
[exec] pg_restore: finished item 6091 CONSTRAINT pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk
[exec] pg_restore: pg_restore: launching item 6088 INDEX pr4_rule_bi_dashboard_idx1
[exec] creating INDEX "rules.autotstres_1"
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_dashboard_idx1"
[exec] pg_restore: finished item 5742 INDEX pr4_rule_app_idx2
[exec] pg_restore: launching item 6089 INDEX pr4_rule_bi_dashboard_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_dashboard_idx2"
[exec] pg_restore: finished item 6088 INDEX pr4_rule_bi_dashboard_idx1
[exec] pg_restore: launching item 6106 CONSTRAINT pr4_rule_bi_insight pr4_rule_bi_insight_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_insight pr4_rule_bi_insight_pk"
[exec] pg_restore: finished item 5835 INDEX autotstres_1
[exec] pg_restore: launching item 6087 CONSTRAINT pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk"
[exec] pg_restore: finished item 6089 INDEX pr4_rule_bi_dashboard_idx2
[exec] pg_restore: launching item 6083 CONSTRAINT pr4_rule_bi_theme pr4_rule_bi_theme_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_theme pr4_rule_bi_theme_pk"
[exec] pg_restore: finished item 6106 CONSTRAINT pr4_rule_bi_insight pr4_rule_bi_insight_pk
[exec] pg_restore: launching item 6103 INDEX pr4_rule_bi_insight_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_insight_idx1"
[exec] pg_restore: finished item 6087 CONSTRAINT pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk
[exec] pg_restore: launching item 6104 INDEX pr4_rule_bi_insight_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_insight_idx2"
[exec] pg_restore: finished item 6083 CONSTRAINT pr4_rule_bi_theme pr4_rule_bi_theme_pk
[exec] pg_restore: launching item 6084 INDEX pr4_rule_bi_queryphrase_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_queryphrase_idx1"
[exec] pg_restore: finished item 6103 INDEX pr4_rule_bi_insight_idx1
[exec] pg_restore: launching item 6085 INDEX pr4_rule_bi_queryphrase_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_queryphrase_idx2"
[exec] pg_restore: finished item 6104 INDEX pr4_rule_bi_insight_idx2
[exec] pg_restore: launching item 6080 INDEX pr4_rule_bi_theme_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_theme_idx1"
[exec] pg_restore: finished item 6084 INDEX pr4_rule_bi_queryphrase_idx1
[exec] pg_restore: launching item 6081 INDEX pr4_rule_bi_theme_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_bi_theme_idx2"
[exec] pg_restore: finished item 6080 INDEX pr4_rule_bi_theme_idx1
[exec] pg_restore: launching item 6069 CONSTRAINT pr4_rule_clientdata pr4_rule_clientdata_pk
[exec] pg_restore: finished item 6085 INDEX pr4_rule_bi_queryphrase_idx2
[exec] pg_restore: launching item 6066 CONSTRAINT pr4_rule_connect pr4_rule_connect_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_clientdata pr4_rule_clientdata_pk"
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_connect pr4_rule_connect_pk"
[exec] pg_restore: finished item 6081 INDEX pr4_rule_bi_theme_idx2
[exec] pg_restore: launching item 6074 CONSTRAINT pr4_rule_connect_robot pr4_rule_connect_robot_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_connect_robot pr4_rule_connect_robot_pk"
[exec] pg_restore: finished item 6074 CONSTRAINT pr4_rule_connect_robot pr4_rule_connect_robot_pk
[exec] pg_restore: launching item 6072 INDEX pr4_rule_connect_robot_idx1
[exec] pg_restore: pg_restore: finished item 6069 CONSTRAINT pr4_rule_clientdata pr4_rule_clientdata_pk
[exec] pg_restore: creating INDEX "rules.pr4_rule_connect_robot_idx1"
[exec] launching item 6067 INDEX pr4_rule_clientdata_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_clientdata_idx1"
[exec] pg_restore: finished item 6066 CONSTRAINT pr4_rule_connect pr4_rule_connect_pk
[exec] pg_restore: launching item 6064 INDEX pr4_rule_connect_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_connect_idx1"
[exec] pg_restore: finished item 6072 INDEX pr4_rule_connect_robot_idx1
[exec] pg_restore: launching item 6116 CONSTRAINT pr4_rule_dataobject pr4_rule_dataobject_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_dataobject pr4_rule_dataobject_pk"
[exec] pg_restore: finished item 6067 INDEX pr4_rule_clientdata_idx1
[exec] pg_restore: launching item 6096 CONSTRAINT pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk"
[exec] pg_restore: finished item 6064 INDEX pr4_rule_connect_idx1
[exec] pg_restore: launching item 5893 CONSTRAINT pr4_rule_declarepages pr4_rule_declarepages_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_declarepages pr4_rule_declarepages_pk"
[exec] pg_restore: finished item 6096 CONSTRAINT pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk
[exec] pg_restore: launching item 6097 INDEX pr4_rule_declare_exp_insid
[exec] pg_restore: creating INDEX "rules.pr4_rule_declare_exp_insid"
[exec] pg_restore: finished item 5893 CONSTRAINT pr4_rule_declarepages pr4_rule_declarepages_pk
[exec] pg_restore: launching item 6098 INDEX pr4_rule_declare_exp_insname
[exec] pg_restore: creating INDEX "rules.pr4_rule_declare_exp_insname"
[exec] pg_restore: finished item 6116 CONSTRAINT pr4_rule_dataobject pr4_rule_dataobject_pk
[exec] pg_restore: launching item 6112 INDEX pr4_rule_dataobject_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx1"
[exec] pg_restore: finished item 6097 INDEX pr4_rule_declare_exp_insid
[exec] pg_restore: launching item 6113 INDEX pr4_rule_dataobject_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx2"
[exec] pg_restore: finished item 6112 INDEX pr4_rule_dataobject_idx1
[exec] pg_restore: launching item 6114 INDEX pr4_rule_dataobject_idx3
[exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx3"
[exec] pg_restore: finished item 6098 INDEX pr4_rule_declare_exp_insname
[exec] pg_restore: launching item 5894 INDEX pr4_rule_dp_objclass
[exec] pg_restore: creating INDEX "rules.pr4_rule_dp_objclass"
[exec] pg_restore: finished item 6113 INDEX pr4_rule_dataobject_idx2
[exec] pg_restore: launching item 5895 INDEX pr4_rule_dp_oc_cn
[exec] pg_restore: finished item 6114 INDEX pr4_rule_dataobject_idx3
[exec] pg_restore: pg_restore: launching item 5896 INDEX pr4_rule_dp_oc_in
[exec] creating INDEX "rules.pr4_rule_dp_oc_cn"
[exec] pg_restore: creating INDEX "rules.pr4_rule_dp_oc_in"
[exec] pg_restore: finished item 5894 INDEX pr4_rule_dp_objclass
[exec] pg_restore: launching item 5897 INDEX pr4_rule_dp_ruleres_1
[exec] pg_restore: creating INDEX "rules.pr4_rule_dp_ruleres_1"
[exec] pg_restore: finished item 5896 INDEX pr4_rule_dp_oc_in
[exec] pg_restore: launching item 5898 INDEX pr4_rule_dp_ruleset
[exec] pg_restore: creating INDEX "rules.pr4_rule_dp_ruleset"
[exec] pg_restore: finished item 5895 INDEX pr4_rule_dp_oc_cn
[exec] pg_restore: launching item 6027 CONSTRAINT pr4_rule_delegationconfig pr4_rule_dc_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_delegationconfig pr4_rule_dc_pk"
[exec] pg_restore: finished item 5898 INDEX pr4_rule_dp_ruleset
[exec] pg_restore: launching item 5790 CONSTRAINT pr4_base pr4_base_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_base pr4_base_pk"
[exec] pg_restore: finished item 5897 INDEX pr4_rule_dp_ruleres_1
[exec] pg_restore: launching item 5798 CONSTRAINT pr4_fieldvalue pr4_fieldvalue_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_fieldvalue pr4_fieldvalue_pk"
[exec] pg_restore: finished item 6027 CONSTRAINT pr4_rule_delegationconfig pr4_rule_dc_pk
[exec] pg_restore: launching item 6024 INDEX pr4_rule_dc_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_dc_idx1"
[exec] pg_restore: finished item 6024 INDEX pr4_rule_dc_idx1
[exec] pg_restore: launching item 6025 INDEX pr4_rule_dc_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_dc_idx2"
[exec] pg_restore: finished item 6025 INDEX pr4_rule_dc_idx2
