  ncs
SG
Last activity: 13 Dec 2018 11:00 EST
Pega 7.3.1 - Deployment manager - Pipeline issue
When we try to deploy app from DEV to SIT using pipleline, seeing the below issue logs. Please advice on how to fix it.
[ PegaRULES-Batch-5] [ STANDARD] [ ] [ Deployme:01.01.01] (L.Embed_Repository_Type.Action) INFO Admin.Deployme - File URL is : file://repo_cicdrepo:/application/Deployme_01.01.01/Deployme_010101_1/Deployme_010101_1.zip
[ PegaRULES-Batch-5] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - ####################################FETCH############################
[ PegaRULES-Batch-5] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - Target File Path # file://web:/StaticContent/global/ServiceExport/Deployme_010101_1.zip
[ PegaRULES-Batch-5] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - Source File Path # file://repo_cicdrepo:/application/Deployme_01.01.01/Deployme_010101_1/Deployme_010101_1.zip
[ PegaRULES-Batch-5] [ STANDARD] [ ] [ Deployme:01.01.01] (apper.Pega_Int_Pipeline.Action) INFO Admin.Deployme - Task execution completed for task : deploy
Posting status to release manager system. Status object:
"pxObjClass":"Pega-Int-Pipeline"
,"pyApplicationName":"Deployme"
,"pyApplicationVersion":"01.01.01"
,"pyBuildArtifactName":"Deployme_010101_1.zip"
,"pyCallBackURL":"http:// Proprietary information hidden:7004/prweb/PRRestService/cicd/v1/task/deploy/status?FlowName=pzDeployRAP&FlowActionName=pzPauseTask"
,"pyID":"PEGA-PIPELINE-CD DE-33"
,"pyRepositoryName":"cicdrepo"
,"pyStatusMessage":"Authentication Failed"
,"pyStatusValue":"FAILED"
,"pyDependencies":[ ]
  ncs
SG
I have orchestration and Development Pega servers in same machine, SIT environment in other machine.
We are using file based repository for CI/CD pipeline.
When i trigger the build manually, it completes in DEV machine and moves to next environment then failing with above mentioned error.
My question is the file based repository supported for DEV OPS CI/CD implemetation.
File based repository should work in Deployment Manager v2.1.1 for platform version 7.3.1. Based on the log snippet you posted, it looks like there is an authentication failure of some sort. Double check the following, Auth profile for connecting to the SIT (QA) environment. Repository configuration should also be double checked in the SIT environment, make sure to test the connectivity to ensure that the repository connectivity passes there as well.
  ncs
SG
Authentication profile was configured properly in Deployment manager. Deployment manager can communicate to SIT server using the authentication profile. SIT environment can connect to its repository, test connection was successful. But when it tries to fetch the zip (RAP) from Deployment manager its failing. I am not sure how to fix it. Please help
A few additional things you can try to pinpoint the issue
a) This is rather obvious, but ensure that you filesystem location has the appropriate read-write permissions and is accessible. Assuming this is true, then try b) and c)
b) Ensure that SIT to filesystem repo connections are valid, beyond just these Test Connectivity - Try to import the archive directly from the repository in the SIT environment? This would require you to login to the SIT environment, use the import wizard, select repository as the source and then you File system based repository.
c) Ensure that dev environment can publish to the filesystem - Check that you are able to successfully publish or export to that repository. Confirm that the dev environment is actually writing the archive to the filesystem either through the Deployment Manager or directly by using the export wizard which will give you an option to export to the repository
  ncs
SG
Hi Linoy,
Thanks for your reply.
Above mentioned all the suggestions are verified. Everything looks good in my system. I have attached screenshots for the same.
a. File permission are good. Please refer the screenshot.
b. I can import the archive directly from the repository in the SIT env. by login to UI.
c. I have tried to export the application to repository in DEV env, it worked fine. I can see the file in repo directory.
Please let me know if require any logs.
Mahendran M
  ncs
SG
Hi Linoy.
We notice that target file path and source file path are different in the logs. But in my repository configuration for both DEV and SIT mentioned the same path.Also target server (SIT- on a separate server) doesn't have this file path.
