Calling a Salesforce REST service from Pega
I have requirement to call a SalesForce REST service from pega. for this first i have tried to do that in Post man tool and am able to call the REST Service. So i am doing 2 service calls. first service call is to get the access token(sending grant_type,client_id,client_secret,username,password as form data. Link:https://developer.salesforce.com/docs/atlas.en-us.api_rest.meta/api_rest/intro_oauth_and_connected_apps.htm) and the other service is to call the actual REST service using the access token.
In Pega, i am trying with 2 approaches.
Approach1:
First i tried to use the OAuth authentication type in the Connector. Followed your post in the below link.
https://pdn.pega.com/forums/rest-conenctor/unable-to-construct-json-format
1. Created the Oauth data instance.
2. Referred this Oauth name in Authentication profile and referred the authentication profile in connctor rule where i am trying to call actuall REST service.
This approach is failing in activity pyConnectOAuthProvider at step2. It is tring open "Data-Admin-Security-OAuth-Client-AccessToken" instance using consumer key and operator id.
Approach2:
I am trying to send the grant_type,client_id,client_secret,username,password in body. As the REST service is expecting these parameters as form data, i am not sure how to pass as form data. So i tried sending these parames separated by & in the Message body.
Ex: grant_type=password&client_id=
This giving me the below response.
"error": "unsupported_grant_type",
"error_description": "grant type not supported"
Please suggest me.
