Elasticsearch connector fails to start in SRS docker container
When I deploy the PEGA SRS docker image package to the docker container, the container cannot start due to ElasticSearch connection and gives the following error. Elastic Search instance has enabled paramater as "xpack.security.enabled: true". (I able to connect with elastic search user and psw into Elastic search node successfuly. There is no problem for user information.)
{"timestamp":"2025-03-06T20:41:22.712","message":"Error starting Micronaut server: Bean definition [com.pega.fnx.cmd.spec.storage.SingleStorageManager]
could not be loaded: Error instantiating bean of type [com.pega.fnx.cmd.spec.storage.SingleStorageManager]\n\nMessage: Cannot create an Elasticsearch connector for endpoint 'http://localhost:9200'\nPath Taken: new SingleStorageManager(StorageConnectorFactory factory,MeterRegistry meterRegistry)","logger":"io.micronaut.runtime.Micronaut","thread":"main","level":"ERROR","stack_trace":"io.micronaut.context.exceptions.BeanInstantiationException: Bean definition [com.pega.fnx.cmd.spec.storage.SingleStorageManager] could not be loaded: Error instantiating bean of type [com.pega.fnx.cmd.spec.storage.SingleStorageManager]\n\nMessage: Cannot create an Elasticsearch connector for endpoint 'http://localhost:9200'\nPath Taken: new SingleStorageManager
io.micronaut.context.exceptions.BeanInstantiationException: Error instantiating bean of type [com.pega.fnx.cmd.spec.storage.SingleStorageManager]\n\nMessage: Cannot create an Elasticsearch connector for endpoint 'http://localhost:9200'\nPath Taken: new SingleStorageManager
com.pega.fnx.cmd.spec.storage.StorageException: Cannot create an Elasticsearch connector for endpoint 'http://localhost:9200'\n\tat
org.elasticsearch.ElasticsearchStatusException: Elasticsearch exception [type=security_exception, reason=missing authentication credentials for REST request [/]]\n\tat
***Edited by Moderator Marije tto add existing INC ***
