Morgan Stanley
Last activity: 11 Jan 2016 16:14 EST
Unable to generate Application document in Pega 7.1.7
PRPC is asking to install plug in for silver light while running document wizard. Still its unable to generate document even After successful installation.
I tried to trace and in tracer below SQL error is coming as an error, I am not sure if it can be an issue.
code: -302 SQLState: 22001 Message: DB2 SQL Error: SQLCODE=-302, SQLSTATE=22001, SQLERRMC=null, DRIVER=3.62.56
CVS Health
Hi Sharad,
I hope you deleted all temp folder data along with marker.txt file and restarted the server. If not, please give a try and see if that works.
Ravi Kumar.
Morgan Stanley
Thanks Ravi, yes we did a clean re start
regards
Sharad
CVS Health
TThanks for the reply. Can you pls try it in other browsers apart from IE?
Morgan Stanley
Thanks Ravi, Yes we tried with chrome browser , but the issue with Chrome is- Its not recognizing the installed PRPC silver light plug in.
And Chrome is not prompting for PRPC plug ins, its taking external site(s) to install and screen is hanging afterwards and its chrome issue is same with 7.1.8 and 7.1.9 versions.
CVS Health
I hope that you guys need to talk to your local admin based on the below PDN article. Looks to me that this plugin is not installed properly due to some privilege issues. Please check the below article.
https://community.pega.com/knowledgebase/release-note/word-merge-support-microsoft-silverlight-plug
Ravi Kumar.
Morgan Stanley
Thanks Ravi- we followed the article, installed the PRPC plug in with Admin help, restarted the system and the server. Also confirmed all registry are in place for MS silver light, still Its not working in IE but its not prompting for plug in to install from OOTB.
For Chrome - There is no option to save Pega prompted plug in, it will take to external web site and Admin can not help on this because its against the firm policy to download something from external site.
We raised an SR for V 7.1.9 and we got some registry setting from GCS and it worked but now the same issue with V 7.1.7
regards
Sharad
Hi sharad kalla,
Could you please reply with the SR number so that we may update this thread for tracking?
Thanks in advance!
Morgan Stanley
Marissa- SR-129832 was raised for Pega V 7.1.9 which worked and we still have issue while generating document in Pega 7.1.7 in IE and chrome both browsers
regards
Sharad.
Hi Sharad - I don't believe that is the correct SR as that pulls up an SR from March of 2015. Could you double check for me please?
Thanks!
Morgan Stanley
Thanks for clarifying for me! I'll update the thread accordingly.
