Accenture
Last activity: 2 Apr 2023 8:11 EDT
Pega 8.7 personal edition installation error-unable to connect to db
Below my log file details....
Targets:Initialization,Database Server Installation,Data Load,Configuration,PRPC Launching
Buildfile: C:\Users\User\Downloads\.\pegaGuiInstallerTemp\build.xml
Initialization:
[echo] Beginning installation of Pega Platform 8.7.0 Personal Edition -- this process should take about 5-10 minutes ...
[unzip] Expanding: C:\Users\User\Downloads\pegaGuiInstallerTemp\PersonalEdition.zip into C:\PRPCPersonalEdition
[echo] Configuring Tomcat (Setting Java Home and Catalina Home)...
[replace] Replaced 0 occurrences in 0 files.
[replace] Replaced 1 occurrences in 1 files.
[replace] Replaced 2 occurrences in 1 files.
Initialization:
Database Server Installation:
[exec] Result: -1073741515
[echo]
[echo] Waiting for Postgres to start...
Feb 11, 2022 7:02:14 PM org.postgresql.Driver connect
SEVERE: Connection error:
org.postgresql.util.PSQLException: Connection to localhost:5432 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265)
at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49)
at org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:194)
at org.postgresql.Driver.makeConnection(Driver.java:431)
at org.postgresql.Driver.connect(Driver.java:247)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:208)
at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform(Task.java:350)
at org.apache.tools.ant.Target.execute(Target.java:449)
at org.apache.tools.ant.Target.performTasks(Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401)
at org.apache.tools.ant.Project.executeTarget(Project.java:1374)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1264)
at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710)
at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218)
at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216)
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method)
at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.postgresql.core.PGStream.<init>(PGStream.java:62)
at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144)
... 25 more
Unable to connect to database -- will retry in 1 second...
Feb 11, 2022 7:02:17 PM org.postgresql.Driver connect
... 25 more
Feb 11, 2022 7:02:20 PM org.postgresql.Driver connect
... 25 more
Feb 11, 2022 7:02:23 PM org.postgresql.Driver connect
... 25 more
Feb 11, 2022 7:02:26 PM org.postgresql.Driver connect
... 25 more
BUILD FAILED
C:\Users\User\Downloads\pegaGuiInstallerTemp\build.xml:164: Unable to connect to database within 15 seconds.
Total time: 2 minutes 3 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81)
... 2 more
--- Nested Exception ---
