Problem in enable MQ Client support in Pega 7
Hi Team,
I'm trying to configure Pega 7 to support MQ Client feature. The only purpose is just put some message in the queue provided by the external system.
I installed the MQ client software, created the shared library and associated it with the application server's class loader of WAS.
Then I created the MQ Server instance in Pega, input host name, port number and channel, but when everytime I test the connectivity, I get "FirstUseAssemblerException". From the SystemOut log It seems some library couldn't be resolved.
Could you please advise me what I can do to fix this problem?
And is there any compatibility issue for the environment below?
Pega version: 7.1.8
MQ Client version: Proprietary information hidden
WAS version: Proprietary information hidden
Thanks a million in advance!
Best Regards,
Yang
***Updated by moderator: Maryrita moved from Pega Academy to Product Support***
***Moderator Edit: Vidyaranjan| Updated Categories***
