TCS
Last activity: 2 Sep 2015 5:50 EDT
Pega 7 Instalation
I am getting the below error , when i am trying to deploy pega 7.1.7 in oracle database , win 7 os.
[java] --
[java] -- Name: pr_read_from_stream
[java] --
[java] -- Description:
[java] --
[java] language java
[java] name 'com.pega.pegarules.data.udf.directstreamreader.DirectStreamReader.get(java.lang.String, java.lang.String, java.sql.Blob) return java.lang.String';
[java] java.sql.SQLSyntaxErrorException: ORA-00955: name is already used by an existing object
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:447)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:396)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:951)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:513)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:227)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:531)
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:195)
[java] at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:1036)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1336)
[java] at oracle.jdbc.driver.OracleStatement.executeInternal(OracleStatement.java:1916)
[java] at oracle.jdbc.driver.OracleStatement.execute(OracleStatement.java:1878)
[java] at oracle.jdbc.driver.OracleStatementWrapper.execute(OracleStatementWrapper.java:318)
[java] at com.pega.pegarules.install.SQLLoader.main(SQLLoader.java:298)
[java] May 28, 2015 12:17:34 PM com.pega.pegarules.install.SQLLoader writeMessage
[java] INFO:
[java] ********************************************************************************
[java]
[java] Encountered a SQL Exception, clean schema before running again.
[java]