Is there any configuration that we need to check for this one.
Hi
Could you please check that repositories on orchestrator and candidates are pointing to correct repositories. Looks like there is some mismatch between candidates and orchestrator.
  Anthony Fournier
Exactly as suggested by gurrup1, there seems to be some mismatch in the repository configuration in the orchestrator instance (Deployment Manager). Make sure this configuration is exactly the same across all the environments including the orchestrator. It is especially important that the repository names (and type of repository) are the same across all instances. See bullet point 2 in the Step 2c of creating repositories .
  ncs
SG
Hi Linoy,
I have recreated orchestrator instance and triggered manual build. This time its failing with below error.
Error - java.io.FileNotFoundException - the given file path is not valid.
File path exist in the orchestration instance (linux system) and its with full permission (777).
For the file based respository, do we need to configure shared folder in orchestrator server and make it available to SIT environment?
Please check and suggest.
file://repo_CICDRepo:/application/DMSample_01.01.01/DMSample_010101_2/DMSample_010101_2.zip
2018-12-12 08:59:54,638 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (apper.Pega_Int_Pipeline.Action) INFO Admin.Deployme - Task execution started for task type: deploy
Request object: {
,"pyApplicationName":"DMSample"
,"pyBuildArtifactName":"DMSample_010101_2.zip"
Hi Linoy,
Request object: {
,"pyCallBackURL":"http://*.*.*.*:7004/prweb/PRRestService/cicd/v1/task/deploy/status?FlowName=pzDeployRAP&FlowActionName=pzPauseTask"
,"pyID":"PEGA-PIPELINE-CD DM-6"
,"pyRepositoryName":"CICDRepo"
2018-12-12 08:59:54,645 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (L.Embed_Repository_Type.Action) INFO Admin.Deployme - File URL is : file://repo_CICDRepo:/application/DMSample_01.01.01/DMSample_010101_2/DMSample_010101_2.zip
2018-12-12 08:59:54,645 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - ####################################FETCH############################
2018-12-12 08:59:54,645 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - Target File Path # file://web:/StaticContent/global/ServiceExport/DMSample_010101_2.zip
2018-12-12 08:59:54,645 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (h.Embed_Repository_Type.Action) INFO Admin.Deployme - Source File Path # file://repo_CICDRepo:/application/DMSample_01.01.01/DMSample_010101_2/DMSample_010101_2.zip
2018-12-12 08:59:54,650 [ PegaRULES-Batch-1] [ STANDARD] [ ] [ Deployme:01.01.01] (.repository.ArtifactRepository) ERROR Admin.Deployme - error in fetching file
java.io.FileNotFoundException: The given path file://repo_CICDRepo:/application/DMSample_01.01.01/DMSample_010101_2/DMSample_010101_2.zip was not valid.
at com.pega.pegarules.data.external.access.artifact.repository.ArtifactRepository.fileCopy(ArtifactRepository.java:357) ~[prenginext.jar:?]
at com.pega.pegarules.data.external.access.artifact.repository.ArtifactRepository.fetchArtifact(ArtifactRepository.java:98) ~[prenginext.jar:?]
at com.pega.pegarules.deploy.internal.PRRuleMgmtUtilsImpl.fetchArtifact(PRRuleMgmtUtilsImpl.java:1756) ~[prprivate.jar:?]
at com.pegarules.generated.activity.ra_action_pxfetch_cc12e0ea21bd32a66925609bb7be52e2.step3_circum0(ra_action_pxfetch_cc12e0ea21bd32a66925609bb7be52e2.java:301) ~[?:?]
at com.pegarules.generated.activity.ra_action_pxfetch_cc12e0ea21bd32a66925609bb7be52e2.perform(ra_action_pxfetch_cc12e0ea21bd32a66925609bb7be52e2.java:90) ~[?:?]
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3597) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10845) ~[prprivate.jar:?]
There seems to be some mismatch between the repository configuration on the deployment manager and the one on the target systems in the pipeline. Double check this again, but it is also likely that someone from DM support should get on a call with you and walk through everything to further diagnose this issue. Please contact [email protected] and we can arrange a time to meet.
