Virtusa
Virtusa
LK
Virtusa
Posted: May 20, 2018
Last activity: May 21, 2018
Last activity: 21 May 2018 4:14 EDT
How to Configure Multiple Web server Nodes for DevOps 7.3.1 Implementation?
For DevOps Implementation We need to configure Multiple Nodes in same machine. as a example SOR and Orchestration Server can configures in same host as two different Nodes (Web servers).And It Accessing two different Databases when Running.
- Configuration changes in 'Server.xml' file tomcat config folder. (File Location : "<<Tomcat Folder >>\tomcat\conf\server.xml" ).
- Web server HTTP/1.1 Port Change the Port that Need to use and Selected port should be unique.
- Web Server Shutdown Port Configuration the Changes done in "Server.xml" file. (File Location : "<<Tomcat Folder >>\tomcat\conf\server.xml" ).
- the shutdown also be a unique port and this is the port that use to shutdown the web Service.
- AJP Port Configuration the Changes done in "Server.xml" file. (File Location : "<<Tomcat Folder >>\tomcat\conf\server.xml" ).
- what is AJP
- AJP Port should be a unique Port as other ports.
- After Saving all the configurations restart web servers.
Note : before select your ports make sure all selected ports are available and check firewall blockings for each port.All the IP Addresses and Ports are arbitrary.
