syntel
Last activity: 3 Sep 2015 1:10 EDT
PEGA Installation
Hi , When i'm trying Install Pega 7.1.7, Windows 7. I'm getting an error "Unable to Connect to Database" , when i checked the error log i'm getting the below , can some help on this issue please
BUILD FAILED
C:\Users\janu\pegaGuiInstallerTemp\build.xml:157: Unable to connect to database within 15 seconds.
Total time: 29 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:89)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:79)
... 2 more
--- Nested Exception ---