[exec] pg_restore: launching item 5889 CONSTRAINT pr4_rule_file pr4_rule_file_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_file pr4_rule_file_pk"
[exec] pg_restore: finished item 5889 CONSTRAINT pr4_rule_file pr4_rule_file_pk
[exec] pg_restore: launching item 5887 INDEX pr4_rule_file_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_file_idx1"
[exec] pg_restore: finished item 5887 INDEX pr4_rule_file_idx1
[exec] pg_restore: launching item 5890 INDEX rf_insnclass
[exec] pg_restore: creating INDEX "rules.rf_insnclass"
[exec] pg_restore: finished item 5890 INDEX rf_insnclass
[exec] pg_restore: launching item 5891 INDEX rule_rulefileres_1
[exec] pg_restore: creating INDEX "rules.rule_rulefileres_1"
[exec] pg_restore: finished item 5891 INDEX rule_rulefileres_1
[exec] pg_restore: launching item 5738 CONSTRAINT pr4_rule_guide pr4_rule_guide_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_guide pr4_rule_guide_pk"
[exec] pg_restore: finished item 5738 CONSTRAINT pr4_rule_guide pr4_rule_guide_pk
[exec] pg_restore: launching item 5736 INDEX pr4_rule_guide_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_guide_idx1"
[exec] pg_restore: finished item 5736 INDEX pr4_rule_guide_idx1
[exec] pg_restore: launching item 5861 CONSTRAINT pr4_rule_flow pr4_rule_flow_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_flow pr4_rule_flow_pk"
[exec] pg_restore: finished item 5861 CONSTRAINT pr4_rule_flow pr4_rule_flow_pk
[exec] pg_restore: launching item 5857 INDEX flow_objclass
[exec] pg_restore: creating INDEX "rules.flow_objclass"
[exec] pg_restore: finished item 5857 INDEX flow_objclass
[exec] pg_restore: launching item 5858 INDEX flow_pyclassname
[exec] pg_restore: creating INDEX "rules.flow_pyclassname"
[exec] pg_restore: finished item 5790 CONSTRAINT pr4_base pr4_base_pk
[exec] pg_restore: launching item 5782 INDEX base_cat
[exec] pg_restore: creating INDEX "rules.base_cat"
[exec] pg_restore: finished item 5858 INDEX flow_pyclassname
[exec] pg_restore: launching item 5783 INDEX base_classname
[exec] pg_restore: creating INDEX "rules.base_classname"
[exec] pg_restore: finished item 5782 INDEX base_cat
[exec] pg_restore: launching item 5784 INDEX base_objclass
[exec] pg_restore: creating INDEX "rules.base_objclass"
[exec] pg_restore: finished item 5783 INDEX base_classname
[exec] pg_restore: launching item 5785 INDEX pr4_base_idx1
[exec] pg_restore: creating INDEX "rules.pr4_base_idx1"
[exec] pg_restore: finished item 5784 INDEX base_objclass
[exec] pg_restore: launching item 5786 INDEX pr4_base_idx2
[exec] pg_restore: creating INDEX "rules.pr4_base_idx2"
[exec] pg_restore: finished item 5785 INDEX pr4_base_idx1
[exec] pg_restore: launching item 5787 INDEX pr4_base_idx3
[exec] pg_restore: creating INDEX "rules.pr4_base_idx3"
[exec] pg_restore: finished item 5786 INDEX pr4_base_idx2
[exec] pg_restore: launching item 5788 INDEX pr4_base_idx4
[exec] pg_restore: creating INDEX "rules.pr4_base_idx4"
[exec] pg_restore: finished item 5788 INDEX pr4_base_idx4
[exec] pg_restore: launching item 5791 INDEX rule_baseres_1
[exec] pg_restore: creating INDEX "rules.rule_baseres_1"
[exec] pg_restore: finished item 5787 INDEX pr4_base_idx3
[exec] pg_restore: launching item 5859 INDEX flow_resolution
[exec] pg_restore: creating INDEX "rules.flow_resolution"
[exec] pg_restore: finished item 5791 INDEX rule_baseres_1
[exec] pg_restore: launching item 5862 INDEX rule_flow_insname
[exec] pg_restore: creating INDEX "rules.rule_flow_insname"
[exec] pg_restore: finished item 5859 INDEX flow_resolution
[exec] pg_restore: launching item 5863 INDEX rule_flow_ruleset
[exec] pg_restore: creating INDEX "rules.rule_flow_ruleset"
[exec] pg_restore: finished item 5862 INDEX rule_flow_insname
[exec] pg_restore: launching item 5864 INDEX rule_ruleflowres_1
[exec] pg_restore: creating INDEX "rules.rule_ruleflowres_1"
[exec] pg_restore: finished item 5863 INDEX rule_flow_ruleset
[exec] pg_restore: launching item 5740 CONSTRAINT pr4_rule_html_property pr4_rule_html_property_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_html_property pr4_rule_html_property_pk"
[exec] pg_restore: finished item 5864 INDEX rule_ruleflowres_1
[exec] pg_restore: launching item 6023 CONSTRAINT pr4_rule_library pr4_rule_library_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_library pr4_rule_library_pk"
[exec] pg_restore: finished item 5740 CONSTRAINT pr4_rule_html_property pr4_rule_html_property_pk
[exec] pg_restore: launching item 6111 CONSTRAINT pr4_rule_persona pr4_rule_persona_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_persona pr4_rule_persona_pk"
[exec] pg_restore: finished item 6111 CONSTRAINT pr4_rule_persona pr4_rule_persona_pk
[exec] pg_restore: launching item 6107 INDEX pr4_rule_persona_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx1"
[exec] pg_restore: finished item 6107 INDEX pr4_rule_persona_idx1
[exec] pg_restore: launching item 6108 INDEX pr4_rule_persona_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx2"
[exec] pg_restore: finished item 6108 INDEX pr4_rule_persona_idx2
[exec] pg_restore: launching item 6109 INDEX pr4_rule_persona_idx3
[exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx3"
[exec] pg_restore: finished item 6109 INDEX pr4_rule_persona_idx3
[exec] pg_restore: launching item 6060 CONSTRAINT pr4_rule_presentation pr4_rule_presentation_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_presentation pr4_rule_presentation_pk"
[exec] pg_restore: finished item 6023 CONSTRAINT pr4_rule_library pr4_rule_library_pk
[exec] pg_restore: launching item 6017 INDEX pr4_rule_library_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx1"
[exec] pg_restore: finished item 6060 CONSTRAINT pr4_rule_presentation pr4_rule_presentation_pk
[exec] pg_restore: launching item 6018 INDEX pr4_rule_library_idx3
[exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx3"
[exec] pg_restore: finished item 6017 INDEX pr4_rule_library_idx1
[exec] pg_restore: launching item 6019 INDEX pr4_rule_library_idx4
[exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx4"
[exec] pg_restore: finished item 6018 INDEX pr4_rule_library_idx3
[exec] pg_restore: launching item 6020 INDEX pr4_rule_library_idx5
[exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx5"
[exec] pg_restore: finished item 6019 INDEX pr4_rule_library_idx4
[exec] pg_restore: launching item 6021 INDEX pr4_rule_library_idx6
[exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx6"
[exec] pg_restore: finished item 6020 INDEX pr4_rule_library_idx5
[exec] pg_restore: launching item 6058 INDEX pr4_rule_presentation_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_presentation_idx1"
[exec] pg_restore: finished item 6021 INDEX pr4_rule_library_idx6
[exec] pg_restore: launching item 6013 CONSTRAINT pr4_rule_message pr4_rule_message_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_message pr4_rule_message_pk"
[exec] pg_restore: finished item 6058 INDEX pr4_rule_presentation_idx1
[exec] pg_restore: launching item 6063 CONSTRAINT pr4_rule_reports pr4_rule_reports_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_reports pr4_rule_reports_pk"
[exec] pg_restore: finished item 6013 CONSTRAINT pr4_rule_message pr4_rule_message_pk
[exec] pg_restore: launching item 6010 INDEX pr4_rule_message_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_message_idx1"
[exec] pg_restore: finished item 6063 CONSTRAINT pr4_rule_reports pr4_rule_reports_pk
[exec] pg_restore: launching item 6011 INDEX pr4_rule_message_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_message_idx2"
[exec] pg_restore: finished item 6010 INDEX pr4_rule_message_idx1
[exec] pg_restore: launching item 6061 INDEX pr4_rule_reports_idex1
[exec] pg_restore: creating INDEX "rules.pr4_rule_reports_idex1"
