Accenture
OpenSpan - Not able to add windows application
I have added a windows application to OpenSpan project. however, on opening the windows application, it is throwing the below error (also attached screenshot).
"Error creating <name> component of openspan.adapters.windows.windowsadapters"
Can someone please help?
Windows 10 is not currently supported. I believe it will be soon (wait for an announcement). It will only be supported by Pega Robotics 8.0 and up though. If you are running 7.1.75 you will need to switch to Windows 7, as that is the highest version of Windows supported by that version.
JagaDeesh,
One of the designer config files may have been corrupt.
Please attempt the following:
- Close all Pega Studios that are currently running
- Go to your user's appdata openspan directory, %appdata%\openspan
- Delete all of the .xmls that are found in the directory (RuntimeConfig.xml, PluginManifest.xml,StudioConfig.xml,TargetFactoryConfigurationCache.xml, etc....)
- Start the Pega Studio again.
- Attempt to open the test windows adapter to see if it works.
Please let us know if this does not resolve your issue.
Accenture
Thanks for your reply.
Howeveer, it did not work. Please see below the exception in the log file.
Also, i googled and found a thread which says it works only on win7 or win8, but not on win10. I have win10 OS. Could it be a problem?
1) Exception Information
Exception Type: System.Reflection.TargetInvocationException
Message: "Exception has been thrown by the target of an invocation."
Data: IDictionary (System.Collections.ListDictionaryInternal) with 0 items
TargetSite: System.Object InvokeMethod(System.Object, System.Object[], System.Signature, Boolean)
HelpLink: NULL
Source: "mscorlib"
HResult: -2146232828
HelpLink: NULL
Source: "mscorlib"
StackTrace Information
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at OpenSpan.Design.Serialization.SerializerManager.Deserialize(XPathDocument[] documents, IComponentCreator componentCreator, IServiceProvider serviceProvider, String externalName, ArrayList errors, String logCategory, String logMessage)
at OpenSpan.Design.DesignComponentLoader.ReadFile(String path, ArrayList errors)
2) Exception Information
Exception Type: System.IO.FileLoadException
Message: "A dynamic link library (DLL) initialization routine failed. (Exception from HRESULT: 0x8007045A)"
FileName: NULL
FusionLog: NULL
TargetSite: Void ThrowExceptionForHRInternal(Int32, IntPtr)
HelpLink: NULL
Source: "mscorlib"
HResult: -2147023782
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(Int32 errorCode)
at OpenSpan.Interop.UnmanagedLibrary..ctor(String fileName)
at OpenSpan.Interop.ScoutInterop.LoadNativeLibrary(String searchPath, String moduleName, UnmanagedLibrary& unmanagedLibrary)
at OpenSpan.Interop.ScoutInterop.Initialize(ScoutInitialization flags, String searchPath)
at OpenSpan.Adapters.Windows.WindowsAdapterBase.set_Site(ISite value)
at System.ComponentModel.Container.Add(IComponent component, String name)
at System.ComponentModel.Design.DesignerHost.PerformAdd(IComponent component, String name)
at System.ComponentModel.Design.DesignerHost.System.ComponentModel.Design.IDesignerHost.CreateComponent(Type componentType, String name)
at OpenSpan.Design.ComponentCreator.CreateComponent(Type componentClass, String name)
at OpenSpan.Serialization.Serializer.ReadCreateInstance(XPathNavigator navigator, Boolean isContent, IComponentCreator componentCreator, String externalName, Boolean missingTypeError, SerializerReadData data, Type& type, Object& instance)
at OpenSpan.Serialization.Serializer.ReadObject(XPathNavigator navigator, Boolean advanceCursor, Boolean isContent, IComponentCreator componentCreator, ComponentInfo componentInfo, String externalName, Boolean missingTypeError, SerializerReadData data)
