Pega Docker Container Minimum Requirements
Are there recommended system requirements that specify CPU/MEM/Heap settings necessary to run the following Pega services in a single docker container? It is viable to run the following services in a single docker container for production?
BackgroundProcessing
Search
Stream
WebUser
That configuration is not supported. You should consider running Kubernetes (which has become the industry standard for container orchestration, which uses docker as container runtime) as documented here: https://community.pega.com/knowledgebase/articles/cloud-choice/deploying-pega-platform-using-kubernetes