[exec] pg_restore: finished item 6011 INDEX pr4_rule_message_idx2
[exec] pg_restore: launching item 5939 CONSTRAINT pr4_rule_requirement pr4_rule_requirement_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_requirement pr4_rule_requirement_pk"
[exec] pg_restore: finished item 6061 INDEX pr4_rule_reports_idex1
[exec] pg_restore: launching item 5876 CONSTRAINT pr4_rule_ruleset pr4_rule_ruleset_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_ruleset pr4_rule_ruleset_pk"
[exec] pg_restore: finished item 5939 CONSTRAINT pr4_rule_requirement pr4_rule_requirement_pk
[exec] pg_restore: launching item 5936 INDEX pr4_rule_req_ruleset
[exec] pg_restore: creating INDEX "rules.pr4_rule_req_ruleset"
[exec] pg_restore: finished item 5876 CONSTRAINT pr4_rule_ruleset pr4_rule_ruleset_pk
[exec] pg_restore: launching item 5937 INDEX pr4_rule_requirement_oc_in
[exec] pg_restore: creating INDEX "rules.pr4_rule_requirement_oc_in"
[exec] pg_restore: finished item 5936 INDEX pr4_rule_req_ruleset
[exec] pg_restore: launching item 5940 INDEX pr4_rule_requirementoc_cn
[exec] pg_restore: creating INDEX "rules.pr4_rule_requirementoc_cn"
[exec] pg_restore: finished item 5937 INDEX pr4_rule_requirement_oc_in
[exec] pg_restore: launching item 5941 INDEX rule_requirement_objclass
[exec] pg_restore: creating INDEX "rules.rule_requirement_objclass"
[exec] pg_restore: finished item 5940 INDEX pr4_rule_requirementoc_cn
[exec] pg_restore: launching item 5942 INDEX rule_requirement_ruleres_1
[exec] pg_restore: creating INDEX "rules.rule_requirement_ruleres_1"
[exec] pg_restore: finished item 5941 INDEX rule_requirement_objclass
[exec] pg_restore: launching item 5873 INDEX pr4_rule_ruleset_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_ruleset_idx1"
[exec] pg_restore: finished item 5942 INDEX rule_requirement_ruleres_1
[exec] pg_restore: launching item 5874 INDEX pr4_rule_ruleset_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_ruleset_idx2"
[exec] pg_restore: finished item 5873 INDEX pr4_rule_ruleset_idx1
[exec] pg_restore: launching item 5877 INDEX rule_resolution_rrs
[exec] pg_restore: creating INDEX "rules.rule_resolution_rrs"
[exec] pg_restore: finished item 5874 INDEX pr4_rule_ruleset_idx2
[exec] pg_restore: launching item 5866 CONSTRAINT pr4_rule_property pr4_rule_property_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_property pr4_rule_property_pk"
[exec] pg_restore: finished item 5877 INDEX rule_resolution_rrs
[exec] pg_restore: launching item 6045 CONSTRAINT pr4_rule_securitypolicies pr4_rule_securitypolicies_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_securitypolicies pr4_rule_securitypolicies_pk"
[exec] pg_restore: finished item 6045 CONSTRAINT pr4_rule_securitypolicies pr4_rule_securitypolicies_pk
[exec] pg_restore: launching item 6039 INDEX pr4_rule_secpol_oc_cn
[exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_oc_cn"
[exec] pg_restore: finished item 6039 INDEX pr4_rule_secpol_oc_cn
[exec] pg_restore: launching item 6040 INDEX pr4_rule_secpol_oc_in
[exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_oc_in"
[exec] pg_restore: finished item 6040 INDEX pr4_rule_secpol_oc_in
[exec] pg_restore: launching item 6041 INDEX pr4_rule_secpol_ruleres_1
[exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_ruleres_1"
[exec] pg_restore: finished item 6041 INDEX pr4_rule_secpol_ruleres_1
[exec] pg_restore: launching item 6042 INDEX pr4_rule_secpol_ruleset
[exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_ruleset"
[exec] pg_restore: finished item 5866 CONSTRAINT pr4_rule_property pr4_rule_property_pk
[exec] pg_restore: launching item 5867 INDEX prop_resolution
[exec] pg_restore: creating INDEX "rules.prop_resolution"
[exec] pg_restore: finished item 6042 INDEX pr4_rule_secpol_ruleset
[exec] pg_restore: launching item 5868 INDEX property_objclass
[exec] pg_restore: creating INDEX "rules.property_objclass"
[exec] pg_restore: finished item 5798 CONSTRAINT pr4_fieldvalue pr4_fieldvalue_pk
[exec] pg_restore: launching item 5794 INDEX pr4_fieldvalue_idx1
[exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx1"
[exec] pg_restore: finished item 5867 INDEX prop_resolution
[exec] pg_restore: launching item 5795 INDEX pr4_fieldvalue_idx2
[exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx2"
[exec] pg_restore: finished item 5868 INDEX property_objclass
[exec] pg_restore: launching item 5796 INDEX pr4_fieldvalue_idx3
[exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx3"
[exec] pg_restore: finished item 5794 INDEX pr4_fieldvalue_idx1
[exec] pg_restore: launching item 5799 INDEX rule_fieldvres_1
[exec] pg_restore: creating INDEX "rules.rule_fieldvres_1"
[exec] pg_restore: finished item 5795 INDEX pr4_fieldvalue_idx2
[exec] pg_restore: launching item 5869 INDEX property_oc_cn
[exec] pg_restore: creating INDEX "rules.property_oc_cn"
[exec] pg_restore: finished item 5796 INDEX pr4_fieldvalue_idx3
[exec] pg_restore: launching item 5870 INDEX property_oc_in
[exec] pg_restore: creating INDEX "rules.property_oc_in"
[exec] pg_restore: finished item 5799 INDEX rule_fieldvres_1
[exec] pg_restore: launching item 5871 INDEX property_ruleset
[exec] pg_restore: creating INDEX "rules.property_ruleset"
[exec] pg_restore: finished item 5869 INDEX property_oc_cn
[exec] pg_restore: launching item 5872 INDEX rule_propres_1
[exec] pg_restore: creating INDEX "rules.rule_propres_1"
[exec] pg_restore: finished item 5870 INDEX property_oc_in
[exec] pg_restore: launching item 6043 INDEX pr4_rule_securitypolicies_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_securitypolicies_idx1"
[exec] pg_restore: finished item 6043 INDEX pr4_rule_securitypolicies_idx1
[exec] pg_restore: launching item 5735 CONSTRAINT pr4_rule_service_rest pr4_rule_service_rest_pk
[exec] pg_restore: finished item 5871 INDEX property_ruleset
[exec] pg_restore: launching item 5840 CONSTRAINT pr4_rule_shortcut pr4_rule_shortcut_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_service_rest pr4_rule_service_rest_pk"
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_shortcut pr4_rule_shortcut_pk"
[exec] pg_restore: finished item 5840 CONSTRAINT pr4_rule_shortcut pr4_rule_shortcut_pk
[exec] pg_restore: launching item 5838 INDEX pr4_rule_shorctcut_idx1
[exec] pg_restore: pg_restore: finished item 5872 INDEX rule_propres_1
[exec] creating INDEX "rules.pr4_rule_shorctcut_idx1"
[exec] pg_restore: launching item 5841 INDEX rule_shortcres_1
[exec] pg_restore: creating INDEX "rules.rule_shortcres_1"
[exec] pg_restore: finished item 5735 CONSTRAINT pr4_rule_service_rest pr4_rule_service_rest_pk
[exec] pg_restore: launching item 5733 INDEX pr4_rule_service_rest_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_service_rest_idx1"
[exec] pg_restore: finished item 5838 INDEX pr4_rule_shorctcut_idx1
[exec] pg_restore: launching item 5842 INDEX shortcut_owner_idx
[exec] pg_restore: creating INDEX "rules.shortcut_owner_idx"
[exec] pg_restore: finished item 5841 INDEX rule_shortcres_1
[exec] pg_restore: launching item 5880 CONSTRAINT pr4_rule_sysgen pr4_rule_sysgen_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_sysgen pr4_rule_sysgen_pk"
[exec] pg_restore: finished item 5733 INDEX pr4_rule_service_rest_idx1
[exec] pg_restore: launching item 6031 CONSTRAINT pr4_rule_testcase pr4_rule_tc_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_testcase pr4_rule_tc_pk"
[exec] pg_restore: finished item 5842 INDEX shortcut_owner_idx
[exec] pg_restore: launching item 6052 CONSTRAINT pr4_rule_testsuite pr4_rule_testsuite_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_testsuite pr4_rule_testsuite_pk"
[exec] pg_restore: finished item 5880 CONSTRAINT pr4_rule_sysgen pr4_rule_sysgen_pk
[exec] pg_restore: launching item 5878 INDEX pr4_rule_sysgen_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_sysgen_idx1"
