Intact Financial Corporation
Last activity: 21 Jan 2021 16:54 EST
New Rule Referencing Tool for Pega 7.3 not showing the circumstance dates in
As suggested in a previous post we made about the Adobe Flash Player deprecation, we've installed the Rule Referencing Tool update for Pega 7.3. It's working fine from a technical standpoint, but we've noticed that even though the option "Show versions and circumstances" is checked in the settings, the circumstance dates are not showing up (but strangely the versions are).
With the original tool, we used to see a "clock" icon where you could hover your mouse to see the circumstance date:
It's not there in the updated tool. In fact only the icon about the "Availability" is showing up (the "circle" icon in both screenshots):
Is there an issue with the new tool? Maybe it's just an oversight? Can this be fixed?
We've also noticed that the "Show Overrides" option is no longer there in the settings. Is there a reason for this?
Finally, is there a way to make the tab wider? We shown it to a few developers and they all said that it was too narrow on screen.
Thanks in advance!
@COEPEGA1 Thank you for all your help with this! Version 01.01.02 has been uploaded to Pega Marketplace. It adds circumstancing information to the Pega Rule Referencing Tool.
As a reminder, after importing you will need to change your built-on application from 01.01.01 to 01.01. Going forward, this will not be necessary for every version.
