pxTransferAssignment throws error -- Database-General error ... instances trying to calculate .... may not be written to Assign-
I am running the OOTB pxTransferAssignment as shown below to transfer an assignment to [email protected].
When I run the activity I get the following message
info: Database-General trying to calculate the handle of a class whose instances may not be written to the database: Assign-
I do an Obj-Open-By-Handle on step 3.2 and let the OOTB pxTransferAssignment to the Save and Commit. After the code runs, the assignment is indeed JohnGault's worklist but there is no Audit History on the WorkObject and this pop up that says info: Database-General trying to calculate the handle of a class whose instances may not be written to the database: Assign-
From the message it seems to be that PEGA is trying to write to the Assign- DB table, instead of the Assign-WorkList table.
I added a .pyNote property after I transfer the assignment (for unit testing) and that is empty which leads me to believe that the WO/Case is not getting saved an/or committed because of the message above, BUT somehow the assignment itself gets transferred.
Can some one point out what the issue is ?