at OpenSpan.Serialization.Serializer.Deserialize(XPathDocument document, IComponentCreator componentCreator, String externalName, SerializerReadData data, String logCategory, String logMessage)
at OpenSpan.Serialization.Serializer.Deserialize(XPathDocument[] documents, IComponentCreator componentCreator, IServiceProvider serviceProvider, String externalName, ArrayList errors, String logCategory, String logMessage)
ERROR | 2016-11-11 10:41:42,651 | 1 | 1 | 4072 | STA | Exception | | | Error creating 'CRM' component of OpenSpan.Adapters.Windows.WindowsAdapter type, Verbose Message: General Information
Diagnostic Info:
Diagnostic.MachineName: HDC4-DX-8H8P6C2
Diagnostic.FullName: OpenSpan, Version= Proprietary information hidden, Culture=neutral, PublicKeyToken=f5db91edc02d8c5e
Diagnostic.AppDomainName: DefaultDomain
Diagnostic.WindowsIdentity: DIR\jagadeesh.kadiyala
Diagnostic.ApplicationName: OpenSpan.Studio.Shell
Exception Type: System.ComponentModel.Design.Serialization.CodeDomSerializerException
LinePragma: System.CodeDom.CodeLinePragma
Message: "Error creating 'CRM' component of OpenSpan.Adapters.Windows.WindowsAdapter type"
TargetSite: System.ComponentModel.Design.DesignSurface InternalDesignerCreate(System.String, OpenSpan.Design.CreateDesignerCallback)
HelpLink: NULL
Source: "OpenSpan.Studio"
HResult: -2146233087
at OpenSpan.Studio.Shell.DesignerShell.InternalDesignerCreate(String storageFile, CreateDesignerCallback callback)
at OpenSpan.Studio.Shell.DesignerShell.CreateDesigner(String storageFile, CreateDesignerCallback callback)
at OpenSpan.Studio.Shell.DesignerFactory.Microsoft.VisualStudio.Shell.Interop.IVsEditorFactory.CreateEditorInstance(UInt32 createEditorFlags, String document, String physicalView, IVsHierarchy hierarchy, UInt32 itemid, IntPtr docDataExisting, IntPtr& docView, IntPtr& docData, String& editorCaption, Guid& commandUIGuid, Int32& createDocumentWindowFlags)
What version of Windows are you using and what version of Pega Robotics are you using?
Accenture
I am running on windows 10 enterprise, version 1511, OS build 10586.218.
Version of Openspan i have downloaded from PDN is: Proprietary information hidden
Datacom group
NZ
Hi Jeff,
I am still getting this error.
I am using VS 2015 Professional and the Robotics plug-in 8.0.1064.0 on Windows 10 Version 1703 OS build 15063.674.I am using the Agile desktop and when I perform a search, sometimes the error appears but most of the time its not.What would be the reason?
AKHIL SAI padidarapu
EY
Hi Jeff,
Do we have any prerequiste document for system compatibilty?
eg, Pega Robotics 8.0 supports windows 10
Accenture
Openspan 7.1.75 or 7.1.63 or below version will support windows 7.
NTT Data
This comment/reply has been branched into a new post
CenTene
Hi All, I am facing the same issue with Windows 10 , Pega ROBOTICS 8.0
Diagnostic Info:
Diagnostic.MachineName: GH-VDISTLDAT08
Diagnostic.AppDomainName: OpenSpan.Runtime.exe
Diagnostic.WindowsIdentity: MASTERCARD\e076384
Diagnostic.ApplicationName: OpenSpan.Runtime
HelpLink: NULL
Source: "mscorlib"
Diagnostic Info:
HelpLink: NULL
Source: "mscorlib"
at OpenSpan.Utils.SafeInvokeHelper.Invoke(Object baseInstance, Object instance, MethodInfo methodInfo, Object[] args)
at OpenSpan.Automation.EventLink.Execute(Object sender, ExecutionEventArgs e)
Please suggest how to resolve this issue.
Accenture Services PVT Ltd
Hi
I am trying to add a global container to the project when I am getting the attached error.
Infosys Limited
Hi Team,
I am getting the attached "Windows can't open this type of file (.os) while trying to interrogate any field using Pega Openspan 8.o for windows 10. Please let me know how to resolve it.
Abhijit
CollabPartnerz
Below link might help you
https://collaborate.pega.com/question/openspan-error-adding-new-windows-application
