The requested resource [/prweb/] is not available
hi I'm trying to access the prweb application after configuring the necessary but from the logs i get this error
Show More
0-Sep-2021 19:12:09.708 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Server version name: Apache Tomcat/9.0.52
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jul 31 2021 04:12:17 UTC
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Server version number: 9.0.52.0
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 4.18.0-193.el8.x86_64
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
10-Sep-2021 19:12:09.710 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /usr/lib/jvm/java-11-openjdk-11.0.12.0.7-0.el8_4.x86_64
10-Sep-2021 19:12:09.711 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 11.0.12+7-LTS
10-Sep-2021 19:12:09.711 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Red Hat, Inc.
10-Sep-2021 19:12:09.711 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /usr/local/tomcat9
10-Sep-2021 19:12:09.711 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /usr/local/tomcat9
10-Sep-2021 19:12:09.719 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.lang=ALL-UNNAMED
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.io=ALL-UNNAMED
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util=ALL-UNNAMED
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.base/java.util.concurrent=ALL-UNNAMED
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: --add-opens=java.rmi/sun.rmi.transport=ALL-UNNAMED
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/usr/local/tomcat9/conf/logging.properties
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
10-Sep-2021 19:12:09.720 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
10-Sep-2021 19:12:09.721 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/usr/local/tomcat9
10-Sep-2021 19:12:09.721 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/usr/local/tomcat9
10-Sep-2021 19:12:09.721 INFORMAZIONI [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/usr/local/tomcat9/temp
10-Sep-2021 19:12:09.722 INFORMAZIONI [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
10-Sep-2021 19:12:09.975 INFORMAZIONI [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
10-Sep-2021 19:12:09.994 INFORMAZIONI [main] org.apache.catalina.startup.Catalina.load Server initialization in [456] milliseconds
10-Sep-2021 19:12:10.040 INFORMAZIONI [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
10-Sep-2021 19:12:10.040 INFORMAZIONI [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet engine: [Apache Tomcat/9.0.52]
10-Sep-2021 19:12:10.051 INFORMAZIONI [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [/usr/local/tomcat9/webapps/prweb.war]
10-Sep-2021 19:12:10.303 INFORMAZIONI [main] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PRFileStore Ignoring unknown property: value of "Database-based File Access" for "description" property
10-Sep-2021 19:12:10.310 INFORMAZIONI [main] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = AdminPegaRULES Ignoring unknown property: value of "PegaRULES Admin datasource" for "description" property
10-Sep-2021 19:12:10.311 INFORMAZIONI [main] org.apache.tomcat.dbcp.dbcp2.BasicDataSourceFactory.getObjectInstance Name = PegaRULES Ignoring unknown property: value of "PegaRULES datasource" for "description" property
10-Sep-2021 19:12:10.329 INFORMAZIONI [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
10-Sep-2021 19:12:10.396 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Loading bootstrap properties from /prbootstrap.properties
10-Sep-2021 19:12:10.397 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prbootstrap/ in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.398 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prbootstrap in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.398 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.399 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.399 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. No default data schema has been set. Will only use bootstrap properties from file.
