Pega Runtime Not Loading/Crashing
One user is reporting that the Pega runtime will not load after restarting. This is the content of the event files:
Faulting application name: OpenSpan.Runtime.exe, version: Proprietary information hidden, time stamp: 0x60cb81ab
Faulting module name: KERNELBASE.dll, version: 10.0.19041.2846, time stamp: 0xb9bbdd8b
Exception code: 0xe0434352
Fault offset: 0x00138fc2
Faulting process id: 0x26d8
Faulting application start time: 0x01d98a8b7522f1c7
Faulting application path: C:\Program Files (x86)\Pegasystems\Pega Robot Runtime\OpenSpan.Runtime.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: ff59f75f-57b2-46f7-855f-7621ae7146dc
Faulting package full name:
Faulting package-relative application ID:
Application: OpenSpan.Runtime.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at OpenSpan.RuntimeApplication.RuntimeApplication.Run(System.String[])
at OpenSpan.RuntimeApplication.RuntimeApplication.Main(System.String[])
The OpenSpan.Runtime.exe file is present in the directory. Windows version 21H2
