Robotics Error creating runtime link!
Hi has any encountered the attached error when using a global container? if so how do you resolve it?
If you deleted something, sometimes the lines themselves do not get deleted. You might be able to locate the missing line as the connection points are slightly darker when something is connected as opposed to when they are disconnected. If not, you may need to disconnect all connection points in the automation related to the component mentioned in the error.
