Database not defined in PRConfig settings (8.5.3 and 8.6.0 install in Kubernetes)
I am doing an install in Kubernetes on AKS and am receiving the following error:
[java] Caused by: com.pega.pegarules.pub.database.ConfigurationException: Database-General PegaDATA is not defined in the prconfig settings for this system. Please ensure that PegaDATA is defined with either datasource or url based connection information
[java] Caused by: com.pega.pegarules.pub.PRRuntimeException: Error determining the mode of PRPC install from database.
This is on an empty database, where the installation runs for approximately 15 minutes and then fails with that error. I noticed this error:
This is likely due to using a copy of prconfig.xml from a previous install.
However, that is not the case as there has not been a previous installation performed on the environment (I even recreated the Kubernetes cluster from scratch).
I rebuilt the cluster and the database and tried Pega 8.5.2, 8.5.3 and 8.6.0 images with the same result.
I followed the instructions from here:
https://github.com/pegasystems/pega-helm-charts/blob/master/docs/Deploying-Pega-on-AKS.md
I did not make any changes to the default `prconfig.xml` and am allowing the system to configure it on its own. Do I need to do anything specialize here?
I see at the start of the logs it gets dynamically generated:
Generating prconfig.xml from templates.
This completely blocks deployment to all environments.
Based on the logs attached it seems that the generated `prconfig.xml` file gets generated improperly:
org.xml.sax.SAXParseException: The reference to entity "GL6" must end with the ';' delimiter.
The JDBC connection string must be good because:
- I am using it to execute a database migration to create the schemas
- I see in the attached logs that the tables are created properly in the databse
- I am able to log into the database manually and see the tables that were created
Steps Followed
- Create AKS cluster
- Create database instance (MSSQL)
- Generate `values.yml` from the Helm instructions
- Update the YAML configuration with the appropriate database information, schema data, etc.
- Create the schema and other initialization data required in the database
- Execute the helm script using `helm upgrade --install --debug --wait --timeout 3h MY_DEPLOY -f /path/to/values.yaml --set global.actions.execute=install .` (additional parameters used to dynamically provide JDBC information)
- Allow install to run (dies consistently after 15 minutes)
Additional Data
Logs attached with connection details removed.
- Helm Chart Version: 1.5.3
- Helm Version: 3.5.4
- Pega Version: 8.6.0
