Capgemini Brasil S.A.
BR
Last activity: 15 Mar 2023 10:08 EDT
Problem installing Pega Personal Edition: postgres
when trying to install, an error message appears with postgres. Ports for it and tomcat are available. It looks like he didn't download some package or the package is out of date.
I already deleted the directory with the downloaded packages, I already released the postgres port in the firewall and tried to install it after restarting the machine. Repeat this process a few times.
According to the tutorial, there shouldn't be an error, because just start the .bat, accept the term and proceed...
erro:
erro:
[exec] Result: 1
[exec] Result: 1
mar 13, 2023 5:07:41 PM org.postgresql.Driver connect
GRAVE: Connection error:
org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:194)
at org.postgresql.Driver.makeConnection(Driver.java:431)
at org.postgresql.Driver.connect(Driver.java:247)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform(Task.java:350)
at org.apache.tools.ant.Target.execute(Target.java:449)
at org.apache.tools.ant.Target.performTasks(Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401)
at org.apache.tools.ant.Project.executeTarget(Project.java:1374)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1264)
at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710)
at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218)
at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216)
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.postgresql.core.PGStream.<init>(PGStream.java:62)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144)
... 25 more
mar 13, 2023 5:07:44 PM org.postgresql.Driver connect
... 25 more
mar 13, 2023 5:07:47 PM org.postgresql.Driver connect
... 25 more
mar 13, 2023 5:07:50 PM org.postgresql.Driver connect
... 25 more
mar 13, 2023 5:07:53 PM org.postgresql.Driver connect
... 25 more
BUILD FAILED
C:\PegaPersonalEdition8.7\pegaGuiInstallerTemp\build.xml:164: Unable to connect to database within 15 seconds.
Total time: 1 minute 14 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81)
... 2 more
--- Nested Exception ---
