SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
[exec] Result: 1
[exec] Result: 1
Dec 25, 2018 7:50:49 PM org.postgresql.Driver connect
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:194)
at org.postgresql.Driver.makeConnection(Driver.java:431)
at org.postgresql.Driver.connect(Driver.java:247)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:108)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:435)
at org.apache.tools.ant.Target.performTasks(Target.java:456)
[exec] Result: 1
Show More
[exec] Result: 1
[exec] Result: 1
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393)
at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1248)
at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:709)
at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:217)
at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:215)
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:78)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.postgresql.core.PGStream.<init>(PGStream.java:62)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144)
... 25 more
[exec] Result: 1
... 25 more
Dec 25, 2018 7:50:51 PM org.postgresql.Driver connect
... 25 more
... 25 more
Dec 25, 2018 7:50:53 PM org.postgresql.Driver connect
... 25 more
... 25 more
Dec 25, 2018 7:50:55 PM org.postgresql.Driver connect
... 25 more
... 25 more
Dec 25, 2018 7:50:57 PM org.postgresql.Driver connect
... 25 more
... 25 more
Dec 25, 2018 7:51:00 PM org.postgresql.Driver connect
... 25 more
... 25 more
Dec 25, 2018 7:51:02 PM org.postgresql.Driver connect
... 25 more
... 25 more
BUILD FAILED
C:\PEGA8\116168_PE8.1.0\pegaGuiInstallerTemp0\build.xml:164: Unable to connect to database within 15 seconds.
Total time: 1 minute 56 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:90)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:80)
... 2 more
--- Nested Exception ---
... 2 more
Show Less