[exec] pg_restore: finished item 6031 CONSTRAINT pr4_rule_testcase pr4_rule_tc_pk
[exec] pg_restore: launching item 5881 INDEX rule_sysgres_1
[exec] pg_restore: creating INDEX "rules.rule_sysgres_1"
[exec] pg_restore: finished item 5878 INDEX pr4_rule_sysgen_idx1
[exec] pg_restore: launching item 5882 INDEX sysgen_objclass
[exec] pg_restore: creating INDEX "rules.sysgen_objclass"
[exec] pg_restore: finished item 6052 CONSTRAINT pr4_rule_testsuite pr4_rule_testsuite_pk
[exec] pg_restore: launching item 5883 INDEX sysgen_oc_cn
[exec] pg_restore: creating INDEX "rules.sysgen_oc_cn"
[exec] pg_restore: finished item 5881 INDEX rule_sysgres_1
[exec] pg_restore: launching item 5884 INDEX sysgen_oc_in
[exec] pg_restore: creating INDEX "rules.sysgen_oc_in"
[exec] pg_restore: finished item 5882 INDEX sysgen_objclass
[exec] pg_restore: launching item 5885 INDEX sysgen_resolution
[exec] pg_restore: finished item 5883 INDEX sysgen_oc_cn
[exec] pg_restore: launching item 5886 INDEX sysgen_ruleset
[exec] pg_restore: creating INDEX "rules.sysgen_resolution"
[exec] pg_restore: creating INDEX "rules.sysgen_ruleset"
[exec] pg_restore: finished item 5884 INDEX sysgen_oc_in
[exec] pg_restore: launching item 6028 INDEX pr4_rule_tc_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_tc_idx1"
[exec] pg_restore: finished item 5885 INDEX sysgen_resolution
[exec] pg_restore: launching item 6029 INDEX pr4_rule_tc_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_tc_idx2"
[exec] pg_restore: finished item 5886 INDEX sysgen_ruleset
[exec] pg_restore: launching item 5945 CONSTRAINT pr4_rule_usecase pr4_rule_usecase_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_usecase pr4_rule_usecase_pk"
[exec] pg_restore: finished item 6028 INDEX pr4_rule_tc_idx1
[exec] pg_restore: launching item 6102 CONSTRAINT pr4_rule_view pr4_rule_view_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_view pr4_rule_view_pk"
[exec] pg_restore: finished item 5945 CONSTRAINT pr4_rule_usecase pr4_rule_usecase_pk
[exec] pg_restore: launching item 5943 INDEX pr4_rule_usecase_oc_in
[exec] pg_restore: creating INDEX "rules.pr4_rule_usecase_oc_in"
[exec] pg_restore: finished item 6029 INDEX pr4_rule_tc_idx2
[exec] pg_restore: launching item 5946 INDEX pr4_rule_usecaseoc_cn
[exec] pg_restore: creating INDEX "rules.pr4_rule_usecaseoc_cn"
[exec] pg_restore: finished item 6102 CONSTRAINT pr4_rule_view pr4_rule_view_pk
[exec] pg_restore: launching item 5947 INDEX pr4_ruleucruleset
[exec] pg_restore: creating INDEX "rules.pr4_ruleucruleset"
[exec] pg_restore: finished item 5946 INDEX pr4_rule_usecaseoc_cn
[exec] pg_restore: launching item 5948 INDEX rule_usecase_objclass
[exec] pg_restore: pg_restore: creating INDEX "rules.rule_usecase_objclass"
[exec] finished item 5943 INDEX pr4_rule_usecase_oc_in
[exec] pg_restore: launching item 5949 INDEX rule_usecase_ruleres_1
[exec] pg_restore: creating INDEX "rules.rule_usecase_ruleres_1"
[exec] pg_restore: finished item 5948 INDEX rule_usecase_objclass
[exec] pg_restore: launching item 6099 INDEX pr4_rule_view_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_view_idx2"
[exec] pg_restore: finished item 5947 INDEX pr4_ruleucruleset
[exec] pg_restore: launching item 6100 INDEX pr4_rule_view_idx4
[exec] pg_restore: pg_restore: creating INDEX "rules.pr4_rule_view_idx4"
[exec] finished item 5949 INDEX rule_usecase_ruleres_1
[exec] pg_restore: launching item 5902 CONSTRAINT pr4_rule_file_binary pr4_rule_file_binary_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_file_binary pr4_rule_file_binary_pk"
[exec] pg_restore: finished item 6100 INDEX pr4_rule_view_idx4
[exec] pg_restore: launching item 5932 CONSTRAINT pr_app_branch_idx pr_app_branch_idx_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_app_branch_idx pr_app_branch_idx_pk"
[exec] pg_restore: finished item 6099 INDEX pr4_rule_view_idx2
[exec] pg_restore: launching item 5850 CONSTRAINT pr4_rule_vw pr4_rule_vw_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_vw pr4_rule_vw_pk"
[exec] pg_restore: finished item 5932 CONSTRAINT pr_app_branch_idx pr_app_branch_idx_pk
[exec] pg_restore: launching item 5929 INDEX app_branch_idx_key
[exec] pg_restore: finished item 5902 CONSTRAINT pr4_rule_file_binary pr4_rule_file_binary_pk
[exec] pg_restore: launching item 5899 INDEX pr4_rule_file_binary_idx1
[exec] pg_restore: creating INDEX "rules.app_branch_idx_key"
[exec] pg_restore: creating INDEX "rules.pr4_rule_file_binary_idx1"
[exec] pg_restore: finished item 5929 INDEX app_branch_idx_key
[exec] pg_restore: launching item 5900 INDEX pr4_rule_file_binary_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_file_binary_idx2"
[exec] pg_restore: finished item 5900 INDEX pr4_rule_file_binary_idx2
[exec] pg_restore: launching item 5903 INDEX rfb_insnclass
[exec] pg_restore: creating INDEX "rules.rfb_insnclass"
[exec] pg_restore: finished item 5899 INDEX pr4_rule_file_binary_idx1
[exec] pg_restore: launching item 5904 INDEX rule_rulefilebinaryres_1
[exec] pg_restore: creating INDEX "rules.rule_rulefilebinaryres_1"
[exec] pg_restore: finished item 5903 INDEX rfb_insnclass
[exec] pg_restore: launching item 5930 INDEX branch_id_idx_key
[exec] pg_restore: creating INDEX "rules.branch_id_idx_key"
[exec] pg_restore: finished item 5904 INDEX rule_rulefilebinaryres_1
[exec] pg_restore: launching item 5767 CONSTRAINT pr_changelog pr_changelog_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_changelog pr_changelog_pk"
[exec] pg_restore: finished item 5930 INDEX branch_id_idx_key
[exec] pg_restore: launching item 5994 CONSTRAINT pr_data_admin_product pr_data_admin_product_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_admin_product pr_data_admin_product_pk"
[exec] pg_restore: finished item 5994 CONSTRAINT pr_data_admin_product pr_data_admin_product_pk
[exec] pg_restore: launching item 5793 CONSTRAINT pr_data_admin_restore pr_data_admin_restore_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_admin_restore pr_data_admin_restore_pk"
[exec] pg_restore: finished item 5767 CONSTRAINT pr_changelog pr_changelog_pk
[exec] pg_restore: launching item 5765 INDEX pr_changelog_idx1
[exec] pg_restore: creating INDEX "rules.pr_changelog_idx1"
[exec] pg_restore: finished item 5793 CONSTRAINT pr_data_admin_restore pr_data_admin_restore_pk
[exec] pg_restore: launching item 6034 CONSTRAINT pr_data_customproperties pr_data_customproperties_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_customproperties pr_data_customproperties_pk"
[exec] pg_restore: finished item 6034 CONSTRAINT pr_data_customproperties pr_data_customproperties_pk
[exec] pg_restore: launching item 6032 INDEX pr_data_customproperties_idx1
[exec] pg_restore: creating INDEX "rules.pr_data_customproperties_idx1"
[exec] pg_restore: finished item 5765 INDEX pr_changelog_idx1
[exec] pg_restore: launching item 5980 CONSTRAINT pr_data_map_entries pr_data_map_entries_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_map_entries pr_data_map_entries_pk"
[exec] pg_restore: finished item 6032 INDEX pr_data_customproperties_idx1
[exec] pg_restore: launching item 5951 CONSTRAINT pr_data_products pr_data_products_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_products pr_data_products_pk"
[exec] pg_restore: finished item 5980 CONSTRAINT pr_data_map_entries pr_data_map_entries_pk
[exec] pg_restore: launching item 5978 INDEX pr_data_map_entries_idx
[exec] pg_restore: creating INDEX "rules.pr_data_map_entries_idx"
[exec] pg_restore: finished item 5951 CONSTRAINT pr_data_products pr_data_products_pk
[exec] pg_restore: launching item 5953 CONSTRAINT pr_data_restore pr_data_restore_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_restore pr_data_restore_pk"
