Pega 8.7 installation error-unable to connect to db
I have Pega 8.7 personal edition. Error while installing
log files are below...
[exec] Result: 1 [exec] Result: 1 Mar 15, 2022 5:05:46 PM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5436 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265) at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49) at org.postgresql.jdbc.PgConnection.(PgConnection.java:194) at org.postgresql.Driver.makeConnection(Driver.java:431) at org.postgresql.Driver.connect(Driver.java:247) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99) at org.apache.tools.ant.Task.perform(Task.java:350) at org.apache.tools.ant.Target.execute(Target.java:449) at org.apache.tools.ant.Target.performTasks(Target.java:470) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401) at org.apache.tools.ant.Project.executeTarget(Project.java:1374) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1264) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at org.postgresql.core.PGStream.(PGStream.java:62) at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144) ... 25 more Mar 15, 2022 5:05:49 PM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5436 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265) at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49) at org.postgresql.jdbc.PgConnection.(PgConnection.java:194) at org.postgresql.Driver.makeConnection(Driver.java:431) at org.postgresql.Driver.connect(Driver.java:247) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99) at org.apache.tools.ant.Task.perform(Task.java:350) at org.apache.tools.ant.Target.execute(Target.java:449) at org.apache.tools.ant.Target.performTasks(Target.java:470) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401) at org.apache.tools.ant.Project.executeTarget(Project.java:1374) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1264) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at org.postgresql.core.PGStream.(PGStream.java:62) at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144) ... 25 more Mar 15, 2022 5:05:52 PM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5436 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265) at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49) at org.postgresql.jdbc.PgConnection.(PgConnection.java:194) at org.postgresql.Driver.makeConnection(Driver.java:431) at org.postgresql.Driver.connect(Driver.java:247) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99) at org.apache.tools.ant.Task.perform(Task.java:350) at org.apache.tools.ant.Target.execute(Target.java:449) at org.apache.tools.ant.Target.performTasks(Target.java:470) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401) at org.apache.tools.ant.Project.executeTarget(Project.java:1374) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1264) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at org.postgresql.core.PGStream.(PGStream.java:62) at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144) ... 25 more Mar 15, 2022 5:05:55 PM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5436 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265) at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49) at org.postgresql.jdbc.PgConnection.(PgConnection.java:194) at org.postgresql.Driver.makeConnection(Driver.java:431) at org.postgresql.Driver.connect(Driver.java:247) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99) at org.apache.tools.ant.Task.perform(Task.java:350) at org.apache.tools.ant.Target.execute(Target.java:449) at org.apache.tools.ant.Target.performTasks(Target.java:470) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401) at org.apache.tools.ant.Project.executeTarget(Project.java:1374) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1264) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at org.postgresql.core.PGStream.(PGStream.java:62) at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144) ... 25 more Mar 15, 2022 5:05:58 PM org.postgresql.Driver connect SEVERE: Connection error: org.postgresql.util.PSQLException: Connection to localhost:5436 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections. at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:265) at org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:49) at org.postgresql.jdbc.PgConnection.(PgConnection.java:194) at org.postgresql.Driver.makeConnection(Driver.java:431) at org.postgresql.Driver.connect(Driver.java:247) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:208) at com.pega.pegarules.util.anttasks.IsDBAvailable.execute(IsDBAvailable.java:112) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292) at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99) at org.apache.tools.ant.Task.perform(Task.java:350) at org.apache.tools.ant.Target.execute(Target.java:449) at org.apache.tools.ant.Target.performTasks(Target.java:470) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1401) at org.apache.tools.ant.Project.executeTarget(Project.java:1374) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Project.java:1264) at org.tp23.antinstaller.antmod.Main.runBuild(Main.java:710) at org.tp23.antinstaller.antmod.Main.startAnt(Main.java:218) at org.tp23.antinstaller.antmod.Launcher.run(Launcher.java:216) at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: java.net.ConnectException: Connection refused: connect at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at org.postgresql.core.PGStream.(PGStream.java:62) at org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:144) ... 25 more BUILD FAILED C:\Users\gasrinu\Downloads\117149_PE_8.7\pegaGuiInstallerTemp\build.xml:164: Unable to connect to database within 15 seconds. Total time: 2 minutes 9 seconds org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) ... 2 more --- Nested Exception --- org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
