Rule Migration failed with parsing error during Pega7 upgrade
We are performing an upgrade to Pega7, but it failed during the Rule Migration.
The error thrown by the script is pasted here below, do we have a workaround to proceed further.
[java] The generated sql is incomplete
[java] java.lang.Exception: Generated DDL cannot be applied automatically due to parsing errors.
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.generateCloneDDL(SchemaGenerator.java:652)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1292)
[java] ERROR: The table pr_index_circumstance_def was ignored because the following column(s) were not recognized: FromKPI: bit, CATabbedNavigation: bit, CreatedInSendMailer: bit, IsPostACA: bit
[java] Error generating ddl for mssql, dbo
[java] Generated DDL cannot be applied automatically due to parsing errors.
BUILD FAILED
F:\114716_Pega717\scripts\migrateSystem.xml:478: The following error occurred while executing this line:
F:\114716_Pega717\scripts\setupDDL.xml:272: Java returned: 1