[exec] pg_restore: finished item 5978 INDEX pr_data_map_entries_idx
[exec] pg_restore: launching item 5986 CONSTRAINT pr_data_rule_appmetadata pr_data_rule_appmetadata_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_rule_appmetadata pr_data_rule_appmetadata_pk"
[exec] pg_restore: finished item 5953 CONSTRAINT pr_data_restore pr_data_restore_pk
[exec] pg_restore: launching item 6006 CONSTRAINT pr_data_scanner pr_data_scanner_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_data_scanner pr_data_scanner_pk"
[exec] pg_restore: finished item 5986 CONSTRAINT pr_data_rule_appmetadata pr_data_rule_appmetadata_pk
[exec] pg_restore: launching item 5834 CONSTRAINT pr4_rule_section pr4_rule_section_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_section pr4_rule_section_pk"
[exec] pg_restore: finished item 6006 CONSTRAINT pr_data_scanner pr_data_scanner_pk
[exec] pg_restore: launching item 6004 INDEX pr_data_scanner_idx1
[exec] pg_restore: creating INDEX "rules.pr_data_scanner_idx1"
[exec] pg_restore: finished item 6004 INDEX pr_data_scanner_idx1
[exec] pg_restore: launching item 6038 CONSTRAINT pr_index_applicationbuilton pr_index_applicationbuilton_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_applicationbuilton pr_index_applicationbuilton_pk"
[exec] pg_restore: finished item 6038 CONSTRAINT pr_index_applicationbuilton pr_index_applicationbuilton_pk
[exec] pg_restore: launching item 6035 INDEX getbuiltonapplications
[exec] pg_restore: creating INDEX "rules.getbuiltonapplications"
[exec] pg_restore: finished item 6035 INDEX getbuiltonapplications
[exec] pg_restore: launching item 6036 INDEX keypurposeidx_appbuilton
[exec] pg_restore: creating INDEX "rules.keypurposeidx_appbuilton"
[exec] pg_restore: finished item 6036 INDEX keypurposeidx_appbuilton
[exec] pg_restore: launching item 6094 CONSTRAINT pr_index_bi_permission pr_index_bi_permission_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_bi_permission pr_index_bi_permission_pk"
[exec] pg_restore: finished item 5834 CONSTRAINT pr4_rule_section pr4_rule_section_pk
[exec] pg_restore: launching item 5831 INDEX pr4_rule_section_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_section_idx1"
[exec] pg_restore: finished item 6094 CONSTRAINT pr_index_bi_permission pr_index_bi_permission_pk
[exec] pg_restore: launching item 5832 INDEX pr4_rule_section_idx2
[exec] pg_restore: pg_restore: finished item 5850 CONSTRAINT pr4_rule_vw pr4_rule_vw_pk
[exec] pg_restore: creating INDEX "rules.pr4_rule_section_idx2"
[exec] launching item 5843 INDEX pr4_rule_vw_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx1"
[exec] pg_restore: finished item 5831 INDEX pr4_rule_section_idx1
[exec] pg_restore: launching item 5844 INDEX pr4_rule_vw_idx2
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx2"
[exec] pg_restore: finished item 5832 INDEX pr4_rule_section_idx2
[exec] pg_restore: launching item 5845 INDEX pr4_rule_vw_idx3
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx3"
[exec] pg_restore: finished item 6558 TABLE DATA pr_engineclasses
[exec] pg_restore: launching item 5846 INDEX pr4_rule_vw_idx4
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx4"
[exec] pg_restore: finished item 5843 INDEX pr4_rule_vw_idx1
[exec] pg_restore: launching item 5847 INDEX pr4_rule_vw_idx5
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx5"
[exec] pg_restore: finished item 5847 INDEX pr4_rule_vw_idx5
[exec] pg_restore: launching item 5848 INDEX pr4_rule_vw_idx6
[exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx6"
[exec] pg_restore: finished item 5845 INDEX pr4_rule_vw_idx3
[exec] pg_restore: launching item 5851 INDEX pr4_view_op
[exec] pg_restore: creating INDEX "rules.pr4_view_op"
[exec] pg_restore: finished item 5844 INDEX pr4_rule_vw_idx2
[exec] pg_restore: launching item 5852 INDEX pr4_vw_oc_in
[exec] pg_restore: creating INDEX "rules.pr4_vw_oc_in"
[exec] pg_restore: finished item 5846 INDEX pr4_rule_vw_idx4
[exec] pg_restore: launching item 5853 INDEX pr4_vwoc_cn
[exec] pg_restore: creating INDEX "rules.pr4_vwoc_cn"
[exec] pg_restore: finished item 5848 INDEX pr4_rule_vw_idx6
[exec] pg_restore: launching item 5854 INDEX pr4_vwruleset
[exec] pg_restore: creating INDEX "rules.pr4_vwruleset"
[exec] pg_restore: finished item 5851 INDEX pr4_view_op
[exec] pg_restore: launching item 5855 INDEX vw_objclass
[exec] pg_restore: creating INDEX "rules.vw_objclass"
[exec] pg_restore: finished item 5853 INDEX pr4_vwoc_cn
[exec] pg_restore: launching item 5856 INDEX vw_resolution
[exec] pg_restore: creating INDEX "rules.vw_resolution"
[exec] pg_restore: finished item 5854 INDEX pr4_vwruleset
[exec] pg_restore: launching item 6092 INDEX pr_index_bi_permission_idx1
[exec] pg_restore: creating INDEX "rules.pr_index_bi_permission_idx1"
[exec] pg_restore: finished item 6092 INDEX pr_index_bi_permission_idx1
[exec] pg_restore: launching item 5825 CONSTRAINT pr4_rule pr4_rule_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr4_rule pr4_rule_pk"
[exec] pg_restore: finished item 5855 INDEX vw_objclass
[exec] pg_restore: launching item 5781 CONSTRAINT pr_index_circumstance_def pr_index_circumstance_def_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_circumstance_def pr_index_circumstance_def_pk"
[exec] pg_restore: finished item 5781 CONSTRAINT pr_index_circumstance_def pr_index_circumstance_def_pk
[exec] pg_restore: launching item 5779 INDEX keypurposeidx_cirdef
[exec] pg_restore: creating INDEX "rules.keypurposeidx_cirdef"
[exec] pg_restore: finished item 5779 INDEX keypurposeidx_cirdef
[exec] pg_restore: launching item 5807 CONSTRAINT pr_index_customfields pr_index_customfields_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_customfields pr_index_customfields_pk"
[exec] pg_restore: finished item 5807 CONSTRAINT pr_index_customfields pr_index_customfields_pk
[exec] pg_restore: launching item 5805 INDEX customfields
[exec] pg_restore: creating INDEX "rules.customfields"
[exec] pg_restore: finished item 5805 INDEX customfields
[exec] pg_restore: launching item 6055 CONSTRAINT pr_index_datasaveoptions pr_index_datasavop_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_datasaveoptions pr_index_datasavop_pk"
[exec] pg_restore: finished item 6055 CONSTRAINT pr_index_datasaveoptions pr_index_datasavop_pk
[exec] pg_restore: launching item 6053 INDEX pr_index_datasaveop_idx1
[exec] pg_restore: creating INDEX "rules.pr_index_datasaveop_idx1"
[exec] pg_restore: finished item 6053 INDEX pr_index_datasaveop_idx1
[exec] pg_restore: launching item 5935 CONSTRAINT pr_index_datasources pr_index_datasources_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_datasources pr_index_datasources_pk"
[exec] pg_restore: finished item 5825 CONSTRAINT pr4_rule pr4_rule_pk
[exec] pg_restore: launching item 5822 INDEX pr4_rule_idx1
[exec] pg_restore: creating INDEX "rules.pr4_rule_idx1"
[exec] pg_restore: finished item 5856 INDEX vw_resolution
[exec] pg_restore: launching item 5823 INDEX pr4_rule_oc_in
[exec] pg_restore: creating INDEX "rules.pr4_rule_oc_in"
[exec] pg_restore: finished item 5935 CONSTRAINT pr_index_datasources pr_index_datasources_pk
[exec] pg_restore: launching item 5826 INDEX pr4_ruleoc_cn
[exec] pg_restore: creating INDEX "rules.pr4_ruleoc_cn"
[exec] pg_restore: finished item 5852 INDEX pr4_vw_oc_in
[exec] pg_restore: launching item 5827 INDEX pr4_ruleruleset
[exec] pg_restore: creating INDEX "rules.pr4_ruleruleset"
[exec] pg_restore: finished item 5822 INDEX pr4_rule_idx1
[exec] pg_restore: launching item 5828 INDEX rule_app_hier
[exec] pg_restore: creating INDEX "rules.rule_app_hier"
[exec] pg_restore: finished item 5826 INDEX pr4_ruleoc_cn
[exec] pg_restore: launching item 5829 INDEX rule_objclass
[exec] pg_restore: creating INDEX "rules.rule_objclass"
