Arbetsformedlingen
SE
Last activity: 2 Jul 2019 23:23 EDT
Pega Web Mashup Session Management Configuration In Pega 7.3.1
I have a requirement in Pega Case Management V7.3.1. I am using Pega Web Mashup for Case Creation and other related activities. In Our Case XXX Application acts as a Parent Application and Our Application ( Pega Application ) is embeeded and acting like a Child Application. The Common Login is happening successfully but we are not able to logout both the application simultaneously.
How can I configure the logout my requestor session in sync with XXX application ( Parent Application). As of now , if i am trying to login with a user name AAA.BBB which is AD authenticated, the login is successful in both the XXX and Pega Application are able to login with The corresponding Operator ID but if I am logging off XXX Application, our Pega Application Sessions remains and it is not logging off.
For the second time, if i am logging in XXX application with Operator CCC:DDD , i am able to login with the operators but when i am creating a case, it is creating the case with the older operator ID AAA.BBB. Since the previous session was not logged off, therefore it is taking the older session operator name in Pega.
How can handle Single/Multiple Session logout using Pega web Mashup if our Pega Application is a Child application of a different Parent appliaction?
Please help me if anyone has gone with this kind of scenario.
Hi Gaurav,
Are you using SSO saml authentication? Are you getting any exception or error on this?
