Hitachi
JP
Last activity: 18 May 2021 0:04 EDT
Pega 8.5 REST API error (Broken process)
[Procedure]
1. I generated a case microservice code by following the procedure described in the URL below. And I sent it to Pega.
https://community.pega.com/knowledgebase/articles/case-management/85/creating-case-using-api
Request URL (HTTP method POST)
http://XX.XX.XX.XX:XX[IP:port]/prweb/api/v1/cases
Request body
"caseTypeID": "XXXX-YYYY-Work-ZZZZ",
"processID": "",
"parentCaseID": "",
"content": {}
2. As a result, I received the 201 response (success) by Pega. And I confirmed the case had been created on Pega collectly.
3. But I found the issue that the Pega judged that case as a "Broken Process".
Could you tell me how to create the case through REST Service in Pega 8.5?