[exec] pg_restore: finished item 5828 INDEX rule_app_hier
[exec] pg_restore: launching item 5830 INDEX rule_ruleres_1
[exec] pg_restore: finished item 5823 INDEX pr4_rule_oc_in
[exec] pg_restore: launching item 5933 INDEX pr_datasource_type
[exec] pg_restore: creating INDEX "rules.rule_ruleres_1"
[exec] pg_restore: creating INDEX "rules.pr_datasource_type"
[exec] pg_restore: finished item 5933 INDEX pr_datasource_type
[exec] pg_restore: launching item 6048 CONSTRAINT pr_index_policyconditions pr_index_policycond_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_policyconditions pr_index_policycond_pk"
[exec] pg_restore: finished item 5827 INDEX pr4_ruleruleset
[exec] pg_restore: launching item 6003 CONSTRAINT pr_index_privilege pr_index_privilege_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_privilege pr_index_privilege_pk"
[exec] pg_restore: finished item 6048 CONSTRAINT pr_index_policyconditions pr_index_policycond_pk
[exec] pg_restore: launching item 6046 INDEX pr_index_policycond_idx1
[exec] pg_restore: finished item 6003 CONSTRAINT pr_index_privilege pr_index_privilege_pk
[exec] pg_restore: launching item 6000 INDEX insindexedkeyprivilege
[exec] pg_restore: creating INDEX "rules.pr_index_policycond_idx1"
[exec] pg_restore: creating INDEX "rules.insindexedkeyprivilege"
[exec] pg_restore: finished item 5829 INDEX rule_objclass
[exec] pg_restore: launching item 6001 INDEX keypurposeidxprivilege
[exec] pg_restore: creating INDEX "rules.keypurposeidxprivilege"
[exec] pg_restore: finished item 6001 INDEX keypurposeidxprivilege
[exec] pg_restore: launching item 5804 CONSTRAINT pr_index_css pr_index_css_pk
[exec] pg_restore: pg_restore: creating CONSTRAINT "rules.pr_index_css pr_index_css_pk"
[exec] finished item 6046 INDEX pr_index_policycond_idx1
[exec] pg_restore: launching item 6009 CONSTRAINT pr_index_rule_agents pr_index_rule_agents_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_rule_agents pr_index_rule_agents_pk"
[exec] pg_restore: finished item 6000 INDEX insindexedkeyprivilege
[exec] pg_restore: launching item 5812 CONSTRAINT pr_index_warnings pr_index_warnings_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_warnings pr_index_warnings_pk"
[exec] pg_restore: finished item 6009 CONSTRAINT pr_index_rule_agents pr_index_rule_agents_pk
[exec] pg_restore: launching item 6007 INDEX pr_index_rule_agents_idx1
[exec] pg_restore: creating INDEX "rules.pr_index_rule_agents_idx1"
[exec] pg_restore: finished item 6007 INDEX pr_index_rule_agents_idx1
[exec] pg_restore: launching item 6050 CONSTRAINT pr_link_feature pr_link_feature_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_link_feature pr_link_feature_pk"
[exec] pg_restore: finished item 6050 CONSTRAINT pr_link_feature pr_link_feature_pk
[exec] pg_restore: launching item 5778 CONSTRAINT pr_link_usecase pr_link_usecase_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_link_usecase pr_link_usecase_pk"
[exec] pg_restore: finished item 5830 INDEX rule_ruleres_1
[exec] pg_restore: launching item 6076 CONSTRAINT pr_migration_point pr_migration_point_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_migration_point pr_migration_point_pk"
[exec] pg_restore: finished item 5778 CONSTRAINT pr_link_usecase pr_link_usecase_pk
[exec] pg_restore: launching item 5774 INDEX pr_link_usecase_faobj
[exec] pg_restore: creating INDEX "rules.pr_link_usecase_faobj"
[exec] pg_restore: finished item 6076 CONSTRAINT pr_migration_point pr_migration_point_pk
[exec] pg_restore: launching item 5775 INDEX pr_link_usecase_linkref
[exec] pg_restore: creating INDEX "rules.pr_link_usecase_linkref"
[exec] pg_restore: finished item 5774 INDEX pr_link_usecase_faobj
[exec] pg_restore: launching item 5776 INDEX pr_link_usecase_linkreffrom
[exec] pg_restore: creating INDEX "rules.pr_link_usecase_linkreffrom"
[exec] pg_restore: finished item 5775 INDEX pr_link_usecase_linkref
[exec] pg_restore: launching item 5992 CONSTRAINT pr_reference_page pr_reference_page_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_reference_page pr_reference_page_pk"
[exec] pg_restore: finished item 5776 INDEX pr_link_usecase_linkreffrom
[exec] pg_restore: launching item 5771 CONSTRAINT pr_selectquerylog pr_selectquerylog_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_selectquerylog pr_selectquerylog_pk"
[exec] pg_restore: finished item 5771 CONSTRAINT pr_selectquerylog pr_selectquerylog_pk
[exec] pg_restore: launching item 5768 INDEX pr_selectquerylog_idx1
[exec] pg_restore: creating INDEX "rules.pr_selectquerylog_idx1"
[exec] pg_restore: finished item 5768 INDEX pr_selectquerylog_idx1
[exec] pg_restore: launching item 5769 INDEX pr_selectquerylog_idx2
[exec] pg_restore: creating INDEX "rules.pr_selectquerylog_idx2"
[exec] pg_restore: finished item 5769 INDEX pr_selectquerylog_idx2
[exec] pg_restore: launching item 5967 CONSTRAINT pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk"
[exec] pg_restore: finished item 5967 CONSTRAINT pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk
[exec] pg_restore: launching item 5961 INDEX apphierarchyflat_report
[exec] pg_restore: creating INDEX "rules.apphierarchyflat_report"
[exec] pg_restore: finished item 5961 INDEX apphierarchyflat_report
[exec] pg_restore: launching item 5962 INDEX pr_sys_app_hierarchy_flat_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx1"
[exec] pg_restore: finished item 5962 INDEX pr_sys_app_hierarchy_flat_idx1
[exec] pg_restore: launching item 5963 INDEX pr_sys_app_hierarchy_flat_idx2
[exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx2"
[exec] pg_restore: finished item 5963 INDEX pr_sys_app_hierarchy_flat_idx2
[exec] pg_restore: launching item 5964 INDEX pr_sys_app_hierarchy_flat_idx3
[exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx3"
[exec] pg_restore: finished item 5964 INDEX pr_sys_app_hierarchy_flat_idx3
[exec] pg_restore: launching item 5965 INDEX pr_sys_app_hierarchy_flat_idx4
[exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx4"
[exec] pg_restore: finished item 5965 INDEX pr_sys_app_hierarchy_flat_idx4
[exec] pg_restore: launching item 5928 CONSTRAINT pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk"
[exec] pg_restore: finished item 5928 CONSTRAINT pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk
[exec] pg_restore: launching item 5924 INDEX pr_sari_appverrs
[exec] pg_restore: creating INDEX "rules.pr_sari_appverrs"
[exec] pg_restore: finished item 5804 CONSTRAINT pr_index_css pr_index_css_pk
[exec] pg_restore: launching item 5800 INDEX css_index1
[exec] pg_restore: creating INDEX "rules.css_index1"
[exec] pg_restore: finished item 5924 INDEX pr_sari_appverrs
[exec] pg_restore: launching item 5801 INDEX css_indexed_key
[exec] pg_restore: creating INDEX "rules.css_indexed_key"
[exec] pg_restore: finished item 5812 CONSTRAINT pr_index_warnings pr_index_warnings_pk
[exec] pg_restore: launching item 5802 INDEX keypurposeidx_css
[exec] pg_restore: creating INDEX "rules.keypurposeidx_css"
[exec] pg_restore: finished item 5992 CONSTRAINT pr_reference_page pr_reference_page_pk
[exec] pg_restore: launching item 5808 INDEX idxwarnings
[exec] pg_restore: creating INDEX "rules.idxwarnings"
[exec] pg_restore: finished item 5800 INDEX css_index1
[exec] pg_restore: launching item 5809 INDEX keypurposeidx_warn
[exec] pg_restore: creating INDEX "rules.keypurposeidx_warn"
[exec] pg_restore: finished item 5801 INDEX css_indexed_key
[exec] pg_restore: launching item 5810 INDEX pr_index_warnings_idx1
[exec] pg_restore: creating INDEX "rules.pr_index_warnings_idx1"
[exec] pg_restore: finished item 5802 INDEX keypurposeidx_css
[exec] pg_restore: launching item 5987 INDEX pr_ref_page_pageclass
[exec] pg_restore: creating INDEX "rules.pr_ref_page_pageclass"
[exec] pg_restore: finished item 5987 INDEX pr_ref_page_pageclass
