Bank of America
Last activity: 28 Jul 2025 9:51 EDT
Pega upgrade 24.2.2 error
We are upgrading pega 23.1 to 24.2.2, seeing this error during the upgrade though upgrade status shows completed. Please let us know how to resolve it.
INFO AntScriptWrapper - [java] 2025-07-23 17:39:49,235 [gaRULES-ShutDownTask] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - Task : class com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.RuleUsageSnapshotTask completed executing.
INFO AntScriptWrapper - [java] 2025-07-23 17:39:49,440 [gaRULES-ShutDownTask] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - Task : class com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.JobSchedulerShutdownTask completed executing.
INFO AntScriptWrapper - [java] 2025-07-23 17:39:49,859 [gaRULES-ShutDownTask] [ STANDARD] [ ] [ ] ( AgentExecution) ERROR - Queue Manager encountered problem checking for orphaned queue items in System-Queue-ServiceLevel-Monitoring class
INFO AntScriptWrapper - [java] com.pega.pegarules.pub.database.DatabaseException: Database-General There was a problem getting a list 90442000 ORA-00904: "PYITEMSTATUS": invalid identifier
INFO AntScriptWrapper - [java] DatabaseException caused by prior exception: java.sql.SQLSyntaxErrorException: ORA-00904: "PYITEMSTATUS": invalid identifier
INFO AntScriptWrapper - [java] | SQL Code: 904 | SQL State: 42000
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.ExceptionInformation.createAppropriateExceptionDueToDBFailure(ExceptionInformation.java:400) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:379) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.Lister.convertSqlExceptionToDatabaseException(Lister.java:616) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.Lister.listWithResultPackager(Lister.java:418) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.Lister.list(Lister.java:193) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.DBQueryExecutor.executeRDB(DBQueryExecutor.java:126) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.DBQueryExecutor.executeRDB(DBQueryExecutor.java:73) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:3236) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:3216) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.agent.OrphanedItemsCleaner.cleanOrphanedItems(OrphanedItemsCleaner.java:50) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.agent.OrphanedItemsCleaner.lambda$cleanOrphanedItems$0(OrphanedItemsCleaner.java:41) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:183) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:179) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1707) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596) ~[?:?]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.agent.OrphanedItemsCleaner.lambda$cleanOrphanedItems$1(OrphanedItemsCleaner.java:40) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at java.base/java.util.Collections$2.tryAdvance(Collections.java:4853) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.Collections$2.forEachRemaining(Collections.java:4861) ~[?:?]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.agent.OrphanedItemsCleaner.cleanOrphanedItems(OrphanedItemsCleaner.java:37) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.Agent.cleanOrphanedItems(Agent.java:2072) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.Agent.lambda$cleanOrphanedItems$1(Agent.java:2061) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1379) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1122) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1003) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.PRSessionProviderImplForModules.doWithRequestorLocked(PRSessionProviderImplForModules.java:83) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.Agent.cleanOrphanedItems(Agent.java:2052) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.async.Agent.stop(Agent.java:2003) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.AgentsShutdownTask.exec(AgentsShutdownTask.java:44) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.IParallelShutdownTask.run(IParallelShutdownTask.java:43) ~[prprivate-session.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
INFO AntScriptWrapper - [java] at java.base/java.lang.Thread.run(Thread.java:842) [?:?]
INFO AntScriptWrapper - [java] Caused by: java.sql.SQLSyntaxErrorException: ORA-00904: "PYITEMSTATUS": invalid identifier
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:628) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:562) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1145) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:726) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:291) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:492) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:148) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:1038) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.OracleStatement.executeSQLStatement(OracleStatement.java:1507) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1287) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3735) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:3933) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:1010) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44) ~[HikariCP-java7-2.4.13.jar:?]
INFO AntScriptWrapper - [java] at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java) ~[HikariCP-java7-2.4.13.jar:?]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.store.DatabasePreparedStatementImpl.execute(DatabasePreparedStatementImpl.java:532) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] at com.pega.pegarules.data.internal.access.Lister.listWithResultPackager(Lister.java:398) ~[prprivate-data.jar:8.24.52-349]
INFO AntScriptWrapper - [java] ... 43 more
INFO AntScriptWrapper - [java] Caused by: oracle.jdbc.OracleDatabaseException: ORA-00904: "PYITEMSTATUS": invalid identifier
INFO AntScriptWrapper - [java] at oracle.jdbc.driver.T4CTTIoer11.processError(T4CTTIoer11.java:632) ~[ojdbc8.jar: Proprietary information hidden.0]
INFO AntScriptWrapper - [java] 2025-07-23 17:39:50,081 [gaRULES-ShutDownTask] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - Task : class com.pega.pegarules.session.internal.engineinterface.shutdown.shutdowntasks.AgentsShutdownTask completed executing.
INFO AntScriptWrapper - [java] 2025-07-23 17:39:50,085 [rp.bankofamerica.com] [ STANDARD] [ ] [ ] ( SystemPulse) INFO - System Pulse module shutdown
Thank you
Veni
