Pega Constellation with Cosmos React only in AWS possible?
the guys in My Support Portal couldn't help me about my question.
I am currently working on installing the Constellation UI for Pega.
I found out that an additional pod for Constellation is needed.
Of course, the installation should be done via Helm, so I also looked at the corresponding chart under the backingservices.
Here I noticed that the existing installation instructions refer exclusively to AWS.
Is it possible to install the Constellation setup on other clouds such as the OTC (Open Telekom Cloud) or are AWS-specific functions used here?
Is there a more detailed documentation, I only found the following documentation related to Helm and Kubernetes:
https://docs-previous.pega.com/user-experience/85/installing-constellation-using-helm-kubernetes
Tank you
Regards Julian
