COGNIZANT
Problem while installing PEGA 7.3 Personal Edition
When I am trying to install the PEGA7.3 personal Edition. There was an prompt with message that "Installation unsuccessful" Please help me to solve this issue
I am attaching the log file that was formed while the installation is going on
please help me to complete the successful installation.
EPAM Systems, Inc.
ES
I have reviewed the shared logs, unfortunately, it doesn't contain any information regarding the failure or error while installation. Kindly share the error stack.
COGNIZANT
Hello AsifHasan,
Please find the files attached for your reference.
JPMorgan Chase & Company
Please attach log files from the below folder, as attached file doesn't have any error.
\115488_Pega7.3\scripts\logs\
COGNIZANT
Hello Sudhakar,
Please find the attached log file.
I can see file permission issue causing this, i hope you are installing installing pega in linux system. Please grant permissions to the following file and don't open any files inside pegaGuiInstallerTempX directory.
Error is: java.io.FileNotFoundException: K:\pega setup file\115490_PE7.3\pegaGuiInstallerTemp0\CreatePegaShortCut.vbs (Access is denied)
COGNIZANT
I am doing installation in the windows 10 machine and tried to install again by removing the old installation but it was not resolved and I am not opening any files inside the pegaGuiInstallerTempX directory
Hi Srinivas,
Did you go through this discussion for the above error you have been specified.
Regards
Mahesh
Virtusa Corporation
Hi Mahesh,
In that post, it is mentioned to give the JAVA HOME path to jdk. Is it the jdk in the Pega personal edition installation folder which we need to give?
