Infosys Limited
Last activity: 23 Sep 2022 5:15 EDT
Query on the default workbasket in workgroup
As part of the worgroup rule configuration, we are giving the default workbasket. As part of the workbasket rule configuration, we will give the work group rule. We configure the work group in the operator ruleform.
There could be a chance that multiple work baskets also configure the same workgroup rule. So that the operator can access the workbaskets that come under this workgroup.
My question is if multiple work baskets can be configured to the work group, what is the use of the default work basket that was configured in the workgroup?
Hi @P.Siva.Praveen: You can have multiple work baskets assigned for a work group. But it is mandatory that each work group should have at least one work basket where your assignments can be routed to. This help to enforce it. Another main usage of this is when performing routing. "ToDefaultWorkbasket" is one of the router which makes use of this.
Thanks.
