Tata Consultancy Services
Last activity: 17 Feb 2021 10:12 EST
Multiple Child case creation from page list data
How can we create multiple child cases using page list data?
Please do needful
Ramesh Nalimela
Sky Solutions LLC
For this, we have 2 methods.
Method 1:
1. Use "Create Case" smart shape.
2. Configure like this,
3. See my Output:
In run time, adding 4 things into list
4 child cases created,
Method 1:
3. See my Output:
Method 2:
Write an activity
You can try this by using Splitforeach smart shape, if you want configuration info revert back to me .
Likhitha Polepalli
You can use the Create Case smart shape in your flow. There is an option in the properties to create multiple child cases using a list.
One more approach is loop on your pagelist inside that you can use pxAddchildWork activity.
CollabPartnerz
Could you please iterate on pagelist and do the pxAddChildWork on it to create the child case.
Ravikumar Mashapogu
Sky Solutions LLC
Method 1:
3. See my Output:
Method 1:
3. See my Output:
Method 2:
Write an activity
Ernst & Young
With this approach we can able to create same multiple case type but how to achieve different case type?
LTIMindtree
It works for me issue. My requirement to pass few property values when child case created. when I try with 'CopyPageData' option true, it is not allowing to create child object. any suggestion to pass PageData into child case.
Capgemini India PVT Ltd
I have followed Method 1, but there are no assignments are created.
Can you send the detailed screenshots of this work. Because im new to pega
Can you send me this work. as im new to pega
still you need clarification ?
Thank you very much for your reply . I understand both options.
Regards
Ramesh Nalimela
Creditone
Thanks Ramesh
