Citigroup Inc
Last activity: 10 Jul 2025 10:02 EDT
Pega Upgrade to 24.2.2 Stuck .
Below error messages are coming up and upgrade process is stuck /stopped.
NFO LoggingUtilsKt - Apply UDFs:
INFO SetupDatabase - ***setting resume checkpoint***
INFO SetupDatabase - ***writing resume property completed.steps.UpgradeDDL=true to file***
INFO LoggingUtilsKt -
INFO LoggingUtilsKt - Engine Load:
INFO HikariDataSource - HikariPool-1 - Starting...
INFO HikariPool - HikariPool-1 - Added connection oracle.jdbc.driver.T4CConnection@7bc6d27a
INFO HikariDataSource - HikariPool-1 - Start completed.
INFO MainKt - Successfully established connection to database
INFO MainKt - Database Type...: Oracle
INFO MainKt - Database Version: Oracle Database 19c Enterprise Edition Release Proprietary information hidden.0 - Production
Version Proprietary information hidden.0
INFO MainKt - Driver Type.....: Oracle JDBC driver
INFO MainKt - Driver Version..: Proprietary information hidden.0
INFO HikariDataSource - HikariPool-1 - Shutdown initiated...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /tmp/bc-fips-jnitk5telo60t-libs/libbc-probe.so: /tmp/bc-fips-jnitk5telo60t-libs/libbc-probe.so: failed to map segment from shared object
INFO HikariDataSource - HikariPool-1 - Shutdown completed.
at java.base/jdk.internal.loader.NativeLibraries.load(Native Method)
at java.base/jdk.internal.loader.NativeLibraries$NativeLibraryImpl.open(NativeLibraries.java:331)
at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:197)
at java.base/jdk.internal.loader.NativeLibraries.loadLibrary(NativeLibraries.java:139)
at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2418)
at java.base/java.lang.Runtime.load0(Runtime.java:852)
at java.base/java.lang.System.load(System.java:2025)
at org.bouncycastle.crypto.fips.NativeLoader$2.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:319)
at org.bouncycastle.crypto.fips.NativeLoader.loadDriver(Unknown Source)
at org.bouncycastle.crypto.fips.FipsStatus.isReady(Unknown Source)
at org.bouncycastle.crypto.CryptoServicesRegistrar.getDefaultMode(Unknown Source)
at org.bouncycastle.crypto.CryptoServicesRegistrar.<clinit>(Unknown Source)
at org.bouncycastle.jcajce.provider.ProvSecureHash$MD5.configure(Unknown Source)
at org.bouncycastle.jcajce.provider.BouncyCastleFipsProvider.<init>(Unknown Source)
at com.pega.codeloader.UtilsKt.<clinit>(Utils.kt:34)
at com.pega.codeloader.engine.EngineCodeDeleter.<init>(EngineCodeDeleter.kt:40)
at com.pega.codeloader.MainKt.doAction(Main.kt:64)
at com.pega.codeloader.MainKt.invokeCodeLoader(Main.kt:57)
at com.pega.deploy.codeloader.CodeLoaderKt.loadCode(CodeLoader.kt:108)
at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine$lambda$1$lambda$0(CodeLoader.kt:38)
at com.pega.deploy.SetupDatabase.withProgressTimestamp(SetupDatabase.kt:344)
at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine$lambda$1(CodeLoader.kt:31)
at com.pega.deploy.SetupDatabase.runResumably(SetupDatabase.kt:355)
at com.pega.deploy.codeloader.CodeLoaderKt.loadEngine(CodeLoader.kt:30)
at com.pega.deploy.UpgradeKt.rulesUpgrade(Upgrade.kt:117)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt:46)
at com.pega.deploy.UpgradeKt.main(Upgrade.kt)
Java Process returned a non 0 value
