Query on Constellation Case Creation DX API
Hello everyone,
I have below query on Constellation Case Creation DX API.
We have two case types, where we use "Property A" as Pick list in both case first assignment (in View), And pick list sourced from Node level Data Page.
When we try use "Property A" in react UI configure dropdown, we have use below location to get the data page details and populate to React UI (For first Case type)
Same way when we try to configure it for Second case type, we have notice we are unable to see same "Shared" tag under "Data" topic.
When I check the DX API documentation, I couldn't find information on this.
Appreciate if anyone can provide info on this? And debug from where its setting to response?
Thanks.
@NuwanD54
Thanks for your clarification. As for the "shared" tag - If a read only data page is defined as a table type for a text property (picklist in the data model tab), then the results of the data page are returned in the response under 'shared', regardless of whether it has parameters or not. The name is kept 'shared' because we keep only one copy of results per param set in the client-side store which can be accessed from different case contexts on the client-side.
These details are missing from the DX API documentation and will be added soon. Thank you for pointing that out.
