Open two assignments from Email url in same opened session in pega
Is there a way to open 2 work objects from Email URL in same tab in Pega without opening a new window tab?
Now if i have an opened portal in Pega, when i click on a URL link to open a work objects, it opens a new tab in the browser and opens a new portal with the object.
What is needed is to open the new work objects in the current portal of Pega already opened.
Because the problem is when 2 Tabs of Pega are opened, each time you navigate between the 2 tabs they will be refreshed.
If there is no way to open the new work object in the same opened portal, is there an option to disable the refresh when navigating between the 2 tabs of pega?
