Aaseya IT Services
Last activity: 5 Feb 2017 22:41 EST
Insufficient privileges to author custom HTML. Please use Auto-Generated HTML
I am using the cloud instance from Pega SAE 7.2 course. As operator ADMIN@TGB, I want to Create an Custom HTML control to display SSN as (xxx-xx-1234). So i am unable to Save to the control rule due to (Insufficient privileges to author custom HTML. Please use Auto-Generated HTML). Could you please help what is the Privilege needs to be added to the application, so that i can save the Custom HTML rule.
***Updated by moderator: Lochan to move post from PSC to Pega Academy***
Hi Sandeep,
Clarification regarding priviledges is mentioned in the below article.You may can tweak priviledges based on your requirement:- https://community.pega.com/sites/default/files/help_v722/procomhelpmain.htm
Also, you will not be able to save or checkin(override) the final rules.
Kindly notify, if it helps you for the benefit of larger audience. Also, share the configuration if you are able to tweak it somehow. At community, it's always learning.
Asif
