Last activity: 3 Apr 2017 9:51 EDT
Looking for minimum requirements for SMA on a separate node
Is there documentation specific to SMA requirements?
fyi: Version is 7.2.1
Hi Melisa,
It would more clear if you explain about your requirement in detail, as we are not clear about which requirement document you are talking about.
Mahesh
Thanks. I have a customer setting up SMA on a separate node and would like to know the systems requirements. There is nothing specific to SMA in the current Installation guides.
Hi Mahesh, Could you please advise?
Hello Thorm,
I believe your looking for some setup as shown in the screen shot. Please confirm on that.
However there are no specific instructions as long as you go an deploy the SMA war correctly.
Let me know if you still have any questions?
Shanthini Charles
Thanks for your response, my customer was looking for more specific sizing details relative to: memory, disk space, and heap space. I assume SMA doesn't need much but wanted to see if there are any concrete recommendations.
Hello Thorm,
Yes since System Management application (SMA) is just a Web application that developers can use to monitor and control caches, agents, listeners, and other processing specific requirements are not there.
I hope this answers your query.
Shanthini Charles
