Atos
Last activity: 7 Feb 2019 11:27 EST
Routing "Route to: Operator - User name" is not saved
Currently using PEGA Infinity. Concerning "Collect information" steps in a "Child case".
When adding routing information to the collect information steps there seems to be an issue with saving specific user name info. Other dropdown options can be saved successfully, as they are supposed to.
So, after choosing the "Route to: Operator - User name", you fill in a operator id. Of course, using the autocomplete. Upon saving the step, the user name field appears blank. Thus, the user name selected is not saved correctly. This occurs at the "edit case type" level as well as the "Edit Flow" level.
Which Pega version are you facing this issue?
This seems to be working fine. Can you attach a quick video or steps to reproduce this?
