Pega Robotics Studio Debugger Stopped Message
Pega Robotics Studio 8.0 SP1 on Windows 10 build 1904, When I start debugging the current project, I receive a message dialog with the following message: "Debugger has stopped in a link that does not belong to this project. Please make sure the project being debugged matches the project open in the IDE." When I click the OK button, the message dialog closes and a second message dialog with the same message appears. When I click the OK button on the second message dialog,
The solution continues to load and displays the user form before I click the first OK button. There is no information for which links threw the exception. How do I find the offending links?
@DarrellE The easiest way to resolve this is to close all open automations and then click the Debug menu. Select the option to delete all breakpoints and then run your solution. It is likely caused by a breakpoint still present in the automation on a link that has since been deleted. If it still persists, I would open a support case as someone who can get hands-on with your solution can help track it down and resolve it.