10-Sep-2021 19:12:10.399 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource. Archive version [0 ]
10-Sep-2021 19:12:10.399 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine schema defined in allclasses: null
10-Sep-2021 19:12:10.399 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find java:comp/env/prconfig/ in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.400 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.SettingReaderJNDI. Could not find prconfig in the local JNDI context, skipping prconfig setting lookup
10-Sep-2021 19:12:10.400 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Engine classes schema: null
10-Sep-2021 19:12:10.400 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Assembled classes schema: null
10-Sep-2021 19:12:10.400 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
10-Sep-2021 19:12:10.402 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create JDBC driver of class '' for connect URL 'null'
10-Sep-2021 19:12:10.404 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
java.sql.SQLException: No suitable driver
at java.sql/java.sql.DriverManager.getDriver(DriverManager.java:298)
at org.apache.tomcat.dbcp.dbcp2.DriverFactory.createDriver(DriverFactory.java:59)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createConnectionFactory(BasicDataSource.java:461)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:527)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:733)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getLatestEngineCodeVersionFromDB(PRBootstrap.java:1024)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:639)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:427)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:225)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:274)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:92)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4768)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5230)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:726)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:698)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:696)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1024)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1911)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:825)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:475)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1618)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:319)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:946)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:835)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1396)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1386)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:919)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:263)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:432)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:927)
at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:345)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:476)
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.getConnection(PRMiniLoader.java:604)
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.getBaseResource(PRMiniLoader.java:511)
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.<init>(PRMiniLoader.java:264)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.createMiniLoader(PRBootstrap.java:728)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:672)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorSe10-Sep-2021 19:12:10.404 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create JDBC driver of class '' for connect URL 'null'
10-Sep-2021 19:12:10.405 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Could not find file:/usr/local/tomcat9/webapps/prweb/WEB-INF/lib/prbootstrap-8.5.3-551.jar
java.sql.SQLException: Cannot create JDBC driver of class '' for connect URL 'null'
at org.apache.tomcat.dbcp.dbcp2.DriverFactory.createDriver(DriverFactory.java:74)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.printConfiguration(PRBootstrap.java:785)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:679)
Caused by: java.sql.SQLException: No suitable driver
... 50 more
10-Sep-2021 19:12:10.407 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap.
============ PegaRULES Bootstrap Configuration ============
Date: Fri Sep 10 19:12:10 EDT 2021
Java Version: Red Hat, Inc. 11.0.12
Configuration: file:/usr/local/tomcat9/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode:
JNDI Reference: java:comp/env/jdbc/PegaRULES
(!) Unable to use given database configuration
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
Unable to load phase 2 bootstrap class: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
10-Sep-2021 19:12:10.407 GRAVE [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:378)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.loadPhase2BootstrapClass(PRBootstrap.java:733)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:676)
10-Sep-2021 19:12:10.408 GRAVE [main] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:225)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:342)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:322)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:428)
10-Sep-2021 19:12:10.408 GRAVE [main] org.apache.catalina.core.StandardContext.startInternal One or more listeners failed to start. Full details will be found in the appropriate container log file
10-Sep-2021 19:12:10.411 GRAVE [main] org.apache.catalina.core.StandardContext.startInternal Context [/prweb] startup failed due to previous errors
10-Sep-2021 19:12:10.414 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
rvice.java:140)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:75)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4816)
at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5477)
at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:257)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:187)
at org.apache.catalina.startup.HostConfig.lifecycleEv10-Sep-2021 19:12:10.415 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. PRBootstrap.calculateEngineCodeVersionFromDB() - unable to calculate codeset version from database: Cannot create JDBC driver of class '' for connect URL 'null'
10-Sep-2021 19:12:10.415 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Will load phase 2 bootstrap from Pega-EngineCode:
10-Sep-2021 19:12:10.415 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. PRMiniLoader - unable to load classes from the database: Cannot create JDBC driver of class '' for connect URL 'null'
10-Sep-2021 19:12:10.415 AVVERTENZA [main] com.pega.pegarules.internal.bootstrap.PRMiniLoader. Could not find file:/usr/local/tomcat9/webapps/prweb/WEB-INF/lib/prbootstrap-8.5.3-551.jar
... 51 more
10-Sep-2021 19:12:10.417 INFORMAZIONI [main] com.pega.pegarules.internal.bootstrap.PRBootstrap.
Pega-EngineCode:
10-Sep-2021 19:12:10.417 GRAVE [main] com.pega.pegarules.internal.bootstrap.PRBootstrap. Error initializing PRAppLoader
10-Sep-2021 19:12:10.417 GRAVE [main] com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega. Problem during method invocation (contextDestroyed)
10-Sep-2021 19:12:10.424 INFORMAZIONI [main] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive [/usr/local/tomcat9/webapps/prweb.war] has finished in [373] ms
Show Less