[exec] pg_restore: launching item 5988 INDEX pr_reference_page_idx1
[exec] pg_restore: creating INDEX "rules.pr_reference_page_idx1"
[exec] pg_restore: finished item 5988 INDEX pr_reference_page_idx1
[exec] pg_restore: launching item 5989 INDEX pr_reference_page_idx2
[exec] pg_restore: creating INDEX "rules.pr_reference_page_idx2"
[exec] pg_restore: finished item 5989 INDEX pr_reference_page_idx2
[exec] pg_restore: launching item 5990 INDEX pr_reference_page_idx3
[exec] pg_restore: creating INDEX "rules.pr_reference_page_idx3"
[exec] pg_restore: finished item 5990 INDEX pr_reference_page_idx3
[exec] pg_restore: launching item 5925 INDEX pr_sys_app_ruleset_index_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_app_ruleset_index_idx1"
[exec] pg_restore: finished item 5925 INDEX pr_sys_app_ruleset_index_idx1
[exec] pg_restore: launching item 5926 INDEX pr_sys_app_ruleset_index_idx4
[exec] pg_restore: creating INDEX "rules.pr_sys_app_ruleset_index_idx4"
[exec] pg_restore: finished item 5926 INDEX pr_sys_app_ruleset_index_idx4
[exec] pg_restore: launching item 5972 CONSTRAINT pr_sys_appcache_dep pr_sys_appcache_dep_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_dep pr_sys_appcache_dep_pk"
[exec] pg_restore: finished item 5972 CONSTRAINT pr_sys_appcache_dep pr_sys_appcache_dep_pk
[exec] pg_restore: launching item 5968 INDEX pr_sys_appcache_dep_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx1"
[exec] pg_restore: finished item 5968 INDEX pr_sys_appcache_dep_idx1
[exec] pg_restore: launching item 5969 INDEX pr_sys_appcache_dep_idx2
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx2"
[exec] pg_restore: finished item 5969 INDEX pr_sys_appcache_dep_idx2
[exec] pg_restore: launching item 5970 INDEX pr_sys_appcache_dep_idx4
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx4"
[exec] pg_restore: finished item 5970 INDEX pr_sys_appcache_dep_idx4
[exec] pg_restore: launching item 5960 CONSTRAINT pr_sys_appcache_entry pr_sys_appcache_entry_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_entry pr_sys_appcache_entry_pk"
[exec] pg_restore: finished item 5960 CONSTRAINT pr_sys_appcache_entry pr_sys_appcache_entry_pk
[exec] pg_restore: launching item 5954 INDEX appentry_apphash
[exec] pg_restore: creating INDEX "rules.appentry_apphash"
[exec] pg_restore: finished item 5954 INDEX appentry_apphash
[exec] pg_restore: launching item 5955 INDEX appentry_impl
[exec] pg_restore: creating INDEX "rules.appentry_impl"
[exec] pg_restore: finished item 5955 INDEX appentry_impl
[exec] pg_restore: launching item 5956 INDEX appentry_rule
[exec] pg_restore: creating INDEX "rules.appentry_rule"
[exec] pg_restore: finished item 5956 INDEX appentry_rule
[exec] pg_restore: launching item 5957 INDEX pr_sys_appcache_entry_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_entry_idx1"
[exec] pg_restore: finished item 5957 INDEX pr_sys_appcache_entry_idx1
[exec] pg_restore: launching item 5958 INDEX pr_sys_appcache_entry_idx2
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_entry_idx2"
[exec] pg_restore: finished item 5958 INDEX pr_sys_appcache_entry_idx2
[exec] pg_restore: launching item 5977 CONSTRAINT pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk"
[exec] pg_restore: finished item 5977 CONSTRAINT pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk
[exec] pg_restore: launching item 5973 INDEX appshortcut_entrykey
[exec] pg_restore: creating INDEX "rules.appshortcut_entrykey"
[exec] pg_restore: finished item 5973 INDEX appshortcut_entrykey
[exec] pg_restore: launching item 5974 INDEX pr_sys_appcache_shortcut_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_shortcut_idx1"
[exec] pg_restore: finished item 5974 INDEX pr_sys_appcache_shortcut_idx1
[exec] pg_restore: launching item 5975 INDEX pr_sys_appcache_shortcut_idx2
[exec] pg_restore: creating INDEX "rules.pr_sys_appcache_shortcut_idx2"
[exec] pg_restore: finished item 5975 INDEX pr_sys_appcache_shortcut_idx2
[exec] pg_restore: launching item 5755 CONSTRAINT pr_sys_cache_dep pr_sys_cache_dep_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_dep pr_sys_cache_dep_pk"
[exec] pg_restore: finished item 5755 CONSTRAINT pr_sys_cache_dep pr_sys_cache_dep_pk
[exec] pg_restore: launching item 5751 INDEX cache_dep_dep
[exec] pg_restore: creating INDEX "rules.cache_dep_dep"
[exec] pg_restore: finished item 5751 INDEX cache_dep_dep
[exec] pg_restore: launching item 5752 INDEX cache_dep_impl
[exec] pg_restore: creating INDEX "rules.cache_dep_impl"
[exec] pg_restore: finished item 5752 INDEX cache_dep_impl
[exec] pg_restore: launching item 5753 INDEX dep_ruleinsid
[exec] pg_restore: creating INDEX "rules.dep_ruleinsid"
[exec] pg_restore: finished item 5753 INDEX dep_ruleinsid
[exec] pg_restore: launching item 5750 CONSTRAINT pr_sys_cache_entry pr_sys_cache_entry_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_entry pr_sys_cache_entry_pk"
[exec] pg_restore: finished item 5750 CONSTRAINT pr_sys_cache_entry pr_sys_cache_entry_pk
[exec] pg_restore: launching item 5745 INDEX cache_entry_hash
[exec] pg_restore: creating INDEX "rules.cache_entry_hash"
[exec] pg_restore: finished item 5745 INDEX cache_entry_hash
[exec] pg_restore: launching item 5746 INDEX cache_entry_impl
[exec] pg_restore: creating INDEX "rules.cache_entry_impl"
[exec] pg_restore: finished item 5746 INDEX cache_entry_impl
[exec] pg_restore: launching item 5747 INDEX cache_entry_rule
[exec] pg_restore: creating INDEX "rules.cache_entry_rule"
[exec] pg_restore: finished item 5747 INDEX cache_entry_rule
[exec] pg_restore: launching item 5748 INDEX pr_sys_cache_entry_idx2
[exec] pg_restore: creating INDEX "rules.pr_sys_cache_entry_idx2"
[exec] pg_restore: finished item 5748 INDEX pr_sys_cache_entry_idx2
[exec] pg_restore: launching item 5759 CONSTRAINT pr_sys_cache_impl pr_sys_cache_impl_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_impl pr_sys_cache_impl_pk"
[exec] pg_restore: finished item 5759 CONSTRAINT pr_sys_cache_impl pr_sys_cache_impl_pk
[exec] pg_restore: launching item 5756 INDEX cache_impl_impl
[exec] pg_restore: creating INDEX "rules.cache_impl_impl"
[exec] pg_restore: finished item 5756 INDEX cache_impl_impl
[exec] pg_restore: launching item 5757 INDEX cache_impl_rulename
[exec] pg_restore: creating INDEX "rules.cache_impl_rulename"
[exec] pg_restore: finished item 5757 INDEX cache_impl_rulename
[exec] pg_restore: launching item 5764 CONSTRAINT pr_sys_class_ancestors pr_sys_class_ancestors_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_class_ancestors pr_sys_class_ancestors_pk"
[exec] pg_restore: finished item 5764 CONSTRAINT pr_sys_class_ancestors pr_sys_class_ancestors_pk
[exec] pg_restore: launching item 5760 INDEX pr_sys_class_ancest_rr
[exec] pg_restore: creating INDEX "rules.pr_sys_class_ancest_rr"
[exec] pg_restore: finished item 5760 INDEX pr_sys_class_ancest_rr
[exec] pg_restore: launching item 5761 INDEX pr_sys_class_ancest_rr2
[exec] pg_restore: creating INDEX "rules.pr_sys_class_ancest_rr2"
[exec] pg_restore: finished item 5761 INDEX pr_sys_class_ancest_rr2
[exec] pg_restore: launching item 5762 INDEX pr_sys_class_ancestors_cc
[exec] pg_restore: creating INDEX "rules.pr_sys_class_ancestors_cc"
[exec] pg_restore: finished item 5762 INDEX pr_sys_class_ancestors_cc
[exec] pg_restore: launching item 5912 CONSTRAINT pr_sys_decchg pr_sys_decchg_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_decchg pr_sys_decchg_pk"
[exec] pg_restore: finished item 5912 CONSTRAINT pr_sys_decchg pr_sys_decchg_pk
[exec] pg_restore: launching item 5910 INDEX pr_sys_decchg_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_decchg_idx1"
[exec] pg_restore: finished item 5910 INDEX pr_sys_decchg_idx1
[exec] pg_restore: launching item 5913 INDEX sdc_class
