The TCP/IP connection to the host <db_servername>, port 1433 has failed after upgrading to Pega 07-10-20
After upgrading to Pega 07-10-20, I get the below errors in the catalina.out file
PRMiniLoader - unable to load classes from the database: Cannot create PoolableConnectionFactory
(The TCP/IP connection to the host <db_servername>, port 1433 has failed.
Error: "null. Verify the connection properties.
Make sure that an instance of SQL Server is running on the host and accepting TCP/IP
connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".)
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The TCP/IP connection to the host <db_servername>,
port 1433 has failed. Error: "null. Verify the connection properties.
Oscar
