Openspan not opening executables on Windows 10
My team's bots are failing to launch executables through Openspan on Windows 10.
We have elevated all our security permissions to admin level for the executables and Openspan.
We our using:
Windows 10.0.15063
Our Openspan version 8.0.1018.00
The error message we are seeing is Unable to start process [Executable Name].exe. Start process injected C:\[Executable Path].exe failed
You are on a very old version, is it possible to test with the latest version? Windows 10 releases can conflict with the injection process. If you have upgraded to a different Windows 10 build, you should upgrade as well to ensure compatibility.
> https://docs-previous.pega.com/pega-rpa/build-notes-pega-robotic-automation-80
Search for SR-52023. It states that the Windows 10 Fall Creators Update causes issue. If you are on Windows 10 Build 1809, then we recommend rolling back to an earlier build as noted here > https://collaborate.pega.com/question/should-i-install-update-1809-windows-10
