Contractor
Robotics Runtime not loading
What do you mean by register a robot on this VM? Have you configured Runtime to point to a deployment package or OMC?
Contractor
Have you registered for OMC (it would have been arranged via your EM)? If so, you'll need to have received your tenant and connection information from support once you have purchased or provided your own security certificate. If you are not using OMC, then it sounds like you have installed Runtime with OMC enabled. If that's the case, it can be disabled in the config file. Please attach your RuntimeConfig.xml and I can tell you what to turn off.
IBM
Hi Sasnt,
Can you please tell the syntax that will be required for the change in the RuntimeConfig.XML file. Do we need to make change in the
<!-- If CanRunMultiplePackages is false and multiple packages are assigned in OMC the user will be prompted for which package to load. -->
<!-- If CanRunMultiplePackages is true all packages assigned in OMC will be loaded by Runtime. -->
<add key="CanRunMultiplePackages" value="false" />
Thanks & Regards,
Vaibhav Sharma
I believe I misspoke in my last message. It is disabled via the CommonConfig.xml in %ProgramData%\OpenSpan.
<ServerConfiguration tenant="TenantName">
<Servers>
<Server name="Config" baseURL="https://omc.openspan.com/" enabled="False" proxyAddress=""/>
<Server name="Intelligence" baseURL="example.url.com" enabled="" proxyAddress=""/>
<Server name="ADFS" baseURL="adfs.openspan.com" enabled="False" proxyAddress=""/>
</Servers>
</ServerConfiguration>
IBM
Hi Sasnt,
Thanks you, after making above changes in the Comman Config ,I was able to resolve the issue.
Thanks & Regards,
Vaibhav Sharma
Contractor
Thank you!. That was the problem indeed.
Regards.
Anthem
I am getting the same error after the change in commonconfig file. what might be the error?
Contractor
Hi, config file is attached (had to change it to txt)
Please let me know which lines to update. Thanks!
Please see the responses above. The server connectivity is disabled (or enabled in the CommonConfig.xml). I misspoke in my response to you.
Registering as a robot involves running a solution set up for RPA. The registration is specific to the solution you run. So while your VM will get registered as an Operator no matter which RPA solution you run, the assignment to a WorkGroup is controlled by the solution you are running.
Can you tell us the PRPC version you are using? a hotfix pack is needed to be installed according to your PRPC version to let RPA work.