[exec] pg_restore: creating INDEX "rules.sdc_class"
[exec] pg_restore: finished item 5913 INDEX sdc_class
[exec] pg_restore: launching item 5914 INDEX sdc_key
[exec] pg_restore: creating INDEX "rules.sdc_key"
[exec] pg_restore: finished item 5914 INDEX sdc_key
[exec] pg_restore: launching item 5915 INDEX sdc_prop
[exec] pg_restore: creating INDEX "rules.sdc_prop"
[exec] pg_restore: finished item 5915 INDEX sdc_prop
[exec] pg_restore: launching item 6016 CONSTRAINT pr_sys_hotfix_events pr_sys_hotfix_events_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_hotfix_events pr_sys_hotfix_events_pk"
[exec] pg_restore: finished item 6016 CONSTRAINT pr_sys_hotfix_events pr_sys_hotfix_events_pk
[exec] pg_restore: launching item 6014 INDEX pr_sys_hotfix_events_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_hotfix_events_idx1"
[exec] pg_restore: finished item 6014 INDEX pr_sys_hotfix_events_idx1
[exec] pg_restore: launching item 6071 CONSTRAINT pr_sys_import_queue pr_sys_import_queue_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_import_queue pr_sys_import_queue_pk"
[exec] pg_restore: finished item 6071 CONSTRAINT pr_sys_import_queue pr_sys_import_queue_pk
[exec] pg_restore: launching item 5984 CONSTRAINT pr_sys_rule_impl pr_sysrulim_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_rule_impl pr_sysrulim_pk"
[exec] pg_restore: finished item 5984 CONSTRAINT pr_sys_rule_impl pr_sysrulim_pk
[exec] pg_restore: launching item 5981 INDEX pr_sys_rule_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_rule_idx1"
[exec] pg_restore: finished item 5981 INDEX pr_sys_rule_idx1
[exec] pg_restore: launching item 5982 INDEX pr_sys_rule_impl_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_rule_impl_idx1"
[exec] pg_restore: finished item 5982 INDEX pr_sys_rule_impl_idx1
[exec] pg_restore: launching item 5907 CONSTRAINT pr_sys_ruleset_index pr_sys_ruleset_index_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_ruleset_index pr_sys_ruleset_index_pk"
[exec] pg_restore: finished item 5907 CONSTRAINT pr_sys_ruleset_index pr_sys_ruleset_index_pk
[exec] pg_restore: launching item 5905 INDEX pr_sys_ruleset_index_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_ruleset_index_idx1"
[exec] pg_restore: finished item 5905 INDEX pr_sys_ruleset_index_idx1
[exec] pg_restore: launching item 5908 INDEX rule_res_rule_join
[exec] pg_restore: creating INDEX "rules.rule_res_rule_join"
[exec] pg_restore: finished item 5908 INDEX rule_res_rule_join
[exec] pg_restore: launching item 5909 INDEX rulesetname
[exec] pg_restore: creating INDEX "rules.rulesetname"
[exec] pg_restore: finished item 5909 INDEX rulesetname
[exec] pg_restore: launching item 6079 CONSTRAINT pr_sys_runtime_context pr_sys_runtime_context_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sys_runtime_context pr_sys_runtime_context_pk"
[exec] pg_restore: finished item 6079 CONSTRAINT pr_sys_runtime_context pr_sys_runtime_context_pk
[exec] pg_restore: launching item 6077 INDEX pr_sys_runtime_context_idx1
[exec] pg_restore: creating INDEX "rules.pr_sys_runtime_context_idx1"
[exec] pg_restore: finished item 6077 INDEX pr_sys_runtime_context_idx1
[exec] pg_restore: launching item 5999 CONSTRAINT pr_sysgen_static_content pr_sysgen_static_content_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_sysgen_static_content pr_sysgen_static_content_pk"
[exec] pg_restore: finished item 5999 CONSTRAINT pr_sysgen_static_content pr_sysgen_static_content_pk
[exec] pg_restore: launching item 5995 INDEX pr_sysgen_static_content_idx2
[exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx2"
[exec] pg_restore: finished item 5995 INDEX pr_sysgen_static_content_idx2
[exec] pg_restore: launching item 5996 INDEX pr_sysgen_static_content_idx3
[exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx3"
[exec] pg_restore: finished item 5996 INDEX pr_sysgen_static_content_idx3
[exec] pg_restore: launching item 5997 INDEX pr_sysgen_static_content_idx4
[exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx4"
[exec] pg_restore: finished item 5997 INDEX pr_sysgen_static_content_idx4
[exec] pg_restore: launching item 5922 CONSTRAINT pr_assembledclasses pr_asmclass_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_assembledclasses pr_asmclass_pk"
[exec] pg_restore: finished item 5922 CONSTRAINT pr_assembledclasses pr_asmclass_pk
[exec] pg_restore: launching item 5923 INDEX pr_assembledclasses_package
[exec] pg_restore: creating INDEX "rules.pr_assembledclasses_package"
[exec] pg_restore: finished item 5923 INDEX pr_assembledclasses_package
[exec] pg_restore: launching item 5818 CONSTRAINT pr_index_reference pr_index_reference_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_index_reference pr_index_reference_pk"
[exec] pg_restore: finished item 5808 INDEX idxwarnings
[exec] pg_restore: launching item 5918 CONSTRAINT pr_engineclasses pr_engclass_pk
[exec] pg_restore: creating CONSTRAINT "rules.pr_engineclasses pr_engclass_pk"
[exec] pg_restore: finished item 5809 INDEX keypurposeidx_warn
[exec] pg_restore: finished item 5810 INDEX pr_index_warnings_idx1
[exec] pg_restore: finished item 5818 CONSTRAINT pr_index_reference pr_index_reference_pk
[exec] pg_restore: launching item 5813 INDEX index_ref
[exec] pg_restore: pg_restore: launching item 5814 INDEX index_refport
[exec] creating INDEX "rules.index_ref"
[exec] pg_restore: pg_restore: launching item 5815 INDEX pr_index_reference_index1
[exec] creating INDEX "rules.index_refport"
[exec] pg_restore: creating INDEX "rules.pr_index_reference_index1"
[exec] pg_restore: finished item 5918 CONSTRAINT pr_engineclasses pr_engclass_pk
[exec] pg_restore: launching item 5816 INDEX pr_index_reference_index2
[exec] pg_restore: creating INDEX "rules.pr_index_reference_index2"
[exec] pg_restore: finished item 5815 INDEX pr_index_reference_index1
[exec] pg_restore: launching item 5819 INDEX ref_index
[exec] pg_restore: creating INDEX "rules.ref_index"
[exec] pg_restore: finished item 5816 INDEX pr_index_reference_index2
[exec] pg_restore: launching item 5820 INDEX ref_objclass
[exec] pg_restore: creating INDEX "rules.ref_objclass"
[exec] pg_restore: finished item 5814 INDEX index_refport
[exec] pg_restore: launching item 5821 INDEX ref_rules
[exec] pg_restore: creating INDEX "rules.ref_rules"
[exec] pg_restore: finished item 5813 INDEX index_ref
[exec] pg_restore: launching item 5916 INDEX pr_engclass_code
[exec] pg_restore: creating INDEX "rules.pr_engclass_code"
[exec] pg_restore: finished item 5820 INDEX ref_objclass
[exec] pg_restore: launching item 5919 INDEX pr_engclass_pkg
[exec] pg_restore: creating INDEX "rules.pr_engclass_pkg"
[exec] pg_restore: finished item 5916 INDEX pr_engclass_code
[exec] pg_restore: launching item 5920 INDEX pr_engclass_querykey
[exec] pg_restore: creating INDEX "rules.pr_engclass_querykey"
[exec] pg_restore: finished item 5919 INDEX pr_engclass_pkg
[exec] pg_restore: finished item 5920 INDEX pr_engclass_querykey
[exec] pg_restore: finished item 5821 INDEX ref_rules
[exec] pg_restore: finished item 5819 INDEX ref_index
[exec] pg_restore: finished main parallel loop
[echo] Reindexing postgres database...
[exec] REINDEX
Assign Ports:
[replace] Replaced 1 occurrences in 1 files.
[replace] Replaced 4 occurrences in 1 files.
Configuration:
[exec] Microsoft (R) Windows Script Host Version 5.812
[exec] Copyright (C) Microsoft Corporation. All rights reserved.
[exec]
[delete] Deleting: D:\116984_PE8.6.0\pegaGuiInstallerTemp\CreatePegaShortCut.vbs
[exec]
[exec]
PRPC Launching:
[echo] Starting tomcat ....
[exec] 'cscript' is not recognized as an internal or external command,
[exec] operable program or batch file.
BUILD FAILED
D:\116984_PE8.6.0\pegaGuiInstallerTemp\build.xml:305: exec returned: 1
Total time: 26 minutes 26 seconds
