Murex
LB
Last activity: 3 Mar 2020 5:51 EST
Queue Processor Is Not Working When Called From Outside Pega Using a Service Rest
Below is the context:
Requirement:
- To call a web-service that does something, then it does another modification on a list of work objects. Since the work object might be locked, an agent was to be used. But since agents are deprecated, a queue processor is required.
Below is what's done so far
- Created a web-service that calls an activity on Post. And it was tested successfully using Advanced Rest Client and the "Pega Run Option" of the web-service.
- Configured a dedicated Queue Processor A that runs an Activity B.
- Initialized the context of the Queue Processor in an ASYNCPROCESSOR Requestor Type that uses an Application-Based-Access-Group that has the access role PegaRULES:AsyncProcessor.
- Adapted the activity in the web service to Queue-To-Process the Queue Processor (A)
The web-service works properly when called from inside Pega, and the first modification from the web-service itself is done, and the request is queued to the Queue Processor A, and the change is reflected on the Objects.
However,
Problem:
When the web-service is called from outside Pega, for example " Advanced Rest Client ". The modification from the web-service is reflected ( Steps in the activity prior to Queue-To-Process ). But the request to the Queue Processor A, is not en-queued. When checked in the admin studio nothing is found on the "Items Ready to Process" column of queue processor A.
Requirement:
However,
Problem:
Summary:
When a queue-to-process step is called from a web-service from outside Pega it is not working/queueing the request to launch the activity.
