Pega install
Build was failed while installing Pega, below is the complete error log.
BUILD FAILED
C:\Users\2066653\Downloads\116984_PE8.6.0 (1)\pegaGuiInstallerTemp\build.xml:305: exec returned: 255
Total time: 84 minutes 22 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81)
... 2 more
--- Nested Exception ---
