HealthFirst
HealthFirst
HealthFirst
Posted: Feb 26, 2021
Last activity: Aug 7, 2023
Last activity: 7 Aug 2023 10:34 EDT
Libraries are failing while compiling after upgrade in from Pega 8.2 to Pega 8.5
Post upgrade to Pega Plat form 8.5 , libraries failing to compile. getting below errors.
Show More
Error(s) detected while generating java. Compiler reported: ----------
1. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 59)
import com.aspose.barcode.barcoderecognition.*; ^^^^^^^^^^
The import com.aspose cannot be resolved ----------
2. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 60)
import com.aspose.pdf.*; ^^^^^^^^^^
3. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 61)
import com.aspose.pdf.devices.*; ^^^^^^^^^^
4. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 69)
import com.aspose.barcode.*; ^^^^^^^^^^
5. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 70)
import com.aspose.cells.*; ^^^^^^^^^^
6. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 73)
import javapasswordsdk.*; ^^^^^^^^^^^^^^^
The import javapasswordsdk cannot be resolved ----------
7. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 74)
import javapasswordsdk.exceptions.*; ^^^^^^^^^^^^^^^
8. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 75)
import com.tivoli.tec.event_delivery.EDException; ^^^^^^^^^^^^^^
The import com.tivoli.tec cannot be resolved ----------
9. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 76)
import com.tivoli.tec.event_delivery.TECAgent; ^^^^^^^^^^^^^^
10. ERROR in /com/pegarules/generated/getAuthenticationProfile_010108_4497587371116278782.java (at line 77)
import com.tivoli.tec.event_delivery.TECEvent; ^^^^^^^^^^^^^^
10 problems (10 errors) Compile failed.
Show Less
***Edited by Moderator Marissa to change type from Product to Upgrade***
