Independent
Last activity: 22 Jun 2023 7:14 EDT
Pega 8 Archival Associated Classes - Association Rule Set Up
We are trying out Pega 8.7 Archival in a Client Cloud Set up. One aspect we are testing is the "Associated Classes" capability.
We have set up a PageList that references a data type based on the pzInsKey of the case.
I was able to set up an association rule from the Case Type to the Data Type, and the Association Rule appears to work in a Report Definition. However, I got an error when I put that Association Rule into the Case Type Archival tab, I got an error - Association cannot be reached from this case type, if relationship is transitive, add the other required associations.
Can someone share your experience on the use the Associated Classes? And also on how your association rule is set up?
