Scientific Research Corporation
Last activity: 3 Oct 2025 18:28 EDT
Java error during upgrade
Trying to perform an upgrade from .8.8.5 to version 24.2 on RHEL 9 and receiving the following error during execution of the upgrade.sh script:
INFO AbstractJvmForker - Caused by: java.security.NoSuchAlgorithmException: Cannot find any provider supporting AES/PCBC/PKCS5Padding
INFO AbstractJvmForker - at java.base/javax.crypto.Cipher.getInstance(Cipher.java:571)
INFO AbstractJvmForker - at com.pega.platform.securitycore.encryption.internal.CipherBase.getCipherInstance(CipherBase.java:178)
INFO AbstractJvmForker - ... 79 more
INFO AbstractJvmForker - Caused by: java.security.NoSuchAlgorithmException: PCBC not found
INFO AbstractJvmForker - at org.bouncycastle.jcajce.provider.BaseCipher.engineSetMode(Unknown Source)
INFO AbstractJvmForker - at java.base/javax.crypto.Cipher$Transform.setModePadding(Cipher.java:385)
INFO AbstractJvmForker - at java.base/javax.crypto.Cipher.getInstance(Cipher.java:564)
INFO AbstractJvmForker - ... 80 more
Exception in thread "main" java.lang.RuntimeException: Java process exited with 1
at com.pega.deploy.fork.AbstractJvmForker.waitForProcessExit(AbstractJvmForker.kt:98)
at com.pega.deploy.fork.AbstractJvmForker.runBlocking(AbstractJvmForker.kt:104)
at com.pega.deploy.rulebase.UpgradeRuleBaseKt.importUpgradeArchive(UpgradeRuleBase.kt:54)
at com.pega.deploy.rulebase.UpgradeRuleBaseKt.importUpgradeArchive$default(UpgradeRuleBase.kt:40)
at com.pega.deploy.rulebase.UpgradeRuleBaseKt.upgradeRuleBase$lambda$1$lambda$0(UpgradeRuleBase.kt:26)
at com.pega.deploy.SetupDatabase.withProgressTimestamp(SetupDatabase.kt:344)
at com.pega.deploy.rulebase.UpgradeRuleBaseKt.upgradeRuleBase$lambda$1(UpgradeRuleBase.kt:25)
at com.pega.deploy.SetupDatabase.runResumably(SetupDatabase.kt:355)
at com.pega.deploy.rulebase.UpgradeRuleBaseKt.upgradeRuleBase(UpgradeRuleBase.kt:24)
at com.pega.deploy.UpgradeKt.rulesUpgrade(Upgrade.kt:120)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt:46)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt)
Java Process returned a non 0 value
