Routing case to the operator from the previous stage
What is the best way to route a case to the user who worked on it in a previous stage?
For example, an analyst steps through a stage. Upon completion the case is sent to a reviewer to be checked over. If the reviewer determines that the case is missing details, it needs to be routed back to the original analyst for amendments, then again returned to the reviewer.
Is there a way to capture the user at a given stage? I've been looking into the participants/roles settings and potentially extracting the info that way. Any suggestions would be greatly appreciated.
The information in the below post sounds like it might be helpful for your scenario.
https://collaborate.pega.com/question/route-back-case-same-operator
Hope this helps!
-Kurt
