Launch local action from grid adding an empty row
Pega 7.1.7
In a Repeat Grid layout we have last column with "Edit" link (this is link is in a embedded section). This link is configured with 'Launch - Local Action' and 'Refresh - Other section' actions.
'Local action' is launched in Modal Dialog and when launched obviously this modal has OOTB Submit and Cancel buttons.
'Refresh - Other section' is used to refresh the outer section having grid.
When edit is performed on last row, on submit of modal dialog, it is adding an empty row at the end apart from editing the intended row.
Empty row is not getting added when edit is performed on any of the rows other than last row.
Is this an issue with product? Any suggestions to fix this issue, if this is a configuration issue?
Note:
When we have tried 'List - Open local action' this issue does not occur. We do not prefer this approach as this OOTB action renders modal with Next/Previous/Ok/Cancel buttons where as desired buttons are Submit/Cancel.
Pega 7.1.7
Note:
Thought of hiding the OOTB buttons and adding Submit/Cancel buttons in section referred by flow action, but this option is also discarded as this flow action is reused in other use cases without a modal (as a connector action rather than local action).
Thanks.
