Wells Fargo
Last activity: 14 Nov 2018 7:48 EST
Parent case should be proceed after one particular child case is Resolved-XXXX
I have a requirement where Parent case contains different class child cases and I need to check only particular child case to be resolved to close parent case. My parent case is waiting at a waiting assignment, once one particular child case is Resolved-XXXX parent case should submit the assignment and proceed further in flow.
Any thoughts?
You could use a Wait shape and select the case dependency option. It will let you select the type of case to wait for and the status.
Wells Fargo
I could use that but my problem is that status of my child case could be Resolved-XXXX
Where XXXX= Timeout or Exception or Completed etc.
In the wait shape, status check is equals and not contains. How to achieve this?
Please suggest.
Wait shape provides the same capability where you can wait for a particular child case(class) to reach some status.
Let us know if this helps.
Wells Fargo
I could use WAIT shape but my problem is that status of my child case could be Resolved-XXXX
Please suggest.
Which Pega version are you using? We have provided enhancement to support this requirement from 7.4 release.
Wells Fargo
We are running on Pega 7.2.2 and therefore this feature is not available. Any thoughts how to achieve it in current version?
Raghavender Reddy Lankapothu SAROJA YADALA
Updated: 14 Nov 2018 3:59 EST
Below is the screenshot of one solution that I suggested long back. Let us know if this works or you need more help.
Raju Botu
Incessant Technologies
Currently pega supports only one status to check in case dependency in your scenario.
There is a another way of achieving your requirement.
1. Move your parent case assignment to a workbasket where no one has access to it.
2.Now create a declare trigger on parent case and resume the flow when one of your child cases reaches resolved-xxxx status.
Hope this sholud work.
