Ernst & Young
Last activity: 8 May 2021 19:56 EDT
Queue Processor
Anyone implemented Queue processor in 8.1 version ?.
Need help in using it.
***Edited by Moderator Marissa to update platform capability tags; update SR Details****
Will the following info provide you some help?
Starting with Pega Platform version 8.1, Job Scheduler and Queue Processor rules replace Agents and improve background processing. More to the point, Job Scheduler rules replace Advanced Agents for recurring or scheduled tasks, and Queue Processor rules replace Standard Agents for queue management and asynchronous processing.
Check below link:
Ernst & Young
thanks for the reply, I need more information on setting up the Stream node and etc. Any implementation doc or steps on this would be much helpful.
Self
Hi Praveen,
This might help you .
How about this one?
JPMC
I have created a queue processor rule and queue activtity which pushes queue items to the queue processor and everything works fine but I want to know the background logic running for the queue processor.
Like how kafka is related to Queue Processor?
How the queueing happens in the back end ?
We used to have pr_sysqueues previously but now it is different. So what is logic happening ?
The attached image might help you to understand all your above queries.
Thank You,
Virtusa
@dasn1 Can you please provide details about how the reattempt works ?
ex: If we specify max attempt count as 3 in queue processor rule, then during processing after first failed attempt will the message post back (republished) to the topic/partition and will be reconsidered by data flow run again?
Morgan Stanley
Sharing Helpful Link : https://onestoppega.com/background-processing/queue-processor-in-pega/
